Weather station purchased at Costco won't connect to Meteohub on NSLU2.
Previously had a TE-923W with no issues.
Log files:
Meteohub Log:
logger (03.12.2015 07:23:22): connect station 0 (Acurite 1025 via USB HID).
logger (03.12.2015 07:28:52): child process received timeout signal (14).
logger (03.12.2015 07:28:52): disconnect station 0 (Acurite 1025): exit
logger (03.12.2015 07:28:52): data logger stopped.
logger (03.12.2015 07:28:52): data logger (version 5.0k, build 1330) started.
logger (03.12.2015 07:28:55): connect station 0 (Acurite 1025 via USB HID).
logger (03.12.2015 07:34:25): child process received timeout signal (14).
logger (03.12.2015 07:34:25): disconnect station 0 (Acurite 1025): exit
logger (03.12.2015 07:34:25): data logger stopped.
logger (03.12.2015 07:34:25): data logger (version 5.0k, build 1330) started.
logger (03.12.2015 07:34:27): connect station 0 (Acurite 1025 via USB HID).
logger (03.12.2015 07:39:57): child process received timeout signal (14).
logger (03.12.2015 07:39:58): disconnect station 0 (Acurite 1025): exit
logger (03.12.2015 07:39:58): data logger stopped.
logger (03.12.2015 07:39:58): data logger (version 5.0k, build 1330) started.
logger (03.12.2015 07:40:00): connect station 0 (Acurite 1025 via USB HID).
Repeats over and over.
Acurite 2064C is in USB 3 mode. There is no other setting available.
Ran Meteohub in virtual machine and station connects right away.
Thoughts?
Acurite 2064C problems
