Meteobridge and meteostick, extra sensor(s)
wsnoordbergum
Post by wsnoordbergum »
Hello.
I'm a user of meteobridge for over a year now, and pleased with it's performance and the support.
Now I use a WMR 200 weatherstation, but considering to replace it with a Davis Vantage pro.
The meteostick is a handy small device, but will it allow for a extra temp sensor for temperature at grass height measurement.
Because a meteostick is the same price as a logger I think I will go with the meteostick.
But only if it supports extra sensors in combination with the meteobridge.
Also the meteobridge pro will be an option but that depends on the price....
So basically my question is does the meteostick/meteobridge combination support extra sensors.
Gr. wsNoordbergum
Re: Meteobridge and meteostick, extra sensor(s)
Yes it does.
When you have a Meteobridge, you can see yourself by selecting Meteostick as weather station on "Select Station" tab and then you can add additional sensors to the ISS.
