Problem with the command ''Convert=enbarotrend'' **solved**
sv2bzq
Post by sv2bzq »
Hi.
After the latest update I have problems with the command Convert = enbarotrend [thb0seapress-delta3h=enbarotrend:--] my returns '' -- ''
I do something wrong.
There are also similar mandate for the temperature sensor ?
George.
Re: Problem with the command '' Convert = enbarotrend ''
Yep, good finding. There was a bug regarding "delta" computation. Bug is fixed with just released version (December 22).
sv2bzq
Post by sv2bzq »
Ok Thanks ......
George.
Does it work for you with todays update?
sv2bzq
Post by sv2bzq »
Ok now works fine .
But is there anything similar for temperature sensors ?
George .
"delta" selector should also work for temperature. But there is no classification into slow/fast rising/falling categories.
sv2bzq
Post by sv2bzq »
Could tells us about rising / falling status ?
George .
