Hi all,
I am using the following setup:
Raspberry Pi B+
5.0k (Build 137)
Station 1: ELV USB-WDE1
Station 2: Plugin-In (basically a Bosch pressure Sensor via GPIO that is triggered by a Python-script that prints the pressure for the plugin station).
Over the last couple of months I had the following problem:
- Meteohub randomly stops uploading data via FTP
- Meteohub stops collecting data from Station1
- RasPi cannot be reached, pinged etc.
- The system seems to be shut down/crashed. But....
- Meteohub still collects data from Station2!!!
How is that possible? It looked like the system was completely down, but all the data from the pressure sensor was there after the system had been down for more than 24 hours.
What can I do to figure out the problem? I already removed some uploads, additional scripts etc, but it still happens.
I can definitely exclude that the wifi stick is shut down (or something).
Meteohub stops half of its work regularly, why?
Re: Meteohub stops half of its work regularly, why?
Ihr könnt auch gern auf Deutsch antworten.
Today it happened again. This time, after rebooting the raspberry, I tot telhe followig messages in the system.log.
Any ideas what that means?
Dec 31 12:10:44 meteohub-rpi kernel: [ 9052.631351] Transfer to device 8 endpoint 0x1 frame 865 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:45 meteohub-rpi kernel: [ 9052.710357] Transfer to device 8 endpoint 0x1 frame 944 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:49 meteohub-rpi kernel: [ 9057.510262] dwc_otg_hcd_handle_hc_fsm: 64 callbacks suppressed
Dec 31 12:10:49 meteohub-rpi kernel: [ 9057.520503] Transfer to device 8 endpoint 0x2 frame 1657 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:49 meteohub-rpi kernel: [ 9057.542018] Transfer to device 8 endpoint 0x2 frame 1679 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:49 meteohub-rpi kernel: [ 9057.606026] Transfer to device 8 endpoint 0x2 frame 1743 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:49 meteohub-rpi kernel: [ 9057.622026] Transfer to device 8 endpoint 0x1 frame 1759 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:50 meteohub-rpi kernel: [ 9057.637040] Transfer to device 8 endpoint 0x1 frame 1774 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:50 meteohub-rpi kernel: [ 9057.652044] Transfer to device 8 endpoint 0x1 frame 1789 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:50 meteohub-rpi kernel: [ 9057.667048] Transfer to device 8 endpoint 0x1 frame 1804 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:50 meteohub-rpi kernel: [ 9057.681922] Transfer to device 8 endpoint 0x2 frame 1819 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:50 meteohub-rpi kernel: [ 9057.713044] Transfer to device 8 endpoint 0x1 frame 1850 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:50 meteohub-rpi kernel: [ 9057.744044] Transfer to device 8 endpoint 0x1 frame 1881 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:54 meteohub-rpi kernel: [ 9062.559695] dwc_otg_hcd_handle_hc_fsm: 63 callbacks suppressed
Dec 31 12:10:54 meteohub-rpi kernel: [ 9062.569829] Transfer to device 8 endpoint 0x1 frame 562 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:54 meteohub-rpi kernel: [ 9062.592705] Transfer to device 8 endpoint 0x1 frame 585 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:54 meteohub-rpi kernel: [ 9062.607706] Transfer to device 8 endpoint 0x1 frame 600 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:54 meteohub-rpi kernel: [ 9062.622582] Transfer to device 8 endpoint 0x2 frame 615 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:54 meteohub-rpi kernel: [ 9062.653710] Transfer to device 8 endpoint 0x1 frame 646 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:55 meteohub-rpi kernel: [ 9062.668715] Transfer to device 8 endpoint 0x1 frame 661 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:55 meteohub-rpi kernel: [ 9062.699723] Transfer to device 8 endpoint 0x1 frame 692 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:55 meteohub-rpi kernel: [ 9062.714737] Transfer to device 8 endpoint 0x1 frame 707 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:55 meteohub-rpi kernel: [ 9062.729736] Transfer to device 8 endpoint 0x2 frame 722 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:55 meteohub-rpi kernel: [ 9062.760724] Transfer to device 8 endpoint 0x1 frame 753 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:10:59 meteohub-rpi kernel: [ 9067.639393] dwc_otg_hcd_handle_hc_fsm: 73 callbacks suppressed
Dec 31 12:10:59 meteohub-rpi kernel: [ 9067.649511] Transfer to device 8 endpoint 0x1 frame 1545 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:00 meteohub-rpi kernel: [ 9067.688392] Transfer to device 8 endpoint 0x1 frame 1584 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:00 meteohub-rpi kernel: [ 9067.703413] Transfer to device 8 endpoint 0x1 frame 1599 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:00 meteohub-rpi kernel: [ 9067.734401] Transfer to device 8 endpoint 0x1 frame 1630 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:00 meteohub-rpi kernel: [ 9067.749414] Transfer to device 8 endpoint 0x1 frame 1645 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:00 meteohub-rpi kernel: [ 9067.764421] Transfer to device 8 endpoint 0x1 frame 1660 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:00 meteohub-rpi kernel: [ 9067.795407] Transfer to device 8 endpoint 0x1 frame 1691 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:00 meteohub-rpi kernel: [ 9067.810413] Transfer to device 8 endpoint 0x1 frame 1706 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:00 meteohub-rpi kernel: [ 9067.841414] Transfer to device 8 endpoint 0x1 frame 1737 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:00 meteohub-rpi kernel: [ 9067.856303] Transfer to device 8 endpoint 0x2 frame 1752 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:05 meteohub-rpi kernel: [ 9072.722079] dwc_otg_hcd_handle_hc_fsm: 73 callbacks suppressed
Dec 31 12:11:05 meteohub-rpi kernel: [ 9072.732182] Transfer to device 8 endpoint 0x2 frame 483 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:05 meteohub-rpi kernel: [ 9072.756086] Transfer to device 8 endpoint 0x1 frame 507 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:05 meteohub-rpi kernel: [ 9072.771098] Transfer to device 8 endpoint 0x1 frame 522 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:05 meteohub-rpi kernel: [ 9072.786093] Transfer to device 8 endpoint 0x1 frame 537 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:05 meteohub-rpi kernel: [ 9072.801093] Transfer to device 8 endpoint 0x1 frame 552 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:05 meteohub-rpi kernel: [ 9072.832096] Transfer to device 8 endpoint 0x1 frame 583 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:05 meteohub-rpi kernel: [ 9072.847107] Transfer to device 8 endpoint 0x1 frame 598 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:05 meteohub-rpi kernel: [ 9072.878103] Transfer to device 8 endpoint 0x1 frame 629 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:05 meteohub-rpi kernel: [ 9072.893104] Transfer to device 8 endpoint 0x1 frame 644 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:05 meteohub-rpi kernel: [ 9072.924109] Transfer to device 8 endpoint 0x1 frame 675 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:10 meteohub-rpi kernel: [ 9077.859403] dwc_otg_hcd_handle_hc_fsm: 66 callbacks suppressed
Dec 31 12:11:10 meteohub-rpi kernel: [ 9077.869456] Transfer to device 8 endpoint 0x1 frame 1524 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:10 meteohub-rpi kernel: [ 9077.884790] Transfer to device 8 endpoint 0x1 frame 1539 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:10 meteohub-rpi kernel: [ 9077.899786] Transfer to device 8 endpoint 0x1 frame 1554 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:10 meteohub-rpi kernel: [ 9077.930788] Transfer to device 8 endpoint 0x1 frame 1585 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:10 meteohub-rpi kernel: [ 9077.945802] Transfer to device 8 endpoint 0x1 frame 1600 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:10 meteohub-rpi kernel: [ 9077.960794] Transfer to device 8 endpoint 0x1 frame 1615 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:10 meteohub-rpi kernel: [ 9077.975807] Transfer to device 8 endpoint 0x1 frame 1630 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:10 meteohub-rpi kernel: [ 9077.990796] Transfer to device 8 endpoint 0x1 frame 1645 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:10 meteohub-rpi kernel: [ 9078.021802] Transfer to device 8 endpoint 0x1 frame 1676 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:10 meteohub-rpi kernel: [ 9078.036812] Transfer to device 8 endpoint 0x1 frame 1691 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:15 meteohub-rpi kernel: [ 9082.978469] dwc_otg_hcd_handle_hc_fsm: 55 callbacks suppressed
Dec 31 12:11:15 meteohub-rpi kernel: [ 9082.988471] Transfer to device 8 endpoint 0x1 frame 498 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:15 meteohub-rpi kernel: [ 9083.002990] Transfer to device 8 endpoint 0x2 frame 512 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:15 meteohub-rpi kernel: [ 9083.018727] Transfer to device 8 endpoint 0x2 frame 528 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:15 meteohub-rpi kernel: [ 9083.082734] Transfer to device 8 endpoint 0x2 frame 592 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:15 meteohub-rpi kernel: [ 9083.114490] Transfer to device 8 endpoint 0x2 frame 624 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:15 meteohub-rpi kernel: [ 9083.178501] Transfer to device 8 endpoint 0x2 frame 688 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:15 meteohub-rpi kernel: [ 9083.224504] Transfer to device 8 endpoint 0x1 frame 734 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:15 meteohub-rpi kernel: [ 9083.239518] Transfer to device 8 endpoint 0x1 frame 749 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:15 meteohub-rpi kernel: [ 9083.254522] Transfer to device 8 endpoint 0x1 frame 764 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:15 meteohub-rpi kernel: [ 9083.285513] Transfer to device 8 endpoint 0x1 frame 795 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:20 meteohub-rpi kernel: [ 9088.042157] dwc_otg_hcd_handle_hc_fsm: 63 callbacks suppressed
Dec 31 12:11:20 meteohub-rpi kernel: [ 9088.052183] Transfer to device 8 endpoint 0x2 frame 1465 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:20 meteohub-rpi kernel: [ 9088.106167] Transfer to device 8 endpoint 0x1 frame 1519 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:20 meteohub-rpi kernel: [ 9088.121165] Transfer to device 8 endpoint 0x1 frame 1534 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:20 meteohub-rpi kernel: [ 9088.152173] Transfer to device 8 endpoint 0x1 frame 1565 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:20 meteohub-rpi kernel: [ 9088.167191] Transfer to device 8 endpoint 0x1 frame 1580 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:20 meteohub-rpi kernel: [ 9088.182063] Transfer to device 8 endpoint 0x2 frame 1595 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:20 meteohub-rpi kernel: [ 9088.213179] Transfer to device 8 endpoint 0x1 frame 1626 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:20 meteohub-rpi kernel: [ 9088.244187] Transfer to device 8 endpoint 0x1 frame 1657 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:20 meteohub-rpi kernel: [ 9088.259186] Transfer to device 8 endpoint 0x1 frame 1672 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:20 meteohub-rpi kernel: [ 9088.290191] Transfer to device 8 endpoint 0x1 frame 1703 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:25 meteohub-rpi kernel: [ 9093.129850] dwc_otg_hcd_handle_hc_fsm: 63 callbacks suppressed
Dec 31 12:11:25 meteohub-rpi kernel: [ 9093.139816] Transfer to device 8 endpoint 0x1 frame 408 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:25 meteohub-rpi kernel: [ 9093.231111] Transfer to device 8 endpoint 0x2 frame 499 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:25 meteohub-rpi kernel: [ 9093.263117] Transfer to device 8 endpoint 0x2 frame 531 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:25 meteohub-rpi kernel: [ 9093.295124] Transfer to device 8 endpoint 0x2 frame 563 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:25 meteohub-rpi kernel: [ 9093.326880] Transfer to device 8 endpoint 0x2 frame 595 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:25 meteohub-rpi kernel: [ 9093.374882] Transfer to device 8 endpoint 0x1 frame 643 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:25 meteohub-rpi kernel: [ 9093.390913] Transfer to device 8 endpoint 0x2 frame 659 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:25 meteohub-rpi kernel: [ 9093.405890] Transfer to device 8 endpoint 0x1 frame 674 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:25 meteohub-rpi kernel: [ 9093.420921] Transfer to device 8 endpoint 0x1 frame 689 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:25 meteohub-rpi kernel: [ 9093.451895] Transfer to device 8 endpoint 0x1 frame 720 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:30 meteohub-rpi kernel: [ 9098.255544] dwc_otg_hcd_handle_hc_fsm: 68 callbacks suppressed
Dec 31 12:11:30 meteohub-rpi kernel: [ 9098.265532] Transfer to device 8 endpoint 0x2 frame 1437 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:30 meteohub-rpi kernel: [ 9098.304552] Transfer to device 8 endpoint 0x1 frame 1476 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:30 meteohub-rpi kernel: [ 9098.319561] Transfer to device 8 endpoint 0x1 frame 1491 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:30 meteohub-rpi kernel: [ 9098.350559] Transfer to device 8 endpoint 0x1 frame 1522 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:30 meteohub-rpi kernel: [ 9098.365454] Transfer to device 8 endpoint 0x2 frame 1537 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:30 meteohub-rpi kernel: [ 9098.396565] Transfer to device 8 endpoint 0x1 frame 1568 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:30 meteohub-rpi kernel: [ 9098.411581] Transfer to device 8 endpoint 0x1 frame 1583 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:30 meteohub-rpi kernel: [ 9098.442572] Transfer to device 8 endpoint 0x1 frame 1614 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:30 meteohub-rpi kernel: [ 9098.457583] Transfer to device 8 endpoint 0x1 frame 1629 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:30 meteohub-rpi kernel: [ 9098.488576] Transfer to device 8 endpoint 0x1 frame 1660 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:35 meteohub-rpi kernel: [ 9103.321233] dwc_otg_hcd_handle_hc_fsm: 75 callbacks suppressed
Dec 31 12:11:35 meteohub-rpi kernel: [ 9103.331240] Transfer to device 8 endpoint 0x2 frame 358 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:35 meteohub-rpi kernel: [ 9103.370240] Transfer to device 8 endpoint 0x1 frame 397 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:35 meteohub-rpi kernel: [ 9103.385241] Transfer to device 8 endpoint 0x1 frame 412 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:35 meteohub-rpi kernel: [ 9103.400258] Transfer to device 8 endpoint 0x1 frame 427 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:35 meteohub-rpi kernel: [ 9103.431252] Transfer to device 8 endpoint 0x1 frame 458 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:35 meteohub-rpi kernel: [ 9103.446262] Transfer to device 8 endpoint 0x1 frame 473 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:35 meteohub-rpi kernel: [ 9103.477255] Transfer to device 8 endpoint 0x1 frame 504 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:35 meteohub-rpi kernel: [ 9103.492252] Transfer to device 8 endpoint 0x1 frame 519 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:35 meteohub-rpi kernel: [ 9103.523262] Transfer to device 8 endpoint 0x1 frame 550 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:35 meteohub-rpi kernel: [ 9103.538260] Transfer to device 8 endpoint 0x1 frame 565 failed - FIQ reported NYET. Data may have been lost.
Dec 31 12:11:40 meteohub-rpi kernel: [ 9108.390921] dwc_otg_hcd_handle_hc_fsm: 71 callbacks suppressed
wdcut (31.12.2015 12:17:02): Error file open /data/export/wd_export.csv: No such file or directory
wdcut (31.12.2015 12:47:01): Error file open /data/export/wd_export.csv: No such file or directory
So, ich habe weitere Daten gesammelt und schreibe auf Deutsch. Vielleicht schreckt es euch ja ab, dass ich englisch geschrieben habe. Hoffentlich kann mir jemand helfen.
heute kurz vor 2 Uhr war es wieder soweit. Keine Daten mehr vom USB WDE1, kein Meteohub mehr erreichbar. Ich habe folgende Meldungen am Bildschirm bekommen (siehe Screenshots unten verlinkt).
Was ist denn da auf einmal los? Liegt's an den letzten Updates? Mit der Version k war es schon schlimm, aber mit L ist es nun unbrauchbar. Ist's Zufall?
Ich habe den USB WDE1 nun einmal direkt am Rasp und den USB HUB deaktiviert. Das ist zumindest einmal ein erster Schritt zum Troubelshooten.
Interessant ist auch folgendes:
Ich lade alle 5min ein html Datei per ftp hoch. Die aktuellen WEtterwerte werden hier nur noch sporadisch eingetragen. zB.: es steht hier [actual_th0_temp_c] statt der aktuelle Temperatur, obwohl Daten in Meteohub vorhanden sind und auch angezeigt werden, wenn ich die HTML Datei lokal anzeigen lasse!
Kann ich einfach wieder zurück zu Version G gehen, ohne dass ich das ganze System neu aufsetzen muss? Das wäre für mich ein Horror....
Screenshot 1:
einige FEhler, unter anderem:
Failed to set baud rate to 9600 / 300
Unable to enable UART
https://drive.google.com/file/d/0B7SIdn ... sp=sharing
Screenshot 2:
haufenweise Kernel Meldungen
Screenshot 1:
Screenshot 2:
