Oregon WRM 88A cannot connect to Meteobridge **solved**
ampa62
Post by ampa62 »
I am new in this forum.
I have been trying to connect my Oregon WRM 88A station via TL-MR3020 to the internet, and unfortunately the result is this:
logger (29.12.2015 22:51:35): connect station 0 (WMR-100/88 via USB HID).
logger (29.12.2015 22:58:51): parent process received termination signal (15).
logger (29.12.2015 22:58:51): child process received termination signal (15).
logger (29.12.2015 22:58:52): No historical data loaded.
logger (29.12.2015 22:58:52): data logger (version 5.0l, build 8552) started.
logger (29.12.2015 22:58:52): error while doing bind (port 5551): Address already in use
logger (29.12.2015 22:58:53): data logger stopped.
logger (29.12.2015 22:59:22): No historical data loaded.
logger (29.12.2015 22:59:22): data logger (version 5.0l, build 8552) started.
logger (29.12.2015 22:59:22): error while doing bind (port 5551): Address already in use
logger (29.12.2015 22:59:22): data logger stopped.
logger (29.12.2015 22:59:52): No historical data loaded.
logger (29.12.2015 22:59:52): data logger (version 5.0l, build 8552) started.
logger (29.12.2015 22:59:52): error while doing bind (port 5551): Address already in use
logger (29.12.2015 22:59:52): data logger stopped.
Can you help me?
Regards,
António
Re: Oregon WRM 88A cannot connect to Meteobridge
Are you using the mandatory USB hub?
ampa62
Post by ampa62 »
No. In fact I did one direct connection between the station and the datalogger.
That is the root cause of the problems. Please add a passive usb hub.
ampa62
Post by ampa62 »
Solved! Thank you.
