Sensori Froggit HP1003
Massimo
Post by Massimo »
Good morning to you, sorry for writing errors I'm using Google Translate
I hope to post in the right section
this morning visiting my page of Meteohub for controls, I noticed that you have added a sensor that my station did not
My station is a Froggit HP1003
http://www.froggit.de/product_info.php/ ... rmast.html
the data that the external sensor WH24 They are taken from meteostick to Meteohub
my question is? the additional sensor that appears on the sensors of Meteohub where does?
I apologize again if I'm posting in the right section,
Thanks to all of you.
Massimo
Re: Sensori Froggit HP1003
Post by Massimo »
:cry: :cry: :cry: :cry: :cry: :cry: :cry:
Please reduce sensitivity to -90 db. This will keep the Meteostick away from picking up
tons of noise with some data packets that can be interpreted as sensor data.
A reboot will cleanup the page.
Massimo
Post by Massimo »
Thanks so much, I went into settings MeteoStick and I lowered the received signal to -90db
as you suggested
now in the settings come only sensors that really my weather station has :wink:
Thanks for the help
my work station 8) https://youtu.be/cjHFqq7EeNM
