Envoy 8x not reporting wind data **solved**
drewt
Post by drewt »
I'm using meteobridge on an MR3020 with an Envoy 8x. All sensor data is reliably uploaded to Wunderground except for any wind data (direction, gusts, current speed, etc). The wind data does however show accurately on the Live Data tab in meteobridge. Does this need to be enabled somewhere or is there a logfile I could look at to see why it's not being sent to Wunderground? Here's the output of my messages field:
wnetd (08.01.2016 15:53:28): process started.
test5m (08.01.2016 15:53:30): logger stalled, will be restarted now.
logger (08.01.2016 15:53:31): Free trial period will end in 11 days. When you want to use this device beyond that period, you are welcome to use online licensing feature on "License" tab to purchase a license.
logger (08.01.2016 15:53:31): Historical data loaded (11 records).
logger (08.01.2016 15:53:31): data logger (version 5.0m, build 8595) started.
logger (08.01.2016 15:53:32): connect station 0 (Envoy 8x via USB serial).
logger (08.01.2016 15:53:32): wakeup sent.
logger (08.01.2016 15:53:32): internal logger activated.
logger (08.01.2016 15:53:32): syncing.
logger (08.01.2016 15:53:42): gettime request sent.
logger (08.01.2016 15:53:42): time offset of Envoy8x is more than 240 days! Please set date/time of Envoy8x correctly.
logger (08.01.2016 15:53:42): eeprom request sent.
logger (08.01.2016 15:53:42): envoy8x ID: 3
logger (08.01.2016 15:53:42): channel 1 is "Vantage Pro 2 ISS": 0.01 inch per rain tick
logger (08.01.2016 15:53:42): channel 2 is "Temp/Hum Station"
Re: Envoy 8x not reporting wind data
Please reboot Meteobridge to make most current code applied.
There were changes in that respect: http://meteobridge.com/wiki/index.php/Forum
drewt
Post by drewt »
Works great now. Thanks!
