Data Errors in Meteohub Log
varadero
Post by varadero »
Hello
I'm just hoping someone can push me in the right direction to eliminate 3 errors in the meteohub log. The meteohub is pushing data to a Davis Vantage Pro Console and has for for several years and this in turn the data is showing on my Weather Display Program. All data seems ok on there except that suddenly the daily rolling rainfall amount has stopped showing. I'm seeing 3 lines of error data in the meteohub log (which appears to be nearly full) and is cleared? from time to time. The error lines are as below :-
loggereval (10.01.2016 02:04:02): illegal data record in line 143406 while reading from file /data/weather/201601/raw: 20120160108195311 wind0 192 36 31 0070
loggereval (10.01.2016 02:22:46): illegal data record in line 699765 while reading from file /data/weather/201512/raw: 20151231120151231135329 wind0 188 49 49 0100
loggereval (10.01.2016 02:22:47): illegal data record in line 707305 while reading from file /data/weather/201512/raw: 220151231205259 wind0 219 31 31 0066
System info reports :-
Media: SDC 09/2009 0x00201de6 (896.70 rounds)
Swap: 0MB of 131MB used (0%)
System: 639MB of 838MB used (76%)
Data: 2522MB of 2542MB used (99%)
I've stopped and rebooted the meteohub several times, recomputed the data several times but nothing has changed.
If someone could assist I will be more than happy!! :D
Re: Data Errors in Meteohub Log
Page "inspect data" has a cleanup functions that removes bad lines from raw data of a specific month.
varaderoxlv1000
Post by varaderoxlv1000 »
Hi, thanks for the response.
Indeed it does, but I cannot seem to clear the erroneous lines. If I transfer the 1st 14 characters (as required) of the date string of the reported error as in line 699765 :- 20151231120151 to the box at the bottom of display data and enter say 100 secs as the period to delete, I then get a message saying that it has been deleted, but the error remains. I just don't understand why it won't delete. Comments please
Richard
do "+100"
varaderoxlv1000
Tried that too, but interestingly the delete action reports that no data was deleted thus suggesting the data isn't present now, but why the error reports on just 2 lines of data. Strange. Is it possible to "cleanup data" relative to the erroneous data as cleanup data seems to be relative to the current month.
Richard
varaderoxlv1000
Further to my original message, the rainfall total issue was to do with a bug in an update file for the Weather Display software I use. This has been fixed but I still have the errors (2 lines) being reported in the meateohub log.
if nothing else helps, you can edit the raw data file with a text editor to remove the faulty line.
Raw data is located at /public/weather/YYYYMM/raw on the PC-network share.
When it is the current month, please stop data logging (on maintenance page) before doing so.
