No Data from Davis Console **solved**
tinu75
Post by tinu75 »
i have the davis vantage pro 2 weatherstation. the console (6312eu) has the firmware 3.15 installed.
connected is the original weatherlink usb datalogger (6510USB). the console is already set to 19200.
i use the newest version of meteohub (5.0n) on the raspberry pi. raspberry is connected over an usb hub to the davis vantage pro2 console.
on meteohub i see the two attached devices: /dev/ttyUSB0 /dev/ttyMH113
you can see my configuration below. but i don't see any sensors?
what i make wrong? any ideas?
i already reset the console and reinstalled meteohub. but always the same :-(
Re: No Data from Davis Console
Console needs a complete power cycle (USB off, batteries off, power supply off).
tinu75
Post by tinu75 »
solved. changed the console.
