Update 5.0n Build 7312 to Build 7313
WSParkstad
Post by WSParkstad »
I have a problem with the update, is it possibel that i can downgrade to 5.0m?
He is no making Graphics any more en the Max temp is not making.
Meteohub Log
2016.01.31 13:54:37 log file cleared by user
logger (31.01.2016 14:05:39): parent process received termination signal (15).
logger (31.01.2016 14:05:39): child process received termination signal (15).
logger (31.01.2016 14:07:56): data logger (version 5.0n, build 7313) started.
logger (31.01.2016 14:08:08): connect station 0 (Vantage via TCP/IP).
logger (31.01.2016 14:08:08): connect station 1 (System Data via Plug-in).
logger (31.01.2016 14:08:08): connect station 2 (TEMPer HID via USB HID).
logger (31.01.2016 14:08:09): station 0 (Vantage), wakeup sent.
logger (31.01.2016 14:08:09): station 0 (Vantage), internal logger activated.
logger (31.01.2016 14:08:09): station 0 (Vantage), syncing.
logger (31.01.2016 14:08:19): station 0 (Vantage), gettime request sent.
logger (31.01.2016 14:08:19): station 0 (Vantage), time offset of Vantage: -685 minutes
logger (31.01.2016 14:08:19): station 0 (Vantage), eeprom request sent.
logger (31.01.2016 14:08:20): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (31.01.2016 14:08:20): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (31.01.2016 14:08:20): station 0 (Vantage), transmitter 2 active as station type (#3) "Temp/Hum" mapped to "th1".
logger (31.01.2016 14:08:20): station 0 (Vantage), transmitter 3 active as station type (#3) "Temp/Hum" mapped to "th2".
logger (31.01.2016 14:08:20): station 0 (Vantage), transmitter 4 active as station type (#8) "Leaf/Soil".
logger (31.01.2016 14:08:20): station 0 (Vantage), transmitter 8 active as station type (#4) "Wind".
logger (31.01.2016 14:08:20): station 0 (Vantage), firmware version request sent.
logger (31.01.2016 14:08:21): station 0 (Vantage), firmware version 1.90
logger (31.01.2016 14:08:21): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 334 secs
wmr928fulleval(31.01.2016 14:10:03): recomputation of weather data started.
logger (31.01.2016 14:10:37): parent process received termination signal (15).
logger (31.01.2016 14:10:37): child process received termination signal (15).
logger (31.01.2016 14:12:56): data logger (version 5.0n, build 7313) started.
logger (31.01.2016 14:13:02): connect station 0 (Vantage via TCP/IP).
logger (31.01.2016 14:13:02): connect station 1 (System Data via Plug-in).
logger (31.01.2016 14:13:02): connect station 2 (TEMPer HID via USB HID).
logger (31.01.2016 14:13:02): station 0 (Vantage), wakeup sent.
logger (31.01.2016 14:13:02): station 0 (Vantage), internal logger activated.
logger (31.01.2016 14:13:02): station 0 (Vantage), syncing.
logger (31.01.2016 14:13:09): error while doing write on socket 5558: Broken pipe
logger (31.01.2016 14:13:13): station 0 (Vantage), gettime request sent.
logger (31.01.2016 14:13:13): station 0 (Vantage), time offset of Vantage: -685 minutes
logger (31.01.2016 14:13:13): station 0 (Vantage), eeprom request sent.
logger (31.01.2016 14:13:14): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (31.01.2016 14:13:14): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (31.01.2016 14:13:14): station 0 (Vantage), transmitter 2 active as station type (#3) "Temp/Hum" mapped to "th1".
logger (31.01.2016 14:13:14): station 0 (Vantage), transmitter 3 active as station type (#3) "Temp/Hum" mapped to "th2".
logger (31.01.2016 14:13:14): station 0 (Vantage), transmitter 4 active as station type (#8) "Leaf/Soil".
logger (31.01.2016 14:13:14): station 0 (Vantage), transmitter 8 active as station type (#4) "Wind".
logger (31.01.2016 14:13:14): station 0 (Vantage), firmware version request sent.
logger (31.01.2016 14:13:15): station 0 (Vantage), firmware version 1.90
logger (31.01.2016 14:13:25): station 0 (Vantage), data gap of 10 minutes, start reading Vantage's internal logger after 2016-01-31 02:35 (Vantage's local time).
logger (31.01.2016 14:13:25): station 0 (Vantage), internal logger provides 4 pages of data.
logger (31.01.2016 14:13:27): station 0 (Vantage), finished reading internal logger, 10 records inserted.
wmr928fulleval(31.01.2016 14:15:01): recomputation of weather data started.
Many many lines in System Log
XXX seapress:10200 s->name:thb0 cal:0 reftemp:0
I have learning one thing, never change's it when it is good working ;-)
WSParkstad
Re: Update 5.0n Build 7312 to Build 7313
I have downgrade to 5.0m en problem is away.
It's working correctly now in the 5.0m version.
I took 5.0n out of the list. If you are on 5.0n, please update to 5.0o.
I will fix the 5.0n issues and present the updates with the next release.
WSParkstad
Hello Boris,
I have update to 5.0o en its working correctly, many thanks.
I hope that the 5.0T version also revisited Twitter hahaha joke Boris, but worth a try.
Have a nice day en thanks for the good job.
Marcel.
