services ftp
VinnyFindley
services ftp
Post by VinnyFindley »
I am trying to get ftp working in push services SW Version: Meteobridge 2.7 (Jan 26 2016, build 8994), FW 1.3
FTP Host: ftp.mywebsite.us Port: 21
User: ******** Password: ********************
Test Path: /public_html
The test upload never makes it to my host. I have http requests working and 3 weather networks working:
WU, PWS and CWOP.
Vinny
Re: services ftp
some of the credentials must be wrong. Are you sure the given path exists on FTP root level?
You might test with a FTP client on your PC.
VinnyFindley
Re: services ftp
Not sure what to put in the path! In my cpanel the path is:
/home/user so I tried /home/user/public_html still no test upload.
I use filezilla to upload files to my host and use the same credentials as filezilla.
Vinny
Re: services ftp
In which directory are you homed, when you login using Filezilla?
VinnyFindley
Re: services ftp
It is the actual root of the host just /
Vinny
Re: services ftp
Being there you can click through the folders until you reach the target dir.
Simply take this sequence of folders as path. :roll:
