Meteohub won't connect to WD (weather displau)
lcoulon
Post by lcoulon »
Hello
My WMR200 station and Meteohub v5.0m (iconnect) are not able to connect to laptop software : Weather Display
Even all settings have been properly entered in Weather display software, the WD can't retrieve xml datas.
ie, when entering the iconnect IP : http://10.0.0.201:80/meteolog.cgi?mode=data&type=xml
It does not display any datas, i only get meteohub login window instead.
Can someone help on this problem, is there a special setting to be done especially in "graph uploads" section ?
My final goal is to be able to display weather datas on Weather Display Live Premium, as i bought a licence for this.
http://www.weather-display.com/index2c.php
Many thanks for your help,
Re: Meteohub won't connect to WD (weather displau)
lcoulon wrote:Hello
You do not need WeatherDisplay (WD) to use WeatherDisplay-Live (WD-Live).
WD-Live is an add-on (sold separately) which uses 4 clientraw files. Those files were originally generated by WD, but already for some years other weather-programs also generate these files. Meteobridge and Meteohub do that also. Meteohub even has a basic WD-Live facility build in.
This is what you should do in Meteohub:
1. on tab "WD Data Export": select the correct sensors to be used
2. on the tab "Graph Uploads": upload the 4 clientraw files to the WD-Live folder on your website.
Those 4 files are selected in the left dropdown and are called "WD-Live" "WD-live extra" "WD-live hour" "WD-live daily"
If you want to use the xml for WD for other reasons: there are two different implementations in WD.
One for Meteohub without a userid/password and one for Meteobridge which needs the userid/password.
lcoulon
Post by lcoulon »
"WD-Live" "WD-live extra" "WD-live hour" "WD-live daily" are already set in Graph upload tab
But generated files are not stored localy, they are uploaded to a distant server through FTP : http://meteo.tousenvol.com
Hence, they are accessible to that place, but this does not permit to get WD (software) to work with the station.
Actually i would like to have WD (software) able to connect the weather station in order to configure all xml files to be displayed in WD Live.
lcoulon wrote:"WD-Live" "WD-live extra" "WD-live hour" "WD-live daily" are already set in Graph upload tab
Your remark: "But generated files are not stored localy,"
All uploaded files can be found in your Meteohub using your lan: public\myweb\iploads\
You have to "tick" at the bottom of the 'Graph Uploads" tab Store local copy in "/public/myweb/uploads/"
If you change the xml files WD-live uses to point to that location, your local WD-live will use those files as input.
Your remark: "to configure all xml files to be displayed in WD Live"
You can not configure the internal xml files on the Meteohub, Why would you do that? They are used to display the WD-live from within Meteohub.
You have a full WD-live licence so you can modify the WD-Live XML files with the supplied tool, 'WD live configurator" . With that windows program you define how and what and where everything is displayed.
WD-Live will read the xml files once every time it is started from within a browser and then will read the data to be displayed from the location specified in the xml.
