I started seeing error with my meteohub not reporting in to weather underground. The problem seems to be that the flash drive is filling up. I had been using one of the original Pis with a 4 BG drive. I thought it was a matter of the size of the drive so decided to upgrade to a new 4 core Pi and used a 32Gb flash drive, thinking that would solve the space problem. Today, I have the same issue.
$ df
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 1680656 1593616 0 100% /
/dev/root 1680656 1593616 0 100% /
devtmpfs 470444 0 470444 0% /dev
tmpfs 94948 2016 92932 3% /run
tmpfs 5120 0 5120 0% /run/lock
tmpfs 216100 0 216100 0% /run/shm
/dev/mmcblk0p1 50396 23826 26571 48% /boot
/dev/mmcblk0p4 28744828 59252 27218748 1% /data
tmpfs 32768 32768 0 100% /var/log
$ uptime
20:26:28 up 6 days, 10:47, 1 user, load average: 0.00, 0.03, 0.05
I'll reboot it and it will probably continue running for a while.
I could produce the output of du, but it's pretty large.
I'd really be interested in any ideas to solve this issue.
ted
my raspberry pi has started filling up the flash drive
Re: my raspberry pi has started filling up the flash drive
Where would those be stored?
