Meteobridge + meteostck pass-through to Meteohub
sv2bzq
Post by sv2bzq »
Hello
I have in my possession a weather station Davis vue + Meteostick + Meteobridge and work fine
but I can I connect to IP address on port 22222 in Meteobridge a Meteohub ?
George.
Re: Meteobridge + meteostck pass-through to Meteohub
No, because simply no Davis LOOP protocol to pass through.
sv2bzq
Post by sv2bzq »
Οκ ...
simply saw that the Weather Display work with Meteobridge + Meteostick
although the Weather Display is the only program that I found and it works with Meteobridge + Meteostick
Ok thanks for your time
George .
Brian did some coding to have WD reading out data from Meteohub.
I don't know if that is also true for Meteobridge.
