MB Pro Standard Export Templates - Blank **solved**
Exporting data using the standard IMP & ISO templates and drawing a blank with data. MB Pro has live data and can push the standard dashboard html template ok, current, min&max values appear good.
Turned back on the services this morning for both standard-ISO & standard-IMP at approx. 6:17am (Current hour, Resolution 1 minute) and immediately created a file tagged as 06 with data for the first 16 minutes starting 6am. This occurred for ISO only.
Come 7am the 07 hourly file for both ISO & IMP are blank, apart from header, date/time? 06 & 07 files attached (zip) for ISO example as recorded this morning
standard-iso20160217.zip
(1009 Bytes) Downloaded 267 times
Re: MB Pro Standard Export Templates - Blank
In my instance have confirmed this over the last 3 days. When initially turned back on from being turned off exports data to the current time for the current hour. At the next full hour exports the whole hour but all blank.
Is anybody else seeing this? Services push is
Data Export: every full hour
Time frame: Current hour
Resolution: minutes
Template standard-iso (or standard-imp)
I am getting the following export as triggered @ 08:00
# Standard CSV template with data in metric units
# date, time, temperature[C], humidity[%], dew point[C], sealevel pressure[hPa], avg wind speed[m/s], gust speed[m/s], winddir, rainfall[mm]
2016-02-18,07:00,,,,,,,,
2016-02-18,07:01,,,,,,,,
2016-02-18,07:02,,,,,,,,
2016-02-18,07:03,,,,,,,,
2016-02-18,07:04,,,,,,,,
2016-02-18,07:05,,,,,,,,
I guess it is a side effect of the bug that stalled some of the MB PROs.
Please reboot to have latest software with fix for this loaded and give
it a second try.
Re: MB Pro Standard Export Templates - Blank **solved**
Sorry have been away and just back in the office.
Have rebooted to 2.7 Feb22 2016 Build 9225
Remains fairly much unchanged, when the export option is turned on writes a file with data to that time with the rest of the file just Date, Time ,,,,,,, etc
On the hour creates a new file all blank as before Date, Time ,,,,,,, etc
One thing different now is that previously there were 3 header/info lines preceded by #, these are no longer included.
Over the past couple of hours (including a repower - same ver) have confirmed the status quo remains for both standard-iso & imp
Mattk wrote:One thing different now is that previously there were 3 header/info lines preceded by #, these are no longer included.
Header lines that should be in the output need now to start with "$" instead of "#".
Ok header lines all good, still get data looking like this
2016-02-24,20:00,,,,,,,,
2016-02-24,20:01,,,,,,,,
