Failed to fork child: Resource temporarily unavail *solved*
Posted: Sat Feb 20, 2016 9:31 pm
Today I rebooted my MBP red, to get the latest firmware.
A few hours later, I got mail from wunderground that my station stopped reporting. I tried to access the user interface, but got the message "Failed to fork child: Resource temporarily unavailable"
What does it mean?
It's running after a power cycle with a few errors - I don't know if it's something to worry about (database is locked).
oled (20.02.2016 16:19:03): process started.
wnetd (20.02.2016 20:14:36): process started.
test5m (20.02.2016 20:16:24): logger stalled, will be restarted now.
test5m (20.02.2016 20:16:25): database daemon stalled, will be restarted now.
database (20.02.2016 20:16:25): process started.
logger (20.02.2016 20:16:25): database connected.
logger (20.02.2016 20:16:25): Historical data loaded (0 records).
logger (20.02.2016 20:16:25): data logger (version 5.0p, build 9167) started.
logger (20.02.2016 20:16:26): connect station 0 (Meteostick Vantage via USB serial).
logger (20.02.2016 20:16:26): connect station 9 (System Data via Plug-in).
logger (20.02.2016 20:16:28): transmitter 1 registered as ISS
logger (20.02.2016 20:16:28): transmitter 2 registered as Wind
logger (20.02.2016 20:16:28): Meteostick Version 2.3b3
logger (20.02.2016 20:16:28): debug off
logger (20.02.2016 20:16:28): verbose off
logger (20.02.2016 20:16:28): output raw (8 bytes)
logger (20.02.2016 20:16:28): output raw (10 bytes)
logger (20.02.2016 20:16:28): filter on
logger (20.02.2016 20:16:28): rx threshold set to -65db
logger (20.02.2016 20:16:28): listening to transmitter 1 2
logger (20.02.2016 20:16:28): bandwidth narrow
logger (20.02.2016 20:16:29): chip authentication ok: 14
logger (20.02.2016 20:16:29): frequency band 868MHz (EU)
logger (20.02.2016 20:16:51): DB cannot retrieve rain0total_day (20 tries, 5503ms): database is locked
logger (20.02.2016 20:16:57): DB cannot retrieve rain0total_day (20 tries, 5503ms): database is locked
logger (20.02.2016 20:17:34): DB cannot retrieve rain0total_day (20 tries, 5505ms): database is locked
logger (20.02.2016 20:17:57): DB cannot retrieve th0temp_min (20 tries, 5532ms): database is locked
logger (20.02.2016 20:19:29): DB cannot retrieve th0temp_min (20 tries, 5527ms): database is locked
If it ain't broke don't fix it
What does it mean?
