MB Pro Standard Templates - Blank (revisited)
Still have no resolution with this one but output/s have changed with the latest firmware (2.8 Feb 26 2016, build 9250).
Is there anybody who could run a similar test and confirm/deny the following output based on a MB Pro (Red) linked via RF to a Davis station?
Services config is
Data Export: every full hour
Time frame: Current hour
Resolution: Minutes
Template: standard-imp or standard-iso
At (for example) 8pm local time (date config is all good) I get an output file (for an -iso example) named standard-iso-2016022720-min.txt containing the following lines (only) essentially blank, no data
# Standard CSV template with data in metric units
# date, time, temperature[C], humidity[%], dew point[C], sealevel pressure[hPa], avg wind speed[m/s], gust speed[m/s], winddir, rainfall[mm]
2016-02-27,20:00,,,,,,,,
I am expecting a header (which is ok but just be aware the header lines are now preceded by a $ which may not be included during a reboot with new firmware?) plus 60 lines of data, 1 for each minute and presumably for the period 19:00 to 19:59 or should that be for the period 19:01 to 20:00, which if so would correspond to the filename time tag at the end of the hour.
I definitely have data available as exporting ok via the template realtime.txt on a 1 minute basis plus other outputs
Re: MB Pro Standard Templates - Blank (revisited)
When you ask for current hour at every full hour you will of course get empty lines, as at 20:00 there is no data for 20:00 - 20:59, may be some data just for 20:00. At every full hour (which means "when hour changes") you might ask for data of the previous hour.
Ok have that one now thankyou, will work through the other options/combinations.
One question then with "Current Hour" re Export, with what option/trigger combination would this be used?
