Version 2.8 released March 3 Database & FTP error **solved*
ewagnernl
Post by ewagnernl »
Installing Version 2.8 March 3 results in DB errors and HTTP and FTP uploads on my Meteo Bridge Pro RED.
after installing version 2.8 today I receive the following errors and all FTP and HTTP upload are not working anymore. I can also no correct this manually.
ogger (03.03.2016 08:54:21): database connected.
logger (03.03.2016 08:54:22): Historical data loaded (54 records).
logger (03.03.2016 08:54:22): data logger (version 5.0p, build 9367) started.
logger (03.03.2016 08:54:22): connect station 0 (Meteostick Vantage via USB serial).
logger (03.03.2016 08:54:22): connect station 9 (System Data via Plug-in).
logger (03.03.2016 08:54:24): transmitter 1 registered as Temperature/Humidity
logger (03.03.2016 08:54:24): transmitter 2 registered as ISS
logger (03.03.2016 08:54:24): Meteostick Version 2.4
logger (03.03.2016 08:54:24): debug off
logger (03.03.2016 08:54:24): verbose off
logger (03.03.2016 08:54:24): output raw (8 bytes)
logger (03.03.2016 08:54:24): output raw (10 bytes)
logger (03.03.2016 08:54:24): filter on
logger (03.03.2016 08:54:24): rx threshold set to -70db
logger (03.03.2016 08:54:24): listening to transmitter 1 2
logger (03.03.2016 08:54:24): bandwidth narrow
logger (03.03.2016 08:54:25): chip authentication ok: 14
logger (03.03.2016 08:54:25): frequency band 868MHz (EU)
logger (03.03.2016 08:54:27): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:54:32): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:54:42): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:54:52): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:54:58): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:55:02): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:55:03): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:55:10): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:55:12): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:55:14): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:55:19): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:55:22): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:55:24): open named pipe "/dev/meteobridge" failed: No such device or address
logger (03.03.2016 08:55:29): open named pipe "/dev/meteobridge" failed: No such device or address
I have switched back to version 2.7 and all is working fine.
MeteoOudkarspel
Re: Version 2.8 released March 3 Database & FTP error
Post by MeteoOudkarspel »
I have the same problem too.
Sincerely,
update just released fixes that.
vastator
Re: Version 2.8 released March 3 Database & FTP error **sol
Post by vastator »
How does one revert back when the only access I have is the luci interface? It looks like it will not load fully up now.
When it get stuck in fast blinking mode, then reach out to the Internet is not working.
Do you get over the "black page"? If so, I don't understand how you are going to reach luci.
Please close the browser to get its cache cleaned. That also helps in many situations,
vastator
Post by vastator »
it can reach the internet fine, I think there is some kind of space issue which is preventing /home to exist. Just started yesterday for me.
Network seems to be fine as I can ping sites on the net.
but if I do something like a crontab -e, I get crontab: can't open '/etc/crontabs.1678': No space left on device
So am thinking that something did not mount so it cant continue? In the system log, I am seeing the following:
Mar 5 14:31:14 MeteoBridge user.info sysinit: /sbin/uci: Parse error (invalid command) at line 35, byte 1
Mar 5 14:31:15 MeteoBridge user.info sysinit: /sbin/uci: Parse error (invalid command) at line 35, byte 1
Mar 5 14:31:15 MeteoBridge user.info sysinit: Loading forwardings
Mar 5 14:31:15 MeteoBridge user.info sysinit: Loading rules
Mar 5 14:31:16 MeteoBridge user.info sysinit: Loading redirects
Mar 5 14:31:16 MeteoBridge user.info sysinit: Loading includes
Mar 5 14:31:16 MeteoBridge user.info sysinit: Optimizing conntrack
Mar 5 14:31:16 MeteoBridge user.info sysinit: Loading interfaces
Mar 5 14:31:16 MeteoBridge user.info sysinit: /sbin/uci: Parse error (invalid command) at line 35, byte 1
Mar 5 14:31:16 MeteoBridge user.info firewall: adding lan (br-lan) to zone lan
Mar 5 14:31:17 MeteoBridge user.info sysinit: /sbin/uci: Parse error (invalid command) at line 35, byte 1
This is all at the time when it stopped working.
