Moving DB to SD card procedure?
dr.diesel
Post by dr.diesel »
Is there a proper procedure for moving from internal flash to external SD card? If I just switch the setting on the System tab does it copy the current DB over before rebooting or?
Re: Moving DB to SD card procedure?
It does not copy the old database to the new storage media.
Your use case "migration of current database to a new external storage media" is not directly supported.
I will check how this can be achieved most easily.
