MBP Pro - can't reboot
plex
Post by plex »
Trying to reboot, but display hangs with "Reboot..."
Power cycle and it runs again, with a ton of errors, and still I can't reboot
Version Meteobridge 2.8 (Mar 3 2016, build 9385), FW 1.4)
oled (07.03.2016 15:36:16): process started.
wnetd (07.03.2016 16:38:56): process started.
test5m (07.03.2016 16:41:06): logger stalled, will be restarted now.
test5m (07.03.2016 16:41:07): database daemon stalled, will be restarted now.
database (07.03.2016 16:41:07): process started.
logger (07.03.2016 16:41:07): database connected.
logger (07.03.2016 16:41:07): Historical data loaded (0 records).
logger (07.03.2016 16:41:07): data logger (version 5.0p, build 9385) started.
logger (07.03.2016 16:41:09): connect station 0 (Meteostick Vantage via USB serial).
logger (07.03.2016 16:41:09): connect station 9 (System Data via Plug-in).
logger (07.03.2016 16:41:11): transmitter 1 registered as ISS
logger (07.03.2016 16:41:11): transmitter 2 registered as Wind
logger (07.03.2016 16:41:11): Meteostick Version 2.3b3
logger (07.03.2016 16:41:11): debug off
logger (07.03.2016 16:41:11): verbose off
logger (07.03.2016 16:41:11): output raw (8 bytes)
logger (07.03.2016 16:41:11): output raw (10 bytes)
logger (07.03.2016 16:41:11): filter on
logger (07.03.2016 16:41:11): rx threshold set to -60db
logger (07.03.2016 16:41:11): listening to transmitter 1 2
logger (07.03.2016 16:41:11): bandwidth narrow
logger (07.03.2016 16:41:11): chip authentication ok: 14
logger (07.03.2016 16:41:11): frequency band 868MHz (EU)
logger (07.03.2016 16:41:50): Bad wind1(1) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (07.03.2016 16:41:52): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (07.03.2016 16:41:52): Bad wind1(1) sensor data, "chill x10" (-999) out of range [-700:1500]
logger (07.03.2016 16:41:54): Bad wind0(0) sensor data, "chill x10" (-999) out of range [-700:1500]
database (07.03.2016 16:42:11): cannot commit (after 30 tries in 10517ms): database is locked
database (07.03.2016 16:42:11): cannot begin transaction (3) (after 0 tries in 1ms): cannot start a transaction within a transaction
logger (07.03.2016 16:42:11): DB cannot retrieve rain0total_day (30 tries, 10520ms): database is locked
logger (07.03.2016 16:42:22): DB cannot retrieve th0temp_min (30 tries, 10507ms): database is locked
database (07.03.2016 16:42:22): cannot commit (after 30 tries in 10509ms): database is locked
database (07.03.2016 16:42:22): cannot begin transaction (3) (after 0 tries in 1ms): cannot start a transaction within a transaction
logger (07.03.2016 16:42:32): DB cannot retrieve th0temp_min (30 tries, 10517ms): database is locked
database (07.03.2016 16:42:32): cannot commit (after 30 tries in 10563ms): database is locked
database (07.03.2016 16:42:32): cannot begin transaction (3) (after 0 tries in 1ms): cannot start a transaction within a transaction
logger (07.03.2016 16:42:43): DB cannot retrieve th0hum_min (30 tries, 10507ms): database is locked
database (07.03.2016 16:42:43): cannot commit (after 30 tries in 10507ms): database is locked
database (07.03.2016 16:42:43): cannot begin transaction (3) (after 0 tries in 1ms): cannot start a transaction within a transaction
logger (07.03.2016 16:42:53): DB cannot retrieve th0hum_min (30 tries, 10509ms): database is locked
database (07.03.2016 16:42:54): cannot commit (after 30 tries in 10508ms): database is locked
database (07.03.2016 16:42:54): cannot begin transaction (3) (after 0 tries in 1ms): cannot start a transaction within a transaction
logger (07.03.2016 16:43:04): DB cannot retrieve thb0seapress_min (30 tries, 10509ms): database is locked
database (07.03.2016 16:43:04): cannot commit (after 30 tries in 10507ms): database is locked
logger (07.03.2016 16:43:14): DB cannot retrieve thb0seapress_min (30 tries, 10507ms): database is locked
logger (07.03.2016 16:43:25): DB cannot retrieve wind0wind_min (30 tries, 10508ms): database is locked
logger (07.03.2016 16:43:35): DB cannot retrieve wind0wind_min (30 tries, 10508ms): database is locked
logger (07.03.2016 16:43:46): DB cannot retrieve wind0dir_min (30 tries, 10654ms): database is locked
dbrepair (07.03.2016 16:43:54): database has integrity errors, repair started.
logger (07.03.2016 16:43:57): DB cannot retrieve rain0total_day (30 tries, 10659ms): database is locked
logger (07.03.2016 16:44:07): DB cannot retrieve rain0total_min (30 tries, 10504ms): database is locked
logger (07.03.2016 16:44:18): DB cannot retrieve th0temp_min (30 tries, 10520ms): database is locked
logger (07.03.2016 16:44:28): DB cannot retrieve th0temp_min (30 tries, 10534ms): database is locked
logger (07.03.2016 16:44:39): DB cannot retrieve th0hum_min (30 tries, 10524ms): database is locked
logger (07.03.2016 16:44:50): DB cannot retrieve th0hum_min (30 tries, 10587ms): database is locked
logger (07.03.2016 16:45:00): DB cannot retrieve thb0seapress_min (30 tries, 10531ms): database is locked
logger (07.03.2016 16:45:11): DB cannot retrieve thb0seapress_min (30 tries, 10553ms): database is locked
logger (07.03.2016 16:45:21): DB cannot retrieve wind0wind_min (30 tries, 10514ms): database is locked
logger (07.03.2016 16:45:32): DB cannot retrieve wind0wind_min (30 tries, 10547ms): database is locked
logger (07.03.2016 16:45:42): DB cannot retrieve wind0dir_min (30 tries, 10527ms): database is locked
logger (07.03.2016 16:45:53): DB cannot retrieve rain0total_day (30 tries, 10514ms): database is locked
logger (07.03.2016 16:46:03): DB cannot retrieve rain0total_min (30 tries, 10515ms): database is locked
logger (07.03.2016 16:46:16): DB cannot retrieve th0temp_day (30 tries, 10565ms): database is locked
logger (07.03.2016 16:46:26): DB cannot retrieve th0temp_day (30 tries, 10524ms): database is locked
logger (07.03.2016 16:46:37): DB cannot retrieve th0dew_day (30 tries, 10531ms): database is locked
logger (07.03.2016 16:46:47): DB cannot retrieve th0dew_day (30 tries, 10517ms): database is locked
logger (07.03.2016 16:46:58): DB cannot retrieve wind0chill_day (30 tries, 10521ms): database is locked
logger (07.03.2016 16:47:08): DB cannot retrieve wind0wind_min (30 tries, 10515ms): database is locked
logger (07.03.2016 16:47:19): DB cannot retrieve wind0wind_day (30 tries, 10504ms): database is locked
logger (07.03.2016 16:47:29): DB cannot retrieve wind0dir_min (30 tries, 10504ms): database is locked
logger (07.03.2016 16:47:40): DB cannot retrieve thb0seapress_day (30 tries, 10515ms): database is locked
logger (07.03.2016 16:47:50): DB cannot retrieve thb0seapress_day (30 tries, 10521ms): database is locked
logger (07.03.2016 16:48:01): DB cannot retrieve thb0seapress_year (30 tries, 10517ms): database is locked
logger (07.03.2016 16:48:11): DB cannot retrieve thb0seapress_year (30 tries, 10540ms): database is locked
logger (07.03.2016 16:48:22): DB cannot retrieve rain0total_day (30 tries, 10527ms): database is locked
logger (07.03.2016 16:48:32): DB cannot retrieve rain0rate_day (30 tries, 10578ms): database is locked
logger (07.03.2016 16:48:43): DB cannot retrieve th0hum_day (30 tries, 10553ms): database is locked
logger (07.03.2016 16:48:54): DB cannot retrieve th0hum_day (30 tries, 10504ms): database is locked
logger (07.03.2016 16:49:04): DB cannot retrieve th0temp_min (30 tries, 10504ms): database is locked
logger (07.03.2016 16:49:15): DB cannot retrieve th0temp_day (30 tries, 10504ms): database is locked
logger (07.03.2016 16:49:25): DB cannot retrieve th0temp_day (30 tries, 10504ms): database is locked
logger (07.03.2016 16:49:36): DB cannot retrieve th0dew_day (30 tries, 10504ms): database is locked
logger (07.03.2016 16:49:46): DB cannot retrieve th0dew_day (30 tries, 10504ms): database is locked
logger (07.03.2016 16:49:57): DB cannot retrieve wind0chill_day (30 tries, 10504ms): database is locked
logger (07.03.2016 16:50:07): DB cannot retrieve rain0rate_day (30 tries, 10505ms): database is locked
logger (07.03.2016 16:50:18): DB cannot retrieve th0hum_day (30 tries, 10504ms): database is locked
logger (07.03.2016 16:50:28): DB cannot retrieve th0hum_day (30 tries, 10504ms): database is locked
logger (07.03.2016 16:50:39): DB cannot retrieve thb0seapress_day (30 tries, 10504ms): database is locked
logger (07.03.2016 16:50:49): DB cannot retrieve thb0seapress_day (30 tries, 10504ms): database is locked
Re: MBP Pro - can't reboot
Can you please give me remote access. I am just working on database code changes,
where your situation should be cured. Please send URL and passcode to "info(at)meteobridge.com".
