v2.3e Data Logging Stopped after Update **solved**
cbhiii
Post by cbhiii »
After upgrading to v2.3e my data logging is stopped. Is this a new thing? It did not do this under 2.3d or previously.
I rebooted and the same thing is true. No weather data is being broadcast by Meteohub.
I tried checking and unckecking the \"data loging\" setting under the Weather Station menu but nothing changed.
ProcessWeather Data Recomputation: in progress
Weather Data Logging: stopped
cbhiii
Re:v2.3e Data Logging Stopped after Update
Post by cbhiii »
50 minutes offline. I can't wait any longer. I went back to v2.3d. :S
With 2.3b a changed behavior according time scheduled generation of graphs was introduced
snip----------------
* Halts scheduled generation of graphs as long as time-compacted data (which builds the base for graph generation) is being reconstructed from scratch.
I think your \"missing\" graphs have their reason in that. Idea is that Meteohub should not upload empty graphs (and overwriting meaningful ones with empty one) during recomputation of data. This just effects the time scheduled graph generation.
Weather network, graph generation of demand, dashboard etc are working all the time, but need the data logger running.
I checked again by installing 2.3e on one of my other machines here, I cannot confirm that the update does provide any harm to the data logging process.
What does the \"meteohub log\" say? What happens when you start data logging manually?
Post by skyewright »
Just to confirm that I have 2.3e installed here, and logging is happening normally, so whatever the problem is/was it does not seem to be general.
cbhiii
Post by cbhiii »
I understand that graph generation will not work during recomputation and that makes sense, but the logger was STOPPED and no data was being captured. There is adifference.
I have since re-upgraded to v2.3e and it is now w working fine, but when I did it the first time it did not function correctly.
