Historic data Rain0Total not working **solved**
StefanV
Post by StefanV »
I'm trying to get historic data from the Meteobrige Pro, in particular the amounts of rain.
This is the data showed by Meteobridge:
As you can see, at 12:08 the amount of rain is 4,8mm.
This is the template I use to retrieve the data (snippet of 24h template):
>>201603041200=[rain0total-sum@201603041200=.:-]
>>201603041201=[rain0total-sum@201603041201=.:-]
>>201603041202=[rain0total-sum@201603041202=.:-]
>>201603041203=[rain0total-sum@201603041203=.:-]
>>201603041204=[rain0total-sum@201603041204=.:-]
>>201603041205=[rain0total-sum@201603041205=.:-]
>>201603041206=[rain0total-sum@201603041206=.:-]
>>201603041207=[rain0total-sum@201603041207=.:-]
>>201603041208=[rain0total-sum@201603041208=.:-]
>>201603041209=[rain0total-sum@201603041209=.:-]
>>201603041210=[rain0total-sum@201603041210=.:-]
>>201603041211=[rain0total-sum@201603041211=.:-]
>>201603041212=[rain0total-sum@201603041212=.:-]
>>201603041213=[rain0total-sum@201603041213=.:-]
>>201603041214=[rain0total-sum@201603041214=.:-]
>>201603041215=[rain0total-sum@201603041215=.:-]
>>201603041216=[rain0total-sum@201603041216=.:-]
>>201603041217=[rain0total-sum@201603041217=.:-]
>>201603041218=[rain0total-sum@201603041218=.:-]
>>201603041219=[rain0total-sum@201603041219=.:-]
>>201603041220=[rain0total-sum@201603041220=.:-]
>>201603041221=[rain0total-sum@201603041221=.:-]
>>201603041222=[rain0total-sum@201603041222=.:-]
>>201603041223=[rain0total-sum@201603041223=.:-]
>>201603041224=[rain0total-sum@201603041224=.:-]
>>201603041225=[rain0total-sum@201603041225=.:-]
>>201603041226=[rain0total-sum@201603041226=.:-]
>>201603041227=[rain0total-sum@201603041227=.:-]
>>201603041228=[rain0total-sum@201603041228=.:-]
>>201603041229=[rain0total-sum@201603041229=.:-]
>>201603041230=[rain0total-sum@201603041230=.:-]
>>201603041231=[rain0total-sum@201603041231=.:-]
>>201603041232=[rain0total-sum@201603041232=.:-]
>>201603041233=[rain0total-sum@201603041233=.:-]
>>201603041234=[rain0total-sum@201603041234=.:-]
>>201603041235=[rain0total-sum@201603041235=.:-]
>>201603041236=[rain0total-sum@201603041236=.:-]
>>201603041237=[rain0total-sum@201603041237=.:-]
>>201603041238=[rain0total-sum@201603041238=.:-]
>>201603041239=[rain0total-sum@201603041239=.:-]
>>201603041240=[rain0total-sum@201603041240=.:-]
>>201603041241=[rain0total-sum@201603041241=.:-]
>>201603041242=[rain0total-sum@201603041242=.:-]
>>201603041243=[rain0total-sum@201603041243=.:-]
>>201603041244=[rain0total-sum@201603041244=.:-]
>>201603041245=[rain0total-sum@201603041245=.:-]
>>201603041246=[rain0total-sum@201603041246=.:-]
>>201603041247=[rain0total-sum@201603041247=.:-]
>>201603041248=[rain0total-sum@201603041248=.:-]
>>201603041249=[rain0total-sum@201603041249=.:-]
>>201603041250=[rain0total-sum@201603041250=.:-]
>>201603041251=[rain0total-sum@201603041251=.:-]
>>201603041252=[rain0total-sum@201603041252=.:-]
>>201603041253=[rain0total-sum@201603041253=.:-]
>>201603041254=[rain0total-sum@201603041254=.:-]
>>201603041255=[rain0total-sum@201603041255=.:-]
>>201603041256=[rain0total-sum@201603041256=.:-]
>>201603041257=[rain0total-sum@201603041257=.:-]
>>201603041258=[rain0total-sum@201603041258=.:-]
>>201603041259=[rain0total-sum@201603041259=.:-]
This outputs:
>>201603041200=0.0
>>201603041201=0.0
>>201603041202=0.0
>>201603041203=0.0
>>201603041204=0.0
>>201603041205=0.0
>>201603041206=0.0
>>201603041207=0.0
>>201603041208=0.0
>>201603041209=0.0
>>201603041210=0.0
>>201603041211=0.0
>>201603041212=0.0
>>201603041213=0.0
>>201603041214=0.0
>>201603041215=0.0
>>201603041216=0.0
>>201603041217=0.0
>>201603041218=0.0
>>201603041219=0.0
>>201603041220=0.0
>>201603041221=0.0
>>201603041222=0.0
>>201603041223=0.0
>>201603041224=0.0
>>201603041225=0.0
>>201603041226=0.0
>>201603041227=0.0
>>201603041228=0.0
>>201603041229=0.0
>>201603041230=0.0
>>201603041231=0.0
>>201603041232=0.0
>>201603041233=0.0
>>201603041234=0.0
>>201603041235=0.0
>>201603041236=0.0
>>201603041237=0.0
>>201603041238=0.0
>>201603041239=0.0
>>201603041240=0.0
>>201603041241=0.0
>>201603041242=0.0
>>201603041243=0.0
>>201603041244=0.0
>>201603041245=0.0
>>201603041246=0.0
>>201603041247=0.0
>>201603041248=0.0
>>201603041249=0.0
>>201603041250=0.0
>>201603041251=0.0
>>201603041252=0.0
>>201603041253=0.0
>>201603041254=0.0
>>201603041255=0.0
>>201603041256=0.0
>>201603041257=0.0
>>201603041258=0.0
>>201603041259=0.0
What is going wrong? Because I don't see the 4,8mm @ 201603041208. Do I have the wrong sensor, wrong selector? Or isn't it possible to retrieve raintotal values from the past?
Thanks for the answer!
Re: Historic data Rain0Total not working
Strange. I test this definition with email sending :
rain0total-sum@201603050306:--#[rain0total-sum@201603050306:--]
and it returns the value of the addressed database field fine. In which context are
you using these template variables? email? http? ftp?
One more remark. You say it is a snippet from a 24h request.
Please tell me that you are not firing 1440 such requests to fill up
the data of a day? It would be rather unwise to do 1440 isolated
database requests for getting this. Please make use of export functions
when you are looking for arrays of data. Doing this via templates
will not work on larger amounts of data. Database will stall at
some point of overload.
StefanV
Post by StefanV »
I did actually fire 1440 requests ;) sorry! But in the meantime I tried to export the data using the export function and that will do the trick for now. But even when I only tried 1 or 2 requests, it didn't work for some reason.
Anyway; it's solved in another way (export functions). :)
