disconnect station 0 (Vantage): wrap-up
17:24 Selecting tab "WeatherNets" "Meteoplug Cloud graphing " (not selected before) Set to 10 minutes => press save => Live interval 10 seconds => Save
Check Live data: cloud uploads were added, BUT no live data anymore, only error message about communicating with station, wait one minute, check the Station tab.
Log on system tab:
logger (28.03.2016 17:24:21): error while waiting for data from weather stations
logger (28.03.2016 17:24:21): disconnect station 0 (Vantage): wrap-up
Waited a few minutes, all the same, no new lines in the log, same error.
Although all seemed normal on the Station tab I pressed save after waiting a few more minutes, checked log:
logger (28.03.2016 17:28:39): database connected.
logger (28.03.2016 17:28:39): Historical data loaded (61 records).
logger (28.03.2016 17:28:39): data logger (version 5.0p, build 9559) started.
logger (28.03.2016 17:28:40): connect station 0 (Vantage via USB serial).
logger (28.03.2016 17:28:40): connect station 9 (System Data via Plug-in).
logger (28.03.2016 17:28:40): wakeup sent.
Most is OK now , so why the station get lost, ????
BUT not OK is the dewpoint for the meteoplug dashboard..
Live data
Outdoor 4 sec 9.2°C 81% (dew 6.1°C, heat 9.2°C)
This data is received from Meteoplug:
&value=9.1
&value=1000000000.0
&value=8.0
&value=208.0
&value=17.6|7.9
&value=996.2|996.4|996.2
&value=0.0
&value=0.5|0.0
&value=139.0|97.0
&value=81.0
&date=20160328174031
This is the website the MB-Pro (2.8-9559) is uploading to: http://leuven.meteobridge.com/leuven28/index.php
