Thought this may be helpful to whole group?
My weather station only reads humidity form 10% to 99% so I can use the Humidity stretch option to correct that by entering10 in --->0 value and 99 in upper value. But I am also seeing that when humidity drops throughout the day my sensor is reading lower than it should and in the evening when humidity is higher my sensor reads higher than it should how could I correct this using the humidity stretch?
Humidity stretch
Re: Humidity stretch
Hello sdwilkinson
Your sensor can only between 10% and 99% rel. humidity measure. The measured values are within this range are correct. I see no reason to make an extension of the measurement data. On the vast majority of measurement locations below 10% and 100% are rarely achieved.
Greeting
Tobias
Greeting
Tobias
