Raintotal not correct in 2.8 (Davis/meteostick) **solved**
wsnoordbergum
Post by wsnoordbergum »
I've tried the new version 2.8 for a few times now and it seems like the raintotal isn't correct.
A few days ago I had 0.6 mm of rain meteobridge was 0.2mm off and showed 0.4
Then after a new rain shower the total didn't go up but it did on my console, Davis VP2 with meteostick.
Strange enough the rainfall of last hour did and showed 0.4 (on my website) (rain0total-sum60)
Something isn't going as it should be.
Now I'm using version 2.6 and sofar no problems with raintotals.
Gr. wsNoordbergum
Re: Raintotal is not correct in 2.8 (Davis VP2/meteostick)
Todays update should have this fixed. Please report if you still experience this problem when having applied todays release.
wsnoordbergum
I will reboot today and see how things go.
Just need to wait for rain, at the moment sunny...
I'll keep you posted.
Thanks in advance, wsNoordbergum.
wsnoordbergum
Well finally got some rain today.
But it seems the rain0total is still not as it should be.
Currently on console 0.2mm of rain.
Meteobridge shows 0.0, the rate is correct at 0.8mm/h and the rain last hour (rain0total-sum60) is also correct at 0.2 mm.
Something strange is going on.
I'll keep my current version (2.8 may 8) running, as to see how it's going with the next rainfall maybe it is only the first 0.2mm that isn't picked up by meteobridge.
By the way thanks for adding the selector nonzerotime!
I will implement this for use on my Leuven template based website.
I'll keep an eye on my rain0total value during the coming period.
Greetz wsNoordbergum.
wsnoordbergum
Seems like it is okay now.
Case closed.
