AcuRite 02064M with Meteobridge via USB?
marke190
Post by marke190 »
Anyone know if the AcuRite 02064M will work with Meteobridge via USB? We've been running Meteobridge with a Davis VantageVue for 2 years, but the sensor pack is failing and Davis wants $100 to rebuild. Davis has replaced parts several times, so I'm less than enthused about spending any more money with them on what appears to be a poorly designed unit. The guy who owns the station is casting about for replacement ideas in the sub-$200 price-range, something that will work with the existing Meteobridge. The Meteobridge stations page says Acurite 1025/1035/1525, but leaves the door open to other USB models by saying "USB enabled weather stations from Acurite are supported". Would that include the 02064M?
Mark in Mexico
Re: AcuRite 02064M with Meteobridge via USB?
I did not test this, so I cant say. As a default please assume that it is not working.
bloomsky1
Post by bloomsky1 »
I'm not familiar with that model number but if the unit has the PC Connect feature on the Acurite display it should work. Is the 02064M the Costco model? If so thats what I'm using with meteobridge and it works well.
