TL-MR3020 reboots when accessing Network tab **solved**
Posted: Tue May 10, 2016 11:14 pm
by Karl139
Every time I try to access the network configuration in the Network tab on my new TL-MR3020 it stops and reboots. All other tabs are ok.
Any suggestions on what the problem might be?
/ Johan
Re: TL-MR3020 reboots when accessing Network tab
Posted: Wed May 11, 2016 6:12 pm
by mrdinks
I had a problem getting to the network tab a month ago. I went to the systems tab, version control and changed it to an older version and restarted.
This let me get to the network tab. I use the current version and it work for me now.
Might try this and see if it works.
Posted: Wed May 11, 2016 9:49 pm
by Karl139
Hi mrdinks,
Thanks for your tip. I have tried that, with all available older versions, without any luck.
Posted: Wed May 11, 2016 11:41 pm
by Karl139
Success!
It started working after I replaced the USB power cable.
Problem solved.
Posted: Fri May 13, 2016 9:34 pm
That is an interesting finding, but somehow logical as when accessing network tab
Meteobridge will start WLAN operation to find a list of available WiFI APs.
When power cable is faulty, this might "brown-out" the hardware.
