Hello
My UV is last updated 40 minutes ago and the other sensors updates every 5 seconds (wind).
Uv db is the same as for other sensors. Uv is updated on the Davis Console.
Using Meteostick and I have seen this a few times now.
Kind Regards
UV last updated 40minutes ago **solved**
Re: UV last updated 40minutes ago
I have rebooted the Meteobridge and UV data is coming in again but I guess I will see this issue again soon.
The sensor db (all of them) is 90db, I guess that is to the high side?
Updated: Now picking up the retransmit from the Davis Console, working fine. Guess the issue was related to poor signal from the ISS.
