MeteoBridge and SteelSeries Gauges
WessexWeather
Post by WessexWeather »
I've finally set up my SteelSeries Gauges here...
http://www.wessexweather.net/saratoga/wxssgauges.php
However there are some errors on the pop-ups: -
The apparent temperature and rain rate time stamps always show midnight.
The heat index time stamp reads n/a.
The wind bearing displays unusual METAR data.
Last rain shows as n/a.
Max per hour rain rate is incorrect.
Has anyone else noticed these errors or can anyone suggest a workaround?
Thanks in advance.
Simon
Re: MeteoBridge and SteelSeries Gauges
how do you feed those?
WessexWeather
Simon
wsnoordbergum
Post by wsnoordbergum »
There is no simple workaround, some tags are not available, like days with rain and wettest days etc.
I've changed a few things on my steelseries page (Leuven template) and also deleted some popup items which meteobridge can't provide a tag for.
Heatindex = [th0heatindex-dmaxtime.:---]
Windbearing seems ok to me.
Lastrain= [rain0rate-nonzerotime.:---]
Maximum per hour isn't available, instead use [rain0total-sum60.1:---] for the rainfall previous hour or use the maximum rate instead, [rain0rate-dmax.1:---) and [rain0rate-dmaxtime.:---]
My steelseries are at
http://www.wsnoordbergum.nl/weather2/in ... #data-area
Goodluck wsNoordbergum
