Illegal Data Records error message ** solved **
cbhiii
Post by cbhiii »
What does this meteohub log error message mean and why is it referencing April data?
wmr928eval (26.05.2008 08:22:12): illegal data record in line 38107 while reading from file /data/weather/200804/raw: 2008040®213316 rain0 0 0 1097
wmr928eval (26.05.2008 08:22:16): illegal data record in line 43829 while reading from file /data/weather/200804/raw: 2O080404073613 wind0 288 4 9 0021
Re:Illegal Data Records error message
That tells you, that you are in risk of serious trouble, as there are bad entries in your raw data.
You can delete these entries with the data inspection tool, by making uses of the \"clean-up\" function for april. (do stop data logging before that).
If that does occur again, be prepared to change you USB stick to a correctly working one.
cbhiii
Post by cbhiii »
Records cleaned up. Thanks!
