MB Pro data lost and no display
chrysnic
Post by chrysnic »
Hi all,
All of a sudden (without rebooting), all the data on my MB Pro is lost. The "data" folder on the SMB share is completely empty (no directories, nothing).
Moreover, the display no longer shows live data (presumably because all the templates/scripts have been lost?).
The log keeps giving these messages (see below):
Could you please help me go back to a functional state?
logger (22.05.2016 13:14:18): database connected.
logger (22.05.2016 13:14:18): Historical data loaded (0 records).
logger (22.05.2016 13:14:18): data logger (version 5.0p, build 9911) started.
logger (22.05.2016 13:14:19): connect station 0 (Vantage via TCP/IP).
logger (22.05.2016 13:14:19): connect station 9 (System Data via Plug-in).
logger (22.05.2016 13:14:19): wakeup sent.
logger (22.05.2016 13:14:19): internal logger activated.
logger (22.05.2016 13:14:20): syncing.
logger (22.05.2016 13:14:25): parent process received termination signal (15).
logger (22.05.2016 13:14:25): child process received termination signal (15).
logger (22.05.2016 13:14:25): disconnect station 0 (Vantage): exit
logger (22.05.2016 13:14:25): disconnect station 9 (System Data): exit
database (22.05.2016 13:14:25): process terminated normally.
test5m (22.05.2016 13:14:26): USB storage remounted: /dev/sda
database (22.05.2016 13:14:26): process started.
logger (22.05.2016 13:14:26): database connected.
logger (22.05.2016 13:14:26): Historical data loaded (0 records).
logger (22.05.2016 13:14:26): data logger (version 5.0p, build 9911) started.
logger (22.05.2016 13:14:27): connect station 0 (Vantage via TCP/IP).
logger (22.05.2016 13:14:27): connect station 9 (System Data via Plug-in).
logger (22.05.2016 13:14:28): wakeup sent.
logger (22.05.2016 13:14:28): internal logger activated.
logger (22.05.2016 13:14:28): syncing.
logger (22.05.2016 13:14:38): gettime request sent.
logger (22.05.2016 13:14:38): time offset of Vantage: 1 minutes
logger (22.05.2016 13:14:38): eeprom request sent.
logger (22.05.2016 13:14:39): rain collector size 0.2 mm per tick.
logger (22.05.2016 13:14:39): transmitter 1 active as station type (#0) "ISS".
logger (22.05.2016 13:14:39): firmware version request sent.
logger (22.05.2016 13:14:40): firmware version 3.12
logger (22.05.2016 13:14:40): no reading of Vantage's internal logger.
logger (22.05.2016 13:15:58): parent process received termination signal (15).
logger (22.05.2016 13:15:58): child process received termination signal (15).
logger (22.05.2016 13:15:58): disconnect station 0 (Vantage): exit
logger (22.05.2016 13:15:58): disconnect station 9 (System Data): exit
logger (22.05.2016 13:15:58): data logger stopped.
database (22.05.2016 13:15:59): process terminated normally.
test5m (22.05.2016 13:16:00): USB storage remounted: /dev/sda
database (22.05.2016 13:16:00): process started.
logger (22.05.2016 13:16:00): database connected.
logger (22.05.2016 13:16:01): Historical data loaded (24 records).
logger (22.05.2016 13:16:01): data logger (version 5.0p, build 9911) started.
logger (22.05.2016 13:16:01): connect station 0 (Vantage via TCP/IP).
logger (22.05.2016 13:16:01): connect station 9 (System Data via Plug-in).
logger (22.05.2016 13:16:02): wakeup sent.
logger (22.05.2016 13:16:02): internal logger activated.
logger (22.05.2016 13:16:02): syncing.
logger (22.05.2016 13:16:11): gettime request sent.
logger (22.05.2016 13:16:11): time offset of Vantage: 1 minutes
logger (22.05.2016 13:16:11): eeprom request sent.
logger (22.05.2016 13:16:12): rain collector size 0.2 mm per tick.
logger (22.05.2016 13:16:12): transmitter 1 active as station type (#0) "ISS".
logger (22.05.2016 13:16:12): firmware version request sent.
logger (22.05.2016 13:16:13): firmware version 3.12
logger (22.05.2016 13:16:13): no reading of Vantage's internal logger.
sgh
Re: MB Pro data lost and no display
Post by sgh »
The same with my MB Pro.
All Data and Templates lost :|
Not good...
Going into details on chrysnic's case a hw failure was identified and we will replace a component.
@sgh: please send remote login details to "info(at)meteobridge.com" so that I can check what is
the reason on your rig.
