Data from Meteoplug into MBPro?
marco
Post by marco »
Hi another noob question here..
Today, all my datas are stored in meteoplug. Because I started with meteohub in 2012, then I've changed to meteobridge in 2015 (still running), and now I've switched to MBPro (parallel to meteobridge). And in that time I allways used meteoplug beside those systems. But MBPro has so much possibilities with exports, variables, templates etc. I think I don't need the meteoplug anymore (sorry admin) and of course i'll will drop the meteobridge to. So in my case, meteoplug is just a Backup-Server for my old datas at the moment.
MBPro is all I need. but how can I grab all the datas form meteoplug, to use them in MBPro for the e.g. export service?
I Know that there is an export function in Meteoplug, but the files are not build in the same way. And how can I import them to my MBPro.??? And I know also, that normaly Meteoplug should be feed by a system and not the other way around!!
I have read about a feature, ( import Data mechanism) that will come. Found here in the "release & forum" section: http://www.meteobridge.com/wiki/index.php/Forum
Maybe it is that what i'm looking for?
Thanks marco
Re: Data from Meteoplug into MBPro?
MB PRO will not be able to handle the data volume stored on the Meteoplug server.
It will need some condensing, which will make it a complicated process.
As there are a lot of requests to import Weatherlink data, this will be the first step.
marco
Post by marco »
Hi admin
hmm.. ok, but is there a way to import or downlaod at least the datas from my other meteobridge (TP-LINK TL-MR3020, running since april 2015), so i can drop that one? The TP-Link, is still up running beside the PRO.
thank you!
marco
Sorry, there is no tool to transfer stored min/max values from one Meteobridge to another.
In the MB PRO you can manually set the min/max data provided by the MB. It is boring
but should be a one time effort. I guess just yearly data is worth doing so.
