mb_*.* ftp files
pettergp
mb_*.* ftp files
Post by pettergp »
I am using meteobridge to upload by ftp a template file named MBtags.php and an image file called image.jpg from my cam.
Sometimes on the same folders it appear new archives named mb_MBtags.php and mb_image.jpg.
When this happens I must delete them to start all working properly again.
Someone know why is this happening and how can I solve it?
thanks,
Peter
Re: mb_*.* ftp files
pettergp wrote:Hello,
thanks,
Peter
The names with mb_*** are the temporary names used by Meteobridge when uploading.
After a correct upload Metebridge will delete the old file and first and then rename the mb_*** to the correct name.
Meteobridge uploads mb_MBtags.php
and when all is OK
Meteobridge deletes MBtags.php
and then
Meteobridge renames mb_MBtags.php to MBtags.php
This is a standard procedure to make sure that the file is always available to the scripts on the server as FTP of a file will take some time.
pettergp
Post by pettergp »
thanks,
Peter
and when all is OK
and then
thanks Wvdkuil for your reply.
I think this could be due to a temporary weak 3g Internet connection.
Do you think running a cron that delete those mb_ files regularly is a right approach to a solution?
I would really appreciate any suggestion
