Error
MeteoOudkarspel
Error
Post by MeteoOudkarspel »
Hi
Does anyone know what to mean the following error message is?
Or has to do with meteobridge server probrlemen last Wednesday afternoon.
Update: 06-24-2016
I have found the cause was the USB stick that proved to being formatted at once anymore.
I have now put on the internal memory and problem gone.
oled (24.06.2016 15:54:20): process started.
database (24.06.2016 17:56:21): process started.
wnetd (24.06.2016 17:56:21): process started.
logger (24.06.2016 17:56:22): database connected.
logger (24.06.2016 17:56:22): Historical data loaded (0 records).
logger (24.06.2016 17:56:22): data logger (version 5.0p, build 9941) started.
logger (24.06.2016 17:56:24): connect station 0 (Vantage via USB serial).
logger (24.06.2016 17:56:24): connect station 9 (System Data via Plug-in).
logger (24.06.2016 17:56:24): wakeup sent.
logger (24.06.2016 17:56:24): internal logger activated.
logger (24.06.2016 17:56:24): syncing.
logger (24.06.2016 17:56:34): gettime request sent.
logger (24.06.2016 17:56:34): no Vantage time offset.
logger (24.06.2016 17:56:34): eeprom request sent.
logger (24.06.2016 17:56:34): rain collector size 0.2 mm per tick.
logger (24.06.2016 17:56:34): transmitter 1 active as station type (#0) "ISS".
logger (24.06.2016 17:56:34): firmware version request sent.
logger (24.06.2016 17:56:34): firmware version 4.18
logger (24.06.2016 17:56:34): no reading of Vantage's internal logger.
database (24.06.2016 17:57:49): cannot prepare create table (after 100 tries in 19283ms): database disk image is malformed (11)
database (24.06.2016 17:58:10): cannot prepare insert into wind0dir_min (after 100 tries in 21103ms): database disk image is malformed (11)
database (24.06.2016 17:58:10): rollback on insert forced: wind0dir
database (24.06.2016 17:58:33): cannot prepare insert into wind0dir_min (after 100 tries in 22360ms): database disk image is malformed (11)
database (24.06.2016 17:58:33): rollback on insert forced: wind0dir
database (24.06.2016 17:58:59): cannot prepare insert into wind0dir_min (after 100 tries in 26514ms): database disk image is malformed (11)
database (24.06.2016 17:58:59): rollback on insert forced: wind0dir
database (24.06.2016 17:59:22): cannot prepare insert into wind0dir_min (after 100 tries in 22407ms): database disk image is malformed (11)
database (24.06.2016 17:59:22): rollback on insert forced: wind0dir
database (24.06.2016 17:59:48): cannot prepare insert into wind0dir_min (after 100 tries in 26048ms): database disk image is malformed (11)
database (24.06.2016 17:59:48): rollback on insert forced: wind0dir
database (24.06.2016 18:00:17): cannot prepare insert into wind0dir_min (after 100 tries in 28940ms): database disk image is malformed (11)
database (24.06.2016 18:00:17): rollback on insert forced: wind0dir
database (24.06.2016 18:00:40): cannot prepare insert into wind0dir_min (after 100 tries in 22358ms): database disk image is malformed (11)
database (24.06.2016 18:00:40): rollback on insert forced: wind0dir
database (24.06.2016 18:01:07): cannot prepare insert into wind0dir_min (after 100 tries in 26747ms): database disk image is malformed (11)
database (24.06.2016 18:01:07): rollback on insert forced: wind0dir
database (24.06.2016 18:01:31): cannot prepare insert into wind0dir_min (after 100 tries in 24551ms): database disk image is malformed (11)
database (24.06.2016 18:01:31): rollback on insert forced: wind0dir
database (24.06.2016 18:01:58): cannot prepare insert into wind0dir_min (after 100 tries in 26414ms): database disk image is malformed (11)
database (24.06.2016 18:01:58): rollback on insert forced: wind0dir
database (24.06.2016 18:02:23): cannot prepare insert into wind0dir_min (after 100 tries in 25007ms): database disk image is malformed (11)
database (24.06.2016 18:02:23): rollback on insert forced: wind0dir
database (24.06.2016 18:02:46): cannot prepare insert into wind0dir_min (after 100 tries in 23133ms): database disk image is malformed (11)
database (24.06.2016 18:02:46): rollback on insert forced: wind0dir
database (24.06.2016 18:03:12): cannot prepare insert into wind0dir_min (after 100 tries in 25913ms): database disk image is malformed (11)
database (24.06.2016 18:03:12): rollback on insert forced: wind0dir
database (24.06.2016 18:03:39): cannot prepare insert into wind0dir_min (after 100 tries in 26327ms): database disk image is malformed (11)
database (24.06.2016 18:03:39): rollback on insert forced: wind0dir
database (24.06.2016 18:04:05): cannot prepare insert into wind0dir_min (after 100 tries in 26590ms): database disk image is malformed (11)
database (24.06.2016 18:04:05): rollback on insert forced: wind0dir
database (24.06.2016 18:04:33): cannot prepare insert into wind0dir_min (after 100 tries in 27388ms): database disk image is malformed (11)
database (24.06.2016 18:04:33): rollback on insert forced: wind0dir
database (24.06.2016 18:04:59): cannot prepare insert into wind0dir_min (after 100 tries in 26130ms): database disk image is malformed (11)
database (24.06.2016 18:04:59): rollback on insert forced: wind0dir
database (24.06.2016 18:05:26): cannot prepare insert into wind0dir_min (after 100 tries in 26680ms): database disk image is malformed (11)
database (24.06.2016 18:05:26): rollback on insert forced: wind0dir
Sincerely,
Re: Error
Mailformed DB image can happen, when system has ben disconnected from power at a bad point in time
and db file remains inconsistent or when USB storage has gone faulty. What does "http://ip-of-meteobridge/cgi-bin/system.cgi?dmesg" tell you?
