Trouble getting VantageVue/Ambient Weather WeatherBridge to
stb
Post by stb »
I've recently purchased a bundle from AmbientWeather, including a WeatherBridge and a VantageVue. I'm having trouble getting RF communication established between the VantageVue and the USB stick. The stick is in a window, the VantageVue in the middle of the lawn, about 80 feet distance, with no obstructions. We're in a rural area, and there should be minimal interference at 915 MHz, although I haven't tested that.
Here's the log output I get in Meteobridge:
wnetd (03.07.2016 12:31:46): process started.
logger (03.07.2016 12:31:46): Historical data loaded (23 records).
logger (03.07.2016 12:31:46): data logger (version 5.0q, build 9993) started.
logger (03.07.2016 12:31:47): connect station 0 (Meteostick Vantage via USB serial).
logger (03.07.2016 12:31:49): transmitter 1 registered as ISS
logger (03.07.2016 12:31:49): Meteostick Version 2.4
logger (03.07.2016 12:31:49): debug off
logger (03.07.2016 12:31:49): verbose off
logger (03.07.2016 12:31:49): output raw (8 bytes)
logger (03.07.2016 12:31:49): output raw (10 bytes)
logger (03.07.2016 12:31:49): filter on
logger (03.07.2016 12:31:49): rx threshold set to -105db
logger (03.07.2016 12:31:49): listening to transmitter 1
logger (03.07.2016 12:31:49): bandwidth wide
logger (03.07.2016 12:31:49): chip authentication ok: 14
logger (03.07.2016 12:31:49): frequency band 915MHz (US)
logger (03.07.2016 12:35:14): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:35:17): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:35:24): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:35:37): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:36:05): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:36:31): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:37:10): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:37:48): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:38:22): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:38:30): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:38:40): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:39:00): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:39:21): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:39:52): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:39:54): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 12:45:50): restart meteostick (356 secs no valid rf signal)
logger (03.07.2016 12:50:51): restart meteostick (301 secs no valid rf signal)
logger (03.07.2016 12:55:52): restart meteostick (301 secs no valid rf signal)
logger (03.07.2016 13:00:53): restart meteostick (301 secs no valid rf signal)
logger (03.07.2016 13:05:54): restart meteostick (301 secs no valid rf signal)
logger (03.07.2016 13:10:55): restart meteostick (301 secs no valid rf signal)
logger (03.07.2016 13:15:56): restart meteostick (301 secs no valid rf signal)
logger (03.07.2016 13:20:57): restart meteostick (301 secs no valid rf signal)
logger (03.07.2016 13:25:58): restart meteostick (301 secs no valid rf signal)
logger (03.07.2016 13:30:59): restart meteostick (301 secs no valid rf signal)
logger (03.07.2016 13:34:03): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 13:34:13): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 13:34:24): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 13:34:34): wind0 data incomplete (missing outdoor temp for windchill)
logger (03.07.2016 13:34:47): wind0 data incomplete (missing outdoor temp for windchill)
On the Live Data tab, I'm only seeing a single line "Rain 1h -60db rate 0.0mm/h".
The configuration on the Weather Station tab is: Meteostick: Vantage, US 915 MHz, RF Sens -105 dB wide, rain 0.2mm, with Station #1 set to Integrated Sensor Suite.
Any hints on what I could try? I did try out having the VantageVue indoors, right next to the receiver, and I did only see data every half our or so.
wsnoordbergum
Re: Trouble getting VantageVue/Ambient Weather WeatherBridge
Post by wsnoordbergum »
First I would update the meteostick firmware.
This can be done in the tab system on meteobridge.
Next set the bandwidth to normal.
Set the threshold about 10 db higher then the current receiving level about 70-75 will be good.
I'm using meteostick with a vantage pro 2 and without trouble...
Try using ferrite shields on the USB cable which connects the stick to the meteobridge.
Make sure the antenna is straight, try a different spot with less interference.
Modems pc screens etc. are very disturbing.
Good luck wsNoordbergum
The hints from the previous poster are all right. :idea:
I think RX threshold is far to high. Please try with -90 db.
