Not stable from firmware 2.9 **solved**
meteoharderwijk
Post by meteoharderwijk »
since firmware 2.9 my meteobridge pro Red version is not stable. for now my old Raspberry pi uploads to my website
I give the unit a factory reset, this was not the solutions.
now I get the follow message
What is going on with the meteobridge pro.
I have a Davis VP2 plus weather station.
oled (05.07.2016 17:03:21): process started.
database (05.07.2016 19:04:41): process started.
wnetd (05.07.2016 19:04:41): process started.
logger (05.07.2016 19:04:41): database connected.
logger (05.07.2016 19:04:41): Historical data loaded (0 records).
logger (05.07.2016 19:04:41): data logger (version 5.0q, build 10043) started.
logger (05.07.2016 19:04:42): connect station 0 (Meteostick Vantage via USB serial).
logger (05.07.2016 19:04:42): connect station 9 (System Data via Plug-in).
logger (05.07.2016 19:04:44): transmitter 1 registered as ISS
logger (05.07.2016 19:04:44): Meteostick Version 2.4
logger (05.07.2016 19:04:44): debug off
logger (05.07.2016 19:04:44): verbose off
logger (05.07.2016 19:04:44): output raw (8 bytes)
logger (05.07.2016 19:04:44): output raw (10 bytes)
logger (05.07.2016 19:04:44): filter on
logger (05.07.2016 19:04:44): rx threshold set to -90db
logger (05.07.2016 19:04:44): listening to transmitter 1
logger (05.07.2016 19:04:45): bandwidth narrow
logger (05.07.2016 19:04:45): chip authentication ok: 14
logger (05.07.2016 19:04:45): frequency band 868MHz (EU)
logger (05.07.2016 19:04:48): parent process received termination signal (15).
logger (05.07.2016 19:04:48): child process received termination signal (15).
logger (05.07.2016 19:04:48): disconnect station 0 (Meteostick Vantage): exit
logger (05.07.2016 19:04:48): disconnect station 9 (System Data): exit
logger (05.07.2016 19:04:48): data logger stopped.
database (05.07.2016 19:04:48): process terminated normally.
test5m (05.07.2016 19:04:48): USB storage remounted: /dev/sda
database (05.07.2016 19:04:48): process started.
logger (05.07.2016 19:04:49): database connected.
logger (05.07.2016 19:04:49): Historical data loaded (0 records).
logger (05.07.2016 19:04:49): data logger (version 5.0q, build 10043) started.
logger (05.07.2016 19:04:50): connect station 0 (Meteostick Vantage via USB serial).
logger (05.07.2016 19:04:50): connect station 9 (System Data via Plug-in).
logger (05.07.2016 19:04:52): transmitter 1 registered as ISS
logger (05.07.2016 19:04:52): Meteostick Version 2.4
logger (05.07.2016 19:04:52): debug off
logger (05.07.2016 19:04:52): verbose off
logger (05.07.2016 19:04:52): output raw (8 bytes)
logger (05.07.2016 19:04:52): output raw (10 bytes)
logger (05.07.2016 19:04:52): filter on
logger (05.07.2016 19:04:52): rx threshold set to -90db
logger (05.07.2016 19:04:52): listening to transmitter 1
logger (05.07.2016 19:04:52): bandwidth narrow
logger (05.07.2016 19:04:52): chip authentication ok: 14
logger (05.07.2016 19:04:52): frequency band 868MHz (EU)
logger (05.07.2016 19:05:29): parent process received termination signal (15).
logger (05.07.2016 19:05:29): child process received termination signal (15).
logger (05.07.2016 19:05:29): disconnect station 0 (Meteostick Vantage): exit
logger (05.07.2016 19:05:29): disconnect station 9 (System Data): exit
logger (05.07.2016 19:05:29): data logger stopped.
database (05.07.2016 19:05:30): process terminated normally.
test5m (05.07.2016 19:05:30): USB storage remounted: /dev/sda
database (05.07.2016 19:05:30): process started.
logger (05.07.2016 19:05:30): database connected.
logger (05.07.2016 19:05:30): Historical data loaded (32 records).
logger (05.07.2016 19:05:30): data logger (version 5.0q, build 10043) started.
logger (05.07.2016 19:05:31): connect station 0 (Meteostick Vantage via USB serial).
logger (05.07.2016 19:05:31): connect station 9 (System Data via Plug-in).
logger (05.07.2016 19:05:33): transmitter 1 registered as ISS
logger (05.07.2016 19:05:33): Meteostick Version 2.4
logger (05.07.2016 19:05:33): debug off
logger (05.07.2016 19:05:33): verbose off
logger (05.07.2016 19:05:33): output raw (8 bytes)
logger (05.07.2016 19:05:33): output raw (10 bytes)
logger (05.07.2016 19:05:33): filter on
logger (05.07.2016 19:05:33): rx threshold set to -90db
logger (05.07.2016 19:05:33): listening to transmitter 1
logger (05.07.2016 19:05:33): bandwidth narrow
logger (05.07.2016 19:05:33): chip authentication ok: 14
logger (05.07.2016 19:05:33): frequency band 868MHz (EU)
logger (05.07.2016 19:11:16): parent process received termination signal (15).
logger (05.07.2016 19:11:16): child process received termination signal (15).
logger (05.07.2016 19:11:16): disconnect station 0 (Meteostick Vantage): exit
logger (05.07.2016 19:11:16): disconnect station 9 (System Data): exit
logger (05.07.2016 19:11:16): data logger stopped.
database (05.07.2016 19:11:16): process terminated normally.
test5m (05.07.2016 19:11:17): USB storage remounted: /dev/sda
database (05.07.2016 19:11:17): process started.
logger (05.07.2016 19:11:17): database connected.
logger (05.07.2016 19:11:17): Historical data loaded (45 records).
logger (05.07.2016 19:11:17): data logger (version 5.0q, build 10043) started.
logger (05.07.2016 19:11:18): connect station 0 (Meteostick Vantage via USB serial).
logger (05.07.2016 19:11:18): connect station 9 (System Data via Plug-in).
logger (05.07.2016 19:11:20): transmitter 1 registered as ISS
logger (05.07.2016 19:11:20): Meteostick Version 2.4
logger (05.07.2016 19:11:20): debug off
logger (05.07.2016 19:11:20): verbose off
logger (05.07.2016 19:11:20): output raw (8 bytes)
logger (05.07.2016 19:11:20): output raw (10 bytes)
logger (05.07.2016 19:11:20): filter on
logger (05.07.2016 19:11:20): rx threshold set to -90db
logger (05.07.2016 19:11:20): listening to transmitter 1
logger (05.07.2016 19:11:20): bandwidth narrow
logger (05.07.2016 19:11:21): chip authentication ok: 14
logger (05.07.2016 19:11:21): frequency band 868MHz (EU)
logger (05.07.2016 19:15:17): parent process received termination signal (15).
logger (05.07.2016 19:15:17): child process received termination signal (15).
logger (05.07.2016 19:15:17): disconnect station 0 (Meteostick Vantage): exit
logger (05.07.2016 19:15:17): disconnect station 9 (System Data): exit
logger (05.07.2016 19:15:17): data logger stopped.
database (05.07.2016 19:15:18): process terminated normally.
test5m (05.07.2016 19:15:19): USB storage remounted: /dev/sda
database (05.07.2016 19:15:19): process started.
logger (05.07.2016 19:15:19): database connected.
logger (05.07.2016 19:15:49): database connected.
logger (05.07.2016 19:16:19): database connected.
logger (05.07.2016 19:16:49): database connected.
logger (05.07.2016 19:17:19): database connected.
logger (05.07.2016 19:17:49): database connected.
logger (05.07.2016 19:18:19): database connected.
logger (05.07.2016 19:18:49): database connected.
logger (05.07.2016 19:19:19): database connected.
logger (05.07.2016 19:19:49): database connected.
logger (05.07.2016 19:20:12): parent process received termination signal (15).
database (05.07.2016 19:20:13): process terminated normally.
test5m (05.07.2016 19:20:13): USB storage remounted: /dev/sda
database (05.07.2016 19:20:14): process started.
logger (05.07.2016 19:20:14): database connected.
logger (05.07.2016 19:20:44): database connected.
logger (05.07.2016 19:21:14): database connected.
logger (05.07.2016 19:21:44): database connected.
logger (05.07.2016 19:22:14): database connected.
logger (05.07.2016 19:22:44): database connected.
logger (05.07.2016 19:23:14): database connected.
logger (05.07.2016 19:23:44): database connected.
logger (05.07.2016 19:24:14): database connected.
logger (05.07.2016 19:24:44): database connected.
logger (05.07.2016 19:25:14): database connected.
logger (05.07.2016 19:25:44): database connected.
logger (05.07.2016 19:26:09): parent process received termination signal (15).
database (05.07.2016 19:26:09): process terminated normally.
test5m (05.07.2016 19:26:09): USB storage remounted: /dev/sda
database (05.07.2016 19:26:09): process started.
logger (05.07.2016 19:26:10): database connected.
logger (05.07.2016 19:26:40): database connected.
logger (05.07.2016 19:27:10): database connected.
logger (05.07.2016 19:27:40): database connected.
logger (05.07.2016 19:28:10): database connected.
logger (05.07.2016 19:28:40): database connected.
logger (05.07.2016 19:29:10): database connected.
logger (05.07.2016 19:29:40): database connected.
logger (05.07.2016 19:30:08): parent process received termination signal (15).
database (05.07.2016 19:30:09): process terminated normally.
test5m (05.07.2016 19:30:10): USB storage remounted: /dev/sda
database (05.07.2016 19:30:10): process started.
logger (05.07.2016 19:30:10): database connected.
logger (05.07.2016 19:30:40): database connected.
logger (05.07.2016 19:31:10): database connected.
logger (05.07.2016 19:31:40): database connected.
logger (05.07.2016 19:32:10): database connected.
logger (05.07.2016 19:32:40): database connected.
logger (05.07.2016 19:33:10): database connected.
logger (05.07.2016 19:33:40): database connected.
logger (05.07.2016 19:34:10): database connected.
logger (05.07.2016 19:34:40): database connected.
logger (05.07.2016 19:35:10): database connected.
logger (05.07.2016 19:35:40): database connected.
logger (05.07.2016 19:36:10): database connected.
logger (05.07.2016 19:36:30): parent process received termination signal (15).
database (05.07.2016 19:36:31): process terminated normally.
test5m (05.07.2016 19:36:32): USB storage remounted: /dev/sda
database (05.07.2016 19:36:32): process started.
logger (05.07.2016 19:36:32): database connected.
logger (05.07.2016 19:37:02): database connected.
logger (05.07.2016 19:37:32): database connected.
logger (05.07.2016 19:38:02): database connected.
logger (05.07.2016 19:38:32): database connected.
logger (05.07.2016 19:39:02): database connected.
logger (05.07.2016 19:39:32): database connected.
logger (05.07.2016 19:40:02): database connected.
logger (05.07.2016 19:40:32): database connected.
logger (05.07.2016 19:41:02): database connected.
logger (05.07.2016 19:41:10): parent process received termination signal (15).
database (05.07.2016 19:41:11): process terminated normally.
test5m (05.07.2016 19:41:12): USB storage remounted: /dev/sda
database (05.07.2016 19:41:12): process started.
logger (05.07.2016 19:41:12): database connected.
logger (05.07.2016 19:41:42): database connected.
logger (05.07.2016 19:42:12): database connected.
logger (05.07.2016 19:42:42): database connected.
logger (05.07.2016 19:43:12): database connected.
logger (05.07.2016 19:43:42): database connected.
logger (05.07.2016 19:44:12): database connected.
logger (05.07.2016 19:44:42): database connected.
logger (05.07.2016 19:45:12): database connected.
logger (05.07.2016 19:45:42): database connected.
logger (05.07.2016 19:46:12): database connected.
logger (05.07.2016 19:46:38): parent process received termination signal (15).
database (05.07.2016 19:46:38): process terminated normally.
test5m (05.07.2016 19:46:39): USB storage remounted: /dev/sda
database (05.07.2016 19:46:39): process started.
logger (05.07.2016 19:46:39): database connected.
logger (05.07.2016 19:47:09): database connected.
logger (05.07.2016 19:47:39): database connected.
logger (05.07.2016 19:48:09): database connected.
logger (05.07.2016 19:48:39): database connected.
logger (05.07.2016 19:49:09): database connected.
logger (05.07.2016 19:49:39): database connected.
logger (05.07.2016 19:50:09): database connected.
logger (05.07.2016 19:50:39): database connected.
logger (05.07.2016 19:51:09): database connected.
logger (05.07.2016 19:51:29): parent process received termination signal (15).
database (05.07.2016 19:51:29): process terminated normally.
test5m (05.07.2016 19:51:30): USB storage remounted: /dev/sda
database (05.07.2016 19:51:30): process started.
logger (05.07.2016 19:51:30): database connected.
logger (05.07.2016 19:52:00): database connected.
logger (05.07.2016 19:52:30): database connected.
logger (05.07.2016 19:53:00): database connected.
logger (05.07.2016 19:53:30): database connected.
logger (05.07.2016 19:54:00): database connected.
logger (05.07.2016 19:54:30): database connected.
logger (05.07.2016 19:55:00): database connected.
logger (05.07.2016 19:55:30): database connected.
logger (05.07.2016 19:56:00): database connected.
logger (05.07.2016 19:56:00): parent process received termination signal (15).
database (05.07.2016 19:56:01): process terminated normally.
test5m (05.07.2016 19:56:02): USB storage remounted: /dev/sda
database (05.07.2016 19:56:02): process started.
logger (05.07.2016 19:56:02): database connected.
logger (05.07.2016 19:56:32): database connected.
logger (05.07.2016 19:57:02): database connected.
logger (05.07.2016 19:57:32): database connected.
logger (05.07.2016 19:58:02): database connected.
logger (05.07.2016 19:58:32): database connected.
logger (05.07.2016 19:59:02): database connected.
logger (05.07.2016 19:59:32): database connected.
logger (05.07.2016 20:00:02): database connected.
logger (05.07.2016 20:00:32): database connected.
logger (05.07.2016 20:00:39): parent process received termination signal (15).
database (05.07.2016 20:00:41): process terminated normally.
test5m (05.07.2016 20:00:41): USB storage remounted: /dev/sda
database (05.07.2016 20:00:41): process started.
logger (05.07.2016 20:00:41): database connected.
logger (05.07.2016 20:01:11): database connected.
logger (05.07.2016 20:01:41): database connected.
logger (05.07.2016 20:02:11): database connected.
logger (05.07.2016 20:02:41): database connected.
logger (05.07.2016 20:03:11): database connected.
logger (05.07.2016 20:03:41): database connected.
logger (05.07.2016 20:04:11): database connected.
logger (05.07.2016 20:04:41): database connected.
logger (05.07.2016 20:05:11): database connected.
logger (05.07.2016 20:05:41): database connected.
logger (05.07.2016 20:06:11): database connected.
logger (05.07.2016 20:06:11): parent process received termination signal (15).
database (05.07.2016 20:06:11): process terminated normally.
test5m (05.07.2016 20:06:12): USB storage remounted: /dev/sda
database (05.07.2016 20:06:12): process started.
logger (05.07.2016 20:06:12): database connected.
logger (05.07.2016 20:06:42): database connected.
logger (05.07.2016 20:07:12): database connected.
logger (05.07.2016 20:07:42): database connected.
logger (05.07.2016 20:08:12): database connected.
logger (05.07.2016 20:08:42): database connected.
logger (05.07.2016 20:09:12): database connected.
logger (05.07.2016 20:09:42): database connected.
logger (05.07.2016 20:10:05): parent process received termination signal (15).
database (05.07.2016 20:10:06): process terminated normally.
test5m (05.07.2016 20:10:06): USB storage remounted: /dev/sda
database (05.07.2016 20:10:06): process started.
logger (05.07.2016 20:10:06): database connected.
logger (05.07.2016 20:10:36): database connected.
logger (05.07.2016 20:11:06): database connected.
logger (05.07.2016 20:11:36): database connected.
logger (05.07.2016 20:12:06): database connected.
logger (05.07.2016 20:12:36): database connected.
logger (05.07.2016 20:13:06): database connected.
logger (05.07.2016 20:13:36): database connected.
logger (05.07.2016 20:14:06): database connected.
logger (05.07.2016 20:14:36): database connected.
logger (05.07.2016 20:15:06): database connected.
logger (05.07.2016 20:15:36): database connected.
logger (05.07.2016 20:16:06): database connected.
logger (05.07.2016 20:16:09): parent process received termination signal (15).
database (05.07.2016 20:16:11): process terminated normally.
test5m (05.07.2016 20:16:12): USB storage remounted: /dev/sda
database (05.07.2016 20:16:12): process started.
logger (05.07.2016 20:16:12): database connected.
logger (05.07.2016 20:16:42): database connected.
logger (05.07.2016 20:17:12): database connected.
logger (05.07.2016 20:17:42): database connected.
logger (05.07.2016 20:18:12): database connected.
logger (05.07.2016 20:18:42): database connected.
logger (05.07.2016 20:19:12): database connected.
logger (05.07.2016 20:19:42): database connected.
logger (05.07.2016 20:20:12): database connected.
logger (05.07.2016 20:20:25): parent process received termination signal (15).
database (05.07.2016 20:20:27): process terminated normally.
test5m (05.07.2016 20:20:28): USB storage remounted: /dev/sda
database (05.07.2016 20:20:28): process started.
logger (05.07.2016 20:20:28): database connected.
logger (05.07.2016 20:20:58): database connected.
logger (05.07.2016 20:21:28): database connected.
logger (05.07.2016 20:21:58): database connected.
logger (05.07.2016 20:22:28): database connected.
logger (05.07.2016 20:22:58): database connected.
logger (05.07.2016 20:23:28): database connected.
logger (05.07.2016 20:23:58): database connected.
logger (05.07.2016 20:24:28): database connected.
logger (05.07.2016 20:24:58): database connected.
logger (05.07.2016 20:25:28): database connected.
logger (05.07.2016 20:25:58): database connected.
logger (05.07.2016 20:26:28): database connected.
logger (05.07.2016 20:26:34): parent process received termination signal (15).
database (05.07.2016 20:26:36): process terminated normally.
test5m (05.07.2016 20:26:36): USB storage remounted: /dev/sda
database (05.07.2016 20:26:36): process started.
logger (05.07.2016 20:26:36): database connected.
logger (05.07.2016 20:27:06): database connected.
logger (05.07.2016 20:27:36): database connected.
logger (05.07.2016 20:28:06): database connected.
logger (05.07.2016 20:28:36): database connected.
logger (05.07.2016 20:29:06): database connected.
logger (05.07.2016 20:29:36): database connected.
Re: Not stable from firmware 2.9
This message does not look good to me and might indicate a storage problem:
The cascade of these messages should be gone with new version 3.0. Please do a reboot to grab the new code:
meteoharderwijk
I updated to the last firmware, but i have the same problem.
Systeem
Platform: Meteobridge PRO
RAM: 61500 kB totaal, 19888 kB beschikbaar (67% gebruikt)
SW Version: Meteobridge 3.0 (Jul 6 2016, build 10055), FW 1.4
Tijd beschikbaar: 0 uren, 10 minuten Buffer:
Power Data: 5.51V 339mA 1.87W (Box Climate: 49.4°C 13%)
oled (06.07.2016 17:23:09): process started.
database (06.07.2016 19:24:34): process started.
wnetd (06.07.2016 19:24:34): process started.
logger (06.07.2016 19:24:35): database connected.
logger (06.07.2016 19:24:35): Historical data loaded (0 records).
logger (06.07.2016 19:24:35): data logger (version 5.0q, build 10055) started.
logger (06.07.2016 19:24:36): connect station 0 (Meteostick Vantage via USB serial).
logger (06.07.2016 19:24:36): connect station 9 (System Data via Plug-in).
logger (06.07.2016 19:24:38): transmitter 1 registered as ISS
logger (06.07.2016 19:24:38): Meteostick Version 2.4
logger (06.07.2016 19:24:38): debug off
logger (06.07.2016 19:24:38): verbose off
logger (06.07.2016 19:24:38): output raw (8 bytes)
logger (06.07.2016 19:24:38): output raw (10 bytes)
logger (06.07.2016 19:24:38): filter on
logger (06.07.2016 19:24:38): rx threshold set to -90db
logger (06.07.2016 19:24:38): listening to transmitter 1
logger (06.07.2016 19:24:38): bandwidth narrow
logger (06.07.2016 19:24:39): chip authentication ok: 14
logger (06.07.2016 19:24:39): frequency band 868MHz (EU)
logger (06.07.2016 19:24:42): parent process received termination signal (15).
logger (06.07.2016 19:24:42): child process received termination signal (15).
logger (06.07.2016 19:24:42): disconnect station 0 (Meteostick Vantage): exit
logger (06.07.2016 19:24:42): disconnect station 9 (System Data): exit
database (06.07.2016 19:24:42): process terminated normally.
test5m (06.07.2016 19:24:42): USB storage remounted: /dev/sda
database (06.07.2016 19:24:42): process started.
logger (06.07.2016 19:24:43): database connected.
logger (06.07.2016 19:24:43): Historical data loaded (0 records).
logger (06.07.2016 19:24:43): data logger (version 5.0q, build 10055) started.
logger (06.07.2016 19:24:43): error while doing bind (port 5557): Address already in use
logger (06.07.2016 19:24:43): data logger stopped.
logger (06.07.2016 19:24:44): data logger stopped.
logger (06.07.2016 19:25:13): database connected.
logger (06.07.2016 19:25:13): Historical data loaded (0 records).
logger (06.07.2016 19:25:13): data logger (version 5.0q, build 10055) started.
logger (06.07.2016 19:25:14): connect station 0 (Meteostick Vantage via USB serial).
logger (06.07.2016 19:25:14): connect station 9 (System Data via Plug-in).
logger (06.07.2016 19:25:16): transmitter 1 registered as ISS
logger (06.07.2016 19:25:16): Meteostick Version 2.4
logger (06.07.2016 19:25:16): debug off
logger (06.07.2016 19:25:16): verbose off
logger (06.07.2016 19:25:16): output raw (8 bytes)
logger (06.07.2016 19:25:16): output raw (10 bytes)
logger (06.07.2016 19:25:16): filter on
logger (06.07.2016 19:25:16): rx threshold set to -90db
logger (06.07.2016 19:25:16): listening to transmitter 1
logger (06.07.2016 19:25:16): bandwidth narrow
logger (06.07.2016 19:25:16): chip authentication ok: 14
logger (06.07.2016 19:25:16): frequency band 868MHz (EU)
logger (06.07.2016 19:25:28): parent process received termination signal (15).
logger (06.07.2016 19:25:28): child process received termination signal (15).
logger (06.07.2016 19:25:28): disconnect station 0 (Meteostick Vantage): exit
logger (06.07.2016 19:25:28): disconnect station 9 (System Data): exit
database (06.07.2016 19:25:29): process terminated normally.
test5m (06.07.2016 19:25:29): USB storage remounted: /dev/sda
database (06.07.2016 19:25:29): process started.
logger (06.07.2016 19:25:29): database connected.
logger (06.07.2016 19:25:29): Historical data loaded (0 records).
logger (06.07.2016 19:25:29): data logger (version 5.0q, build 10055) started.
logger (06.07.2016 19:25:29): error while doing bind (port 5557): Address already in use
logger (06.07.2016 19:25:29): killed process "3046/loggerd" listening to port 5556.
logger (06.07.2016 19:25:29): data logger stopped.
logger (06.07.2016 19:25:59): database connected.
logger (06.07.2016 19:25:59): Historical data loaded (0 records).
logger (06.07.2016 19:25:59): data logger (version 5.0q, build 10055) started.
logger (06.07.2016 19:26:00): connect station 0 (Meteostick Vantage via USB serial).
logger (06.07.2016 19:26:00): connect station 9 (System Data via Plug-in).
logger (06.07.2016 19:26:02): transmitter 1 registered as ISS
logger (06.07.2016 19:26:02): Meteostick Version 2.4
logger (06.07.2016 19:26:02): debug off
logger (06.07.2016 19:26:02): verbose off
logger (06.07.2016 19:26:02): output raw (8 bytes)
logger (06.07.2016 19:26:02): output raw (10 bytes)
logger (06.07.2016 19:26:02): filter on
logger (06.07.2016 19:26:02): rx threshold set to -90db
logger (06.07.2016 19:26:02): listening to transmitter 1
logger (06.07.2016 19:26:02): bandwidth narrow
logger (06.07.2016 19:26:02): chip authentication ok: 14
logger (06.07.2016 19:26:02): frequency band 868MHz (EU)
logger (06.07.2016 19:30:07): parent process received termination signal (15).
logger (06.07.2016 19:30:07): child process received termination signal (15).
logger (06.07.2016 19:30:07): disconnect station 0 (Meteostick Vantage): exit
logger (06.07.2016 19:30:08): disconnect station 9 (System Data): exit
database (06.07.2016 19:30:08): process terminated normally.
logger (06.07.2016 19:30:08): data logger stopped.
test5m (06.07.2016 19:30:09): USB storage remounted: /dev/sda
database (06.07.2016 19:30:09): process started.
logger (06.07.2016 19:30:09): database connected.
logger (06.07.2016 19:30:39): database connected.
logger (06.07.2016 19:31:09): database connected.
logger (06.07.2016 19:31:39): database connected.
logger (06.07.2016 19:32:09): database connected.
Can you please browse to "http://ip-of-your-meteobridge/cgi-bin/system.cgi?dmesg" and paste the returned log file into this thread?
meteoharderwijk
command: dmesg
[25687.880000] sd 87:0:0:0: Attached scsi generic sg0 type 0
[25687.880000] sd 87:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[25687.890000] sd 87:0:0:0: [sda] Write Protect is on
[25687.900000] sd 87:0:0:0: [sda] Mode Sense: 23 00 80 00
[25687.900000] sd 87:0:0:0: [sda] No Caching mode page found
[25687.910000] sd 87:0:0:0: [sda] Assuming drive cache: write through
[25687.920000] sd 87:0:0:0: [sda] No Caching mode page found
[25687.920000] sd 87:0:0:0: [sda] Assuming drive cache: write through
[25687.930000] sda: unknown partition table
[25687.940000] sd 87:0:0:0: [sda] No Caching mode page found
[25687.940000] sd 87:0:0:0: [sda] Assuming drive cache: write through
[25687.950000] sd 87:0:0:0: [sda] Attached SCSI removable disk
[25691.160000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[25691.170000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[25691.180000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[25691.190000] EXT4-fs (sda): write access unavailable, cannot proceed
[25938.840000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[25938.840000] scsi88 : usb-storage 1-1.4:1.0
[25939.850000] scsi 88:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[25939.860000] sd 88:0:0:0: Attached scsi generic sg0 type 0
[25939.860000] sd 88:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[25939.870000] sd 88:0:0:0: [sda] Write Protect is on
[25939.880000] sd 88:0:0:0: [sda] Mode Sense: 23 00 80 00
[25939.880000] sd 88:0:0:0: [sda] No Caching mode page found
[25939.890000] sd 88:0:0:0: [sda] Assuming drive cache: write through
[25939.900000] sd 88:0:0:0: [sda] No Caching mode page found
[25939.900000] sd 88:0:0:0: [sda] Assuming drive cache: write through
[25939.910000] sda: unknown partition table
[25939.920000] sd 88:0:0:0: [sda] No Caching mode page found
[25939.920000] sd 88:0:0:0: [sda] Assuming drive cache: write through
[25939.930000] sd 88:0:0:0: [sda] Attached SCSI removable disk
[25942.120000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[25942.130000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[25942.150000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[25942.150000] EXT4-fs (sda): write access unavailable, cannot proceed
[26260.870000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[26260.870000] scsi89 : usb-storage 1-1.4:1.0
[26261.880000] scsi 89:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[26261.890000] sd 89:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[26261.900000] sd 89:0:0:0: Attached scsi generic sg0 type 0
[26261.900000] sd 89:0:0:0: [sda] Write Protect is on
[26261.910000] sd 89:0:0:0: [sda] Mode Sense: 23 00 80 00
[26261.910000] sd 89:0:0:0: [sda] No Caching mode page found
[26261.920000] sd 89:0:0:0: [sda] Assuming drive cache: write through
[26261.930000] sd 89:0:0:0: [sda] No Caching mode page found
[26261.930000] sd 89:0:0:0: [sda] Assuming drive cache: write through
[26261.940000] sda: unknown partition table
[26261.950000] sd 89:0:0:0: [sda] No Caching mode page found
[26261.950000] sd 89:0:0:0: [sda] Assuming drive cache: write through
[26261.960000] sd 89:0:0:0: [sda] Attached SCSI removable disk
[26265.170000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[26265.180000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[26265.190000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[26265.190000] EXT4-fs (sda): write access unavailable, cannot proceed
[26528.890000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[26528.890000] scsi90 : usb-storage 1-1.4:1.0
[26529.900000] scsi 90:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[26529.910000] sd 90:0:0:0: Attached scsi generic sg0 type 0
[26529.910000] sd 90:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[26529.920000] sd 90:0:0:0: [sda] Write Protect is on
[26529.930000] sd 90:0:0:0: [sda] Mode Sense: 23 00 80 00
[26529.930000] sd 90:0:0:0: [sda] No Caching mode page found
[26529.940000] sd 90:0:0:0: [sda] Assuming drive cache: write through
[26529.950000] sd 90:0:0:0: [sda] No Caching mode page found
[26529.950000] sd 90:0:0:0: [sda] Assuming drive cache: write through
[26529.960000] sda: unknown partition table
[26529.970000] sd 90:0:0:0: [sda] No Caching mode page found
[26529.970000] sd 90:0:0:0: [sda] Assuming drive cache: write through
[26529.980000] sd 90:0:0:0: [sda] Attached SCSI removable disk
[26533.190000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[26533.190000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[26533.210000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[26533.210000] EXT4-fs (sda): write access unavailable, cannot proceed
[26900.880000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[26900.880000] scsi91 : usb-storage 1-1.4:1.0
[26901.890000] scsi 91:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[26901.900000] sd 91:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[26901.910000] sd 91:0:0:0: Attached scsi generic sg0 type 0
[26901.910000] sd 91:0:0:0: [sda] Write Protect is on
[26901.920000] sd 91:0:0:0: [sda] Mode Sense: 23 00 80 00
[26901.920000] sd 91:0:0:0: [sda] No Caching mode page found
[26901.930000] sd 91:0:0:0: [sda] Assuming drive cache: write through
[26901.940000] sd 91:0:0:0: [sda] No Caching mode page found
[26901.940000] sd 91:0:0:0: [sda] Assuming drive cache: write through
[26901.950000] sda: unknown partition table
[26901.960000] sd 91:0:0:0: [sda] No Caching mode page found
[26901.960000] sd 91:0:0:0: [sda] Assuming drive cache: write through
[26901.970000] sd 91:0:0:0: [sda] Attached SCSI removable disk
[26904.160000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[26904.170000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[26904.180000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[26904.190000] EXT4-fs (sda): write access unavailable, cannot proceed
[27152.870000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[27152.870000] scsi92 : usb-storage 1-1.4:1.0
[27153.880000] scsi 92:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[27153.890000] sd 92:0:0:0: Attached scsi generic sg0 type 0
[27153.890000] sd 92:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[27153.900000] sd 92:0:0:0: [sda] Write Protect is on
[27153.910000] sd 92:0:0:0: [sda] Mode Sense: 23 00 80 00
[27153.910000] sd 92:0:0:0: [sda] No Caching mode page found
[27153.920000] sd 92:0:0:0: [sda] Assuming drive cache: write through
[27153.930000] sd 92:0:0:0: [sda] No Caching mode page found
[27153.930000] sd 92:0:0:0: [sda] Assuming drive cache: write through
[27153.940000] sda: unknown partition table
[27153.950000] sd 92:0:0:0: [sda] No Caching mode page found
[27153.950000] sd 92:0:0:0: [sda] Assuming drive cache: write through
[27153.960000] sd 92:0:0:0: [sda] Attached SCSI removable disk
[27157.170000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[27157.180000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[27157.190000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[27157.190000] EXT4-fs (sda): write access unavailable, cannot proceed
[27496.920000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[27496.920000] scsi93 : usb-storage 1-1.4:1.0
[27497.930000] scsi 93:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[27497.940000] sd 93:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[27497.950000] sd 93:0:0:0: Attached scsi generic sg0 type 0
[27497.950000] sd 93:0:0:0: [sda] Write Protect is on
[27497.960000] sd 93:0:0:0: [sda] Mode Sense: 23 00 80 00
[27497.960000] sd 93:0:0:0: [sda] No Caching mode page found
[27497.970000] sd 93:0:0:0: [sda] Assuming drive cache: write through
[27497.980000] sd 93:0:0:0: [sda] No Caching mode page found
[27497.980000] sd 93:0:0:0: [sda] Assuming drive cache: write through
[27497.990000] sda: unknown partition table
[27498.000000] sd 93:0:0:0: [sda] No Caching mode page found
[27498.000000] sd 93:0:0:0: [sda] Assuming drive cache: write through
[27498.010000] sd 93:0:0:0: [sda] Attached SCSI removable disk
[27501.210000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[27501.220000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[27501.240000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[27501.240000] EXT4-fs (sda): write access unavailable, cannot proceed
[27706.890000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[27706.890000] scsi94 : usb-storage 1-1.4:1.0
[27707.900000] scsi 94:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[27707.910000] sd 94:0:0:0: Attached scsi generic sg0 type 0
[27707.910000] sd 94:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[27707.920000] sd 94:0:0:0: [sda] Write Protect is on
[27707.930000] sd 94:0:0:0: [sda] Mode Sense: 23 00 80 00
[27707.930000] sd 94:0:0:0: [sda] No Caching mode page found
[27707.940000] sd 94:0:0:0: [sda] Assuming drive cache: write through
[27707.950000] sd 94:0:0:0: [sda] No Caching mode page found
[27707.950000] sd 94:0:0:0: [sda] Assuming drive cache: write through
[27707.960000] sda: unknown partition table
[27707.970000] sd 94:0:0:0: [sda] No Caching mode page found
[27707.970000] sd 94:0:0:0: [sda] Assuming drive cache: write through
[27707.980000] sd 94:0:0:0: [sda] Attached SCSI removable disk
[27711.190000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[27711.190000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[27711.210000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[27711.210000] EXT4-fs (sda): write access unavailable, cannot proceed
[28076.930000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[28076.930000] scsi95 : usb-storage 1-1.4:1.0
[28077.940000] scsi 95:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[28077.950000] sd 95:0:0:0: Attached scsi generic sg0 type 0
[28077.950000] sd 95:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[28077.960000] sd 95:0:0:0: [sda] Write Protect is on
[28077.970000] sd 95:0:0:0: [sda] Mode Sense: 23 00 80 00
[28077.970000] sd 95:0:0:0: [sda] No Caching mode page found
[28077.980000] sd 95:0:0:0: [sda] Assuming drive cache: write through
[28077.990000] sd 95:0:0:0: [sda] No Caching mode page found
[28077.990000] sd 95:0:0:0: [sda] Assuming drive cache: write through
[28078.000000] sda: unknown partition table
[28078.010000] sd 95:0:0:0: [sda] No Caching mode page found
[28078.010000] sd 95:0:0:0: [sda] Assuming drive cache: write through
[28078.020000] sd 95:0:0:0: [sda] Attached SCSI removable disk
[28081.230000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[28081.230000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[28081.250000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[28081.250000] EXT4-fs (sda): write access unavailable, cannot proceed
[28320.930000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[28320.930000] scsi96 : usb-storage 1-1.4:1.0
[28321.940000] scsi 96:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[28321.950000] sd 96:0:0:0: Attached scsi generic sg0 type 0
[28321.950000] sd 96:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[28321.960000] sd 96:0:0:0: [sda] Write Protect is on
[28321.970000] sd 96:0:0:0: [sda] Mode Sense: 23 00 80 00
[28321.970000] sd 96:0:0:0: [sda] No Caching mode page found
[28321.980000] sd 96:0:0:0: [sda] Assuming drive cache: write through
[28321.990000] sd 96:0:0:0: [sda] No Caching mode page found
[28321.990000] sd 96:0:0:0: [sda] Assuming drive cache: write through
[28322.000000] sda: unknown partition table
[28322.010000] sd 96:0:0:0: [sda] No Caching mode page found
[28322.010000] sd 96:0:0:0: [sda] Assuming drive cache: write through
[28322.020000] sd 96:0:0:0: [sda] Attached SCSI removable disk
[28325.220000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[28325.230000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[28325.250000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[28325.250000] EXT4-fs (sda): write access unavailable, cannot proceed
[28651.940000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[28651.940000] scsi97 : usb-storage 1-1.4:1.0
[28652.950000] scsi 97:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[28652.960000] sd 97:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[28652.970000] sd 97:0:0:0: Attached scsi generic sg0 type 0
[28652.970000] sd 97:0:0:0: [sda] Write Protect is on
[28652.980000] sd 97:0:0:0: [sda] Mode Sense: 23 00 80 00
[28652.980000] sd 97:0:0:0: [sda] No Caching mode page found
[28652.990000] sd 97:0:0:0: [sda] Assuming drive cache: write through
[28653.000000] sd 97:0:0:0: [sda] No Caching mode page found
[28653.000000] sd 97:0:0:0: [sda] Assuming drive cache: write through
[28653.010000] sda: unknown partition table
[28653.020000] sd 97:0:0:0: [sda] No Caching mode page found
[28653.020000] sd 97:0:0:0: [sda] Assuming drive cache: write through
[28653.030000] sd 97:0:0:0: [sda] Attached SCSI removable disk
[28656.240000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[28656.250000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[28656.260000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[28656.260000] EXT4-fs (sda): write access unavailable, cannot proceed
[28995.920000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[28995.920000] scsi98 : usb-storage 1-1.4:1.0
[28996.930000] scsi 98:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[28996.940000] sd 98:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[28996.950000] sd 98:0:0:0: Attached scsi generic sg0 type 0
[28996.950000] sd 98:0:0:0: [sda] Write Protect is on
[28996.960000] sd 98:0:0:0: [sda] Mode Sense: 23 00 80 00
[28996.960000] sd 98:0:0:0: [sda] No Caching mode page found
[28996.970000] sd 98:0:0:0: [sda] Assuming drive cache: write through
[28996.980000] sd 98:0:0:0: [sda] No Caching mode page found
[28996.980000] sd 98:0:0:0: [sda] Assuming drive cache: write through
[28996.990000] sda: unknown partition table
[28997.000000] sd 98:0:0:0: [sda] No Caching mode page found
[28997.000000] sd 98:0:0:0: [sda] Assuming drive cache: write through
[28997.010000] sd 98:0:0:0: [sda] Attached SCSI removable disk
[29000.220000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[29000.220000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[29000.240000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[29000.240000] EXT4-fs (sda): write access unavailable, cannot proceed
[29239.980000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[29239.980000] scsi99 : usb-storage 1-1.4:1.0
[29240.990000] scsi 99:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[29241.000000] sd 99:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[29241.010000] sd 99:0:0:0: Attached scsi generic sg0 type 0
[29241.010000] sd 99:0:0:0: [sda] Write Protect is on
[29241.020000] sd 99:0:0:0: [sda] Mode Sense: 23 00 80 00
[29241.020000] sd 99:0:0:0: [sda] No Caching mode page found
[29241.030000] sd 99:0:0:0: [sda] Assuming drive cache: write through
[29241.040000] sd 99:0:0:0: [sda] No Caching mode page found
[29241.040000] sd 99:0:0:0: [sda] Assuming drive cache: write through
[29241.050000] sda: unknown partition table
[29241.070000] sd 99:0:0:0: [sda] No Caching mode page found
[29241.070000] sd 99:0:0:0: [sda] Assuming drive cache: write through
[29241.080000] sd 99:0:0:0: [sda] Attached SCSI removable disk
[29243.260000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[29243.270000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[29243.280000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[29243.290000] EXT4-fs (sda): write access unavailable, cannot proceed
[29533.960000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[29533.960000] scsi100 : usb-storage 1-1.4:1.0
[29534.970000] scsi 100:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[29534.980000] sd 100:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[29534.990000] sd 100:0:0:0: Attached scsi generic sg0 type 0
[29534.990000] sd 100:0:0:0: [sda] Write Protect is on
[29535.000000] sd 100:0:0:0: [sda] Mode Sense: 23 00 80 00
[29535.000000] sd 100:0:0:0: [sda] No Caching mode page found
[29535.010000] sd 100:0:0:0: [sda] Assuming drive cache: write through
[29535.020000] sd 100:0:0:0: [sda] No Caching mode page found
[29535.020000] sd 100:0:0:0: [sda] Assuming drive cache: write through
[29535.030000] sda: unknown partition table
[29535.050000] sd 100:0:0:0: [sda] No Caching mode page found
[29535.050000] sd 100:0:0:0: [sda] Assuming drive cache: write through
[29535.060000] sd 100:0:0:0: [sda] Attached SCSI removable disk
[29539.270000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[29539.280000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[29539.300000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[29539.300000] EXT4-fs (sda): write access unavailable, cannot proceed
[29864.990000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[29864.990000] scsi101 : usb-storage 1-1.4:1.0
[29866.000000] scsi 101:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[29866.010000] sd 101:0:0:0: Attached scsi generic sg0 type 0
[29866.010000] sd 101:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[29866.020000] sd 101:0:0:0: [sda] Write Protect is on
[29866.030000] sd 101:0:0:0: [sda] Mode Sense: 23 00 80 00
[29866.030000] sd 101:0:0:0: [sda] No Caching mode page found
[29866.040000] sd 101:0:0:0: [sda] Assuming drive cache: write through
[29866.050000] sd 101:0:0:0: [sda] No Caching mode page found
[29866.050000] sd 101:0:0:0: [sda] Assuming drive cache: write through
[29866.060000] sda: unknown partition table
[29866.080000] sd 101:0:0:0: [sda] No Caching mode page found
[29866.080000] sd 101:0:0:0: [sda] Assuming drive cache: write through
[29866.090000] sd 101:0:0:0: [sda] Attached SCSI removable disk
[29868.270000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[29868.280000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[29868.290000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[29868.300000] EXT4-fs (sda): write access unavailable, cannot proceed
[30192.000000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[30192.000000] scsi102 : usb-storage 1-1.4:1.0
[30193.010000] scsi 102:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[30193.020000] sd 102:0:0:0: Attached scsi generic sg0 type 0
[30193.020000] sd 102:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[30193.030000] sd 102:0:0:0: [sda] Write Protect is on
[30193.040000] sd 102:0:0:0: [sda] Mode Sense: 23 00 80 00
[30193.040000] sd 102:0:0:0: [sda] No Caching mode page found
[30193.050000] sd 102:0:0:0: [sda] Assuming drive cache: write through
[30193.060000] sd 102:0:0:0: [sda] No Caching mode page found
[30193.060000] sd 102:0:0:0: [sda] Assuming drive cache: write through
[30193.070000] sda: unknown partition table
[30193.090000] sd 102:0:0:0: [sda] No Caching mode page found
[30193.090000] sd 102:0:0:0: [sda] Assuming drive cache: write through
[30193.100000] sd 102:0:0:0: [sda] Attached SCSI removable disk
[30196.300000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[30196.310000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[30196.320000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[30196.320000] EXT4-fs (sda): write access unavailable, cannot proceed
[30503.010000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[30503.010000] scsi103 : usb-storage 1-1.4:1.0
[30504.020000] scsi 103:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[30504.030000] sd 103:0:0:0: Attached scsi generic sg0 type 0
[30504.030000] sd 103:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[30504.040000] sd 103:0:0:0: [sda] Write Protect is on
[30504.050000] sd 103:0:0:0: [sda] Mode Sense: 23 00 80 00
[30504.050000] sd 103:0:0:0: [sda] No Caching mode page found
[30504.060000] sd 103:0:0:0: [sda] Assuming drive cache: write through
[30504.070000] sd 103:0:0:0: [sda] No Caching mode page found
[30504.070000] sd 103:0:0:0: [sda] Assuming drive cache: write through
[30504.080000] sda: unknown partition table
[30504.090000] sd 103:0:0:0: [sda] No Caching mode page found
[30504.090000] sd 103:0:0:0: [sda] Assuming drive cache: write through
[30504.100000] sd 103:0:0:0: [sda] Attached SCSI removable disk
[30507.310000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[30507.310000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[30507.330000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[30507.330000] EXT4-fs (sda): write access unavailable, cannot proceed
[30721.010000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[30721.010000] scsi104 : usb-storage 1-1.4:1.0
[30722.020000] scsi 104:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[30722.030000] sd 104:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[30722.040000] sd 104:0:0:0: Attached scsi generic sg0 type 0
[30722.040000] sd 104:0:0:0: [sda] Write Protect is on
[30722.050000] sd 104:0:0:0: [sda] Mode Sense: 23 00 80 00
[30722.050000] sd 104:0:0:0: [sda] No Caching mode page found
[30722.060000] sd 104:0:0:0: [sda] Assuming drive cache: write through
[30722.070000] sd 104:0:0:0: [sda] No Caching mode page found
[30722.070000] sd 104:0:0:0: [sda] Assuming drive cache: write through
[30722.080000] sda: unknown partition table
[30722.100000] sd 104:0:0:0: [sda] No Caching mode page found
[30722.100000] sd 104:0:0:0: [sda] Assuming drive cache: write through
[30722.110000] sd 104:0:0:0: [sda] Attached SCSI removable disk
[30724.300000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[30724.300000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[30724.320000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[30724.320000] EXT4-fs (sda): write access unavailable, cannot proceed
[31076.050000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[31076.050000] scsi105 : usb-storage 1-1.4:1.0
[31077.060000] scsi 105:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[31077.070000] sd 105:0:0:0: Attached scsi generic sg0 type 0
[31077.070000] sd 105:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[31077.080000] sd 105:0:0:0: [sda] Write Protect is on
[31077.090000] sd 105:0:0:0: [sda] Mode Sense: 23 00 80 00
[31077.090000] sd 105:0:0:0: [sda] No Caching mode page found
[31077.100000] sd 105:0:0:0: [sda] Assuming drive cache: write through
[31077.110000] sd 105:0:0:0: [sda] No Caching mode page found
[31077.110000] sd 105:0:0:0: [sda] Assuming drive cache: write through
[31077.120000] sda: unknown partition table
[31077.140000] sd 105:0:0:0: [sda] No Caching mode page found
[31077.140000] sd 105:0:0:0: [sda] Assuming drive cache: write through
[31077.150000] sd 105:0:0:0: [sda] Attached SCSI removable disk
[31079.330000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[31079.340000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[31079.350000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[31079.360000] EXT4-fs (sda): write access unavailable, cannot proceed
[31316.020000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[31316.020000] scsi106 : usb-storage 1-1.4:1.0
[31317.030000] scsi 106:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[31317.040000] sd 106:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[31317.050000] sd 106:0:0:0: Attached scsi generic sg0 type 0
[31317.050000] sd 106:0:0:0: [sda] Write Protect is on
[31317.060000] sd 106:0:0:0: [sda] Mode Sense: 23 00 80 00
[31317.060000] sd 106:0:0:0: [sda] No Caching mode page found
[31317.070000] sd 106:0:0:0: [sda] Assuming drive cache: write through
[31317.080000] sd 106:0:0:0: [sda] No Caching mode page found
[31317.080000] sd 106:0:0:0: [sda] Assuming drive cache: write through
[31317.090000] sda: unknown partition table
[31317.110000] sd 106:0:0:0: [sda] No Caching mode page found
[31317.110000] sd 106:0:0:0: [sda] Assuming drive cache: write through
[31317.120000] sd 106:0:0:0: [sda] Attached SCSI removable disk
[31320.320000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[31320.330000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[31320.340000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[31320.350000] EXT4-fs (sda): write access unavailable, cannot proceed
[31672.040000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[31672.040000] scsi107 : usb-storage 1-1.4:1.0
[31673.050000] scsi 107:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[31673.060000] sd 107:0:0:0: Attached scsi generic sg0 type 0
[31673.060000] sd 107:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[31673.070000] sd 107:0:0:0: [sda] Write Protect is on
[31673.080000] sd 107:0:0:0: [sda] Mode Sense: 23 00 80 00
[31673.080000] sd 107:0:0:0: [sda] No Caching mode page found
[31673.090000] sd 107:0:0:0: [sda] Assuming drive cache: write through
[31673.100000] sd 107:0:0:0: [sda] No Caching mode page found
[31673.100000] sd 107:0:0:0: [sda] Assuming drive cache: write through
[31673.110000] sda: unknown partition table
[31673.130000] sd 107:0:0:0: [sda] No Caching mode page found
[31673.130000] sd 107:0:0:0: [sda] Assuming drive cache: write through
[31673.140000] sd 107:0:0:0: [sda] Attached SCSI removable disk
[31676.340000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[31676.350000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[31676.360000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[31676.360000] EXT4-fs (sda): write access unavailable, cannot proceed
[31971.050000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[31971.050000] scsi108 : usb-storage 1-1.4:1.0
[31972.060000] scsi 108:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[31972.070000] sd 108:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[31972.080000] sd 108:0:0:0: Attached scsi generic sg0 type 0
[31972.080000] sd 108:0:0:0: [sda] Write Protect is on
[31972.090000] sd 108:0:0:0: [sda] Mode Sense: 23 00 80 00
[31972.090000] sd 108:0:0:0: [sda] No Caching mode page found
[31972.100000] sd 108:0:0:0: [sda] Assuming drive cache: write through
[31972.110000] sd 108:0:0:0: [sda] No Caching mode page found
[31972.110000] sd 108:0:0:0: [sda] Assuming drive cache: write through
[31972.120000] sda: unknown partition table
[31972.140000] sd 108:0:0:0: [sda] No Caching mode page found
[31972.140000] sd 108:0:0:0: [sda] Assuming drive cache: write through
[31972.150000] sd 108:0:0:0: [sda] Attached SCSI removable disk
[31975.340000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[31975.350000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[31975.370000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[31975.370000] EXT4-fs (sda): write access unavailable, cannot proceed
[32252.070000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[32252.070000] scsi109 : usb-storage 1-1.4:1.0
[32253.080000] scsi 109:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[32253.090000] sd 109:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[32253.100000] sd 109:0:0:0: Attached scsi generic sg0 type 0
[32253.100000] sd 109:0:0:0: [sda] Write Protect is on
[32253.110000] sd 109:0:0:0: [sda] Mode Sense: 23 00 80 00
[32253.110000] sd 109:0:0:0: [sda] No Caching mode page found
[32253.120000] sd 109:0:0:0: [sda] Assuming drive cache: write through
[32253.130000] sd 109:0:0:0: [sda] No Caching mode page found
[32253.130000] sd 109:0:0:0: [sda] Assuming drive cache: write through
[32253.140000] sda: unknown partition table
[32253.160000] sd 109:0:0:0: [sda] No Caching mode page found
[32253.160000] sd 109:0:0:0: [sda] Assuming drive cache: write through
[32253.170000] sd 109:0:0:0: [sda] Attached SCSI removable disk
[32255.350000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[32255.360000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[32255.380000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[32255.380000] EXT4-fs (sda): write access unavailable, cannot proceed
[32553.040000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[32553.040000] scsi110 : usb-storage 1-1.4:1.0
[32554.050000] scsi 110:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[32554.060000] sd 110:0:0:0: Attached scsi generic sg0 type 0
[32554.060000] sd 110:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[32554.070000] sd 110:0:0:0: [sda] Write Protect is on
[32554.080000] sd 110:0:0:0: [sda] Mode Sense: 23 00 80 00
[32554.080000] sd 110:0:0:0: [sda] No Caching mode page found
[32554.090000] sd 110:0:0:0: [sda] Assuming drive cache: write through
[32554.100000] sd 110:0:0:0: [sda] No Caching mode page found
[32554.100000] sd 110:0:0:0: [sda] Assuming drive cache: write through
[32554.110000] sda: unknown partition table
[32554.130000] sd 110:0:0:0: [sda] No Caching mode page found
[32554.130000] sd 110:0:0:0: [sda] Assuming drive cache: write through
[32554.140000] sd 110:0:0:0: [sda] Attached SCSI removable disk
[32556.320000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[32556.330000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[32556.340000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[32556.350000] EXT4-fs (sda): write access unavailable, cannot proceed
[32846.090000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[32846.090000] scsi111 : usb-storage 1-1.4:1.0
[32847.100000] scsi 111:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[32847.110000] sd 111:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[32847.120000] sd 111:0:0:0: Attached scsi generic sg0 type 0
[32847.120000] sd 111:0:0:0: [sda] Write Protect is on
[32847.130000] sd 111:0:0:0: [sda] Mode Sense: 23 00 80 00
[32847.130000] sd 111:0:0:0: [sda] No Caching mode page found
[32847.140000] sd 111:0:0:0: [sda] Assuming drive cache: write through
[32847.150000] sd 111:0:0:0: [sda] No Caching mode page found
[32847.150000] sd 111:0:0:0: [sda] Assuming drive cache: write through
[32847.160000] sda: unknown partition table
[32847.180000] sd 111:0:0:0: [sda] No Caching mode page found
[32847.180000] sd 111:0:0:0: [sda] Assuming drive cache: write through
[32847.190000] sd 111:0:0:0: [sda] Attached SCSI removable disk
[32850.390000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[32850.400000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[32850.410000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[32850.420000] EXT4-fs (sda): write access unavailable, cannot proceed
[33112.060000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[33112.060000] scsi112 : usb-storage 1-1.4:1.0
[33113.070000] scsi 112:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[33113.080000] sd 112:0:0:0: Attached scsi generic sg0 type 0
[33113.080000] sd 112:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[33113.090000] sd 112:0:0:0: [sda] Write Protect is on
[33113.100000] sd 112:0:0:0: [sda] Mode Sense: 23 00 80 00
[33113.100000] sd 112:0:0:0: [sda] No Caching mode page found
[33113.110000] sd 112:0:0:0: [sda] Assuming drive cache: write through
[33113.120000] sd 112:0:0:0: [sda] No Caching mode page found
[33113.120000] sd 112:0:0:0: [sda] Assuming drive cache: write through
[33113.130000] sda: unknown partition table
[33113.150000] sd 112:0:0:0: [sda] No Caching mode page found
[33113.150000] sd 112:0:0:0: [sda] Assuming drive cache: write through
[33113.160000] sd 112:0:0:0: [sda] Attached SCSI removable disk
[33116.360000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[33116.370000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[33116.380000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[33116.390000] EXT4-fs (sda): write access unavailable, cannot proceed
[33489.100000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[33489.100000] scsi113 : usb-storage 1-1.4:1.0
[33490.110000] scsi 113:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[33490.120000] sd 113:0:0:0: Attached scsi generic sg0 type 0
[33490.120000] sd 113:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[33490.130000] sd 113:0:0:0: [sda] Write Protect is on
[33490.140000] sd 113:0:0:0: [sda] Mode Sense: 23 00 80 00
[33490.140000] sd 113:0:0:0: [sda] No Caching mode page found
[33490.150000] sd 113:0:0:0: [sda] Assuming drive cache: write through
[33490.160000] sd 113:0:0:0: [sda] No Caching mode page found
[33490.160000] sd 113:0:0:0: [sda] Assuming drive cache: write through
[33490.170000] sda: unknown partition table
[33490.180000] sd 113:0:0:0: [sda] No Caching mode page found
[33490.180000] sd 113:0:0:0: [sda] Assuming drive cache: write through
[33490.190000] sd 113:0:0:0: [sda] Attached SCSI removable disk
[33493.400000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[33493.400000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[33493.420000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[33493.420000] EXT4-fs (sda): write access unavailable, cannot proceed
[33772.100000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[33772.100000] scsi114 : usb-storage 1-1.4:1.0
[33773.110000] scsi 114:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[33773.120000] sd 114:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[33773.130000] sd 114:0:0:0: Attached scsi generic sg0 type 0
[33773.130000] sd 114:0:0:0: [sda] Write Protect is on
[33773.140000] sd 114:0:0:0: [sda] Mode Sense: 23 00 80 00
[33773.140000] sd 114:0:0:0: [sda] No Caching mode page found
[33773.150000] sd 114:0:0:0: [sda] Assuming drive cache: write through
[33773.160000] sd 114:0:0:0: [sda] No Caching mode page found
[33773.160000] sd 114:0:0:0: [sda] Assuming drive cache: write through
[33773.170000] sda: unknown partition table
[33773.190000] sd 114:0:0:0: [sda] No Caching mode page found
[33773.190000] sd 114:0:0:0: [sda] Assuming drive cache: write through
[33773.200000] sd 114:0:0:0: [sda] Attached SCSI removable disk
[33775.390000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[33775.400000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[33775.410000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[33775.410000] EXT4-fs (sda): write access unavailable, cannot proceed
[34101.110000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[34101.110000] scsi115 : usb-storage 1-1.4:1.0
[34102.120000] scsi 115:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[34102.130000] sd 115:0:0:0: Attached scsi generic sg0 type 0
[34102.130000] sd 115:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[34102.140000] sd 115:0:0:0: [sda] Write Protect is on
[34102.150000] sd 115:0:0:0: [sda] Mode Sense: 23 00 80 00
[34102.150000] sd 115:0:0:0: [sda] No Caching mode page found
[34102.160000] sd 115:0:0:0: [sda] Assuming drive cache: write through
[34102.170000] sd 115:0:0:0: [sda] No Caching mode page found
[34102.170000] sd 115:0:0:0: [sda] Assuming drive cache: write through
[34102.180000] sda: unknown partition table
[34102.200000] sd 115:0:0:0: [sda] No Caching mode page found
[34102.200000] sd 115:0:0:0: [sda] Assuming drive cache: write through
[34102.210000] sd 115:0:0:0: [sda] Attached SCSI removable disk
[34105.400000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[34105.410000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[34105.430000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[34105.430000] EXT4-fs (sda): write access unavailable, cannot proceed
[34401.090000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[34401.090000] scsi116 : usb-storage 1-1.4:1.0
[34402.100000] scsi 116:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[34402.110000] sd 116:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[34402.120000] sd 116:0:0:0: Attached scsi generic sg0 type 0
[34402.120000] sd 116:0:0:0: [sda] Write Protect is on
[34402.130000] sd 116:0:0:0: [sda] Mode Sense: 23 00 80 00
[34402.130000] sd 116:0:0:0: [sda] No Caching mode page found
[34402.140000] sd 116:0:0:0: [sda] Assuming drive cache: write through
[34402.150000] sd 116:0:0:0: [sda] No Caching mode page found
[34402.150000] sd 116:0:0:0: [sda] Assuming drive cache: write through
[34402.160000] sda: unknown partition table
[34402.180000] sd 116:0:0:0: [sda] No Caching mode page found
[34402.180000] sd 116:0:0:0: [sda] Assuming drive cache: write through
[34402.190000] sd 116:0:0:0: [sda] Attached SCSI removable disk
[34404.370000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[34404.380000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[34404.400000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[34404.400000] EXT4-fs (sda): write access unavailable, cannot proceed
[34654.160000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[34654.160000] scsi117 : usb-storage 1-1.4:1.0
[34655.170000] scsi 117:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[34655.180000] sd 117:0:0:0: Attached scsi generic sg0 type 0
[34655.180000] sd 117:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[34655.190000] sd 117:0:0:0: [sda] Write Protect is on
[34655.200000] sd 117:0:0:0: [sda] Mode Sense: 23 00 80 00
[34655.200000] sd 117:0:0:0: [sda] No Caching mode page found
[34655.210000] sd 117:0:0:0: [sda] Assuming drive cache: write through
[34655.220000] sd 117:0:0:0: [sda] No Caching mode page found
[34655.220000] sd 117:0:0:0: [sda] Assuming drive cache: write through
[34655.230000] sda: unknown partition table
[34655.240000] sd 117:0:0:0: [sda] No Caching mode page found
[34655.240000] sd 117:0:0:0: [sda] Assuming drive cache: write through
[34655.250000] sd 117:0:0:0: [sda] Attached SCSI removable disk
[34657.440000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[34657.450000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[34657.470000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[34657.470000] EXT4-fs (sda): write access unavailable, cannot proceed
[34942.130000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[34942.130000] scsi118 : usb-storage 1-1.4:1.0
[34943.140000] scsi 118:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[34943.150000] sd 118:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[34943.160000] sd 118:0:0:0: Attached scsi generic sg0 type 0
[34943.160000] sd 118:0:0:0: [sda] Write Protect is on
[34943.170000] sd 118:0:0:0: [sda] Mode Sense: 23 00 80 00
[34943.170000] sd 118:0:0:0: [sda] No Caching mode page found
[34943.180000] sd 118:0:0:0: [sda] Assuming drive cache: write through
[34943.190000] sd 118:0:0:0: [sda] No Caching mode page found
[34943.190000] sd 118:0:0:0: [sda] Assuming drive cache: write through
[34943.200000] sda: unknown partition table
[34943.220000] sd 118:0:0:0: [sda] No Caching mode page found
[34943.220000] sd 118:0:0:0: [sda] Assuming drive cache: write through
[34943.230000] sd 118:0:0:0: [sda] Attached SCSI removable disk
[34946.430000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[34946.440000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[34946.450000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[34946.450000] EXT4-fs (sda): write access unavailable, cannot proceed
[35287.150000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[35287.150000] scsi119 : usb-storage 1-1.4:1.0
[35288.160000] scsi 119:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[35288.170000] sd 119:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[35288.180000] sd 119:0:0:0: Attached scsi generic sg0 type 0
[35288.180000] sd 119:0:0:0: [sda] Write Protect is on
[35288.190000] sd 119:0:0:0: [sda] Mode Sense: 23 00 80 00
[35288.190000] sd 119:0:0:0: [sda] No Caching mode page found
[35288.200000] sd 119:0:0:0: [sda] Assuming drive cache: write through
[35288.210000] sd 119:0:0:0: [sda] No Caching mode page found
[35288.210000] sd 119:0:0:0: [sda] Assuming drive cache: write through
[35288.220000] sda: unknown partition table
[35288.240000] sd 119:0:0:0: [sda] No Caching mode page found
[35288.240000] sd 119:0:0:0: [sda] Assuming drive cache: write through
[35288.250000] sd 119:0:0:0: [sda] Attached SCSI removable disk
[35291.440000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[35291.450000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[35291.470000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[35291.470000] EXT4-fs (sda): write access unavailable, cannot proceed
[35550.170000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[35550.170000] scsi120 : usb-storage 1-1.4:1.0
[35551.180000] scsi 120:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[35551.190000] sd 120:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[35551.200000] sd 120:0:0:0: Attached scsi generic sg0 type 0
[35551.200000] sd 120:0:0:0: [sda] Write Protect is on
[35551.210000] sd 120:0:0:0: [sda] Mode Sense: 23 00 80 00
[35551.210000] sd 120:0:0:0: [sda] No Caching mode page found
[35551.220000] sd 120:0:0:0: [sda] Assuming drive cache: write through
[35551.230000] sd 120:0:0:0: [sda] No Caching mode page found
[35551.230000] sd 120:0:0:0: [sda] Assuming drive cache: write through
[35551.240000] sda: unknown partition table
[35551.260000] sd 120:0:0:0: [sda] No Caching mode page found
[35551.260000] sd 120:0:0:0: [sda] Assuming drive cache: write through
[35551.270000] sd 120:0:0:0: [sda] Attached SCSI removable disk
[35554.470000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[35554.480000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[35554.490000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[35554.500000] EXT4-fs (sda): write access unavailable, cannot proceed
[35905.190000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[35905.190000] scsi121 : usb-storage 1-1.4:1.0
[35906.200000] scsi 121:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[35906.210000] sd 121:0:0:0: Attached scsi generic sg0 type 0
[35906.210000] sd 121:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[35906.220000] sd 121:0:0:0: [sda] Write Protect is on
[35906.230000] sd 121:0:0:0: [sda] Mode Sense: 23 00 80 00
[35906.230000] sd 121:0:0:0: [sda] No Caching mode page found
[35906.240000] sd 121:0:0:0: [sda] Assuming drive cache: write through
[35906.250000] sd 121:0:0:0: [sda] No Caching mode page found
[35906.250000] sd 121:0:0:0: [sda] Assuming drive cache: write through
[35906.260000] sda: unknown partition table
[35906.280000] sd 121:0:0:0: [sda] No Caching mode page found
[35906.280000] sd 121:0:0:0: [sda] Assuming drive cache: write through
[35906.290000] sd 121:0:0:0: [sda] Attached SCSI removable disk
[35908.470000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[35908.480000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[35908.490000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[35908.500000] EXT4-fs (sda): write access unavailable, cannot proceed
[36204.170000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[36204.170000] scsi122 : usb-storage 1-1.4:1.0
[36205.180000] scsi 122:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[36205.190000] sd 122:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[36205.200000] sd 122:0:0:0: Attached scsi generic sg0 type 0
[36205.200000] sd 122:0:0:0: [sda] Write Protect is on
[36205.210000] sd 122:0:0:0: [sda] Mode Sense: 23 00 80 00
[36205.210000] sd 122:0:0:0: [sda] No Caching mode page found
[36205.220000] sd 122:0:0:0: [sda] Assuming drive cache: write through
[36205.230000] sd 122:0:0:0: [sda] No Caching mode page found
[36205.230000] sd 122:0:0:0: [sda] Assuming drive cache: write through
[36205.240000] sda: unknown partition table
[36205.260000] sd 122:0:0:0: [sda] No Caching mode page found
[36205.260000] sd 122:0:0:0: [sda] Assuming drive cache: write through
[36205.270000] sd 122:0:0:0: [sda] Attached SCSI removable disk
[36207.450000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[36207.460000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[36207.480000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[36207.480000] EXT4-fs (sda): write access unavailable, cannot proceed
[36457.240000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[36457.240000] scsi123 : usb-storage 1-1.4:1.0
[36458.250000] scsi 123:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[36458.260000] sd 123:0:0:0: Attached scsi generic sg0 type 0
[36458.260000] sd 123:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[36458.270000] sd 123:0:0:0: [sda] Write Protect is on
[36458.280000] sd 123:0:0:0: [sda] Mode Sense: 23 00 80 00
[36458.280000] sd 123:0:0:0: [sda] No Caching mode page found
[36458.290000] sd 123:0:0:0: [sda] Assuming drive cache: write through
[36458.300000] sd 123:0:0:0: [sda] No Caching mode page found
[36458.300000] sd 123:0:0:0: [sda] Assuming drive cache: write through
[36458.310000] sda: unknown partition table
[36458.320000] sd 123:0:0:0: [sda] No Caching mode page found
[36458.320000] sd 123:0:0:0: [sda] Assuming drive cache: write through
[36458.330000] sd 123:0:0:0: [sda] Attached SCSI removable disk
[36461.540000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[36461.550000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[36461.560000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[36461.570000] EXT4-fs (sda): write access unavailable, cannot proceed
[36746.210000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[36746.210000] scsi124 : usb-storage 1-1.4:1.0
[36747.220000] scsi 124:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[36747.230000] sd 124:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[36747.240000] sd 124:0:0:0: Attached scsi generic sg0 type 0
[36747.240000] sd 124:0:0:0: [sda] Write Protect is on
[36747.250000] sd 124:0:0:0: [sda] Mode Sense: 23 00 80 00
[36747.250000] sd 124:0:0:0: [sda] No Caching mode page found
[36747.260000] sd 124:0:0:0: [sda] Assuming drive cache: write through
[36747.270000] sd 124:0:0:0: [sda] No Caching mode page found
[36747.270000] sd 124:0:0:0: [sda] Assuming drive cache: write through
[36747.280000] sda: unknown partition table
[36747.300000] sd 124:0:0:0: [sda] No Caching mode page found
[36747.300000] sd 124:0:0:0: [sda] Assuming drive cache: write through
[36747.310000] sd 124:0:0:0: [sda] Attached SCSI removable disk
[36750.510000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[36750.520000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[36750.530000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[36750.530000] EXT4-fs (sda): write access unavailable, cannot proceed
[37090.240000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[37090.240000] scsi125 : usb-storage 1-1.4:1.0
[37091.250000] scsi 125:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[37091.260000] sd 125:0:0:0: Attached scsi generic sg0 type 0
[37091.260000] sd 125:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[37091.270000] sd 125:0:0:0: [sda] Write Protect is on
[37091.280000] sd 125:0:0:0: [sda] Mode Sense: 23 00 80 00
[37091.280000] sd 125:0:0:0: [sda] No Caching mode page found
[37091.290000] sd 125:0:0:0: [sda] Assuming drive cache: write through
[37091.300000] sd 125:0:0:0: [sda] No Caching mode page found
[37091.300000] sd 125:0:0:0: [sda] Assuming drive cache: write through
[37091.310000] sda: unknown partition table
[37091.330000] sd 125:0:0:0: [sda] No Caching mode page found
[37091.330000] sd 125:0:0:0: [sda] Assuming drive cache: write through
[37091.340000] sd 125:0:0:0: [sda] Attached SCSI removable disk
[37094.530000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[37094.540000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[37094.560000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[37094.560000] EXT4-fs (sda): write access unavailable, cannot proceed
[37325.260000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[37325.260000] scsi126 : usb-storage 1-1.4:1.0
[37326.270000] scsi 126:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[37326.280000] sd 126:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[37326.290000] sd 126:0:0:0: Attached scsi generic sg0 type 0
[37326.290000] sd 126:0:0:0: [sda] Write Protect is on
[37326.300000] sd 126:0:0:0: [sda] Mode Sense: 23 00 80 00
[37326.300000] sd 126:0:0:0: [sda] No Caching mode page found
[37326.310000] sd 126:0:0:0: [sda] Assuming drive cache: write through
[37326.320000] sd 126:0:0:0: [sda] No Caching mode page found
[37326.320000] sd 126:0:0:0: [sda] Assuming drive cache: write through
[37326.330000] sda: unknown partition table
[37326.350000] sd 126:0:0:0: [sda] No Caching mode page found
[37326.350000] sd 126:0:0:0: [sda] Assuming drive cache: write through
[37326.360000] sd 126:0:0:0: [sda] Attached SCSI removable disk
[37328.540000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[37328.550000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[37328.570000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[37328.570000] EXT4-fs (sda): write access unavailable, cannot proceed
[37682.250000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[37682.250000] scsi127 : usb-storage 1-1.4:1.0
[37683.260000] scsi 127:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[37683.270000] sd 127:0:0:0: Attached scsi generic sg0 type 0
[37683.270000] sd 127:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[37683.280000] sd 127:0:0:0: [sda] Write Protect is on
[37683.290000] sd 127:0:0:0: [sda] Mode Sense: 23 00 80 00
[37683.290000] sd 127:0:0:0: [sda] No Caching mode page found
[37683.300000] sd 127:0:0:0: [sda] Assuming drive cache: write through
[37683.310000] sd 127:0:0:0: [sda] No Caching mode page found
[37683.310000] sd 127:0:0:0: [sda] Assuming drive cache: write through
[37683.320000] sda: unknown partition table
[37683.330000] sd 127:0:0:0: [sda] No Caching mode page found
[37683.330000] sd 127:0:0:0: [sda] Assuming drive cache: write through
[37683.340000] sd 127:0:0:0: [sda] Attached SCSI removable disk
[37686.550000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[37686.550000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[37686.570000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[37686.570000] EXT4-fs (sda): write access unavailable, cannot proceed
[37991.260000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[37991.260000] scsi128 : usb-storage 1-1.4:1.0
[37992.270000] scsi 128:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[37992.280000] sd 128:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[37992.290000] sd 128:0:0:0: Attached scsi generic sg0 type 0
[37992.290000] sd 128:0:0:0: [sda] Write Protect is on
[37992.300000] sd 128:0:0:0: [sda] Mode Sense: 23 00 80 00
[37992.300000] sd 128:0:0:0: [sda] No Caching mode page found
[37992.310000] sd 128:0:0:0: [sda] Assuming drive cache: write through
[37992.320000] sd 128:0:0:0: [sda] No Caching mode page found
[37992.320000] sd 128:0:0:0: [sda] Assuming drive cache: write through
[37992.330000] sda: unknown partition table
[37992.350000] sd 128:0:0:0: [sda] No Caching mode page found
[37992.350000] sd 128:0:0:0: [sda] Assuming drive cache: write through
[37992.360000] sd 128:0:0:0: [sda] Attached SCSI removable disk
[37995.560000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[37995.570000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[37995.580000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[37995.580000] EXT4-fs (sda): write access unavailable, cannot proceed
[38218.310000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[38218.310000] scsi129 : usb-storage 1-1.4:1.0
[38219.320000] scsi 129:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[38219.330000] sd 129:0:0:0: Attached scsi generic sg0 type 0
[38219.330000] sd 129:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[38219.340000] sd 129:0:0:0: [sda] Write Protect is on
[38219.350000] sd 129:0:0:0: [sda] Mode Sense: 23 00 80 00
[38219.350000] sd 129:0:0:0: [sda] No Caching mode page found
[38219.360000] sd 129:0:0:0: [sda] Assuming drive cache: write through
[38219.370000] sd 129:0:0:0: [sda] No Caching mode page found
[38219.370000] sd 129:0:0:0: [sda] Assuming drive cache: write through
[38219.380000] sda: unknown partition table
[38219.390000] sd 129:0:0:0: [sda] No Caching mode page found
[38219.390000] sd 129:0:0:0: [sda] Assuming drive cache: write through
[38219.400000] sd 129:0:0:0: [sda] Attached SCSI removable disk
[38223.620000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[38223.630000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[38223.640000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[38223.650000] EXT4-fs (sda): write access unavailable, cannot proceed
[38545.280000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[38545.280000] scsi130 : usb-storage 1-1.4:1.0
[38546.290000] scsi 130:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[38546.300000] sd 130:0:0:0: Attached scsi generic sg0 type 0
[38546.300000] sd 130:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[38546.310000] sd 130:0:0:0: [sda] Write Protect is on
[38546.320000] sd 130:0:0:0: [sda] Mode Sense: 23 00 80 00
[38546.320000] sd 130:0:0:0: [sda] No Caching mode page found
[38546.330000] sd 130:0:0:0: [sda] Assuming drive cache: write through
[38546.340000] sd 130:0:0:0: [sda] No Caching mode page found
[38546.340000] sd 130:0:0:0: [sda] Assuming drive cache: write through
[38546.350000] sda: unknown partition table
[38546.370000] sd 130:0:0:0: [sda] No Caching mode page found
[38546.370000] sd 130:0:0:0: [sda] Assuming drive cache: write through
[38546.380000] sd 130:0:0:0: [sda] Attached SCSI removable disk
[38549.570000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[38549.580000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[38549.600000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[38549.600000] EXT4-fs (sda): write access unavailable, cannot proceed
[38831.290000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[38831.290000] scsi131 : usb-storage 1-1.4:1.0
[38832.300000] scsi 131:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[38832.310000] sd 131:0:0:0: Attached scsi generic sg0 type 0
[38832.310000] sd 131:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[38832.320000] sd 131:0:0:0: [sda] Write Protect is on
[38832.330000] sd 131:0:0:0: [sda] Mode Sense: 23 00 80 00
[38832.330000] sd 131:0:0:0: [sda] No Caching mode page found
[38832.340000] sd 131:0:0:0: [sda] Assuming drive cache: write through
[38832.350000] sd 131:0:0:0: [sda] No Caching mode page found
[38832.350000] sd 131:0:0:0: [sda] Assuming drive cache: write through
[38832.360000] sda: unknown partition table
[38832.370000] sd 131:0:0:0: [sda] No Caching mode page found
[38832.370000] sd 131:0:0:0: [sda] Assuming drive cache: write through
[38832.380000] sd 131:0:0:0: [sda] Attached SCSI removable disk
[38835.580000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[38835.590000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[38835.600000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[38835.610000] EXT4-fs (sda): write access unavailable, cannot proceed
[39140.310000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[39140.310000] scsi132 : usb-storage 1-1.4:1.0
[39141.320000] scsi 132:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[39141.330000] sd 132:0:0:0: Attached scsi generic sg0 type 0
[39141.330000] sd 132:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[39141.340000] sd 132:0:0:0: [sda] Write Protect is on
[39141.350000] sd 132:0:0:0: [sda] Mode Sense: 23 00 80 00
[39141.350000] sd 132:0:0:0: [sda] No Caching mode page found
[39141.360000] sd 132:0:0:0: [sda] Assuming drive cache: write through
[39141.370000] sd 132:0:0:0: [sda] No Caching mode page found
[39141.370000] sd 132:0:0:0: [sda] Assuming drive cache: write through
meteoharderwijk
Re: Not stable from firmware 2.9
Post by meteoharderwijk »
[39141.380000] sda: unknown partition table
[39141.400000] sd 132:0:0:0: [sda] No Caching mode page found
[39141.400000] sd 132:0:0:0: [sda] Assuming drive cache: write through
[39141.410000] sd 132:0:0:0: [sda] Attached SCSI removable disk
[39144.600000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[39144.610000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[39144.630000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[39144.630000] EXT4-fs (sda): write access unavailable, cannot proceed
[39453.300000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[39453.300000] scsi133 : usb-storage 1-1.4:1.0
[39454.310000] scsi 133:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[39454.320000] sd 133:0:0:0: Attached scsi generic sg0 type 0
[39454.320000] sd 133:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[39454.330000] sd 133:0:0:0: [sda] Write Protect is on
[39454.340000] sd 133:0:0:0: [sda] Mode Sense: 23 00 80 00
[39454.340000] sd 133:0:0:0: [sda] No Caching mode page found
[39454.350000] sd 133:0:0:0: [sda] Assuming drive cache: write through
[39454.360000] sd 133:0:0:0: [sda] No Caching mode page found
[39454.360000] sd 133:0:0:0: [sda] Assuming drive cache: write through
[39454.370000] sda: unknown partition table
[39454.390000] sd 133:0:0:0: [sda] No Caching mode page found
[39454.390000] sd 133:0:0:0: [sda] Assuming drive cache: write through
[39454.400000] sd 133:0:0:0: [sda] Attached SCSI removable disk
[39457.590000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[39457.600000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[39457.620000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[39457.620000] EXT4-fs (sda): write access unavailable, cannot proceed
[39736.290000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[39736.290000] scsi134 : usb-storage 1-1.4:1.0
[39737.300000] scsi 134:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[39737.310000] sd 134:0:0:0: Attached scsi generic sg0 type 0
[39737.310000] sd 134:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[39737.320000] sd 134:0:0:0: [sda] Write Protect is on
[39737.330000] sd 134:0:0:0: [sda] Mode Sense: 23 00 80 00
[39737.330000] sd 134:0:0:0: [sda] No Caching mode page found
[39737.340000] sd 134:0:0:0: [sda] Assuming drive cache: write through
[39737.350000] sd 134:0:0:0: [sda] No Caching mode page found
[39737.350000] sd 134:0:0:0: [sda] Assuming drive cache: write through
[39737.360000] sda: unknown partition table
[39737.370000] sd 134:0:0:0: [sda] No Caching mode page found
[39737.370000] sd 134:0:0:0: [sda] Assuming drive cache: write through
[39737.380000] sd 134:0:0:0: [sda] Attached SCSI removable disk
[39740.590000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[39740.600000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[39740.610000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[39740.610000] EXT4-fs (sda): write access unavailable, cannot proceed
[40036.340000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[40036.340000] scsi135 : usb-storage 1-1.4:1.0
[40037.350000] scsi 135:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[40037.360000] sd 135:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[40037.370000] sd 135:0:0:0: Attached scsi generic sg0 type 0
[40037.370000] sd 135:0:0:0: [sda] Write Protect is on
[40037.380000] sd 135:0:0:0: [sda] Mode Sense: 23 00 80 00
[40037.380000] sd 135:0:0:0: [sda] No Caching mode page found
[40037.390000] sd 135:0:0:0: [sda] Assuming drive cache: write through
[40037.400000] sd 135:0:0:0: [sda] No Caching mode page found
[40037.400000] sd 135:0:0:0: [sda] Assuming drive cache: write through
[40037.410000] sda: unknown partition table
[40037.430000] sd 135:0:0:0: [sda] No Caching mode page found
[40037.430000] sd 135:0:0:0: [sda] Assuming drive cache: write through
[40037.440000] sd 135:0:0:0: [sda] Attached SCSI removable disk
[40040.640000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[40040.650000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[40040.660000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[40040.670000] EXT4-fs (sda): write access unavailable, cannot proceed
[40329.310000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[40329.310000] scsi136 : usb-storage 1-1.4:1.0
[40330.320000] scsi 136:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[40330.330000] sd 136:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[40330.340000] sd 136:0:0:0: Attached scsi generic sg0 type 0
[40330.340000] sd 136:0:0:0: [sda] Write Protect is on
[40330.350000] sd 136:0:0:0: [sda] Mode Sense: 23 00 80 00
[40330.350000] sd 136:0:0:0: [sda] No Caching mode page found
[40330.360000] sd 136:0:0:0: [sda] Assuming drive cache: write through
[40330.370000] sd 136:0:0:0: [sda] No Caching mode page found
[40330.370000] sd 136:0:0:0: [sda] Assuming drive cache: write through
[40330.380000] sda: unknown partition table
[40330.400000] sd 136:0:0:0: [sda] No Caching mode page found
[40330.400000] sd 136:0:0:0: [sda] Assuming drive cache: write through
[40330.410000] sd 136:0:0:0: [sda] Attached SCSI removable disk
[40333.610000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[40333.620000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[40333.630000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[40333.640000] EXT4-fs (sda): write access unavailable, cannot proceed
[40615.340000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[40615.340000] scsi137 : usb-storage 1-1.4:1.0
[40616.350000] scsi 137:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[40616.360000] sd 137:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[40616.370000] sd 137:0:0:0: Attached scsi generic sg0 type 0
[40616.370000] sd 137:0:0:0: [sda] Write Protect is on
[40616.380000] sd 137:0:0:0: [sda] Mode Sense: 23 00 80 00
[40616.380000] sd 137:0:0:0: [sda] No Caching mode page found
[40616.390000] sd 137:0:0:0: [sda] Assuming drive cache: write through
[40616.400000] sd 137:0:0:0: [sda] No Caching mode page found
[40616.400000] sd 137:0:0:0: [sda] Assuming drive cache: write through
[40616.410000] sda: unknown partition table
[40616.430000] sd 137:0:0:0: [sda] No Caching mode page found
[40616.430000] sd 137:0:0:0: [sda] Assuming drive cache: write through
[40616.440000] sd 137:0:0:0: [sda] Attached SCSI removable disk
[40618.620000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[40618.630000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[40618.650000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[40618.650000] EXT4-fs (sda): write access unavailable, cannot proceed
[40995.360000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[40995.360000] scsi138 : usb-storage 1-1.4:1.0
[40996.370000] scsi 138:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[40996.380000] sd 138:0:0:0: Attached scsi generic sg0 type 0
[40996.380000] sd 138:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[40996.390000] sd 138:0:0:0: [sda] Write Protect is on
[40996.400000] sd 138:0:0:0: [sda] Mode Sense: 23 00 80 00
[40996.400000] sd 138:0:0:0: [sda] No Caching mode page found
[40996.410000] sd 138:0:0:0: [sda] Assuming drive cache: write through
[40996.420000] sd 138:0:0:0: [sda] No Caching mode page found
[40996.420000] sd 138:0:0:0: [sda] Assuming drive cache: write through
[40996.430000] sda: unknown partition table
[40996.450000] sd 138:0:0:0: [sda] No Caching mode page found
[40996.450000] sd 138:0:0:0: [sda] Assuming drive cache: write through
[40996.460000] sd 138:0:0:0: [sda] Attached SCSI removable disk
[40999.650000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[40999.660000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[40999.680000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[40999.680000] EXT4-fs (sda): write access unavailable, cannot proceed
[41266.350000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[41266.350000] scsi139 : usb-storage 1-1.4:1.0
[41267.360000] scsi 139:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[41267.370000] sd 139:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[41267.380000] sd 139:0:0:0: Attached scsi generic sg0 type 0
[41267.380000] sd 139:0:0:0: [sda] Write Protect is on
[41267.390000] sd 139:0:0:0: [sda] Mode Sense: 23 00 80 00
[41267.390000] sd 139:0:0:0: [sda] No Caching mode page found
[41267.400000] sd 139:0:0:0: [sda] Assuming drive cache: write through
[41267.410000] sd 139:0:0:0: [sda] No Caching mode page found
[41267.410000] sd 139:0:0:0: [sda] Assuming drive cache: write through
[41267.420000] sda: unknown partition table
[41267.440000] sd 139:0:0:0: [sda] No Caching mode page found
[41267.440000] sd 139:0:0:0: [sda] Assuming drive cache: write through
[41267.450000] sd 139:0:0:0: [sda] Attached SCSI removable disk
[41270.650000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[41270.660000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[41270.670000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[41270.680000] EXT4-fs (sda): write access unavailable, cannot proceed
[41572.340000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[41572.340000] scsi140 : usb-storage 1-1.4:1.0
[41573.350000] scsi 140:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[41573.360000] sd 140:0:0:0: Attached scsi generic sg0 type 0
[41573.360000] sd 140:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[41573.370000] sd 140:0:0:0: [sda] Write Protect is on
[41573.380000] sd 140:0:0:0: [sda] Mode Sense: 23 00 80 00
[41573.380000] sd 140:0:0:0: [sda] No Caching mode page found
[41573.390000] sd 140:0:0:0: [sda] Assuming drive cache: write through
[41573.400000] sd 140:0:0:0: [sda] No Caching mode page found
[41573.400000] sd 140:0:0:0: [sda] Assuming drive cache: write through
[41573.410000] sda: unknown partition table
[41573.430000] sd 140:0:0:0: [sda] No Caching mode page found
[41573.430000] sd 140:0:0:0: [sda] Assuming drive cache: write through
[41573.440000] sd 140:0:0:0: [sda] Attached SCSI removable disk
[41576.630000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[41576.640000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[41576.660000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[41576.660000] EXT4-fs (sda): write access unavailable, cannot proceed
[41860.390000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[41860.390000] scsi141 : usb-storage 1-1.4:1.0
[41861.400000] scsi 141:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[41861.410000] sd 141:0:0:0: Attached scsi generic sg0 type 0
[41861.410000] sd 141:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[41861.420000] sd 141:0:0:0: [sda] Write Protect is on
[41861.430000] sd 141:0:0:0: [sda] Mode Sense: 23 00 80 00
[41861.430000] sd 141:0:0:0: [sda] No Caching mode page found
[41861.440000] sd 141:0:0:0: [sda] Assuming drive cache: write through
[41861.450000] sd 141:0:0:0: [sda] No Caching mode page found
[41861.450000] sd 141:0:0:0: [sda] Assuming drive cache: write through
[41861.460000] sda: unknown partition table
[41861.470000] sd 141:0:0:0: [sda] No Caching mode page found
[41861.470000] sd 141:0:0:0: [sda] Assuming drive cache: write through
[41861.480000] sd 141:0:0:0: [sda] Attached SCSI removable disk
[41863.670000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[41863.680000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[41863.690000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[41863.700000] EXT4-fs (sda): write access unavailable, cannot proceed
[42180.360000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[42180.360000] scsi142 : usb-storage 1-1.4:1.0
[42181.370000] scsi 142:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[42181.380000] sd 142:0:0:0: Attached scsi generic sg0 type 0
[42181.380000] sd 142:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[42181.390000] sd 142:0:0:0: [sda] Write Protect is on
[42181.400000] sd 142:0:0:0: [sda] Mode Sense: 23 00 80 00
[42181.400000] sd 142:0:0:0: [sda] No Caching mode page found
[42181.410000] sd 142:0:0:0: [sda] Assuming drive cache: write through
[42181.420000] sd 142:0:0:0: [sda] No Caching mode page found
[42181.420000] sd 142:0:0:0: [sda] Assuming drive cache: write through
[42181.430000] sda: unknown partition table
[42181.440000] sd 142:0:0:0: [sda] No Caching mode page found
[42181.440000] sd 142:0:0:0: [sda] Assuming drive cache: write through
[42181.450000] sd 142:0:0:0: [sda] Attached SCSI removable disk
[42184.650000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[42184.660000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[42184.680000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[42184.680000] EXT4-fs (sda): write access unavailable, cannot proceed
[42494.390000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[42494.390000] scsi143 : usb-storage 1-1.4:1.0
[42495.400000] scsi 143:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[42495.410000] sd 143:0:0:0: Attached scsi generic sg0 type 0
[42495.410000] sd 143:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[42495.420000] sd 143:0:0:0: [sda] Write Protect is on
[42495.430000] sd 143:0:0:0: [sda] Mode Sense: 23 00 80 00
[42495.430000] sd 143:0:0:0: [sda] No Caching mode page found
[42495.440000] sd 143:0:0:0: [sda] Assuming drive cache: write through
[42495.450000] sd 143:0:0:0: [sda] No Caching mode page found
[42495.450000] sd 143:0:0:0: [sda] Assuming drive cache: write through
[42495.460000] sda: unknown partition table
[42495.480000] sd 143:0:0:0: [sda] No Caching mode page found
[42495.480000] sd 143:0:0:0: [sda] Assuming drive cache: write through
[42495.490000] sd 143:0:0:0: [sda] Attached SCSI removable disk
[42498.690000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[42498.700000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[42498.710000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[42498.710000] EXT4-fs (sda): write access unavailable, cannot proceed
[42742.400000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[42742.400000] scsi144 : usb-storage 1-1.4:1.0
[42743.410000] scsi 144:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[42743.420000] sd 144:0:0:0: Attached scsi generic sg0 type 0
[42743.420000] sd 144:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[42743.430000] sd 144:0:0:0: [sda] Write Protect is on
[42743.440000] sd 144:0:0:0: [sda] Mode Sense: 23 00 80 00
[42743.440000] sd 144:0:0:0: [sda] No Caching mode page found
[42743.450000] sd 144:0:0:0: [sda] Assuming drive cache: write through
[42743.460000] sd 144:0:0:0: [sda] No Caching mode page found
[42743.460000] sd 144:0:0:0: [sda] Assuming drive cache: write through
[42743.470000] sda: unknown partition table
[42743.480000] sd 144:0:0:0: [sda] No Caching mode page found
[42743.480000] sd 144:0:0:0: [sda] Assuming drive cache: write through
[42743.490000] sd 144:0:0:0: [sda] Attached SCSI removable disk
[42745.680000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[42745.690000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[42745.700000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[42745.710000] EXT4-fs (sda): write access unavailable, cannot proceed
[43042.420000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[43042.420000] scsi145 : usb-storage 1-1.4:1.0
[43043.430000] scsi 145:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[43043.440000] sd 145:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[43043.450000] sd 145:0:0:0: Attached scsi generic sg0 type 0
[43043.450000] sd 145:0:0:0: [sda] Write Protect is on
[43043.460000] sd 145:0:0:0: [sda] Mode Sense: 23 00 80 00
[43043.460000] sd 145:0:0:0: [sda] No Caching mode page found
[43043.470000] sd 145:0:0:0: [sda] Assuming drive cache: write through
[43043.480000] sd 145:0:0:0: [sda] No Caching mode page found
[43043.480000] sd 145:0:0:0: [sda] Assuming drive cache: write through
[43043.490000] sda: unknown partition table
[43043.510000] sd 145:0:0:0: [sda] No Caching mode page found
[43043.510000] sd 145:0:0:0: [sda] Assuming drive cache: write through
[43043.520000] sd 145:0:0:0: [sda] Attached SCSI removable disk
[43047.730000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[43047.740000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[43047.760000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[43047.760000] EXT4-fs (sda): write access unavailable, cannot proceed
[43402.390000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[43402.390000] scsi146 : usb-storage 1-1.4:1.0
[43403.400000] scsi 146:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[43403.410000] sd 146:0:0:0: Attached scsi generic sg0 type 0
[43403.410000] sd 146:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[43403.420000] sd 146:0:0:0: [sda] Write Protect is on
[43403.430000] sd 146:0:0:0: [sda] Mode Sense: 23 00 80 00
[43403.430000] sd 146:0:0:0: [sda] No Caching mode page found
[43403.440000] sd 146:0:0:0: [sda] Assuming drive cache: write through
[43403.450000] sd 146:0:0:0: [sda] No Caching mode page found
[43403.450000] sd 146:0:0:0: [sda] Assuming drive cache: write through
[43403.460000] sda: unknown partition table
[43403.480000] sd 146:0:0:0: [sda] No Caching mode page found
[43403.480000] sd 146:0:0:0: [sda] Assuming drive cache: write through
[43403.490000] sd 146:0:0:0: [sda] Attached SCSI removable disk
[43405.670000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[43405.680000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[43405.690000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[43405.700000] EXT4-fs (sda): write access unavailable, cannot proceed
[43615.440000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[43615.440000] scsi147 : usb-storage 1-1.4:1.0
[43616.450000] scsi 147:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[43616.460000] sd 147:0:0:0: Attached scsi generic sg0 type 0
[43616.460000] sd 147:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[43616.470000] sd 147:0:0:0: [sda] Write Protect is on
[43616.480000] sd 147:0:0:0: [sda] Mode Sense: 23 00 80 00
[43616.480000] sd 147:0:0:0: [sda] No Caching mode page found
[43616.490000] sd 147:0:0:0: [sda] Assuming drive cache: write through
[43616.500000] sd 147:0:0:0: [sda] No Caching mode page found
[43616.500000] sd 147:0:0:0: [sda] Assuming drive cache: write through
[43616.510000] sda: unknown partition table
[43616.530000] sd 147:0:0:0: [sda] No Caching mode page found
[43616.530000] sd 147:0:0:0: [sda] Assuming drive cache: write through
[43616.540000] sd 147:0:0:0: [sda] Attached SCSI removable disk
[43619.740000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[43619.740000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[43619.760000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[43619.760000] EXT4-fs (sda): write access unavailable, cannot proceed
[43937.430000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[43937.430000] scsi148 : usb-storage 1-1.4:1.0
[43938.440000] scsi 148:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[43938.450000] sd 148:0:0:0: Attached scsi generic sg0 type 0
[43938.450000] sd 148:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[43938.460000] sd 148:0:0:0: [sda] Write Protect is on
[43938.470000] sd 148:0:0:0: [sda] Mode Sense: 23 00 80 00
[43938.470000] sd 148:0:0:0: [sda] No Caching mode page found
[43938.480000] sd 148:0:0:0: [sda] Assuming drive cache: write through
[43938.490000] sd 148:0:0:0: [sda] No Caching mode page found
[43938.490000] sd 148:0:0:0: [sda] Assuming drive cache: write through
[43938.500000] sda: unknown partition table
[43938.520000] sd 148:0:0:0: [sda] No Caching mode page found
[43938.520000] sd 148:0:0:0: [sda] Assuming drive cache: write through
[43938.530000] sd 148:0:0:0: [sda] Attached SCSI removable disk
[43940.710000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[43940.720000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[43940.730000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[43940.740000] EXT4-fs (sda): write access unavailable, cannot proceed
[44222.460000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[44222.460000] scsi149 : usb-storage 1-1.4:1.0
[44223.470000] scsi 149:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[44223.480000] sd 149:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[44223.490000] sd 149:0:0:0: Attached scsi generic sg0 type 0
[44223.490000] sd 149:0:0:0: [sda] Write Protect is on
[44223.500000] sd 149:0:0:0: [sda] Mode Sense: 23 00 80 00
[44223.500000] sd 149:0:0:0: [sda] No Caching mode page found
[44223.510000] sd 149:0:0:0: [sda] Assuming drive cache: write through
[44223.520000] sd 149:0:0:0: [sda] No Caching mode page found
[44223.520000] sd 149:0:0:0: [sda] Assuming drive cache: write through
[44223.530000] sda: unknown partition table
[44223.550000] sd 149:0:0:0: [sda] No Caching mode page found
[44223.550000] sd 149:0:0:0: [sda] Assuming drive cache: write through
[44223.560000] sd 149:0:0:0: [sda] Attached SCSI removable disk
[44227.770000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[44227.780000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[44227.790000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[44227.800000] EXT4-fs (sda): write access unavailable, cannot proceed
[44561.470000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[44561.470000] scsi150 : usb-storage 1-1.4:1.0
[44562.480000] scsi 150:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[44562.490000] sd 150:0:0:0: Attached scsi generic sg0 type 0
[44562.490000] sd 150:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[44562.500000] sd 150:0:0:0: [sda] Write Protect is on
[44562.510000] sd 150:0:0:0: [sda] Mode Sense: 23 00 80 00
[44562.510000] sd 150:0:0:0: [sda] No Caching mode page found
[44562.520000] sd 150:0:0:0: [sda] Assuming drive cache: write through
[44562.530000] sd 150:0:0:0: [sda] No Caching mode page found
[44562.530000] sd 150:0:0:0: [sda] Assuming drive cache: write through
[44562.540000] sda: unknown partition table
[44562.560000] sd 150:0:0:0: [sda] No Caching mode page found
[44562.560000] sd 150:0:0:0: [sda] Assuming drive cache: write through
[44562.570000] sd 150:0:0:0: [sda] Attached SCSI removable disk
[44564.750000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[44564.760000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[44564.780000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[44564.780000] EXT4-fs (sda): write access unavailable, cannot proceed
[44828.490000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[44828.490000] scsi151 : usb-storage 1-1.4:1.0
[44829.500000] scsi 151:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[44829.510000] sd 151:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[44829.520000] sd 151:0:0:0: Attached scsi generic sg0 type 0
[44829.520000] sd 151:0:0:0: [sda] Write Protect is on
[44829.530000] sd 151:0:0:0: [sda] Mode Sense: 23 00 80 00
[44829.530000] sd 151:0:0:0: [sda] No Caching mode page found
[44829.540000] sd 151:0:0:0: [sda] Assuming drive cache: write through
[44829.550000] sd 151:0:0:0: [sda] No Caching mode page found
[44829.550000] sd 151:0:0:0: [sda] Assuming drive cache: write through
[44829.560000] sda: unknown partition table
[44829.580000] sd 151:0:0:0: [sda] No Caching mode page found
[44829.580000] sd 151:0:0:0: [sda] Assuming drive cache: write through
[44829.590000] sd 151:0:0:0: [sda] Attached SCSI removable disk
[44832.790000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[44832.800000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[44832.810000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[44832.820000] EXT4-fs (sda): write access unavailable, cannot proceed
[45163.470000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[45163.470000] scsi152 : usb-storage 1-1.4:1.0
[45164.480000] scsi 152:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[45164.490000] sd 152:0:0:0: Attached scsi generic sg0 type 0
[45164.490000] sd 152:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[45164.500000] sd 152:0:0:0: [sda] Write Protect is on
[45164.510000] sd 152:0:0:0: [sda] Mode Sense: 23 00 80 00
[45164.510000] sd 152:0:0:0: [sda] No Caching mode page found
[45164.520000] sd 152:0:0:0: [sda] Assuming drive cache: write through
[45164.530000] sd 152:0:0:0: [sda] No Caching mode page found
[45164.530000] sd 152:0:0:0: [sda] Assuming drive cache: write through
[45164.540000] sda: unknown partition table
[45164.560000] sd 152:0:0:0: [sda] No Caching mode page found
[45164.560000] sd 152:0:0:0: [sda] Assuming drive cache: write through
[45164.570000] sd 152:0:0:0: [sda] Attached SCSI removable disk
[45168.780000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[45168.790000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[45168.800000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[45168.810000] EXT4-fs (sda): write access unavailable, cannot proceed
[45440.520000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[45440.520000] scsi153 : usb-storage 1-1.4:1.0
[45441.530000] scsi 153:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[45441.540000] sd 153:0:0:0: Attached scsi generic sg0 type 0
[45441.540000] sd 153:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[45441.550000] sd 153:0:0:0: [sda] Write Protect is on
[45441.560000] sd 153:0:0:0: [sda] Mode Sense: 23 00 80 00
[45441.560000] sd 153:0:0:0: [sda] No Caching mode page found
[45441.570000] sd 153:0:0:0: [sda] Assuming drive cache: write through
[45441.580000] sd 153:0:0:0: [sda] No Caching mode page found
[45441.580000] sd 153:0:0:0: [sda] Assuming drive cache: write through
[45441.590000] sda: unknown partition table
[45441.600000] sd 153:0:0:0: [sda] No Caching mode page found
[45441.600000] sd 153:0:0:0: [sda] Assuming drive cache: write through
[45441.610000] sd 153:0:0:0: [sda] Attached SCSI removable disk
[45444.820000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[45444.820000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[45444.840000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[45444.840000] EXT4-fs (sda): write access unavailable, cannot proceed
[45723.480000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[45723.480000] scsi154 : usb-storage 1-1.4:1.0
[45724.490000] scsi 154:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[45724.500000] sd 154:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[45724.510000] sd 154:0:0:0: Attached scsi generic sg0 type 0
[45724.510000] sd 154:0:0:0: [sda] Write Protect is on
[45724.520000] sd 154:0:0:0: [sda] Mode Sense: 23 00 80 00
[45724.520000] sd 154:0:0:0: [sda] No Caching mode page found
[45724.530000] sd 154:0:0:0: [sda] Assuming drive cache: write through
[45724.540000] sd 154:0:0:0: [sda] No Caching mode page found
[45724.540000] sd 154:0:0:0: [sda] Assuming drive cache: write through
[45724.550000] sda: unknown partition table
[45724.570000] sd 154:0:0:0: [sda] No Caching mode page found
[45724.570000] sd 154:0:0:0: [sda] Assuming drive cache: write through
[45724.580000] sd 154:0:0:0: [sda] Attached SCSI removable disk
[45726.760000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[45726.770000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[45726.790000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[45726.790000] EXT4-fs (sda): write access unavailable, cannot proceed
[46082.510000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[46082.510000] scsi155 : usb-storage 1-1.4:1.0
[46083.520000] scsi 155:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[46083.530000] sd 155:0:0:0: Attached scsi generic sg0 type 0
[46083.530000] sd 155:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[46083.540000] sd 155:0:0:0: [sda] Write Protect is on
[46083.550000] sd 155:0:0:0: [sda] Mode Sense: 23 00 80 00
[46083.550000] sd 155:0:0:0: [sda] No Caching mode page found
[46083.560000] sd 155:0:0:0: [sda] Assuming drive cache: write through
[46083.570000] sd 155:0:0:0: [sda] No Caching mode page found
[46083.570000] sd 155:0:0:0: [sda] Assuming drive cache: write through
[46083.580000] sda: unknown partition table
[46083.600000] sd 155:0:0:0: [sda] No Caching mode page found
[46083.600000] sd 155:0:0:0: [sda] Assuming drive cache: write through
[46083.610000] sd 155:0:0:0: [sda] Attached SCSI removable disk
[46086.800000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[46086.810000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[46086.830000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[46086.830000] EXT4-fs (sda): write access unavailable, cannot proceed
[46369.520000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[46369.520000] scsi156 : usb-storage 1-1.4:1.0
[46370.530000] scsi 156:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[46370.540000] sd 156:0:0:0: Attached scsi generic sg0 type 0
[46370.540000] sd 156:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[46370.550000] sd 156:0:0:0: [sda] Write Protect is on
[46370.560000] sd 156:0:0:0: [sda] Mode Sense: 23 00 80 00
[46370.560000] sd 156:0:0:0: [sda] No Caching mode page found
[46370.570000] sd 156:0:0:0: [sda] Assuming drive cache: write through
[46370.580000] sd 156:0:0:0: [sda] No Caching mode page found
[46370.580000] sd 156:0:0:0: [sda] Assuming drive cache: write through
[46370.590000] sda: unknown partition table
[46370.610000] sd 156:0:0:0: [sda] No Caching mode page found
[46370.610000] sd 156:0:0:0: [sda] Assuming drive cache: write through
[46370.620000] sd 156:0:0:0: [sda] Attached SCSI removable disk
[46373.820000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[46373.830000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[46373.840000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[46373.850000] EXT4-fs (sda): write access unavailable, cannot proceed
[46659.550000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[46659.550000] scsi157 : usb-storage 1-1.4:1.0
[46660.560000] scsi 157:0:0:0: Direct-Access TOSHIBA TransMemory PMAP PQ: 0 ANSI: 0 CCS
[46660.570000] sd 157:0:0:0: Attached scsi generic sg0 type 0
[46660.570000] sd 157:0:0:0: [sda] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[46660.580000] sd 157:0:0:0: [sda] Write Protect is on
[46660.590000] sd 157:0:0:0: [sda] Mode Sense: 23 00 80 00
[46660.590000] sd 157:0:0:0: [sda] No Caching mode page found
[46660.600000] sd 157:0:0:0: [sda] Assuming drive cache: write through
[46660.610000] sd 157:0:0:0: [sda] No Caching mode page found
[46660.610000] sd 157:0:0:0: [sda] Assuming drive cache: write through
[46660.620000] sda: unknown partition table
[46660.640000] sd 157:0:0:0: [sda] No Caching mode page found
[46660.640000] sd 157:0:0:0: [sda] Assuming drive cache: write through
[46660.650000] sd 157:0:0:0: [sda] Attached SCSI removable disk
[46662.830000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[46662.840000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[46662.850000] EXT4-fs (sda): INFO: recovery required on readonly filesystem
[46662.860000] EXT4-fs (sda): write access unavailable, cannot proceed
[26261.900000] sd 89:0:0:0: [sda] Write Protect is on
[26261.910000] sd 89:0:0:0: [sda] Mode Sense: 23 00 80 00
[26261.910000] sd 89:0:0:0: [sda] No Caching mode page found
[26261.920000] sd 89:0:0:0: [sda] Assuming drive cache: write through
[26261.930000] sd 89:0:0:0: [sda] No Caching mode page found
[26261.930000] sd 89:0:0:0: [sda] Assuming drive cache: write through
Your internal flash has decided to go to read-only mode. It will need a replacement. Where did you buy from?
meteoharderwijk
I bought this one from www.weerhuisje.nl
Please exchange. USB storage has gone.
MeteoLeudal
Post by MeteoLeudal »
The same story in this post for me I think. Have a Davis VP+ and also bought the MBPRO from the same vendor. Also doing all what you tell to meteoharderwijk.
Here are my results:
On system messages:
oled (12.07.2016 08:00:50): process started.
database (12.07.2016 11:17:24): process started.
wnetd (12.07.2016 11:17:24): process started.
database (12.07.2016 11:17:24): Can't open database: disk I/O error
database (12.07.2016 11:17:24): process stopped.
logger (12.07.2016 11:17:25): can't open database: disk I/O error
database (12.07.2016 11:17:25): cannot prepare init database: out of memory
logger (12.07.2016 11:17:25): Historical data loaded (0 records).
logger (12.07.2016 11:17:25): data logger (version 5.0q, build 10055) started.
logger (12.07.2016 11:17:26): connect station 0 (Meteostick Vantage via USB serial).
logger (12.07.2016 11:17:26): connect station 9 (System Data via Plug-in).
test5m (12.07.2016 11:17:28): database daemon stalled, will be restarted now.
database (12.07.2016 11:17:28): process started.
database (12.07.2016 11:17:28): Can't open database: disk I/O error
database (12.07.2016 11:17:28): process stopped.
logger (12.07.2016 11:17:28): transmitter 1 registered as ISS
logger (12.07.2016 11:17:28): transmitter 2 registered as Wind
logger (12.07.2016 11:17:28): Meteostick Version 2.4
logger (12.07.2016 11:17:28): debug off
logger (12.07.2016 11:17:28): verbose off
logger (12.07.2016 11:17:28): output raw (8 bytes)
logger (12.07.2016 11:17:28): output raw (10 bytes)
logger (12.07.2016 11:17:28): filter on
logger (12.07.2016 11:17:28): rx threshold set to -90db
logger (12.07.2016 11:17:28): listening to transmitter 1 2
logger (12.07.2016 11:17:28): bandwidth wide
logger (12.07.2016 11:17:29): chip authentication ok: 14
logger (12.07.2016 11:17:29): frequency band 868MHz (EU)
test5m (12.07.2016 11:21:41): database daemon stalled, will be restarted now.
database (12.07.2016 11:21:41): process started.
database (12.07.2016 11:21:41): Can't open database: disk I/O error
database (12.07.2016 11:21:41): process stopped.
test5m (12.07.2016 11:26:36): database daemon stalled, will be restarted now.
database (12.07.2016 11:26:37): process started.
database (12.07.2016 11:26:37): Can't open database: disk I/O error
database (12.07.2016 11:26:37): process stopped.
test5m (12.07.2016 11:30:30): database daemon stalled, will be restarted now.
database (12.07.2016 11:30:30): process started.
database (12.07.2016 11:30:30): Can't open database: disk I/O error
database (12.07.2016 11:30:30): process stopped.
test5m (12.07.2016 11:36:09): database daemon stalled, will be restarted now.
database (12.07.2016 11:36:09): process started.
database (12.07.2016 11:36:09): Can't open database: disk I/O error
database (12.07.2016 11:36:09): process stopped.
test5m (12.07.2016 11:41:00): database daemon stalled, will be restarted now.
database (12.07.2016 11:41:00): process started.
database (12.07.2016 11:41:00): Can't open database: disk I/O error
database (12.07.2016 11:41:00): process stopped.
test5m (12.07.2016 11:45:14): database daemon stalled, will be restarted now.
database (12.07.2016 11:45:14): process started.
database (12.07.2016 11:45:14): Can't open database: disk I/O error
database (12.07.2016 11:45:14): process stopped.
logger (12.07.2016 11:48:02): write persist data to "/tmp/mnt/persist/thb0temp" failed: No such file or directory
test5m (12.07.2016 11:50:35): database daemon stalled, will be restarted now.
database (12.07.2016 11:50:35): process started.
database (12.07.2016 11:50:35): Can't open database: disk I/O error
database (12.07.2016 11:50:35): process stopped.
On "http://ip-of-your-meteobridge/cgi-bin/system.cgi?dmesg":
command: dmesg
[   55.150000] sd 0:0:0:0: [sda] Unhandled sense code
[   55.160000] sd 0:0:0:0: [sda]
[   55.160000] Result: hostbyte=0x00 driverbyte=0x08
[   55.170000] Sense Key : 0x3 [current]
[   55.170000] sd 0:0:0:0: [sda]
[   55.170000] ASC=0x11 ASCQ=0x0
[   55.180000] sd 0:0:0:0: [sda] CDB:
[   55.180000] cdb[0]=0x28: 28 00 00 40 01 00 00 00 08 00
[   55.190000] end_request: critical target error, dev sda, sector 4194560
[   55.200000] sd 0:0:0:0: [sda] Unhandled sense code
[   55.200000] Result: hostbyte=0x00 driverbyte=0x08
[   55.210000] sd 0:0:0:0: [sda]
[   55.210000] Sense Key : 0x7 [current]
[   55.220000] ASC=0x27 ASCQ=0x0
[   55.220000] sd 0:0:0:0: [sda] CDB:
[   55.220000] cdb[0]=0x2a: 2a 00 00 00 00 00 00 00 08 00
[   55.230000] end_request: critical target error, dev sda, sector 0
[   55.230000] Buffer I/O error on device sda, logical block 0
[   55.240000] lost page write due to I/O error on sda
[   55.240000] EXT4-fs error (device sda): __ext4_get_inode_loc:4028: inode #129281: block 524320: comm start.sh: unable to read itable block
[   70.090000] sd 0:0:0:0: [sda] Unhandled sense code
[   70.100000] Result: hostbyte=0x00 driverbyte=0x08
[   70.100000] sd 0:0:0:0: [sda]
[   70.100000] Sense Key : 0x7 [current]
[   70.110000] sd 0:0:0:0: [sda]
[   70.110000] ASC=0x27 ASCQ=0x0
[   70.110000] sd 0:0:0:0: [sda] CDB:
[   70.120000] cdb[0]=0x2a: 2a 00 00 04 14 00 00 00 f0 00
[   70.120000] end_request: critical target error, dev sda, sector 267264
[   70.130000] Buffer I/O error on device sda, logical block 33408
[   70.140000] Buffer I/O error on device sda, logical block 33409
[   70.140000] Buffer I/O error on device sda, logical block 33410
[   70.150000] Buffer I/O error on device sda, logical block 33411
[   70.150000] Buffer I/O error on device sda, logical block 33412
[   70.160000] Buffer I/O error on device sda, logical block 33413
[   70.160000] Buffer I/O error on device sda, logical block 33414
[   70.170000] Buffer I/O error on device sda, logical block 33415
[   70.180000] Buffer I/O error on device sda, logical block 33416
[   70.180000] Buffer I/O error on device sda, logical block 33417
[   70.190000] Buffer I/O error on device sda, logical block 33418
[   70.190000] Buffer I/O error on device sda, logical block 33419
[   70.200000] Buffer I/O error on device sda, logical block 33420
[   70.210000] Buffer I/O error on device sda, logical block 33421
[   70.210000] Buffer I/O error on device sda, logical block 33422
[   70.220000] Buffer I/O error on device sda, logical block 33423
[   70.220000] Buffer I/O error on device sda, logical block 33424
[   70.230000] Buffer I/O error on device sda, logical block 33425
[   70.240000] Buffer I/O error on device sda, logical block 33426
[   70.240000] Buffer I/O error on device sda, logical block 33427
[   70.250000] Buffer I/O error on device sda, logical block 33428
[   70.250000] Buffer I/O error on device sda, logical block 33429
[   70.260000] Buffer I/O error on device sda, logical block 33430
[   70.270000] Buffer I/O error on device sda, logical block 33431
[   70.270000] Buffer I/O error on device sda, logical block 33432
[   70.280000] Buffer I/O error on device sda, logical block 33433
[   70.280000] Buffer I/O error on device sda, logical block 33434
[   70.290000] Buffer I/O error on device sda, logical block 33435
[   70.290000] Buffer I/O error on device sda, logical block 33436
[   70.300000] Buffer I/O error on device sda, logical block 33437
[   70.310000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 0 size 126976 starting block 33438)
[   70.330000] sd 0:0:0:0: [sda] Unhandled sense code
[   70.330000] Result: hostbyte=0x00 driverbyte=0x08
[   70.340000] sd 0:0:0:0: [sda]
[   70.340000] Sense Key : 0x7 [current]
[   70.350000] ASC=0x27 ASCQ=0x0
[   70.350000] sd 0:0:0:0: [sda] CDB:
[   70.350000] cdb[0]=0x2a: 2a 00 00 04 14 f0 00 00 f0 00
[   70.360000] end_request: critical target error, dev sda, sector 267504
[   70.360000] Buffer I/O error on device sda, logical block 33438
[   70.370000] Buffer I/O error on device sda, logical block 33439
[   70.380000] Buffer I/O error on device sda, logical block 33440
[   70.380000] Buffer I/O error on device sda, logical block 33441
[   70.390000] Buffer I/O error on device sda, logical block 33442
[   70.390000] Buffer I/O error on device sda, logical block 33443
[   70.400000] Buffer I/O error on device sda, logical block 33444
[   70.410000] Buffer I/O error on device sda, logical block 33445
[   70.410000] Buffer I/O error on device sda, logical block 33446
[   70.420000] Buffer I/O error on device sda, logical block 33447
[   70.420000] Buffer I/O error on device sda, logical block 33448
[   70.430000] Buffer I/O error on device sda, logical block 33449
[   70.440000] Buffer I/O error on device sda, logical block 33450
[   70.440000] Buffer I/O error on device sda, logical block 33451
[   70.450000] Buffer I/O error on device sda, logical block 33452
[   70.450000] Buffer I/O error on device sda, logical block 33453
[   70.460000] Buffer I/O error on device sda, logical block 33454
[   70.460000] Buffer I/O error on device sda, logical block 33455
[   70.470000] Buffer I/O error on device sda, logical block 33456
[   70.480000] Buffer I/O error on device sda, logical block 33457
[   70.480000] Buffer I/O error on device sda, logical block 33458
[   70.490000] Buffer I/O error on device sda, logical block 33459
[   70.490000] Buffer I/O error on device sda, logical block 33460
[   70.500000] Buffer I/O error on device sda, logical block 33461
[   70.510000] Buffer I/O error on device sda, logical block 33462
[   70.510000] Buffer I/O error on device sda, logical block 33463
[   70.520000] Buffer I/O error on device sda, logical block 33464
[   70.520000] Buffer I/O error on device sda, logical block 33465
[   70.530000] Buffer I/O error on device sda, logical block 33466
[   70.540000] Buffer I/O error on device sda, logical block 33467
[   70.540000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 122880 size 126976 starting block 33468)
[   70.560000] sd 0:0:0:0: [sda] Unhandled sense code
[   70.560000] Result: hostbyte=0x00 driverbyte=0x08
[   70.570000] sd 0:0:0:0: [sda]
[   70.570000] Sense Key : 0x7 [current]
[   70.580000] ASC=0x27 ASCQ=0x0
[   70.580000] sd 0:0:0:0: [sda] CDB:
[   70.580000] cdb[0]=0x2a: 2a 00 00 04 15 e0 00 00 f0 00
[   70.590000] end_request: critical target error, dev sda, sector 267744
[   70.600000] Buffer I/O error on device sda, logical block 33468
[   70.600000] Buffer I/O error on device sda, logical block 33469
[   70.610000] Buffer I/O error on device sda, logical block 33470
[   70.610000] Buffer I/O error on device sda, logical block 33471
[   70.620000] Buffer I/O error on device sda, logical block 33472
[   70.620000] Buffer I/O error on device sda, logical block 33473
[   70.630000] Buffer I/O error on device sda, logical block 33474
[   70.640000] Buffer I/O error on device sda, logical block 33475
[   70.640000] Buffer I/O error on device sda, logical block 33476
[   70.650000] Buffer I/O error on device sda, logical block 33477
[   70.650000] Buffer I/O error on device sda, logical block 33478
[   70.660000] Buffer I/O error on device sda, logical block 33479
[   70.670000] Buffer I/O error on device sda, logical block 33480
[   70.670000] Buffer I/O error on device sda, logical block 33481
[   70.680000] Buffer I/O error on device sda, logical block 33482
[   70.680000] Buffer I/O error on device sda, logical block 33483
[   70.690000] Buffer I/O error on device sda, logical block 33484
[   70.700000] Buffer I/O error on device sda, logical block 33485
[   70.700000] Buffer I/O error on device sda, logical block 33486
[   70.710000] Buffer I/O error on device sda, logical block 33487
[   70.710000] Buffer I/O error on device sda, logical block 33488
[   70.720000] Buffer I/O error on device sda, logical block 33489
[   70.720000] Buffer I/O error on device sda, logical block 33490
[   70.730000] Buffer I/O error on device sda, logical block 33491
[   70.740000] Buffer I/O error on device sda, logical block 33492
[   70.740000] Buffer I/O error on device sda, logical block 33493
[   70.750000] Buffer I/O error on device sda, logical block 33494
[   70.750000] Buffer I/O error on device sda, logical block 33495
[   70.760000] Buffer I/O error on device sda, logical block 33496
[   70.770000] Buffer I/O error on device sda, logical block 33497
[   70.770000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 245760 size 126976 starting block 33498)
[   70.810000] sd 0:0:0:0: [sda] Unhandled sense code
[   70.820000] Result: hostbyte=0x00 driverbyte=0x08
[   70.820000] sd 0:0:0:0: [sda]
[   70.820000] Sense Key : 0x7 [current]
[   70.830000] sd 0:0:0:0: [sda]
[   70.830000] ASC=0x27 ASCQ=0x0
[   70.830000] sd 0:0:0:0: [sda] CDB:
[   70.840000] cdb[0]=0x2a: 2a 00 00 04 16 d0 00 00 f0 00
[   70.840000] end_request: critical target error, dev sda, sector 267984
[   70.850000] Buffer I/O error on device sda, logical block 33498
[   70.850000] Buffer I/O error on device sda, logical block 33499
[   70.860000] Buffer I/O error on device sda, logical block 33500
[   70.870000] Buffer I/O error on device sda, logical block 33501
[   70.870000] Buffer I/O error on device sda, logical block 33502
[   70.880000] Buffer I/O error on device sda, logical block 33503
[   70.880000] Buffer I/O error on device sda, logical block 33504
[   70.890000] Buffer I/O error on device sda, logical block 33505
[   70.900000] Buffer I/O error on device sda, logical block 33506
[   70.900000] Buffer I/O error on device sda, logical block 33507
[   70.910000] Buffer I/O error on device sda, logical block 33508
[   70.910000] Buffer I/O error on device sda, logical block 33509
[   70.920000] Buffer I/O error on device sda, logical block 33510
[   70.920000] Buffer I/O error on device sda, logical block 33511
[   70.930000] Buffer I/O error on device sda, logical block 33512
[   70.940000] Buffer I/O error on device sda, logical block 33513
[   70.940000] Buffer I/O error on device sda, logical block 33514
[   70.950000] Buffer I/O error on device sda, logical block 33515
[   70.950000] Buffer I/O error on device sda, logical block 33516
[   70.960000] Buffer I/O error on device sda, logical block 33517
[   70.970000] Buffer I/O error on device sda, logical block 33518
[   70.970000] Buffer I/O error on device sda, logical block 33519
[   70.980000] Buffer I/O error on device sda, logical block 33520
[   70.980000] Buffer I/O error on device sda, logical block 33521
[   70.990000] Buffer I/O error on device sda, logical block 33522
[   71.000000] Buffer I/O error on device sda, logical block 33523
[   71.000000] Buffer I/O error on device sda, logical block 33524
[   71.010000] Buffer I/O error on device sda, logical block 33525
[   71.010000] Buffer I/O error on device sda, logical block 33526
[   71.020000] Buffer I/O error on device sda, logical block 33527
[   71.030000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 368640 size 126976 starting block 33528)
[   71.050000] sd 0:0:0:0: [sda] Unhandled sense code
[   71.050000] Result: hostbyte=0x00 driverbyte=0x08
[   71.060000] sd 0:0:0:0: [sda]
[   71.060000] Sense Key : 0x7 [current]
[   71.070000] ASC=0x27 ASCQ=0x0
[   71.070000] sd 0:0:0:0: [sda] CDB:
[   71.070000] cdb[0]=0x2a: 2a 00 00 04 17 c0 00 00 48 00
[   71.080000] end_request: critical target error, dev sda, sector 268224
[   71.080000] Buffer I/O error on device sda, logical block 33528
[   71.090000] Buffer I/O error on device sda, logical block 33529
[   71.100000] Buffer I/O error on device sda, logical block 33530
[   71.100000] Buffer I/O error on device sda, logical block 33531
[   71.110000] Buffer I/O error on device sda, logical block 33532
[   71.110000] Buffer I/O error on device sda, logical block 33533
[   71.120000] Buffer I/O error on device sda, logical block 33534
[   71.130000] Buffer I/O error on device sda, logical block 33535
[   71.130000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 491520 size 32768 starting block 33536)
[   71.140000] Buffer I/O error on device sda, logical block 33536
[   71.150000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 524288 size 4096 starting block 33537)
[   71.170000] sd 0:0:0:0: [sda] Unhandled sense code
[   71.170000] Result: hostbyte=0x00 driverbyte=0x08
[   71.180000] sd 0:0:0:0: [sda]
[   71.180000] Sense Key : 0x7 [current]
[   71.190000] ASC=0x27 ASCQ=0x0
[   71.190000] sd 0:0:0:0: [sda] CDB:
[   71.190000] cdb[0]=0x2a: 2a 00 00 04 18 08 00 00 f0 00
[   71.200000] end_request: critical target error, dev sda, sector 268296
[   71.200000] Buffer I/O error on device sda, logical block 33537
[   71.210000] Buffer I/O error on device sda, logical block 33538
[   71.220000] Buffer I/O error on device sda, logical block 33539
[   71.220000] Buffer I/O error on device sda, logical block 33540
[   71.230000] Buffer I/O error on device sda, logical block 33541
[   71.230000] Buffer I/O error on device sda, logical block 33542
[   71.240000] Buffer I/O error on device sda, logical block 33543
[   71.250000] Buffer I/O error on device sda, logical block 33544
[   71.250000] Buffer I/O error on device sda, logical block 33545
[   71.260000] Buffer I/O error on device sda, logical block 33546
[   71.260000] Buffer I/O error on device sda, logical block 33547
[   71.270000] Buffer I/O error on device sda, logical block 33548
[   71.280000] Buffer I/O error on device sda, logical block 33549
[   71.280000] Buffer I/O error on device sda, logical block 33550
[   71.290000] Buffer I/O error on device sda, logical block 33551
[   71.290000] Buffer I/O error on device sda, logical block 33552
[   71.300000] Buffer I/O error on device sda, logical block 33553
[   71.300000] Buffer I/O error on device sda, logical block 33554
[   71.310000] Buffer I/O error on device sda, logical block 33555
[   71.320000] Buffer I/O error on device sda, logical block 33556
[   71.320000] Buffer I/O error on device sda, logical block 33557
[   71.330000] Buffer I/O error on device sda, logical block 33558
[   71.330000] Buffer I/O error on device sda, logical block 33559
[   71.340000] Buffer I/O error on device sda, logical block 33560
[   71.350000] Buffer I/O error on device sda, logical block 33561
[   71.350000] Buffer I/O error on device sda, logical block 33562
[   71.360000] Buffer I/O error on device sda, logical block 33563
[   71.360000] Buffer I/O error on device sda, logical block 33564
[   71.370000] Buffer I/O error on device sda, logical block 33565
[   71.380000] Buffer I/O error on device sda, logical block 33566
[   71.380000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 528384 size 126976 starting block 33567)
[   71.400000] sd 0:0:0:0: [sda] Unhandled sense code
[   71.400000] Result: hostbyte=0x00 driverbyte=0x08
[   71.410000] sd 0:0:0:0: [sda]
[   71.410000] Sense Key : 0x7 [current]
[   71.420000] ASC=0x27 ASCQ=0x0
[   71.420000] sd 0:0:0:0: [sda] CDB:
[   71.420000] cdb[0]=0x2a: 2a 00 00 04 18 f8 00 00 f0 00
[   71.430000] end_request: critical target error, dev sda, sector 268536
[   71.440000] Buffer I/O error on device sda, logical block 33567
[   71.440000] Buffer I/O error on device sda, logical block 33568
[   71.450000] Buffer I/O error on device sda, logical block 33569
[   71.450000] Buffer I/O error on device sda, logical block 33570
[   71.460000] Buffer I/O error on device sda, logical block 33571
[   71.460000] Buffer I/O error on device sda, logical block 33572
[   71.470000] Buffer I/O error on device sda, logical block 33573
[   71.480000] Buffer I/O error on device sda, logical block 33574
[   71.480000] Buffer I/O error on device sda, logical block 33575
[   71.490000] Buffer I/O error on device sda, logical block 33576
[   71.490000] Buffer I/O error on device sda, logical block 33577
[   71.500000] Buffer I/O error on device sda, logical block 33578
[   71.510000] Buffer I/O error on device sda, logical block 33579
[   71.510000] Buffer I/O error on device sda, logical block 33580
[   71.520000] Buffer I/O error on device sda, logical block 33581
[   71.520000] Buffer I/O error on device sda, logical block 33582
[   71.530000] Buffer I/O error on device sda, logical block 33583
[   71.540000] Buffer I/O error on device sda, logical block 33584
[   71.540000] Buffer I/O error on device sda, logical block 33585
[   71.550000] Buffer I/O error on device sda, logical block 33586
[   71.550000] Buffer I/O error on device sda, logical block 33587
[   71.560000] Buffer I/O error on device sda, logical block 33588
[   71.570000] Buffer I/O error on device sda, logical block 33589
[   71.570000] Buffer I/O error on device sda, logical block 33590
[   71.580000] Buffer I/O error on device sda, logical block 33591
[   71.580000] Buffer I/O error on device sda, logical block 33592
[   71.590000] Buffer I/O error on device sda, logical block 33593
[   71.590000] Buffer I/O error on device sda, logical block 33594
[   71.600000] Buffer I/O error on device sda, logical block 33595
[   71.610000] Buffer I/O error on device sda, logical block 33596
[   71.610000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 651264 size 126976 starting block 33597)
[   71.640000] sd 0:0:0:0: [sda] Unhandled sense code
[   71.640000] Result: hostbyte=0x00 driverbyte=0x08
[   71.650000] sd 0:0:0:0: [sda]
[   71.650000] Sense Key : 0x7 [current]
[   71.660000] ASC=0x27 ASCQ=0x0
[   71.660000] sd 0:0:0:0: [sda] CDB:
[   71.660000] cdb[0]=0x2a: 2a 00 00 04 19 e8 00 00 f0 00
[   71.670000] end_request: critical target error, dev sda, sector 268776
[   71.670000] Buffer I/O error on device sda, logical block 33597
[   71.680000] Buffer I/O error on device sda, logical block 33598
[   71.690000] Buffer I/O error on device sda, logical block 33599
[   71.690000] Buffer I/O error on device sda, logical block 33600
[   71.700000] Buffer I/O error on device sda, logical block 33601
[   71.700000] Buffer I/O error on device sda, logical block 33602
[   71.710000] Buffer I/O error on device sda, logical block 33603
[   71.720000] Buffer I/O error on device sda, logical block 33604
[   71.720000] Buffer I/O error on device sda, logical block 33605
[   71.730000] Buffer I/O error on device sda, logical block 33606
[   71.730000] Buffer I/O error on device sda, logical block 33607
[   71.740000] Buffer I/O error on device sda, logical block 33608
[   71.750000] Buffer I/O error on device sda, logical block 33609
[   71.750000] Buffer I/O error on device sda, logical block 33610
[   71.760000] Buffer I/O error on device sda, logical block 33611
[   71.760000] Buffer I/O error on device sda, logical block 33612
[   71.770000] Buffer I/O error on device sda, logical block 33613
[   71.770000] Buffer I/O error on device sda, logical block 33614
[   71.780000] Buffer I/O error on device sda, logical block 33615
[   71.790000] Buffer I/O error on device sda, logical block 33616
[   71.790000] Buffer I/O error on device sda, logical block 33617
[   71.800000] Buffer I/O error on device sda, logical block 33618
[   71.800000] Buffer I/O error on device sda, logical block 33619
[   71.810000] Buffer I/O error on device sda, logical block 33620
[   71.820000] Buffer I/O error on device sda, logical block 33621
[   71.820000] Buffer I/O error on device sda, logical block 33622
[   71.830000] Buffer I/O error on device sda, logical block 33623
[   71.830000] Buffer I/O error on device sda, logical block 33624
[   71.840000] Buffer I/O error on device sda, logical block 33625
[   71.850000] Buffer I/O error on device sda, logical block 33626
[   71.850000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 774144 size 126976 starting block 33627)
[   71.870000] sd 0:0:0:0: [sda] Unhandled sense code
[   71.870000] Result: hostbyte=0x00 driverbyte=0x08
[   71.880000] sd 0:0:0:0: [sda]
[   71.880000] Sense Key : 0x7 [current]
[   71.890000] ASC=0x27 ASCQ=0x0
[   71.890000] sd 0:0:0:0: [sda] CDB:
[   71.890000] cdb[0]=0x2a: 2a 00 00 04 1a d8 00 00 f0 00
[   71.900000] end_request: critical target error, dev sda, sector 269016
[   71.910000] Buffer I/O error on device sda, logical block 33627
[   71.910000] Buffer I/O error on device sda, logical block 33628
[   71.920000] Buffer I/O error on device sda, logical block 33629
[   71.920000] Buffer I/O error on device sda, logical block 33630
[   71.930000] Buffer I/O error on device sda, logical block 33631
[   71.940000] Buffer I/O error on device sda, logical block 33632
[   71.940000] Buffer I/O error on device sda, logical block 33633
[   71.950000] Buffer I/O error on device sda, logical block 33634
[   71.950000] Buffer I/O error on device sda, logical block 33635
[   71.960000] Buffer I/O error on device sda, logical block 33636
[   71.970000] Buffer I/O error on device sda, logical block 33637
[   71.970000] Buffer I/O error on device sda, logical block 33638
[   71.980000] Buffer I/O error on device sda, logical block 33639
[   71.980000] Buffer I/O error on device sda, logical block 33640
[   71.990000] Buffer I/O error on device sda, logical block 33641
[   71.990000] Buffer I/O error on device sda, logical block 33642
[   72.000000] Buffer I/O error on device sda, logical block 33643
[   72.010000] Buffer I/O error on device sda, logical block 33644
[   72.010000] Buffer I/O error on device sda, logical block 33645
[   72.020000] Buffer I/O error on device sda, logical block 33646
[   72.020000] Buffer I/O error on device sda, logical block 33647
[   72.030000] Buffer I/O error on device sda, logical block 33648
[   72.040000] Buffer I/O error on device sda, logical block 33649
[   72.040000] Buffer I/O error on device sda, logical block 33650
[   72.050000] Buffer I/O error on device sda, logical block 33651
[   72.050000] Buffer I/O error on device sda, logical block 33652
[   72.060000] Buffer I/O error on device sda, logical block 33653
[   72.070000] Buffer I/O error on device sda, logical block 33654
[   72.070000] Buffer I/O error on device sda, logical block 33655
[   72.080000] Buffer I/O error on device sda, logical block 33656
[   72.080000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 897024 size 126976 starting block 33657)
[   72.100000] sd 0:0:0:0: [sda] Unhandled sense code
[   72.110000] sd 0:0:0:0: [sda]
[   72.110000] Result: hostbyte=0x00 driverbyte=0x08
[   72.120000] Sense Key : 0x7 [current]
[   72.120000] sd 0:0:0:0: [sda]
[   72.120000] ASC=0x27 ASCQ=0x0
[   72.130000] sd 0:0:0:0: [sda] CDB:
[   72.130000] cdb[0]=0x2a: 2a 00 00 04 1b c8 00 00 38 00
[   72.140000] end_request: critical target error, dev sda, sector 269256
[   72.140000] Buffer I/O error on device sda, logical block 33657
[   72.150000] Buffer I/O error on device sda, logical block 33658
[   72.150000] Buffer I/O error on device sda, logical block 33659
[   72.160000] Buffer I/O error on device sda, logical block 33660
[   72.170000] Buffer I/O error on device sda, logical block 33661
[   72.170000] Buffer I/O error on device sda, logical block 33662
[   72.180000] Buffer I/O error on device sda, logical block 33663
[   72.180000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 1019904 size 28672 starting block 33664)
[   72.200000] sd 0:0:0:0: [sda] Unhandled sense code
[   72.210000] sd 0:0:0:0: [sda]
[   72.210000] Result: hostbyte=0x00 driverbyte=0x08
[   72.220000] sd 0:0:0:0: [sda]
[   72.220000] Sense Key : 0x7 [current]
[   72.230000] ASC=0x27 ASCQ=0x0
[   72.230000] sd 0:0:0:0: [sda] CDB:
[   72.230000] cdb[0]=0x2a: 2a 00 00 04 1c 00 00 00 f0 00
[   72.240000] Buffer I/O error on device sda, logical block 33664
[   72.240000] Buffer I/O error on device sda, logical block 33665
[   72.250000] Buffer I/O error on device sda, logical block 33666
[   72.250000] Buffer I/O error on device sda, logical block 33667
[   72.260000] Buffer I/O error on device sda, logical block 33668
[   72.270000] Buffer I/O error on device sda, logical block 33669
[   72.270000] Buffer I/O error on device sda, logical block 33670
[   72.280000] Buffer I/O error on device sda, logical block 33671
[   72.280000] Buffer I/O error on device sda, logical block 33672
[   72.290000] Buffer I/O error on device sda, logical block 33673
[   72.300000] Buffer I/O error on device sda, logical block 33674
[   72.300000] Buffer I/O error on device sda, logical block 33675
[   72.310000] Buffer I/O error on device sda, logical block 33676
[   72.310000] Buffer I/O error on device sda, logical block 33677
[   72.320000] Buffer I/O error on device sda, logical block 33678
[   72.330000] Buffer I/O error on device sda, logical block 33679
[   72.330000] Buffer I/O error on device sda, logical block 33680
[   72.340000] Buffer I/O error on device sda, logical block 33681
[   72.340000] Buffer I/O error on device sda, logical block 33682
[   72.350000] Buffer I/O error on device sda, logical block 33683
[   72.350000] Buffer I/O error on device sda, logical block 33684
[   72.360000] Buffer I/O error on device sda, logical block 33685
[   72.370000] Buffer I/O error on device sda, logical block 33686
[   72.370000] Buffer I/O error on device sda, logical block 33687
[   72.380000] Buffer I/O error on device sda, logical block 33688
[   72.380000] Buffer I/O error on device sda, logical block 33689
[   72.390000] Buffer I/O error on device sda, logical block 33690
[   72.400000] Buffer I/O error on device sda, logical block 33691
[   72.400000] Buffer I/O error on device sda, logical block 33692
[   72.410000] Buffer I/O error on device sda, logical block 33693
[   72.410000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 1048576 size 126976 starting block 33694)
[   72.430000] sd 0:0:0:0: [sda] Unhandled sense code
[   72.440000] sd 0:0:0:0: [sda]
[   72.440000] Result: hostbyte=0x00 driverbyte=0x08
[   72.450000] sd 0:0:0:0: [sda]
[   72.450000] Sense Key : 0x7 [current]
[   72.450000] ASC=0x27 ASCQ=0x0
[   72.460000] sd 0:0:0:0: [sda] CDB:
[   72.460000] cdb[0]=0x2a: 2a 00 00 04 1c f0 00 00 f0 00
[   72.470000] Buffer I/O error on device sda, logical block 33694
[   72.470000] Buffer I/O error on device sda, logical block 33695
[   72.480000] Buffer I/O error on device sda, logical block 33696
[   72.480000] Buffer I/O error on device sda, logical block 33697
[   72.490000] Buffer I/O error on device sda, logical block 33698
[   72.500000] Buffer I/O error on device sda, logical block 33699
[   72.500000] Buffer I/O error on device sda, logical block 33700
[   72.510000] Buffer I/O error on device sda, logical block 33701
[   72.510000] Buffer I/O error on device sda, logical block 33702
[   72.520000] Buffer I/O error on device sda, logical block 33703
[   72.530000] Buffer I/O error on device sda, logical block 33704
[   72.530000] Buffer I/O error on device sda, logical block 33705
[   72.540000] Buffer I/O error on device sda, logical block 33706
[   72.540000] Buffer I/O error on device sda, logical block 33707
[   72.550000] Buffer I/O error on device sda, logical block 33708
[   72.560000] Buffer I/O error on device sda, logical block 33709
[   72.560000] Buffer I/O error on device sda, logical block 33710
[   72.570000] Buffer I/O error on device sda, logical block 33711
[   72.570000] Buffer I/O error on device sda, logical block 33712
[   72.580000] Buffer I/O error on device sda, logical block 33713
[   72.580000] Buffer I/O error on device sda, logical block 33714
[   72.590000] Buffer I/O error on device sda, logical block 33715
[   72.600000] Buffer I/O error on device sda, logical block 33716
[   72.600000] Buffer I/O error on device sda, logical block 33717
[   72.610000] Buffer I/O error on device sda, logical block 33718
[   72.610000] Buffer I/O error on device sda, logical block 33719
[   72.620000] Buffer I/O error on device sda, logical block 33720
[   72.630000] Buffer I/O error on device sda, logical block 33721
[   72.630000] Buffer I/O error on device sda, logical block 33722
[   72.640000] Buffer I/O error on device sda, logical block 33723
[   72.640000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 1171456 size 126976 starting block 33724)
[   72.660000] sd 0:0:0:0: [sda] Unhandled sense code
[   72.660000] Result: hostbyte=0x00 driverbyte=0x08
[   72.670000] sd 0:0:0:0: [sda]
[   72.670000] Sense Key : 0x7 [current]
[   72.680000] sd 0:0:0:0: [sda]
[   72.680000] ASC=0x27 ASCQ=0x0
[   72.680000] sd 0:0:0:0: [sda] CDB:
[   72.690000] cdb[0]=0x2a: 2a 00 00 04 1d e0 00 00 f0 00
[   72.690000] Buffer I/O error on device sda, logical block 33724
[   72.700000] Buffer I/O error on device sda, logical block 33725
[   72.700000] Buffer I/O error on device sda, logical block 33726
[   72.710000] Buffer I/O error on device sda, logical block 33727
[   72.710000] Buffer I/O error on device sda, logical block 33728
[   72.720000] Buffer I/O error on device sda, logical block 33729
[   72.730000] Buffer I/O error on device sda, logical block 33730
[   72.730000] Buffer I/O error on device sda, logical block 33731
[   72.740000] Buffer I/O error on device sda, logical block 33732
[   72.740000] Buffer I/O error on device sda, logical block 33733
[   72.750000] Buffer I/O error on device sda, logical block 33734
[   72.760000] Buffer I/O error on device sda, logical block 33735
[   72.760000] Buffer I/O error on device sda, logical block 33736
[   72.770000] Buffer I/O error on device sda, logical block 33737
[   72.770000] Buffer I/O error on device sda, logical block 33738
[   72.780000] Buffer I/O error on device sda, logical block 33739
[   72.790000] Buffer I/O error on device sda, logical block 33740
[   72.790000] Buffer I/O error on device sda, logical block 33741
[   72.800000] Buffer I/O error on device sda, logical block 33742
[   72.800000] Buffer I/O error on device sda, logical block 33743
[   72.810000] Buffer I/O error on device sda, logical block 33744
[   72.810000] Buffer I/O error on device sda, logical block 33745
[   72.820000] Buffer I/O error on device sda, logical block 33746
[   72.830000] Buffer I/O error on device sda, logical block 33747
[   72.830000] Buffer I/O error on device sda, logical block 33748
[   72.840000] Buffer I/O error on device sda, logical block 33749
[   72.840000] Buffer I/O error on device sda, logical block 33750
[   72.850000] Buffer I/O error on device sda, logical block 33751
[   72.860000] Buffer I/O error on device sda, logical block 33752
[   72.860000] Buffer I/O error on device sda, logical block 33753
[   72.870000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 1294336 size 126976 starting block 33754)
[   72.890000] sd 0:0:0:0: [sda] Unhandled sense code
[   72.890000] Result: hostbyte=0x00 driverbyte=0x08
[   72.900000] sd 0:0:0:0: [sda]
[   72.900000] Sense Key : 0x7 [current]
[   72.910000] ASC=0x27 ASCQ=0x0
[   72.910000] sd 0:0:0:0: [sda] CDB:
[   72.910000] cdb[0]=0x2a: 2a 00 00 04 1e d0 00 00 f0 00
[   72.920000] Buffer I/O error on device sda, logical block 33754
[   72.920000] Buffer I/O error on device sda, logical block 33755
[   72.930000] Buffer I/O error on device sda, logical block 33756
[   72.940000] Buffer I/O error on device sda, logical block 33757
[   72.940000] Buffer I/O error on device sda, logical block 33758
[   72.950000] Buffer I/O error on device sda, logical block 33759
[   72.950000] Buffer I/O error on device sda, logical block 33760
[   72.960000] Buffer I/O error on device sda, logical block 33761
[   72.970000] Buffer I/O error on device sda, logical block 33762
[   72.970000] Buffer I/O error on device sda, logical block 33763
[   72.980000] Buffer I/O error on device sda, logical block 33764
[   72.980000] Buffer I/O error on device sda, logical block 33765
[   72.990000] Buffer I/O error on device sda, logical block 33766
[   72.990000] Buffer I/O error on device sda, logical block 33767
[   73.000000] Buffer I/O error on device sda, logical block 33768
[   73.010000] Buffer I/O error on device sda, logical block 33769
[   73.010000] Buffer I/O error on device sda, logical block 33770
[   73.020000] Buffer I/O error on device sda, logical block 33771
[   73.020000] Buffer I/O error on device sda, logical block 33772
[   73.030000] Buffer I/O error on device sda, logical block 33773
[   73.040000] Buffer I/O error on device sda, logical block 33774
[   73.040000] Buffer I/O error on device sda, logical block 33775
[   73.050000] Buffer I/O error on device sda, logical block 33776
[   73.050000] Buffer I/O error on device sda, logical block 33777
[   73.060000] Buffer I/O error on device sda, logical block 33778
[   73.070000] Buffer I/O error on device sda, logical block 33779
[   73.070000] Buffer I/O error on device sda, logical block 33780
[   73.080000] Buffer I/O error on device sda, logical block 33781
[   73.080000] Buffer I/O error on device sda, logical block 33782
[   73.090000] Buffer I/O error on device sda, logical block 33783
[   73.090000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 1417216 size 126976 starting block 33784)
[   73.110000] sd 0:0:0:0: [sda] Unhandled sense code
[   73.120000] sd 0:0:0:0: [sda]
[   73.120000] Result: hostbyte=0x00 driverbyte=0x08
[   73.130000] sd 0:0:0:0: [sda]
[   73.130000] Sense Key : 0x7 [current]
[   73.140000] ASC=0x27 ASCQ=0x0
[   73.140000] sd 0:0:0:0: [sda] CDB:
[   73.140000] cdb[0]=0x2a: 2a 00 00 04 1f c0 00 00 f0 00
[   73.150000] Buffer I/O error on device sda, logical block 33784
[   73.150000] Buffer I/O error on device sda, logical block 33785
[   73.160000] Buffer I/O error on device sda, logical block 33786
[   73.170000] Buffer I/O error on device sda, logical block 33787
[   73.170000] Buffer I/O error on device sda, logical block 33788
[   73.180000] Buffer I/O error on device sda, logical block 33789
[   73.180000] Buffer I/O error on device sda, logical block 33790
[   73.190000] Buffer I/O error on device sda, logical block 33791
[   73.190000] Buffer I/O error on device sda, logical block 33792
[   73.200000] Buffer I/O error on device sda, logical block 33793
[   73.210000] Buffer I/O error on device sda, logical block 33794
[   73.210000] Buffer I/O error on device sda, logical block 33795
[   73.220000] Buffer I/O error on device sda, logical block 33796
[   73.220000] Buffer I/O error on device sda, logical block 33797
[   73.230000] Buffer I/O error on device sda, logical block 33798
[   73.240000] Buffer I/O error on device sda, logical block 33799
[   73.240000] Buffer I/O error on device sda, logical block 33800
[   73.250000] Buffer I/O error on device sda, logical block 33801
[   73.250000] Buffer I/O error on device sda, logical block 33802
[   73.260000] Buffer I/O error on device sda, logical block 33803
[   73.270000] Buffer I/O error on device sda, logical block 33804
[   73.270000] Buffer I/O error on device sda, logical block 33805
[   73.280000] Buffer I/O error on device sda, logical block 33806
[   73.280000] Buffer I/O error on device sda, logical block 33807
[   73.290000] Buffer I/O error on device sda, logical block 33808
[   73.300000] Buffer I/O error on device sda, logical block 33809
[   73.300000] Buffer I/O error on device sda, logical block 33810
[   73.310000] Buffer I/O error on device sda, logical block 33811
[   73.310000] Buffer I/O error on device sda, logical block 33812
[   73.320000] Buffer I/O error on device sda, logical block 33813
[   73.320000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 1540096 size 126976 starting block 33814)
[   73.340000] sd 0:0:0:0: [sda] Unhandled sense code
[   73.350000] sd 0:0:0:0: [sda]
[   73.350000] Result: hostbyte=0x00 driverbyte=0x08
[   73.360000] sd 0:0:0:0: [sda]
[   73.360000] Sense Key : 0x7 [current]
[   73.370000] ASC=0x27 ASCQ=0x0
[   73.370000] sd 0:0:0:0: [sda] CDB:
[   73.370000] cdb[0]=0x2a: 2a 00 00 04 20 b0 00 00 f0 00
[   73.380000] Buffer I/O error on device sda, logical block 33814
[   73.380000] Buffer I/O error on device sda, logical block 33815
[   73.390000] Buffer I/O error on device sda, logical block 33816
[   73.390000] Buffer I/O error on device sda, logical block 33817
[   73.400000] Buffer I/O error on device sda, logical block 33818
[   73.410000] Buffer I/O error on device sda, logical block 33819
[   73.410000] Buffer I/O error on device sda, logical block 33820
[   73.420000] Buffer I/O error on device sda, logical block 33821
[   73.420000] Buffer I/O error on device sda, logical block 33822
[   73.430000] Buffer I/O error on device sda, logical block 33823
[   73.440000] Buffer I/O error on device sda, logical block 33824
[   73.440000] Buffer I/O error on device sda, logical block 33825
[   73.450000] Buffer I/O error on device sda, logical block 33826
[   73.450000] Buffer I/O error on device sda, logical block 33827
[   73.460000] Buffer I/O error on device sda, logical block 33828
[   73.470000] Buffer I/O error on device sda, logical block 33829
[   73.470000] Buffer I/O error on device sda, logical block 33830
[   73.480000] Buffer I/O error on device sda, logical block 33831
[   73.480000] Buffer I/O error on device sda, logical block 33832
[   73.490000] Buffer I/O error on device sda, logical block 33833
[   73.500000] Buffer I/O error on device sda, logical block 33834
[   73.500000] Buffer I/O error on device sda, logical block 33835
[   73.510000] Buffer I/O error on device sda, logical block 33836
[   73.510000] Buffer I/O error on device sda, logical block 33837
[   73.520000] Buffer I/O error on device sda, logical block 33838
[   73.520000] Buffer I/O error on device sda, logical block 33839
[   73.530000] Buffer I/O error on device sda, logical block 33840
[   73.540000] Buffer I/O error on device sda, logical block 33841
[   73.540000] Buffer I/O error on device sda, logical block 33842
[   73.550000] Buffer I/O error on device sda, logical block 33843
[   73.550000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 1662976 size 126976 starting block 33844)
[   73.570000] sd 0:0:0:0: [sda] Unhandled sense code
[   73.580000] Result: hostbyte=0x00 driverbyte=0x08
[   73.580000] sd 0:0:0:0: [sda]
[   73.580000] Sense Key : 0x7 [current]
[   73.590000] sd 0:0:0:0: [sda]
[   73.590000] ASC=0x27 ASCQ=0x0
[   73.590000] sd 0:0:0:0: [sda] CDB:
[   73.600000] cdb[0]=0x2a: 2a 00 00 04 21 a0 00 00 e0 00
[   73.600000] Buffer I/O error on device sda, logical block 33844
[   73.610000] Buffer I/O error on device sda, logical block 33845
[   73.610000] Buffer I/O error on device sda, logical block 33846
[   73.620000] Buffer I/O error on device sda, logical block 33847
[   73.630000] Buffer I/O error on device sda, logical block 33848
[   73.630000] Buffer I/O error on device sda, logical block 33849
[   73.640000] Buffer I/O error on device sda, logical block 33850
[   73.640000] Buffer I/O error on device sda, logical block 33851
[   73.650000] Buffer I/O error on device sda, logical block 33852
[   73.660000] Buffer I/O error on device sda, logical block 33853
[   73.660000] Buffer I/O error on device sda, logical block 33854
[   73.670000] Buffer I/O error on device sda, logical block 33855
[   73.670000] Buffer I/O error on device sda, logical block 33856
[   73.680000] Buffer I/O error on device sda, logical block 33857
[   73.680000] Buffer I/O error on device sda, logical block 33858
[   73.690000] Buffer I/O error on device sda, logical block 33859
[   73.700000] Buffer I/O error on device sda, logical block 33860
[   73.700000] Buffer I/O error on device sda, logical block 33861
[   73.710000] Buffer I/O error on device sda, logical block 33862
[   73.710000] Buffer I/O error on device sda, logical block 33863
[   73.720000] Buffer I/O error on device sda, logical block 33864
[   73.730000] Buffer I/O error on device sda, logical block 33865
[   73.730000] Buffer I/O error on device sda, logical block 33866
[   73.740000] Buffer I/O error on device sda, logical block 33867
[   73.740000] Buffer I/O error on device sda, logical block 33868
[   73.750000] Buffer I/O error on device sda, logical block 33869
[   73.760000] Buffer I/O error on device sda, logical block 33870
[   73.760000] Buffer I/O error on device sda, logical block 33871
[   73.770000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 1785856 size 114688 starting block 33872)
[   73.790000] sd 0:0:0:0: [sda] Unhandled sense code
[   73.790000] Result: hostbyte=0x00 driverbyte=0x08
[   73.800000] sd 0:0:0:0: [sda]
[   73.800000] Sense Key : 0x7 [current]
[   73.810000] ASC=0x27 ASCQ=0x0
[   73.810000] sd 0:0:0:0: [sda] CDB:
[   73.810000] cdb[0]=0x2a: 2a 00 00 04 22 80 00 00 f0 00
[   73.820000] Buffer I/O error on device sda, logical block 33872
[   73.820000] Buffer I/O error on device sda, logical block 33873
[   73.830000] Buffer I/O error on device sda, logical block 33874
[   73.840000] Buffer I/O error on device sda, logical block 33875
[   73.840000] Buffer I/O error on device sda, logical block 33876
[   73.850000] Buffer I/O error on device sda, logical block 33877
[   73.850000] Buffer I/O error on device sda, logical block 33878
[   73.860000] Buffer I/O error on device sda, logical block 33879
[   73.870000] Buffer I/O error on device sda, logical block 33880
[   73.870000] Buffer I/O error on device sda, logical block 33881
[   73.880000] Buffer I/O error on device sda, logical block 33882
[   73.880000] Buffer I/O error on device sda, logical block 33883
[   73.890000] Buffer I/O error on device sda, logical block 33884
[   73.890000] Buffer I/O error on device sda, logical block 33885
[   73.900000] Buffer I/O error on device sda, logical block 33886
[   73.910000] Buffer I/O error on device sda, logical block 33887
[   73.910000] Buffer I/O error on device sda, logical block 33888
[   73.920000] Buffer I/O error on device sda, logical block 33889
[   73.920000] Buffer I/O error on device sda, logical block 33890
[   73.930000] Buffer I/O error on device sda, logical block 33891
[   73.940000] Buffer I/O error on device sda, logical block 33892
[   73.940000] Buffer I/O error on device sda, logical block 33893
[   73.950000] Buffer I/O error on device sda, logical block 33894
[   73.950000] Buffer I/O error on device sda, logical block 33895
[   73.960000] Buffer I/O error on device sda, logical block 33896
[   73.970000] Buffer I/O error on device sda, logical block 33897
[   73.970000] Buffer I/O error on device sda, logical block 33898
[   73.980000] Buffer I/O error on device sda, logical block 33899
[   73.980000] Buffer I/O error on device sda, logical block 33900
[   73.990000] Buffer I/O error on device sda, logical block 33901
[   73.990000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 1900544 size 126976 starting block 33902)
[   74.010000] sd 0:0:0:0: [sda] Unhandled sense code
[   74.020000] sd 0:0:0:0: [sda]
[   74.020000] Result: hostbyte=0x00 driverbyte=0x08
[   74.030000] sd 0:0:0:0: [sda]
[   74.030000] Sense Key : 0x7 [current]
[   74.040000] ASC=0x27 ASCQ=0x0
[   74.040000] sd 0:0:0:0: [sda] CDB:
[   74.040000] cdb[0]=0x2a: 2a 00 00 04 23 70 00 00 90 00
[   74.050000] Buffer I/O error on device sda, logical block 33902
[   74.050000] Buffer I/O error on device sda, logical block 33903
[   74.060000] Buffer I/O error on device sda, logical block 33904
[   74.070000] Buffer I/O error on device sda, logical block 33905
[   74.070000] Buffer I/O error on device sda, logical block 33906
[   74.080000] Buffer I/O error on device sda, logical block 33907
[   74.080000] Buffer I/O error on device sda, logical block 33908
[   74.090000] Buffer I/O error on device sda, logical block 33909
[   74.090000] Buffer I/O error on device sda, logical block 33910
[   74.100000] Buffer I/O error on device sda, logical block 33911
[   74.110000] Buffer I/O error on device sda, logical block 33912
[   74.110000] Buffer I/O error on device sda, logical block 33913
[   74.120000] Buffer I/O error on device sda, logical block 33914
[   74.120000] Buffer I/O error on device sda, logical block 33915
[   74.130000] Buffer I/O error on device sda, logical block 33916
[   74.140000] Buffer I/O error on device sda, logical block 33917
[   74.140000] Buffer I/O error on device sda, logical block 33918
[   74.150000] Buffer I/O error on device sda, logical block 33919
[   74.150000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 2023424 size 73728 starting block 33920)
[   74.170000] sd 0:0:0:0: [sda] Unhandled sense code
[   74.170000] Result: hostbyte=0x00 driverbyte=0x08
[   74.180000] sd 0:0:0:0: [sda]
[   74.180000] Sense Key : 0x7 [current]
[   74.190000] sd 0:0:0:0: [sda]
[   74.190000] ASC=0x27 ASCQ=0x0
[   74.190000] sd 0:0:0:0: [sda] CDB:
[   74.200000] cdb[0]=0x2a: 2a 00 00 04 24 00 00 00 f0 00
[   74.200000] Buffer I/O error on device sda, logical block 33920
[   74.210000] Buffer I/O error on device sda, logical block 33921
[   74.210000] Buffer I/O error on device sda, logical block 33922
[   74.220000] Buffer I/O error on device sda, logical block 33923
[   74.220000] Buffer I/O error on device sda, logical block 33924
[   74.230000] Buffer I/O error on device sda, logical block 33925
[   74.240000] Buffer I/O error on device sda, logical block 33926
[   74.240000] Buffer I/O error on device sda, logical block 33927
[   74.250000] Buffer I/O error on device sda, logical block 33928
[   74.250000] Buffer I/O error on device sda, logical block 33929
[   74.260000] Buffer I/O error on device sda, logical block 33930
[   74.270000] Buffer I/O error on device sda, logical block 33931
[   74.270000] Buffer I/O error on device sda, logical block 33932
[   74.280000] Buffer I/O error on device sda, logical block 33933
[   74.280000] Buffer I/O error on device sda, logical block 33934
....... rest on next post!
For the sequel of above code see the following 2 messages.
What todo now!!! On every reboot no internal database anymore. Many times try a factoy reset but no improvement. I spent hours and hours and try everyting with no better results.
Thanks for you advice.
MeteoLeudal
Re: Not stable from firmware 2.9
[   74.290000] Buffer I/O error on device sda, logical block 33935
[   74.300000] Buffer I/O error on device sda, logical block 33936
[   74.300000] Buffer I/O error on device sda, logical block 33937
[   74.310000] Buffer I/O error on device sda, logical block 33938
[   74.310000] Buffer I/O error on device sda, logical block 33939
[   74.320000] Buffer I/O error on device sda, logical block 33940
[   74.320000] Buffer I/O error on device sda, logical block 33941
[   74.330000] Buffer I/O error on device sda, logical block 33942
[   74.340000] Buffer I/O error on device sda, logical block 33943
[   74.340000] Buffer I/O error on device sda, logical block 33944
[   74.350000] Buffer I/O error on device sda, logical block 33945
[   74.350000] Buffer I/O error on device sda, logical block 33946
[   74.360000] Buffer I/O error on device sda, logical block 33947
[   74.370000] Buffer I/O error on device sda, logical block 33948
[   74.370000] Buffer I/O error on device sda, logical block 33949
[   74.380000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 2097152 size 126976 starting block 33950)
[   74.400000] sd 0:0:0:0: [sda] Unhandled sense code
[   74.400000] Result: hostbyte=0x00 driverbyte=0x08
[   74.410000] sd 0:0:0:0: [sda]
[   74.410000] Sense Key : 0x7 [current]
[   74.420000] ASC=0x27 ASCQ=0x0
[   74.420000] sd 0:0:0:0: [sda] CDB:
[   74.420000] cdb[0]=0x2a: 2a 00 00 04 24 f0 00 00 f0 00
[   74.430000] Buffer I/O error on device sda, logical block 33950
[   74.430000] Buffer I/O error on device sda, logical block 33951
[   74.440000] Buffer I/O error on device sda, logical block 33952
[   74.450000] Buffer I/O error on device sda, logical block 33953
[   74.450000] Buffer I/O error on device sda, logical block 33954
[   74.460000] Buffer I/O error on device sda, logical block 33955
[   74.460000] Buffer I/O error on device sda, logical block 33956
[   74.470000] Buffer I/O error on device sda, logical block 33957
[   74.480000] Buffer I/O error on device sda, logical block 33958
[   74.480000] Buffer I/O error on device sda, logical block 33959
[   74.490000] Buffer I/O error on device sda, logical block 33960
[   74.490000] Buffer I/O error on device sda, logical block 33961
[   74.500000] Buffer I/O error on device sda, logical block 33962
[   74.500000] Buffer I/O error on device sda, logical block 33963
[   74.510000] Buffer I/O error on device sda, logical block 33964
[   74.520000] Buffer I/O error on device sda, logical block 33965
[   74.520000] Buffer I/O error on device sda, logical block 33966
[   74.530000] Buffer I/O error on device sda, logical block 33967
[   74.530000] Buffer I/O error on device sda, logical block 33968
[   74.540000] Buffer I/O error on device sda, logical block 33969
[   74.550000] Buffer I/O error on device sda, logical block 33970
[   74.550000] Buffer I/O error on device sda, logical block 33971
[   74.560000] Buffer I/O error on device sda, logical block 33972
[   74.560000] Buffer I/O error on device sda, logical block 33973
[   74.570000] Buffer I/O error on device sda, logical block 33974
[   74.580000] Buffer I/O error on device sda, logical block 33975
[   74.580000] Buffer I/O error on device sda, logical block 33976
[   74.590000] Buffer I/O error on device sda, logical block 33977
[   74.590000] Buffer I/O error on device sda, logical block 33978
[   74.600000] Buffer I/O error on device sda, logical block 33979
[   74.600000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 2220032 size 126976 starting block 33980)
[   74.620000] sd 0:0:0:0: [sda] Unhandled sense code
[   74.630000] sd 0:0:0:0: [sda]
[   74.630000] Result: hostbyte=0x00 driverbyte=0x08
[   74.640000] Sense Key : 0x7 [current]
[   74.640000] sd 0:0:0:0: [sda]
[   74.640000] ASC=0x27 ASCQ=0x0
[   74.650000] sd 0:0:0:0: [sda] CDB:
[   74.650000] cdb[0]=0x2a: 2a 00 00 04 25 e0 00 00 20 00
[   74.660000] Buffer I/O error on device sda, logical block 33980
[   74.660000] Buffer I/O error on device sda, logical block 33981
[   74.670000] Buffer I/O error on device sda, logical block 33982
[   74.670000] Buffer I/O error on device sda, logical block 33983
[   74.680000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 2342912 size 16384 starting block 33984)
[   74.780000] sd 0:0:0:0: [sda] Unhandled sense code
[   74.780000] Result: hostbyte=0x00 driverbyte=0x08
[   74.790000] sd 0:0:0:0: [sda]
[   74.790000] Sense Key : 0x7 [current]
[   74.800000] ASC=0x27 ASCQ=0x0
[   74.800000] sd 0:0:0:0: [sda] CDB:
[   74.800000] cdb[0]=0x2a: 2a 00 00 04 26 00 00 00 f0 00
[   74.810000] Buffer I/O error on device sda, logical block 33984
[   74.810000] Buffer I/O error on device sda, logical block 33985
[   74.820000] Buffer I/O error on device sda, logical block 33986
[   74.830000] Buffer I/O error on device sda, logical block 33987
[   74.830000] Buffer I/O error on device sda, logical block 33988
[   74.840000] Buffer I/O error on device sda, logical block 33989
[   74.840000] Buffer I/O error on device sda, logical block 33990
[   74.850000] Buffer I/O error on device sda, logical block 33991
[   74.860000] Buffer I/O error on device sda, logical block 33992
[   74.860000] Buffer I/O error on device sda, logical block 33993
[   74.870000] Buffer I/O error on device sda, logical block 33994
[   74.870000] Buffer I/O error on device sda, logical block 33995
[   74.880000] Buffer I/O error on device sda, logical block 33996
[   74.880000] Buffer I/O error on device sda, logical block 33997
[   74.890000] Buffer I/O error on device sda, logical block 33998
[   74.900000] Buffer I/O error on device sda, logical block 33999
[   74.900000] Buffer I/O error on device sda, logical block 34000
[   74.910000] Buffer I/O error on device sda, logical block 34001
[   74.910000] Buffer I/O error on device sda, logical block 34002
[   74.920000] Buffer I/O error on device sda, logical block 34003
[   74.930000] Buffer I/O error on device sda, logical block 34004
[   74.930000] Buffer I/O error on device sda, logical block 34005
[   74.940000] Buffer I/O error on device sda, logical block 34006
[   74.940000] Buffer I/O error on device sda, logical block 34007
[   74.950000] Buffer I/O error on device sda, logical block 34008
[   74.960000] Buffer I/O error on device sda, logical block 34009
[   74.960000] Buffer I/O error on device sda, logical block 34010
[   74.970000] Buffer I/O error on device sda, logical block 34011
[   74.970000] Buffer I/O error on device sda, logical block 34012
[   74.980000] Buffer I/O error on device sda, logical block 34013
[   74.980000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 2359296 size 126976 starting block 34014)
[   75.000000] sd 0:0:0:0: [sda] Unhandled sense code
[   75.010000] sd 0:0:0:0: [sda]
[   75.010000] Result: hostbyte=0x00 driverbyte=0x08
[   75.020000] sd 0:0:0:0: [sda]
[   75.020000] Sense Key : 0x7 [current]
[   75.030000] ASC=0x27 ASCQ=0x0
[   75.030000] sd 0:0:0:0: [sda] CDB:
[   75.030000] cdb[0]=0x2a: 2a 00 00 04 26 f0 00 00 f0 00
[   75.040000] Buffer I/O error on device sda, logical block 34014
[   75.040000] Buffer I/O error on device sda, logical block 34015
[   75.050000] Buffer I/O error on device sda, logical block 34016
[   75.060000] Buffer I/O error on device sda, logical block 34017
[   75.060000] Buffer I/O error on device sda, logical block 34018
[   75.070000] Buffer I/O error on device sda, logical block 34019
[   75.070000] Buffer I/O error on device sda, logical block 34020
[   75.080000] Buffer I/O error on device sda, logical block 34021
[   75.080000] Buffer I/O error on device sda, logical block 34022
[   75.090000] Buffer I/O error on device sda, logical block 34023
[   75.100000] Buffer I/O error on device sda, logical block 34024
[   75.100000] Buffer I/O error on device sda, logical block 34025
[   75.110000] Buffer I/O error on device sda, logical block 34026
[   75.110000] Buffer I/O error on device sda, logical block 34027
[   75.120000] Buffer I/O error on device sda, logical block 34028
[   75.130000] Buffer I/O error on device sda, logical block 34029
[   75.130000] Buffer I/O error on device sda, logical block 34030
[   75.140000] Buffer I/O error on device sda, logical block 34031
[   75.140000] Buffer I/O error on device sda, logical block 34032
[   75.150000] Buffer I/O error on device sda, logical block 34033
[   75.160000] Buffer I/O error on device sda, logical block 34034
[   75.160000] Buffer I/O error on device sda, logical block 34035
[   75.170000] Buffer I/O error on device sda, logical block 34036
[   75.170000] Buffer I/O error on device sda, logical block 34037
[   75.180000] Buffer I/O error on device sda, logical block 34038
[   75.190000] Buffer I/O error on device sda, logical block 34039
[   75.190000] Buffer I/O error on device sda, logical block 34040
[   75.200000] Buffer I/O error on device sda, logical block 34041
[   75.200000] Buffer I/O error on device sda, logical block 34042
[   75.210000] Buffer I/O error on device sda, logical block 34043
[   75.210000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 2482176 size 126976 starting block 34044)
[   75.230000] sd 0:0:0:0: [sda] Unhandled sense code
[   75.240000] sd 0:0:0:0: [sda]
[   75.240000] Result: hostbyte=0x00 driverbyte=0x08
[   75.250000] sd 0:0:0:0: [sda]
[   75.250000] Sense Key : 0x7 [current]
[   75.260000] ASC=0x27 ASCQ=0x0
[   75.260000] sd 0:0:0:0: [sda] CDB:
[   75.260000] cdb[0]=0x2a: 2a 00 00 04 27 e0 00 00 f0 00
[   75.270000] Buffer I/O error on device sda, logical block 34044
[   75.270000] Buffer I/O error on device sda, logical block 34045
[   75.280000] Buffer I/O error on device sda, logical block 34046
[   75.290000] Buffer I/O error on device sda, logical block 34047
[   75.290000] Buffer I/O error on device sda, logical block 34048
[   75.300000] Buffer I/O error on device sda, logical block 34049
[   75.300000] Buffer I/O error on device sda, logical block 34050
[   75.310000] Buffer I/O error on device sda, logical block 34051
[   75.310000] Buffer I/O error on device sda, logical block 34052
[   75.320000] Buffer I/O error on device sda, logical block 34053
[   75.330000] Buffer I/O error on device sda, logical block 34054
[   75.330000] Buffer I/O error on device sda, logical block 34055
[   75.340000] Buffer I/O error on device sda, logical block 34056
[   75.340000] Buffer I/O error on device sda, logical block 34057
[   75.350000] Buffer I/O error on device sda, logical block 34058
[   75.360000] Buffer I/O error on device sda, logical block 34059
[   75.360000] Buffer I/O error on device sda, logical block 34060
[   75.370000] Buffer I/O error on device sda, logical block 34061
[   75.370000] Buffer I/O error on device sda, logical block 34062
[   75.380000] Buffer I/O error on device sda, logical block 34063
[   75.390000] Buffer I/O error on device sda, logical block 34064
[   75.390000] Buffer I/O error on device sda, logical block 34065
[   75.400000] Buffer I/O error on device sda, logical block 34066
[   75.400000] Buffer I/O error on device sda, logical block 34067
[   75.410000] Buffer I/O error on device sda, logical block 34068
[   75.420000] Buffer I/O error on device sda, logical block 34069
[   75.420000] Buffer I/O error on device sda, logical block 34070
[   75.430000] Buffer I/O error on device sda, logical block 34071
[   75.430000] Buffer I/O error on device sda, logical block 34072
[   75.440000] Buffer I/O error on device sda, logical block 34073
[   75.440000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 2605056 size 126976 starting block 34074)
[   75.460000] sd 0:0:0:0: [sda] Unhandled sense code
[   75.470000] Result: hostbyte=0x00 driverbyte=0x08
[   75.470000] sd 0:0:0:0: [sda]
[   75.470000] Sense Key : 0x7 [current]
[   75.480000] sd 0:0:0:0: [sda]
[   75.480000] ASC=0x27 ASCQ=0x0
[   75.480000] sd 0:0:0:0: [sda] CDB:
[   75.490000] cdb[0]=0x2a: 2a 00 00 04 28 d0 00 00 f0 00
[   75.490000] blk_update_request: 15 callbacks suppressed
[   75.500000] end_request: critical target error, dev sda, sector 272592
[   75.500000] Buffer I/O error on device sda, logical block 34074
[   75.510000] Buffer I/O error on device sda, logical block 34075
[   75.520000] Buffer I/O error on device sda, logical block 34076
[   75.520000] Buffer I/O error on device sda, logical block 34077
[   75.530000] Buffer I/O error on device sda, logical block 34078
[   75.530000] Buffer I/O error on device sda, logical block 34079
[   75.540000] Buffer I/O error on device sda, logical block 34080
[   75.540000] Buffer I/O error on device sda, logical block 34081
[   75.550000] Buffer I/O error on device sda, logical block 34082
[   75.560000] Buffer I/O error on device sda, logical block 34083
[   75.560000] Buffer I/O error on device sda, logical block 34084
[   75.570000] Buffer I/O error on device sda, logical block 34085
[   75.570000] Buffer I/O error on device sda, logical block 34086
[   75.580000] Buffer I/O error on device sda, logical block 34087
[   75.590000] Buffer I/O error on device sda, logical block 34088
[   75.590000] Buffer I/O error on device sda, logical block 34089
[   75.600000] Buffer I/O error on device sda, logical block 34090
[   75.600000] Buffer I/O error on device sda, logical block 34091
[   75.610000] Buffer I/O error on device sda, logical block 34092
[   75.620000] Buffer I/O error on device sda, logical block 34093
[   75.620000] Buffer I/O error on device sda, logical block 34094
[   75.630000] Buffer I/O error on device sda, logical block 34095
[   75.630000] Buffer I/O error on device sda, logical block 34096
[   75.640000] Buffer I/O error on device sda, logical block 34097
[   75.640000] Buffer I/O error on device sda, logical block 34098
[   75.650000] Buffer I/O error on device sda, logical block 34099
[   75.660000] Buffer I/O error on device sda, logical block 34100
[   75.660000] Buffer I/O error on device sda, logical block 34101
[   75.670000] Buffer I/O error on device sda, logical block 34102
[   75.670000] Buffer I/O error on device sda, logical block 34103
[   75.680000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 2727936 size 126976 starting block 34104)
[   75.700000] sd 0:0:0:0: [sda] Unhandled sense code
[   75.700000] Result: hostbyte=0x00 driverbyte=0x08
[   75.710000] sd 0:0:0:0: [sda]
[   75.710000] Sense Key : 0x7 [current]
[   75.720000] ASC=0x27 ASCQ=0x0
[   75.720000] sd 0:0:0:0: [sda] CDB:
[   75.720000] cdb[0]=0x2a: 2a 00 00 04 29 c0 00 00 f0 00
[   75.730000] end_request: critical target error, dev sda, sector 272832
[   75.730000] Buffer I/O error on device sda, logical block 34104
[   75.740000] Buffer I/O error on device sda, logical block 34105
[   75.750000] Buffer I/O error on device sda, logical block 34106
[   75.750000] Buffer I/O error on device sda, logical block 34107
[   75.760000] Buffer I/O error on device sda, logical block 34108
[   75.760000] Buffer I/O error on device sda, logical block 34109
[   75.770000] Buffer I/O error on device sda, logical block 34110
[   75.780000] Buffer I/O error on device sda, logical block 34111
[   75.780000] Buffer I/O error on device sda, logical block 34112
[   75.790000] Buffer I/O error on device sda, logical block 34113
[   75.790000] Buffer I/O error on device sda, logical block 34114
[   75.800000] Buffer I/O error on device sda, logical block 34115
[   75.810000] Buffer I/O error on device sda, logical block 34116
[   75.810000] Buffer I/O error on device sda, logical block 34117
[   75.820000] Buffer I/O error on device sda, logical block 34118
[   75.820000] Buffer I/O error on device sda, logical block 34119
[   75.830000] Buffer I/O error on device sda, logical block 34120
[   75.830000] Buffer I/O error on device sda, logical block 34121
[   75.840000] Buffer I/O error on device sda, logical block 34122
[   75.850000] Buffer I/O error on device sda, logical block 34123
[   75.850000] Buffer I/O error on device sda, logical block 34124
[   75.860000] Buffer I/O error on device sda, logical block 34125
[   75.860000] Buffer I/O error on device sda, logical block 34126
[   75.870000] Buffer I/O error on device sda, logical block 34127
[   75.880000] Buffer I/O error on device sda, logical block 34128
[   75.880000] Buffer I/O error on device sda, logical block 34129
[   75.890000] Buffer I/O error on device sda, logical block 34130
[   75.890000] Buffer I/O error on device sda, logical block 34131
[   75.900000] Buffer I/O error on device sda, logical block 34132
[   75.910000] Buffer I/O error on device sda, logical block 34133
[   75.910000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 2850816 size 126976 starting block 34134)
[   75.930000] sd 0:0:0:0: [sda] Unhandled sense code
[   75.940000] Result: hostbyte=0x00 driverbyte=0x08
[   75.940000] sd 0:0:0:0: [sda]
[   75.950000] Sense Key : 0x7 [current]
[   75.950000] sd 0:0:0:0: [sda]
[   75.950000] ASC=0x27 ASCQ=0x0
[   75.960000] sd 0:0:0:0: [sda] CDB:
[   75.960000] cdb[0]=0x2a: 2a 00 00 04 2a b0 00 00 f0 00
[   75.960000] end_request: critical target error, dev sda, sector 273072
[   75.970000] Buffer I/O error on device sda, logical block 34134
[   75.980000] Buffer I/O error on device sda, logical block 34135
[   75.980000] Buffer I/O error on device sda, logical block 34136
[   75.990000] Buffer I/O error on device sda, logical block 34137
[   75.990000] Buffer I/O error on device sda, logical block 34138
[   76.000000] Buffer I/O error on device sda, logical block 34139
[   76.010000] Buffer I/O error on device sda, logical block 34140
[   76.010000] Buffer I/O error on device sda, logical block 34141
[   76.020000] Buffer I/O error on device sda, logical block 34142
[   76.020000] Buffer I/O error on device sda, logical block 34143
[   76.030000] Buffer I/O error on device sda, logical block 34144
[   76.040000] Buffer I/O error on device sda, logical block 34145
[   76.040000] Buffer I/O error on device sda, logical block 34146
[   76.050000] Buffer I/O error on device sda, logical block 34147
[   76.050000] Buffer I/O error on device sda, logical block 34148
[   76.060000] Buffer I/O error on device sda, logical block 34149
[   76.060000] Buffer I/O error on device sda, logical block 34150
[   76.070000] Buffer I/O error on device sda, logical block 34151
[   76.080000] Buffer I/O error on device sda, logical block 34152
[   76.080000] Buffer I/O error on device sda, logical block 34153
[   76.090000] Buffer I/O error on device sda, logical block 34154
[   76.090000] Buffer I/O error on device sda, logical block 34155
[   76.100000] Buffer I/O error on device sda, logical block 34156
[   76.110000] Buffer I/O error on device sda, logical block 34157
[   76.110000] Buffer I/O error on device sda, logical block 34158
[   76.120000] Buffer I/O error on device sda, logical block 34159
[   76.120000] Buffer I/O error on device sda, logical block 34160
[   76.130000] Buffer I/O error on device sda, logical block 34161
[   76.140000] Buffer I/O error on device sda, logical block 34162
[   76.140000] Buffer I/O error on device sda, logical block 34163
[   76.150000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 2973696 size 126976 starting block 34164)
[   76.170000] sd 0:0:0:0: [sda] Unhandled sense code
[   76.170000] Result: hostbyte=0x00 driverbyte=0x08
[   76.180000] sd 0:0:0:0: [sda]
[   76.180000] Sense Key : 0x7 [current]
[   76.190000] ASC=0x27 ASCQ=0x0
[   76.190000] sd 0:0:0:0: [sda] CDB:
[   76.190000] cdb[0]=0x2a: 2a 00 00 04 2b a0 00 00 f0 00
[   76.200000] end_request: critical target error, dev sda, sector 273312
[   76.200000] Buffer I/O error on device sda, logical block 34164
[   76.210000] Buffer I/O error on device sda, logical block 34165
[   76.220000] Buffer I/O error on device sda, logical block 34166
[   76.220000] Buffer I/O error on device sda, logical block 34167
[   76.230000] Buffer I/O error on device sda, logical block 34168
[   76.230000] Buffer I/O error on device sda, logical block 34169
[   76.240000] Buffer I/O error on device sda, logical block 34170
[   76.250000] Buffer I/O error on device sda, logical block 34171
[   76.250000] Buffer I/O error on device sda, logical block 34172
[   76.260000] Buffer I/O error on device sda, logical block 34173
[   76.260000] Buffer I/O error on device sda, logical block 34174
[   76.270000] Buffer I/O error on device sda, logical block 34175
[   76.280000] Buffer I/O error on device sda, logical block 34176
[   76.280000] Buffer I/O error on device sda, logical block 34177
[   76.290000] Buffer I/O error on device sda, logical block 34178
[   76.290000] Buffer I/O error on device sda, logical block 34179
[   76.300000] Buffer I/O error on device sda, logical block 34180
[   76.300000] Buffer I/O error on device sda, logical block 34181
[   76.310000] Buffer I/O error on device sda, logical block 34182
[   76.320000] Buffer I/O error on device sda, logical block 34183
[   76.320000] Buffer I/O error on device sda, logical block 34184
[   76.330000] Buffer I/O error on device sda, logical block 34185
[   76.330000] Buffer I/O error on device sda, logical block 34186
[   76.340000] Buffer I/O error on device sda, logical block 34187
[   76.350000] Buffer I/O error on device sda, logical block 34188
[   76.350000] Buffer I/O error on device sda, logical block 34189
[   76.360000] Buffer I/O error on device sda, logical block 34190
[   76.360000] Buffer I/O error on device sda, logical block 34191
[   76.370000] Buffer I/O error on device sda, logical block 34192
[   76.380000] Buffer I/O error on device sda, logical block 34193
[   76.380000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 3096576 size 126976 starting block 34194)
[   76.400000] sd 0:0:0:0: [sda] Unhandled sense code
[   76.400000] Result: hostbyte=0x00 driverbyte=0x08
[   76.410000] sd 0:0:0:0: [sda]
[   76.410000] Sense Key : 0x7 [current]
[   76.420000] ASC=0x27 ASCQ=0x0
[   76.420000] sd 0:0:0:0: [sda] CDB:
[   76.420000] cdb[0]=0x2a: 2a 00 00 04 2c 90 00 00 f0 00
[   76.430000] end_request: critical target error, dev sda, sector 273552
[   76.440000] Buffer I/O error on device sda, logical block 34194
[   76.440000] Buffer I/O error on device sda, logical block 34195
[   76.450000] Buffer I/O error on device sda, logical block 34196
[   76.450000] Buffer I/O error on device sda, logical block 34197
[   76.460000] Buffer I/O error on device sda, logical block 34198
[   76.470000] Buffer I/O error on device sda, logical block 34199
[   76.470000] Buffer I/O error on device sda, logical block 34200
[   76.480000] Buffer I/O error on device sda, logical block 34201
[   76.480000] Buffer I/O error on device sda, logical block 34202
[   76.490000] Buffer I/O error on device sda, logical block 34203
[   76.490000] Buffer I/O error on device sda, logical block 34204
[   76.500000] Buffer I/O error on device sda, logical block 34205
[   76.510000] Buffer I/O error on device sda, logical block 34206
[   76.510000] Buffer I/O error on device sda, logical block 34207
[   76.520000] Buffer I/O error on device sda, logical block 34208
[   76.520000] Buffer I/O error on device sda, logical block 34209
[   76.530000] Buffer I/O error on device sda, logical block 34210
[   76.540000] Buffer I/O error on device sda, logical block 34211
[   76.540000] Buffer I/O error on device sda, logical block 34212
[   76.550000] Buffer I/O error on device sda, logical block 34213
[   76.550000] Buffer I/O error on device sda, logical block 34214
[   76.560000] Buffer I/O error on device sda, logical block 34215
[   76.570000] Buffer I/O error on device sda, logical block 34216
[   76.570000] Buffer I/O error on device sda, logical block 34217
[   76.580000] Buffer I/O error on device sda, logical block 34218
[   76.580000] Buffer I/O error on device sda, logical block 34219
[   76.590000] Buffer I/O error on device sda, logical block 34220
[   76.590000] Buffer I/O error on device sda, logical block 34221
[   76.600000] Buffer I/O error on device sda, logical block 34222
[   76.610000] Buffer I/O error on device sda, logical block 34223
[   76.610000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 3219456 size 126976 starting block 34224)
[   76.630000] sd 0:0:0:0: [sda] Unhandled sense code
[   76.640000] Result: hostbyte=0x00 driverbyte=0x08
[   76.640000] sd 0:0:0:0: [sda]
[   76.650000] Sense Key : 0x7 [current]
[   76.650000] sd 0:0:0:0: [sda]
[   76.650000] ASC=0x27 ASCQ=0x0
[   76.660000] sd 0:0:0:0: [sda] CDB:
[   76.660000] cdb[0]=0x2a: 2a 00 00 04 2d 80 00 00 f0 00
[   76.660000] end_request: critical target error, dev sda, sector 273792
[   76.670000] Buffer I/O error on device sda, logical block 34224
[   76.680000] Buffer I/O error on device sda, logical block 34225
[   76.680000] Buffer I/O error on device sda, logical block 34226
[   76.690000] Buffer I/O error on device sda, logical block 34227
[   76.690000] Buffer I/O error on device sda, logical block 34228
[   76.700000] Buffer I/O error on device sda, logical block 34229
[   76.710000] Buffer I/O error on device sda, logical block 34230
[   76.710000] Buffer I/O error on device sda, logical block 34231
[   76.720000] Buffer I/O error on device sda, logical block 34232
[   76.720000] Buffer I/O error on device sda, logical block 34233
[   76.730000] Buffer I/O error on device sda, logical block 34234
[   76.740000] Buffer I/O error on device sda, logical block 34235
[   76.740000] Buffer I/O error on device sda, logical block 34236
[   76.750000] Buffer I/O error on device sda, logical block 34237
[   76.750000] Buffer I/O error on device sda, logical block 34238
[   76.760000] Buffer I/O error on device sda, logical block 34239
[   76.760000] Buffer I/O error on device sda, logical block 34240
[   76.770000] Buffer I/O error on device sda, logical block 34241
[   76.780000] Buffer I/O error on device sda, logical block 34242
[   76.780000] Buffer I/O error on device sda, logical block 34243
[   76.790000] Buffer I/O error on device sda, logical block 34244
[   76.790000] Buffer I/O error on device sda, logical block 34245
[   76.800000] Buffer I/O error on device sda, logical block 34246
[   76.810000] Buffer I/O error on device sda, logical block 34247
[   76.810000] Buffer I/O error on device sda, logical block 34248
[   76.820000] Buffer I/O error on device sda, logical block 34249
[   76.820000] Buffer I/O error on device sda, logical block 34250
[   76.830000] Buffer I/O error on device sda, logical block 34251
[   76.840000] Buffer I/O error on device sda, logical block 34252
[   76.840000] Buffer I/O error on device sda, logical block 34253
[   76.850000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 3342336 size 126976 starting block 34254)
[   76.870000] sd 0:0:0:0: [sda] Unhandled sense code
[   76.870000] Result: hostbyte=0x00 driverbyte=0x08
[   76.880000] sd 0:0:0:0: [sda]
[   76.880000] Sense Key : 0x7 [current]
[   76.890000] ASC=0x27 ASCQ=0x0
[   76.890000] sd 0:0:0:0: [sda] CDB:
[   76.890000] cdb[0]=0x2a: 2a 00 00 04 2e 70 00 00 f0 00
[   76.900000] end_request: critical target error, dev sda, sector 274032
[   76.900000] Buffer I/O error on device sda, logical block 34254
[   76.910000] Buffer I/O error on device sda, logical block 34255
[   76.920000] Buffer I/O error on device sda, logical block 34256
[   76.920000] Buffer I/O error on device sda, logical block 34257
[   76.930000] Buffer I/O error on device sda, logical block 34258
[   76.930000] Buffer I/O error on device sda, logical block 34259
[   76.940000] Buffer I/O error on device sda, logical block 34260
[   76.950000] Buffer I/O error on device sda, logical block 34261
[   76.950000] Buffer I/O error on device sda, logical block 34262
[   76.960000] Buffer I/O error on device sda, logical block 34263
[   76.960000] Buffer I/O error on device sda, logical block 34264
[   76.970000] Buffer I/O error on device sda, logical block 34265
[   76.980000] Buffer I/O error on device sda, logical block 34266
[   76.980000] Buffer I/O error on device sda, logical block 34267
[   76.990000] Buffer I/O error on device sda, logical block 34268
[   76.990000] Buffer I/O error on device sda, logical block 34269
[   77.000000] Buffer I/O error on device sda, logical block 34270
[   77.000000] Buffer I/O error on device sda, logical block 34271
[   77.010000] Buffer I/O error on device sda, logical block 34272
[   77.020000] Buffer I/O error on device sda, logical block 34273
[   77.020000] Buffer I/O error on device sda, logical block 34274
[   77.030000] Buffer I/O error on device sda, logical block 34275
[   77.030000] Buffer I/O error on device sda, logical block 34276
[   77.040000] Buffer I/O error on device sda, logical block 34277
[   77.050000] Buffer I/O error on device sda, logical block 34278
[   77.050000] Buffer I/O error on device sda, logical block 34279
[   77.060000] Buffer I/O error on device sda, logical block 34280
[   77.060000] Buffer I/O error on device sda, logical block 34281
[   77.070000] Buffer I/O error on device sda, logical block 34282
[   77.080000] Buffer I/O error on device sda, logical block 34283
[   77.080000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 3465216 size 126976 starting block 34284)
[   77.100000] sd 0:0:0:0: [sda] Unhandled sense code
[   77.110000] Result: hostbyte=0x00 driverbyte=0x08
[   77.110000] sd 0:0:0:0: [sda]
[   77.120000] Sense Key : 0x7 [current]
[   77.120000] sd 0:0:0:0: [sda]
[   77.120000] ASC=0x27 ASCQ=0x0
[   77.130000] sd 0:0:0:0: [sda] CDB:
[   77.130000] cdb[0]=0x2a: 2a 00 00 04 2f 60 00 00 f0 00
[   77.130000] end_request: critical target error, dev sda, sector 274272
[   77.140000] Buffer I/O error on device sda, logical block 34284
[   77.150000] Buffer I/O error on device sda, logical block 34285
[   77.150000] Buffer I/O error on device sda, logical block 34286
[   77.160000] Buffer I/O error on device sda, logical block 34287
[   77.160000] Buffer I/O error on device sda, logical block 34288
[   77.170000] Buffer I/O error on device sda, logical block 34289
[   77.180000] Buffer I/O error on device sda, logical block 34290
[   77.180000] Buffer I/O error on device sda, logical block 34291
[   77.190000] Buffer I/O error on device sda, logical block 34292
[   77.190000] Buffer I/O error on device sda, logical block 34293
[   77.200000] Buffer I/O error on device sda, logical block 34294
[   77.210000] Buffer I/O error on device sda, logical block 34295
[   77.210000] Buffer I/O error on device sda, logical block 34296
[   77.220000] Buffer I/O error on device sda, logical block 34297
[   77.220000] Buffer I/O error on device sda, logical block 34298
[   77.230000] Buffer I/O error on device sda, logical block 34299
[   77.230000] Buffer I/O error on device sda, logical block 34300
[   77.240000] Buffer I/O error on device sda, logical block 34301
[   77.250000] Buffer I/O error on device sda, logical block 34302
[   77.250000] Buffer I/O error on device sda, logical block 34303
[   77.260000] Buffer I/O error on device sda, logical block 34304
[   77.260000] Buffer I/O error on device sda, logical block 34305
[   77.270000] Buffer I/O error on device sda, logical block 34306
[   77.280000] Buffer I/O error on device sda, logical block 34307
[   77.280000] Buffer I/O error on device sda, logical block 34308
[   77.290000] Buffer I/O error on device sda, logical block 34309
[   77.290000] Buffer I/O error on device sda, logical block 34310
[   77.300000] Buffer I/O error on device sda, logical block 34311
[   77.310000] Buffer I/O error on device sda, logical block 34312
[   77.310000] Buffer I/O error on device sda, logical block 34313
[   77.320000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 3588096 size 126976 starting block 34314)
[   77.330000] sd 0:0:0:0: [sda] Unhandled sense code
[   77.340000] sd 0:0:0:0: [sda]
[   77.340000] Result: hostbyte=0x00 driverbyte=0x08
[   77.350000] sd 0:0:0:0: [sda]
[   77.350000] Sense Key : 0x7 [current]
[   77.360000] ASC=0x27 ASCQ=0x0
[   77.360000] sd 0:0:0:0: [sda] CDB:
[   77.360000] cdb[0]=0x2a: 2a 00 00 04 30 50 00 00 f0 00
[   77.370000] end_request: critical target error, dev sda, sector 274512
[   77.370000] Buffer I/O error on device sda, logical block 34314
[   77.380000] Buffer I/O error on device sda, logical block 34315
[   77.390000] Buffer I/O error on device sda, logical block 34316
[   77.390000] Buffer I/O error on device sda, logical block 34317
[   77.400000] Buffer I/O error on device sda, logical block 34318
[   77.400000] Buffer I/O error on device sda, logical block 34319
[   77.410000] Buffer I/O error on device sda, logical block 34320
[   77.410000] Buffer I/O error on device sda, logical block 34321
[   77.420000] Buffer I/O error on device sda, logical block 34322
[   77.430000] Buffer I/O error on device sda, logical block 34323
[   77.430000] Buffer I/O error on device sda, logical block 34324
[   77.440000] Buffer I/O error on device sda, logical block 34325
[   77.440000] Buffer I/O error on device sda, logical block 34326
[   77.450000] Buffer I/O error on device sda, logical block 34327
[   77.460000] Buffer I/O error on device sda, logical block 34328
[   77.460000] Buffer I/O error on device sda, logical block 34329
[   77.470000] Buffer I/O error on device sda, logical block 34330
[   77.470000] Buffer I/O error on device sda, logical block 34331
[   77.480000] Buffer I/O error on device sda, logical block 34332
[   77.490000] Buffer I/O error on device sda, logical block 34333
[   77.490000] Buffer I/O error on device sda, logical block 34334
[   77.500000] Buffer I/O error on device sda, logical block 34335
[   77.500000] Buffer I/O error on device sda, logical block 34336
[   77.510000] Buffer I/O error on device sda, logical block 34337
[   77.510000] Buffer I/O error on device sda, logical block 34338
[   77.520000] Buffer I/O error on device sda, logical block 34339
[   77.530000] Buffer I/O error on device sda, logical block 34340
[   77.530000] Buffer I/O error on device sda, logical block 34341
[   77.540000] Buffer I/O error on device sda, logical block 34342
[   77.540000] Buffer I/O error on device sda, logical block 34343
[   77.550000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 3710976 size 126976 starting block 34344)
[   77.560000] sd 0:0:0:0: [sda] Unhandled sense code
[   77.570000] sd 0:0:0:0: [sda]
[   77.570000] Result: hostbyte=0x00 driverbyte=0x08
[   77.580000] sd 0:0:0:0: [sda]
[   77.580000] Sense Key : 0x7 [current]
[   77.590000] ASC=0x27 ASCQ=0x0
[   77.590000] sd 0:0:0:0: [sda] CDB:
[   77.590000] cdb[0]=0x2a: 2a 00 00 04 31 40 00 00 f0 00
[   77.600000] end_request: critical target error, dev sda, sector 274752
[   77.600000] Buffer I/O error on device sda, logical block 34344
[   77.610000] Buffer I/O error on device sda, logical block 34345
[   77.620000] Buffer I/O error on device sda, logical block 34346
[   77.620000] Buffer I/O error on device sda, logical block 34347
[   77.630000] Buffer I/O error on device sda, logical block 34348
[   77.630000] Buffer I/O error on device sda, logical block 34349
[   77.640000] Buffer I/O error on device sda, logical block 34350
[   77.650000] Buffer I/O error on device sda, logical block 34351
[   77.650000] Buffer I/O error on device sda, logical block 34352
[   77.660000] Buffer I/O error on device sda, logical block 34353
[   77.660000] Buffer I/O error on device sda, logical block 34354
[   77.670000] Buffer I/O error on device sda, logical block 34355
[   77.680000] Buffer I/O error on device sda, logical block 34356
[   77.680000] Buffer I/O error on device sda, logical block 34357
[   77.690000] Buffer I/O error on device sda, logical block 34358
[   77.690000] Buffer I/O error on device sda, logical block 34359
[   77.700000] Buffer I/O error on device sda, logical block 34360
[   77.700000] Buffer I/O error on device sda, logical block 34361
[   77.710000] Buffer I/O error on device sda, logical block 34362
[   77.720000] Buffer I/O error on device sda, logical block 34363
[   77.720000] Buffer I/O error on device sda, logical block 34364
[   77.730000] Buffer I/O error on device sda, logical block 34365
[   77.730000] Buffer I/O error on device sda, logical block 34366
[   77.740000] Buffer I/O error on device sda, logical block 34367
[   77.750000] Buffer I/O error on device sda, logical block 34368
[   77.750000] Buffer I/O error on device sda, logical block 34369
[   77.760000] Buffer I/O error on device sda, logical block 34370
[   77.760000] Buffer I/O error on device sda, logical block 34371
[   77.770000] Buffer I/O error on device sda, logical block 34372
[   77.780000] Buffer I/O error on device sda, logical block 34373
[   77.780000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 3833856 size 126976 starting block 34374)
[   77.800000] sd 0:0:0:0: [sda] Unhandled sense code
[   77.810000] Result: hostbyte=0x00 driverbyte=0x08
[   77.810000] sd 0:0:0:0: [sda]
[   77.820000] Sense Key : 0x7 [current]
[   77.820000] sd 0:0:0:0: [sda]
[   77.820000] ASC=0x27 ASCQ=0x0
[   77.830000] sd 0:0:0:0: [sda] CDB:
[   77.830000] cdb[0]=0x2a: 2a 00 00 04 32 30 00 00 f0 00
[   77.830000] Buffer I/O error on device sda, logical block 34374
[   77.840000] Buffer I/O error on device sda, logical block 34375
[   77.850000] Buffer I/O error on device sda, logical block 34376
[   77.850000] Buffer I/O error on device sda, logical block 34377
[   77.860000] Buffer I/O error on device sda, logical block 34378
[   77.860000] Buffer I/O error on device sda, logical block 34379
[   77.870000] Buffer I/O error on device sda, logical block 34380
[   77.880000] Buffer I/O error on device sda, logical block 34381
[   77.880000] Buffer I/O error on device sda, logical block 34382
[   77.890000] Buffer I/O error on device sda, logical block 34383
[   77.890000] Buffer I/O error on device sda, logical block 34384
[   77.900000] Buffer I/O error on device sda, logical block 34385
[   77.900000] Buffer I/O error on device sda, logical block 34386
[   77.910000] Buffer I/O error on device sda, logical block 34387
[   77.920000] Buffer I/O error on device sda, logical block 34388
[   77.920000] Buffer I/O error on device sda, logical block 34389
[   77.930000] Buffer I/O error on device sda, logical block 34390
[   77.930000] Buffer I/O error on device sda, logical block 34391
[   77.940000] Buffer I/O error on device sda, logical block 34392
[   77.950000] Buffer I/O error on device sda, logical block 34393
[   77.950000] Buffer I/O error on device sda, logical block 34394
[   77.960000] Buffer I/O error on device sda, logical block 34395
[   77.960000] Buffer I/O error on device sda, logical block 34396
[   77.970000] Buffer I/O error on device sda, logical block 34397
[   77.980000] Buffer I/O error on device sda, logical block 34398
[   77.980000] Buffer I/O error on device sda, logical block 34399
[   77.990000] Buffer I/O error on device sda, logical block 34400
[   77.990000] Buffer I/O error on device sda, logical block 34401
[   78.000000] Buffer I/O error on device sda, logical block 34402
[   78.010000] Buffer I/O error on device sda, logical block 34403
[   78.010000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 3956736 size 126976 starting block 34404)
[   78.030000] sd 0:0:0:0: [sda] Unhandled sense code
[   78.030000] Result: hostbyte=0x00 driverbyte=0x08
[   78.040000] sd 0:0:0:0: [sda]
[   78.040000] Sense Key : 0x7 [current]
[   78.050000] ASC=0x27 ASCQ=0x0
[   78.050000] sd 0:0:0:0: [sda] CDB:
[   78.050000] cdb[0]=0x2a: 2a 00 00 04 33 20 00 00 e0 00
[   78.060000] Buffer I/O error on device sda, logical block 34404
[   78.060000] Buffer I/O error on device sda, logical block 34405
[   78.070000] Buffer I/O error on device sda, logical block 34406
[   78.080000] Buffer I/O error on device sda, logical block 34407
[   78.080000] Buffer I/O error on device sda, logical block 34408
[   78.090000] Buffer I/O error on device sda, logical block 34409
[   78.090000] Buffer I/O error on device sda, logical block 34410
[   78.100000] Buffer I/O error on device sda, logical block 34411
[   78.110000] Buffer I/O error on device sda, logical block 34412
[   78.110000] Buffer I/O error on device sda, logical block 34413
[   78.120000] Buffer I/O error on device sda, logical block 34414
[   78.120000] Buffer I/O error on device sda, logical block 34415
[   78.130000] Buffer I/O error on device sda, logical block 34416
[   78.130000] Buffer I/O error on device sda, logical block 34417
[   78.140000] Buffer I/O error on device sda, logical block 34418
[   78.150000] Buffer I/O error on device sda, logical block 34419
[   78.150000] Buffer I/O error on device sda, logical block 34420
[   78.160000] Buffer I/O error on device sda, logical block 34421
[   78.160000] Buffer I/O error on device sda, logical block 34422
[   78.170000] Buffer I/O error on device sda, logical block 34423
[   78.180000] Buffer I/O error on device sda, logical block 34424
[   78.180000] Buffer I/O error on device sda, logical block 34425
[   78.190000] Buffer I/O error on device sda, logical block 34426
[   78.190000] Buffer I/O error on device sda, logical block 34427
[   78.200000] Buffer I/O error on device sda, logical block 34428
[   78.210000] Buffer I/O error on device sda, logical block 34429
[   78.210000] Buffer I/O error on device sda, logical block 34430
[   78.220000] Buffer I/O error on device sda, logical block 34431
[   78.220000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 4079616 size 114688 starting block 34432)
[   78.240000] sd 0:0:0:0: [sda] Unhandled sense code
[   78.250000] sd 0:0:0:0: [sda]
[   78.250000] Result: hostbyte=0x00 driverbyte=0x08
[   78.260000] Sense Key : 0x7 [current]
[   78.260000] sd 0:0:0:0: [sda]
[   78.260000] ASC=0x27 ASCQ=0x0
[   78.270000] sd 0:0:0:0: [sda] CDB:
[   78.270000] cdb[0]=0x2a: 2a 00 00 04 57 f0 00 00 f0 00
[   78.280000] Buffer I/O error on device sda, logical block 35582
[   78.280000] Buffer I/O error on device sda, logical block 35583
[   78.290000] Buffer I/O error on device sda, logical block 35584
[   78.290000] Buffer I/O error on device sda, logical block 35585
[   78.300000] Buffer I/O error on device sda, logical block 35586
[   78.310000] Buffer I/O error on device sda, logical block 35587
[   78.310000] Buffer I/O error on device sda, logical block 35588
[   78.320000] Buffer I/O error on device sda, logical block 35589
[   78.320000] Buffer I/O error on device sda, logical block 35590
[   78.330000] Buffer I/O error on device sda, logical block 35591
[   78.340000] Buffer I/O error on device sda, logical block 35592
[   78.340000] Buffer I/O error on device sda, logical block 35593
[   78.350000] Buffer I/O error on device sda, logical block 35594
[   78.350000] Buffer I/O error on device sda, logical block 35595
[   78.360000] Buffer I/O error on device sda, logical block 35596
[   78.360000] Buffer I/O error on device sda, logical block 35597
[   78.370000] Buffer I/O error on device sda, logical block 35598
[   78.380000] Buffer I/O error on device sda, logical block 35599
[   78.380000] Buffer I/O error on device sda, logical block 35600
[   78.390000] Buffer I/O error on device sda, logical block 35601
[   78.390000] Buffer I/O error on device sda, logical block 35602
[   78.400000] Buffer I/O error on device sda, logical block 35603
[   78.410000] Buffer I/O error on device sda, logical block 35604
[   78.410000] Buffer I/O error on device sda, logical block 35605
[   78.420000] Buffer I/O error on device sda, logical block 35606
[   78.420000] Buffer I/O error on device sda, logical block 35607
[   78.430000] Buffer I/O error on device sda, logical block 35608
[   78.440000] Buffer I/O error on device sda, logical block 35609
[   78.440000] Buffer I/O error on device sda, logical block 35610
[   78.450000] Buffer I/O error on device sda, logical block 35611
[   78.450000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 4194304 size 126976 starting block 35612)
[   78.470000] sd 0:0:0:0: [sda] Unhandled sense code
[   78.480000] sd 0:0:0:0: [sda]
[   78.480000] Result: hostbyte=0x00 driverbyte=0x08
[   78.490000] Sense Key : 0x7 [current]
[   78.490000] sd 0:0:0:0: [sda]
[   78.490000] ASC=0x27 ASCQ=0x0
[   78.500000] sd 0:0:0:0: [sda] CDB:
[   78.500000] cdb[0]=0x2a: 2a 00 00 04 58 e0 00 00 f0 00
[   78.510000] Buffer I/O error on device sda, logical block 35612
[   78.510000] Buffer I/O error on device sda, logical block 35613
[   78.520000] Buffer I/O error on device sda, logical block 35614
[   78.520000] Buffer I/O error on device sda, logical block 35615
[   78.530000] Buffer I/O error on device sda, logical block 35616
[   78.540000] Buffer I/O error on device sda, logical block 35617
[   78.540000] Buffer I/O error on device sda, logical block 35618
[   78.550000] Buffer I/O error on device sda, logical block 35619
[   78.550000] Buffer I/O error on device sda, logical block 35620
[   78.560000] Buffer I/O error on device sda, logical block 35621
[   78.560000] Buffer I/O error on device sda, logical block 35622
[   78.570000] Buffer I/O error on device sda, logical block 35623
[   78.580000] Buffer I/O error on device sda, logical block 35624
[   78.580000] Buffer I/O error on device sda, logical block 35625
[   78.590000] Buffer I/O error on device sda, logical block 35626
[   78.590000] Buffer I/O error on device sda, logical block 35627
[   78.600000] Buffer I/O error on device sda, logical block 35628
[   78.610000] Buffer I/O error on device sda, logical block 35629
[   78.610000] Buffer I/O error on device sda, logical block 35630
[   78.620000] Buffer I/O error on device sda, logical block 35631
[   78.620000] Buffer I/O error on device sda, logical block 35632
[   78.630000] Buffer I/O error on device sda, logical block 35633
[   78.640000] Buffer I/O error on device sda, logical block 35634
[   78.640000] Buffer I/O error on device sda, logical block 35635
[   78.650000] Buffer I/O error on device sda, logical block 35636
[   78.650000] Buffer I/O error on device sda, logical block 35637
[   78.660000] Buffer I/O error on device sda, logical block 35638
[   78.670000] Buffer I/O error on device sda, logical block 35639
[   78.670000] Buffer I/O error on device sda, logical block 35640
[   78.680000] Buffer I/O error on device sda, logical block 35641
[   78.680000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 4317184 size 126976 starting block 35642)
[   78.700000] sd 0:0:0:0: [sda] Unhandled sense code
[   78.700000] Result: hostbyte=0x00 driverbyte=0x08
[   78.710000] sd 0:0:0:0: [sda]
[   78.710000] Sense Key : 0x7 [current]
[   78.720000] sd 0:0:0:0: [sda]
[   78.720000] ASC=0x27 ASCQ=0x0
[   78.720000] sd 0:0:0:0: [sda] CDB:
[   78.730000] cdb[0]=0x2a: 2a 00 00 04 59 d0 00 00 f0 00
[   78.730000] Buffer I/O error on device sda, logical block 35642
[   78.740000] Buffer I/O error on device sda, logical block 35643
[   78.740000] Buffer I/O error on device sda, logical block 35644
[   78.750000] Buffer I/O error on device sda, logical block 35645
[   78.750000] Buffer I/O error on device sda, logical block 35646
[   78.760000] Buffer I/O error on device sda, logical block 35647
[   78.770000] Buffer I/O error on device sda, logical block 35648
[   78.770000] Buffer I/O error on device sda, logical block 35649
[   78.780000] Buffer I/O error on device sda, logical block 35650
[   78.780000] Buffer I/O error on device sda, logical block 35651
[   78.790000] Buffer I/O error on device sda, logical block 35652
[   78.800000] Buffer I/O error on device sda, logical block 35653
[   78.800000] Buffer I/O error on device sda, logical block 35654
[   78.810000] Buffer I/O error on device sda, logical block 35655
[   78.810000] Buffer I/O error on device sda, logical block 35656
[   78.820000] Buffer I/O error on device sda, logical block 35657
[   78.820000] Buffer I/O error on device sda, logical block 35658
[   78.830000] Buffer I/O error on device sda, logical block 35659
[   78.840000] Buffer I/O error on device sda, logical block 35660
[   78.840000] Buffer I/O error on device sda, logical block 35661
[   78.850000] Buffer I/O error on device sda, logical block 35662
[   78.850000] Buffer I/O error on device sda, logical block 35663
[   78.860000] Buffer I/O error on device sda, logical block 35664
[   78.870000] Buffer I/O error on device sda, logical block 35665
[   78.870000] Buffer I/O error on device sda, logical block 35666
[   78.880000] Buffer I/O error on device sda, logical block 35667
[   78.880000] Buffer I/O error on device sda, logical block 35668
[   78.890000] Buffer I/O error on device sda, logical block 35669
[   78.900000] Buffer I/O error on device sda, logical block 35670
[   78.900000] Buffer I/O error on device sda, logical block 35671
[   78.910000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 4440064 size 126976 starting block 35672)
[   78.930000] sd 0:0:0:0: [sda] Unhandled sense code
[   78.930000] Result: hostbyte=0x00 driverbyte=0x08
[   78.940000] sd 0:0:0:0: [sda]
[   78.940000] Sense Key : 0x7 [current]
[   78.950000] ASC=0x27 ASCQ=0x0
[   78.950000] sd 0:0:0:0: [sda] CDB:
[   78.950000] cdb[0]=0x2a: 2a 00 00 04 5a c0 00 00 f0 00
[   78.960000] Buffer I/O error on device sda, logical block 35672
[   78.960000] Buffer I/O error on device sda, logical block 35673
[   78.970000] Buffer I/O error on device sda, logical block 35674
[   78.980000] Buffer I/O error on device sda, logical block 35675
[   78.980000] Buffer I/O error on device sda, logical block 35676
[   78.990000] Buffer I/O error on device sda, logical block 35677
[   78.990000] Buffer I/O error on device sda, logical block 35678
[   79.000000] Buffer I/O error on device sda, logical block 35679
[   79.010000] Buffer I/O error on device sda, logical block 35680
[   79.010000] Buffer I/O error on device sda, logical block 35681
[   79.020000] Buffer I/O error on device sda, logical block 35682
[   79.020000] Buffer I/O error on device sda, logical block 35683
[   79.030000] Buffer I/O error on device sda, logical block 35684
[   79.030000] Buffer I/O error on device sda, logical block 35685
[   79.040000] Buffer I/O error on device sda, logical block 35686
[   79.050000] Buffer I/O error on device sda, logical block 35687
[   79.050000] Buffer I/O error on device sda, logical block 35688
[   79.060000] Buffer I/O error on device sda, logical block 35689
[   79.060000] Buffer I/O error on device sda, logical block 35690
[   79.070000] Buffer I/O error on device sda, logical block 35691
[   79.080000] Buffer I/O error on device sda, logical block 35692
[   79.080000] Buffer I/O error on device sda, logical block 35693
[   79.090000] Buffer I/O error on device sda, logical block 35694
[   79.090000] Buffer I/O error on device sda, logical block 35695
[   79.100000] Buffer I/O error on device sda, logical block 35696
[   79.110000] Buffer I/O error on device sda, logical block 35697
[   79.110000] Buffer I/O error on device sda, logical block 35698
[   79.120000] Buffer I/O error on device sda, logical block 35699
[   79.120000] Buffer I/O error on device sda, logical block 35700
[   79.130000] Buffer I/O error on device sda, logical block 35701
[   79.130000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 4562944 size 126976 starting block 35702)
[   79.150000] sd 0:0:0:0: [sda] Unhandled sense code
[   79.160000] sd 0:0:0:0: [sda]
[   79.160000] Result: hostbyte=0x00 driverbyte=0x08
[   79.170000] sd 0:0:0:0: [sda]
[   79.170000] Sense Key : 0x7 [current]
[   79.180000] ASC=0x27 ASCQ=0x0
[   79.180000] sd 0:0:0:0: [sda] CDB:
[   79.180000] cdb[0]=0x2a: 2a 00 00 04 5b b0 00 00 30 00
[   79.190000] Buffer I/O error on device sda, logical block 35702
[   79.190000] Buffer I/O error on device sda, logical block 35703
[   79.200000] Buffer I/O error on device sda, logical block 35704
[   79.210000] Buffer I/O error on device sda, logical block 35705
[   79.210000] Buffer I/O error on device sda, logical block 35706
[   79.220000] Buffer I/O error on device sda, logical block 35707
[   79.220000] EXT4-fs warning (device sda): ext4_end_bio:286: I/O error writing to inode 12 (offset 4685824 size 24576 starting block 35708)
[   79.240000] sd 0:0:0:0: [sda] Unhandled sense code
[   79.240000] Result: hostbyte=0x00 driverbyte=0x08
[   79.250000] sd 0:0:0:0: [sda]
[   79.250000] Sense Key : 0x7 [current]
[   79.260000] sd 0:0:0:0: [sda]
[   79.260000] ASC=0x27 ASCQ=0x0
[   79.260000] sd 0:0:0:0: [sda] CDB:
MeteoLeudal
Post by MeteoLeudal »
[   79.260000] cdb[0]=0x2a: 2a 00 00 44 00 00 00 00 08 00
[   79.270000] Buffer I/O error on device sda, logical block 557056
[   79.280000] lost page write due to I/O error on sda
[   79.280000] JBD2: Error -5 detected when updating journal superblock for sda-8.
[   79.290000] sd 0:0:0:0: [sda] Unhandled sense code
[   79.300000] Result: hostbyte=0x00 driverbyte=0x08
[   79.300000] sd 0:0:0:0: [sda]
[   79.300000] Sense Key : 0x7 [current]
[   79.310000] sd 0:0:0:0: [sda]
[   79.310000] ASC=0x27 ASCQ=0x0
[   79.310000] sd 0:0:0:0: [sda] CDB:
[   79.320000] cdb[0]=0x2a: 2a 00 00 44 00 08 00 00 38 00
[   79.320000] Aborting journal on device sda-8.
[   79.330000] sd 0:0:0:0: [sda] Unhandled sense code
[   79.340000] Result: hostbyte=0x00 driverbyte=0x08
[   79.340000] sd 0:0:0:0: [sda]
[   79.340000] Sense Key : 0x7 [current]
[   79.350000] sd 0:0:0:0: [sda]
[   79.350000] ASC=0x27 ASCQ=0x0
[   79.350000] sd 0:0:0:0: [sda] CDB:
[   79.360000] cdb[0]=0x2a: 2a 00 00 44 00 00 00 00 08 00
[   79.360000] Buffer I/O error on device sda, logical block 557056
[   79.370000] lost page write due to I/O error on sda
[   79.380000] JBD2: Error -5 detected when updating journal superblock for sda-8.
[   83.880000] EXT4-fs (sda): previous I/O error to superblock detected
[   83.890000] sd 0:0:0:0: [sda] Unhandled sense code
[   83.900000] Result: hostbyte=0x00 driverbyte=0x08
[   83.900000] sd 0:0:0:0: [sda]
[   83.900000] Sense Key : 0x7 [current]
[   83.910000] sd 0:0:0:0: [sda]
[   83.910000] ASC=0x27 ASCQ=0x0
[   83.910000] sd 0:0:0:0: [sda] CDB:
[   83.920000] cdb[0]=0x2a: 2a 00 00 00 00 00 00 00 08 00
[   83.920000] blk_update_request: 10 callbacks suppressed
[   83.930000] end_request: critical target error, dev sda, sector 0
[   83.930000] Buffer I/O error on device sda, logical block 0
[   83.940000] lost page write due to I/O error on sda
[   83.940000] EXT4-fs error (device sda): __ext4_journal_start_sb:62: Detected aborted journal
[   83.950000] EXT4-fs (sda): Remounting filesystem read-only
[   83.960000] EXT4-fs (sda): previous I/O error to superblock detected
[   83.970000] sd 0:0:0:0: [sda] Unhandled sense code
[   83.970000] Result: hostbyte=0x00 driverbyte=0x08
[   83.980000] sd 0:0:0:0: [sda]
[   83.980000] Sense Key : 0x7 [current]
[   83.990000] ASC=0x27 ASCQ=0x0
[   83.990000] sd 0:0:0:0: [sda] CDB:
[   83.990000] cdb[0]=0x2a: 2a 00 00 00 00 00 00 00 08 00
[   84.000000] end_request: critical target error, dev sda, sector 0
[   84.000000] Buffer I/O error on device sda, logical block 0
[   84.010000] lost page write due to I/O error on sda
[   84.030000] EXT4-fs (sda): previous I/O error to superblock detected
[   84.040000] sd 0:0:0:0: [sda] Unhandled sense code
[   84.050000] Result: hostbyte=0x00 driverbyte=0x08
[   84.050000] sd 0:0:0:0: [sda]
[   84.060000] Sense Key : 0x7 [current]
[   84.060000] sd 0:0:0:0: [sda]
[   84.060000] ASC=0x27 ASCQ=0x0
[   84.070000] sd 0:0:0:0: [sda] CDB:
[   84.070000] cdb[0]=0x2a: 2a 00 00 00 00 00 00 00 08 00
[   84.070000] end_request: critical target error, dev sda, sector 0
[   84.080000] Buffer I/O error on device sda, logical block 0
[   84.090000] lost page write due to I/O error on sda
[   84.090000] EXT4-fs error (device sda): ext4_remount:4679: Abort forced by user
[   84.100000] EXT4-fs (sda): re-mounted. Opts: data=ordered,commit=60,max_batch_time=1000000,min_batch_time=1000000,errors=remount-ro
[   93.230000] sd 0:0:0:0: [sda] Unhandled sense code
[   93.240000] Result: hostbyte=0x00 driverbyte=0x08
[   93.240000] sd 0:0:0:0: [sda]
[   93.240000] Sense Key : 0x3 [current]
[   93.250000] sd 0:0:0:0: [sda]
[   93.250000] ASC=0x11 ASCQ=0x0
[   93.250000] sd 0:0:0:0: [sda] CDB:
[   93.260000] cdb[0]=0x28: 28 00 00 48 10 10 00 00 08 00
[   93.260000] end_request: critical target error, dev sda, sector 4722704
[   93.290000] sd 0:0:0:0: [sda] Unhandled sense code
[   93.300000] Result: hostbyte=0x00 driverbyte=0x08
[   93.300000] sd 0:0:0:0: [sda]
[   93.300000] Sense Key : 0x3 [current]
[   93.310000] sd 0:0:0:0: [sda]
[   93.310000] ASC=0x11 ASCQ=0x0
[   93.310000] sd 0:0:0:0: [sda] CDB:
[   93.320000] cdb[0]=0x28: 28 00 00 48 10 60 00 00 08 00
[   93.320000] end_request: critical target error, dev sda, sector 4722784
[   93.350000] sd 0:0:0:0: [sda] Unhandled sense code
[   93.350000] Result: hostbyte=0x00 driverbyte=0x08
[   93.360000] sd 0:0:0:0: [sda]
[   93.360000] Sense Key : 0x3 [current]
[   93.370000] ASC=0x11 ASCQ=0x0
[   93.370000] sd 0:0:0:0: [sda] CDB:
[   93.370000] cdb[0]=0x28: 28 00 00 48 10 80 00 00 08 00
[   93.380000] end_request: critical target error, dev sda, sector 4722816
[   93.400000] sd 0:0:0:0: [sda] Unhandled sense code
[   93.400000] Result: hostbyte=0x00 driverbyte=0x08
[   93.410000] sd 0:0:0:0: [sda]
[   93.410000] Sense Key : 0x3 [current]
[   93.420000] ASC=0x11 ASCQ=0x0
[   93.420000] sd 0:0:0:0: [sda] CDB:
[   93.420000] cdb[0]=0x28: 28 00 00 48 10 10 00 00 08 00
[   93.430000] end_request: critical target error, dev sda, sector 4722704
[   93.780000] sd 0:0:0:0: [sda] Unhandled sense code
[   93.780000] Result: hostbyte=0x00 driverbyte=0x08
[   93.790000] sd 0:0:0:0: [sda]
[   93.790000] Sense Key : 0x3 [current]
[   93.800000] ASC=0x11 ASCQ=0x0
[   93.800000] sd 0:0:0:0: [sda] CDB:
[   93.800000] cdb[0]=0x28: 28 00 00 48 10 10 00 00 08 00
[   93.810000] end_request: critical target error, dev sda, sector 4722704
[   96.920000] sd 0:0:0:0: [sda] Unhandled sense code
[   96.930000] sd 0:0:0:0: [sda]
[   96.930000] Result: hostbyte=0x00 driverbyte=0x08
[   96.940000] sd 0:0:0:0: [sda]
[   96.940000] Sense Key : 0x3 [current]
[   96.950000] ASC=0x11 ASCQ=0x0
[   96.950000] sd 0:0:0:0: [sda] CDB:
[   96.950000] cdb[0]=0x28: 28 00 00 48 10 10 00 00 08 00
[   96.960000] end_request: critical target error, dev sda, sector 4722704
[  227.700000] sd 0:0:0:0: [sda] Unhandled sense code
[  227.700000] Result: hostbyte=0x00 driverbyte=0x08
[  227.710000] sd 0:0:0:0: [sda]
[  227.710000] Sense Key : 0x3 [current]
[  227.720000] sd 0:0:0:0: [sda]
[  227.720000] ASC=0x11 ASCQ=0x0
[  227.720000] sd 0:0:0:0: [sda] CDB:
[  227.720000] cdb[0]=0x28: 28 00 00 48 10 10 00 00 08 00
[  227.730000] end_request: critical target error, dev sda, sector 4722704
[  349.080000] sd 0:0:0:0: [sda] Unhandled sense code
[  349.080000] Result: hostbyte=0x00 driverbyte=0x08
[  349.090000] sd 0:0:0:0: [sda]
[  349.090000] Sense Key : 0x3 [current]
[  349.100000] ASC=0x11 ASCQ=0x0
[  349.100000] sd 0:0:0:0: [sda] CDB:
[  349.100000] cdb[0]=0x28: 28 00 00 48 10 10 00 00 08 00
[  349.110000] end_request: critical target error, dev sda, sector 4722704
[  491.210000] sd 0:0:0:0: [sda] Unhandled sense code
[  491.210000] Result: hostbyte=0x00 driverbyte=0x08
[  491.220000] sd 0:0:0:0: [sda]
[  491.220000] Sense Key : 0x3 [current]
[  491.230000] ASC=0x11 ASCQ=0x0
[  491.230000] sd 0:0:0:0: [sda] CDB:
[  491.230000] cdb[0]=0x28: 28 00 00 48 10 10 00 00 08 00
[  491.240000] end_request: critical target error, dev sda, sector 4722704
[  645.040000] sd 0:0:0:0: [sda] Unhandled sense code
[  645.040000] Result: hostbyte=0x00 driverbyte=0x08
[  645.050000] sd 0:0:0:0: [sda]
[  645.050000] Sense Key : 0x3 [current]
[  645.060000] sd 0:0:0:0: [sda]
[  645.060000] ASC=0x11 ASCQ=0x0
[  645.060000] sd 0:0:0:0: [sda] CDB:
[  645.060000] cdb[0]=0x28: 28 00 00 48 10 10 00 00 08 00
[  645.070000] end_request: critical target error, dev sda, sector 4722704
[  878.130000] sd 0:0:0:0: [sda] Unhandled sense code
[  878.130000] Result: hostbyte=0x00 driverbyte=0x08
[  878.140000] sd 0:0:0:0: [sda]
[  878.140000] Sense Key : 0x3 [current]
[  878.150000] ASC=0x11 ASCQ=0x0
[  878.150000] sd 0:0:0:0: [sda] CDB:
[  878.150000] cdb[0]=0x28: 28 00 00 48 10 10 00 00 08 00
[  878.160000] end_request: critical target error, dev sda, sector 4722704
[ 1217.080000] sd 0:0:0:0: [sda] Unhandled sense code
[ 1217.080000] Result: hostbyte=0x00 driverbyte=0x08
[ 1217.090000] sd 0:0:0:0: [sda]
[ 1217.090000] Sense Key : 0x3 [current]
[ 1217.100000] ASC=0x11 ASCQ=0x0
[ 1217.100000] sd 0:0:0:0: [sda] CDB:
[ 1217.100000] cdb[0]=0x28: 28 00 00 48 10 10 00 00 08 00
[ 1217.110000] end_request: critical target error, dev sda, sector 4722704
MeteoLeudal
Code from last reboot on system massages:
oled (12.07.2016 10:35:23): process started.
database (12.07.2016 12:36:47): process started.
wnetd (12.07.2016 12:36:47): process started.
logger (12.07.2016 12:36:48): database connected.
logger (12.07.2016 12:36:48): Historical data loaded (0 records).
logger (12.07.2016 12:36:48): data logger (version 5.0q, build 10055) started.
logger (12.07.2016 12:36:49): connect station 0 (Meteostick Vantage via USB serial).
logger (12.07.2016 12:36:49): connect station 9 (System Data via Plug-in).
logger (12.07.2016 12:36:51): transmitter 1 registered as ISS
logger (12.07.2016 12:36:51): transmitter 2 registered as Wind
logger (12.07.2016 12:36:51): Meteostick Version 2.4
logger (12.07.2016 12:36:51): debug off
logger (12.07.2016 12:36:51): verbose off
logger (12.07.2016 12:36:51): output raw (8 bytes)
logger (12.07.2016 12:36:51): output raw (10 bytes)
logger (12.07.2016 12:36:51): filter on
logger (12.07.2016 12:36:51): rx threshold set to -90db
logger (12.07.2016 12:36:51): listening to transmitter 1 2
logger (12.07.2016 12:36:51): bandwidth wide
logger (12.07.2016 12:36:52): chip authentication ok: 14
logger (12.07.2016 12:36:52): frequency band 868MHz (EU)
logger (12.07.2016 12:36:55): parent process received termination signal (15).
logger (12.07.2016 12:36:55): child process received termination signal (15).
logger (12.07.2016 12:36:55): disconnect station 0 (Meteostick Vantage): exit
logger (12.07.2016 12:36:55): disconnect station 9 (System Data): exit
database (12.07.2016 12:36:55): process terminated normally.
test5m (12.07.2016 12:36:55): USB storage remounted: /dev/sda
database (12.07.2016 12:36:55): process started.
logger (12.07.2016 12:36:56): database connected.
logger (12.07.2016 12:36:56): Historical data loaded (0 records).
logger (12.07.2016 12:36:56): data logger (version 5.0q, build 10055) started.
logger (12.07.2016 12:36:56): error while doing bind (port 5557): Address already in use
logger (12.07.2016 12:36:56): killed process "2729/loggerd" listening to port 5556.
logger (12.07.2016 12:36:56): data logger stopped.
logger (12.07.2016 12:37:26): database connected.
logger (12.07.2016 12:37:26): Historical data loaded (0 records).
logger (12.07.2016 12:37:26): data logger (version 5.0q, build 10055) started.
logger (12.07.2016 12:37:27): connect station 0 (Meteostick Vantage via USB serial).
logger (12.07.2016 12:37:27): connect station 9 (System Data via Plug-in).
logger (12.07.2016 12:37:29): transmitter 1 registered as ISS
logger (12.07.2016 12:37:29): transmitter 2 registered as Wind
logger (12.07.2016 12:37:29): Meteostick Version 2.4
logger (12.07.2016 12:37:29): debug off
logger (12.07.2016 12:37:29): verbose off
logger (12.07.2016 12:37:29): output raw (8 bytes)
logger (12.07.2016 12:37:29): output raw (10 bytes)
logger (12.07.2016 12:37:29): filter on
logger (12.07.2016 12:37:29): rx threshold set to -90db
logger (12.07.2016 12:37:29): listening to transmitter 1 2
logger (12.07.2016 12:37:29): bandwidth wide
logger (12.07.2016 12:37:29): chip authentication ok: 14
logger (12.07.2016 12:37:29): frequency band 868MHz (EU)
logger (12.07.2016 12:40:20): wind1 data incomplete (missing outdoor temp for windchill)
logger (12.07.2016 12:40:25): wind1 data incomplete (missing outdoor temp for windchill)
logger (12.07.2016 12:40:28): parent process received termination signal (15).
logger (12.07.2016 12:40:28): child process received termination signal (15).
logger (12.07.2016 12:40:28): disconnect station 0 (Meteostick Vantage): exit
logger (12.07.2016 12:40:28): disconnect station 9 (System Data): exit
database (12.07.2016 12:40:28): process terminated normally.
test5m (12.07.2016 12:40:29): USB storage remounted: /dev/sda
database (12.07.2016 12:40:29): process started.
logger (12.07.2016 12:40:29): database connected.
logger (12.07.2016 12:40:29): Historical data loaded (0 records).
logger (12.07.2016 12:40:29): data logger (version 5.0q, build 10055) started.
logger (12.07.2016 12:40:29): error while doing bind (port 5557): Address already in use
logger (12.07.2016 12:40:29): killed process "3467/loggerd" listening to port 5556.
logger (12.07.2016 12:40:29): data logger stopped.
logger (12.07.2016 12:40:59): database connected.
logger (12.07.2016 12:40:59): Historical data loaded (26 records).
logger (12.07.2016 12:40:59): data logger (version 5.0q, build 10055) started.
logger (12.07.2016 12:41:00): connect station 0 (Meteostick Vantage via USB serial).
logger (12.07.2016 12:41:00): connect station 9 (System Data via Plug-in).
logger (12.07.2016 12:41:02): transmitter 1 registered as ISS
logger (12.07.2016 12:41:02): transmitter 2 registered as Wind
logger (12.07.2016 12:41:02): Meteostick Version 2.4
logger (12.07.2016 12:41:02): debug off
logger (12.07.2016 12:41:02): verbose off
logger (12.07.2016 12:41:02): output raw (8 bytes)
logger (12.07.2016 12:41:02): output raw (10 bytes)
logger (12.07.2016 12:41:02): filter on
logger (12.07.2016 12:41:02): rx threshold set to -90db
logger (12.07.2016 12:41:02): listening to transmitter 1 2
logger (12.07.2016 12:41:02): bandwidth wide
logger (12.07.2016 12:41:02): chip authentication ok: 14
logger (12.07.2016 12:41:02): frequency band 868MHz (EU)
logger (12.07.2016 12:45:53): parent process received termination signal (15).
logger (12.07.2016 12:45:53): child process received termination signal (15).
logger (12.07.2016 12:45:53): disconnect station 0 (Meteostick Vantage): exit
logger (12.07.2016 12:45:53): disconnect station 9 (System Data): exit
database (12.07.2016 12:45:54): process terminated normally.
logger (12.07.2016 12:45:54): data logger stopped.
test5m (12.07.2016 12:45:55): USB storage remounted: /dev/sda
database (12.07.2016 12:45:55): process started.
logger (12.07.2016 12:45:55): database connected.
logger (12.07.2016 12:46:25): database connected.
logger (12.07.2016 12:46:55): database connected.
logger (12.07.2016 12:47:25): database connected.
Always there is an differend code in the system messages after reboot. The mbpro does strange things.
Re: Not stable from firmware 2.9
There is anew release of 3.0 time stamped July 12 that should work fine.
Nevertheless messages like these indicate storage failure:
Could you please call "http://ip-of-your-mbpro/cgi-bin/system.cgi?dmesg" with your browser and post here.
If you have USB storage related problems, they will show up in the output.
MeteoLeudal
admin wrote:There is anew release of 3.0 time stamped July 12 that should work fine.
Ok thanks for your reply :)
First updated the new release 3.0 July 12 and reboot again with database media : internal USB storage.
On system messages:
oled (13.07.2016 17:11:40): process started.
database (13.07.2016 19:13:04): process started.
database (13.07.2016 19:13:04): sync of internal databases done (0 tables)
wnetd (13.07.2016 19:13:06): process started.
logger (13.07.2016 19:13:06): databases connected. Update interval 3600 seconds.
logger (13.07.2016 19:13:06): Historical data loaded (0 records).
logger (13.07.2016 19:13:06): data logger (version 5.0q, build 10178) started.
logger (13.07.2016 19:13:08): connect station 0 (Vantage via USB serial).
logger (13.07.2016 19:13:08): connect station 9 (System Data via Plug-in).
logger (13.07.2016 19:13:08): wakeup sent.
logger (13.07.2016 19:13:08): internal logger activated.
logger (13.07.2016 19:13:08): syncing.
logger (13.07.2016 19:13:14): parent process received termination signal (15).
logger (13.07.2016 19:13:14): child process received termination signal (15).
logger (13.07.2016 19:13:14): disconnect station 0 (Vantage): exit
logger (13.07.2016 19:13:14): disconnect station 9 (System Data): exit
database (13.07.2016 19:13:14): process terminated normally.
test5m (13.07.2016 19:13:14): USB storage remounted: /dev/sdb
database (13.07.2016 19:13:14): process started.
database (13.07.2016 19:13:14): sync of internal databases done (0 tables)
logger (13.07.2016 19:13:14): databases connected. Update interval 3600 seconds.
logger (13.07.2016 19:13:14): Historical data loaded (0 records).
logger (13.07.2016 19:13:14): data logger (version 5.0q, build 10178) started.
logger (13.07.2016 19:13:14): error while doing bind (port 22222): Address already in use
logger (13.07.2016 19:13:15): killed process "2493/loggerd" listening to port 22222.
logger (13.07.2016 19:13:45): databases connected. Update interval 3600 seconds.
logger (13.07.2016 19:13:45): Historical data loaded (0 records).
logger (13.07.2016 19:13:45): data logger (version 5.0q, build 10178) started.
logger (13.07.2016 19:13:45): connect station 0 (Vantage via USB serial).
logger (13.07.2016 19:13:45): connect station 9 (System Data via Plug-in).
logger (13.07.2016 19:13:45): wakeup sent.
logger (13.07.2016 19:13:46): internal logger activated.
logger (13.07.2016 19:13:46): syncing.
logger (13.07.2016 19:13:56): gettime request sent.
logger (13.07.2016 19:13:56): no Vantage time offset.
logger (13.07.2016 19:13:56): eeprom request sent.
logger (13.07.2016 19:13:56): rain collector size 0.2 mm per tick.
logger (13.07.2016 19:13:56): transmitter 1 active as station type (#0) "ISS".
logger (13.07.2016 19:13:56): transmitter 2 active as station type (#4) "Wind".
logger (13.07.2016 19:13:56): firmware version request sent.
logger (13.07.2016 19:13:56): firmware version 1.90
logger (13.07.2016 19:13:56): no reading of Vantage's internal logger.
logger (13.07.2016 19:15:48): parent process received termination signal (15).
logger (13.07.2016 19:15:48): child process received termination signal (15).
logger (13.07.2016 19:15:48): disconnect station 0 (Vantage): exit
logger (13.07.2016 19:15:48): disconnect station 9 (System Data): exit
database (13.07.2016 19:15:48): process terminated normally.
logger (13.07.2016 19:15:49): data logger stopped.
test5m (13.07.2016 19:15:49): USB storage remounted: /dev/sdb
database (13.07.2016 19:15:50): process started.
logger (13.07.2016 19:15:50): databases connected. Update interval 3600 seconds.
logger (13.07.2016 19:15:50): Historical data loaded (0 records).
logger (13.07.2016 19:15:50): data logger (version 5.0q, build 10178) started.
logger (13.07.2016 19:15:51): connect station 0 (Vantage via USB serial).
logger (13.07.2016 19:15:51): connect station 9 (System Data via Plug-in).
database (13.07.2016 19:15:51): sync of internal databases done (24 tables)
logger (13.07.2016 19:15:51): wakeup sent.
logger (13.07.2016 19:15:52): internal logger activated.
logger (13.07.2016 19:15:52): syncing.
logger (13.07.2016 19:16:02): gettime request sent.
logger (13.07.2016 19:16:02): no Vantage time offset.
logger (13.07.2016 19:16:02): eeprom request sent.
logger (13.07.2016 19:16:02): rain collector size 0.2 mm per tick.
logger (13.07.2016 19:16:02): transmitter 1 active as station type (#0) "ISS".
logger (13.07.2016 19:16:02): transmitter 2 active as station type (#4) "Wind".
logger (13.07.2016 19:16:02): firmware version request sent.
logger (13.07.2016 19:16:02): firmware version 1.90
logger (13.07.2016 19:16:02): no reading of Vantage's internal logger.
logger (13.07.2016 19:20:26): parent process received termination signal (15).
logger (13.07.2016 19:20:26): child process received termination signal (15).
logger (13.07.2016 19:20:26): disconnect station 0 (Vantage): exit
logger (13.07.2016 19:20:26): disconnect station 9 (System Data): exit
database (13.07.2016 19:20:26): process terminated normally.
logger (13.07.2016 19:20:27): data logger stopped.
test5m (13.07.2016 19:20:28): USB storage remounted: /dev/sdb
database (13.07.2016 19:20:28): process started.
logger (13.07.2016 19:20:28): databases connected. Update interval 3600 seconds.
logger (13.07.2016 19:20:28): Historical data loaded (0 records).
logger (13.07.2016 19:20:28): data logger (version 5.0q, build 10178) started.
logger (13.07.2016 19:20:29): connect station 0 (Vantage via USB serial).
logger (13.07.2016 19:20:29): connect station 9 (System Data via Plug-in).
logger (13.07.2016 19:20:29): wakeup sent.
logger (13.07.2016 19:20:30): internal logger activated.
logger (13.07.2016 19:20:30): syncing.
database (13.07.2016 19:20:30): sync of internal databases done (40 tables)
logger (13.07.2016 19:20:40): gettime request sent.
logger (13.07.2016 19:20:40): no Vantage time offset.
logger (13.07.2016 19:20:40): eeprom request sent.
logger (13.07.2016 19:20:40): rain collector size 0.2 mm per tick.
logger (13.07.2016 19:20:40): transmitter 1 active as station type (#0) "ISS".
logger (13.07.2016 19:20:40): transmitter 2 active as station type (#4) "Wind".
logger (13.07.2016 19:20:40): firmware version request sent.
logger (13.07.2016 19:20:40): firmware version 1.90
logger (13.07.2016 19:20:40): no reading of Vantage's internal logger.
logger (13.07.2016 19:26:08): parent process received termination signal (15).
logger (13.07.2016 19:26:08): child process received termination signal (15).
logger (13.07.2016 19:26:08): disconnect station 0 (Vantage): exit
logger (13.07.2016 19:26:08): disconnect station 9 (System Data): exit
database (13.07.2016 19:26:08): process terminated normally.
logger (13.07.2016 19:26:09): data logger stopped.
test5m (13.07.2016 19:26:10): USB storage remounted: /dev/sdb
database (13.07.2016 19:26:10): process started.
logger (13.07.2016 19:26:10): databases connected. Update interval 3600 seconds.
logger (13.07.2016 19:26:10): Historical data loaded (0 records).
logger (13.07.2016 19:26:10): data logger (version 5.0q, build 10178) started.
logger (13.07.2016 19:26:11): connect station 0 (Vantage via USB serial).
logger (13.07.2016 19:26:11): connect station 9 (System Data via Plug-in).
logger (13.07.2016 19:26:12): wakeup sent.
logger (13.07.2016 19:26:12): internal logger activated.
logger (13.07.2016 19:26:12): syncing.
database (13.07.2016 19:26:12): sync of internal databases done (40 tables)
logger (13.07.2016 19:26:22): gettime request sent.
logger (13.07.2016 19:26:22): no Vantage time offset.
logger (13.07.2016 19:26:22): eeprom request sent.
logger (13.07.2016 19:26:22): rain collector size 0.2 mm per tick.
logger (13.07.2016 19:26:22): transmitter 1 active as station type (#0) "ISS".
logger (13.07.2016 19:26:22): transmitter 2 active as station type (#4) "Wind".
logger (13.07.2016 19:26:22): firmware version request sent.
logger (13.07.2016 19:26:22): firmware version 1.90
logger (13.07.2016 19:26:22): no reading of Vantage's internal logger.
logger (13.07.2016 19:31:32): parent process received termination signal (15).
logger (13.07.2016 19:31:32): child process received termination signal (15).
logger (13.07.2016 19:31:32): disconnect station 0 (Vantage): exit
logger (13.07.2016 19:31:32): disconnect station 9 (System Data): exit
database (13.07.2016 19:31:32): process terminated normally.
test5m (13.07.2016 19:31:34): USB storage remounted: /dev/sdb
logger (13.07.2016 19:31:34): data logger stopped.
database (13.07.2016 19:31:34): process started.
logger (13.07.2016 19:31:34): databases connected. Update interval 3600 seconds.
logger (13.07.2016 19:31:34): Historical data loaded (0 records).
logger (13.07.2016 19:31:34): data logger (version 5.0q, build 10178) started.
logger (13.07.2016 19:31:36): connect station 0 (Vantage via USB serial).
logger (13.07.2016 19:31:36): connect station 9 (System Data via Plug-in).
logger (13.07.2016 19:31:36): wakeup sent.
logger (13.07.2016 19:31:36): internal logger activated.
logger (13.07.2016 19:31:36): syncing.
database (13.07.2016 19:31:36): sync of internal databases done (40 tables)
logger (13.07.2016 19:31:46): gettime request sent.
logger (13.07.2016 19:31:46): no Vantage time offset.
logger (13.07.2016 19:31:46): eeprom request sent.
logger (13.07.2016 19:31:46): rain collector size 0.2 mm per tick.
logger (13.07.2016 19:31:46): transmitter 1 active as station type (#0) "ISS".
logger (13.07.2016 19:31:46): transmitter 2 active as station type (#4) "Wind".
logger (13.07.2016 19:31:46): firmware version request sent.
logger (13.07.2016 19:31:46): firmware version 1.90
logger (13.07.2016 19:31:46): no reading of Vantage's internal logger.
On "http://ip-of-your-meteobridge/cgi-bin/system.cgi?dmesg":
command: dmesg
[    0.000000] Linux version 3.10.49 (boris@mars) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r44550) ) #685 Thu Dec 17 00:17:35 CET 2015
[    0.000000] MyLoader: sysp=aaabaaab, boardp=aabaaa2a, parts=aaaeba2a
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[    0.000000] SoC: Atheros AR9330 rev 1
[    0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:40.000MHz
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 04000000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x03ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x00000000-0x03ffffff]
[    0.000000] On node 0 totalpages: 16384
[    0.000000] free_area_init_node: node 0, pgdat 803109b0, node_mem_map 81000000
[    0.000000]   Normal zone: 128 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 16384 pages, LIFO batch:3
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
[    0.000000] Kernel command line:  board=CARAMBOLA2 console=ttyATH0,115200 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env)ro,16000k(firmware),64k(art)ro rootfstype=squashfs,jffs2 noinitrd
[    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Writing ErrCtl register=00000000
[    0.000000] Readback ErrCtl register=00000000
[    0.000000] Memory: 61272k/65536k available (2239k kernel code, 4264k reserved, 603k data, 228k init, 0k highmem)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:51
[    0.080000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[    0.080000] pid_max: default: 32768 minimum: 301
[    0.080000] Mount-cache hash table entries: 512
[    0.090000] NET: Registered protocol family 16
[    0.100000] MIPS: machine is 8devices Carambola2 board
[    0.550000] bio: create slab <bio-0> at 0
[    0.560000] Switching to clocksource MIPS
[    0.570000] NET: Registered protocol family 2
[    0.570000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[    0.570000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[    0.580000] TCP: Hash tables configured (established 512 bind 512)
[    0.580000] TCP: reno registered
[    0.580000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.590000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.600000] NET: Registered protocol family 1
[    0.600000] PCI: CLS 0 bytes, default 32
[    0.620000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.630000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.640000] msgmni has been set to 119
[    0.640000] io scheduler noop registered
[    0.640000] io scheduler deadline registered (default)
[    0.650000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[    0.660000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
[    0.660000] console [ttyATH0] enabled, bootconsole disabled
[    0.680000] ath79-spi ath79-spi: master is unqueued, this is deprecated
[    0.680000] m25p80 spi0.0: found w25q128, expected m25p80
[    0.690000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    0.690000] 4 cmdlinepart partitions found on MTD device spi0.0
[    0.700000] Creating 4 MTD partitions on "spi0.0":
[    0.700000] 0x000000000000-0x000000040000 : "u-boot"
[    0.710000] 0x000000040000-0x000000050000 : "u-boot-env"
[    0.720000] 0x000000050000-0x000000ff0000 : "firmware"
[    0.740000] 2 uimage-fw partitions found on MTD device firmware
[    0.740000] 0x000000050000-0x000000160000 : "kernel"
[    0.750000] 0x000000160000-0x000000ff0000 : "rootfs"
[    0.750000] mtd: device 4 (rootfs) set to be root filesystem
[    0.760000] 1 squashfs-split partitions found on MTD device rootfs
[    0.760000] 0x0000006d0000-0x000000ff0000 : "rootfs_data"
[    0.770000] 0x000000ff0000-0x000001000000 : "art"
[    0.790000] libphy: ag71xx_mdio: probed
[    1.340000] ag71xx-mdio.1: Found an AR7240/AR9330 built-in switch
[    2.380000] eth0: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[    2.930000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[    2.940000] eth1: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[    2.950000] TCP: cubic registered
[    2.950000] NET: Registered protocol family 17
[    2.960000] 8021q: 802.1Q VLAN Support v1.8
[    2.970000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[    2.970000] Freeing unused kernel memory: 228K (80327000 - 80360000)
[    6.790000] usbcore: registered new interface driver usbfs
[    6.800000] usbcore: registered new interface driver hub
[    6.800000] usbcore: registered new device driver usb
[    6.860000] SCSI subsystem initialized
[    6.870000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    6.870000] ehci-platform: EHCI generic platform driver
[    6.880000] ehci-platform ehci-platform: EHCI Host Controller
[    6.880000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[    6.890000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[    6.920000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[    6.920000] hub 1-0:1.0: USB hub found
[    6.920000] hub 1-0:1.0: 1 port detected
[    6.930000] usbcore: registered new interface driver usb-storage
[    7.360000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    7.630000] hub 1-1:1.0: USB hub found
[    7.630000] hub 1-1:1.0: 4 ports detected
[    7.920000] usb 1-1.1: new high-speed USB device number 3 using ehci-platform
[    8.030000] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[    8.040000] scsi0 : usb-storage 1-1.1:1.0
[    8.120000] usb 1-1.2: new full-speed USB device number 4 using ehci-platform
[    8.310000] usb 1-1.3: new full-speed USB device number 5 using ehci-platform
[    8.510000] usb 1-1.4: new high-speed USB device number 6 using ehci-platform
[    8.630000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[    8.640000] scsi1 : usb-storage 1-1.4:1.0
[    9.040000] scsi 0:0:0:0: Direct-Access     Lexar    microSD RDR      0815 PQ: 0 ANSI: 6
[    9.170000] eth0: link up (1000Mbps/Full duplex)
[    9.640000] scsi 1:0:0:0: Direct-Access     TOSHIBA  TransMemory      PMAP PQ: 0 ANSI: 0 CCS
[    9.650000] sd 1:0:0:0: [sdb] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[    9.660000] sd 1:0:0:0: [sdb] Write Protect is on
[    9.660000] sd 1:0:0:0: [sdb] Mode Sense: 23 00 80 00
[    9.660000] sd 1:0:0:0: [sdb] No Caching mode page found
[    9.660000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[    9.680000] sd 0:0:0:0: [sda] 62552064 512-byte logical blocks: (32.0 GB/29.8 GiB)
[    9.690000] sd 0:0:0:0: [sda] Write Protect is off
[    9.690000] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[    9.690000] sd 1:0:0:0: [sdb] No Caching mode page found
[    9.690000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[    9.700000] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    9.710000]  sdb: unknown partition table
[    9.720000] sd 1:0:0:0: [sdb] No Caching mode page found
[    9.730000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[    9.730000] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[    9.740000]  sda: unknown partition table
[    9.750000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[   12.500000] jffs2: notice: (359) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 58 of xref (0 dead, 43 orphan) found.
[   12.520000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[   12.520000] block: unable to load configuration (fstab: Entry not found)
[   12.530000] block: attempting to load /tmp/jffs_cfg/etc/config/fstab
[   12.550000] block: extroot: not configured
[   12.640000] jffs2: notice: (356) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 58 of xref (0 dead, 43 orphan) found.
[   12.980000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[   12.990000] block: unable to load configuration (fstab: Entry not found)
[   13.000000] block: attempting to load /tmp/jffs_cfg/etc/config/fstab
[   13.010000] block: extroot: not configured
[   13.040000] eth0: link down
[   18.930000] NET: Registered protocol family 10
[   18.960000] nf_conntrack version 0.5.0 (960 buckets, 3840 max)
[   18.980000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   19.010000] hidraw: raw HID events driver (C) Jiri Kosina
[   19.030000] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   19.030000] sd 1:0:0:0: Attached scsi generic sg1 type 0
[   19.340000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[   19.350000] Backport generated by backports.git backports-20140320-37-g5c33da0
[   19.360000] ip_tables: (C) 2000-2006 Netfilter Core Team
[   19.390000] usbcore: registered new interface driver usbhid
[   19.400000] usbhid: USB HID core driver
[   19.420000] usbcore: registered new interface driver usbserial
[   19.420000] usbcore: registered new interface driver usbserial_generic
[   19.430000] usbserial: USB Serial support registered for generic
[   19.460000] xt_time: kernel timezone is -0000
[   19.470000] usbcore: registered new interface driver cdc_ether
[   19.510000] cfg80211: Calling CRDA to update world regulatory domain
[   19.510000] cfg80211: World regulatory domain updated:
[   19.520000] cfg80211:  DFS Master region: unset
[   19.520000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   19.530000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   19.540000] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   19.550000] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   19.550000] cfg80211:   (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[   19.560000] cfg80211:   (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   19.570000] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   19.580000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   19.590000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   19.600000] usbcore: registered new interface driver ch341
[   19.600000] usbserial: USB Serial support registered for ch341-uart
[   19.620000] usbcore: registered new interface driver cp210x
[   19.620000] usbserial: USB Serial support registered for cp210x
[   19.630000] cp210x 1-1.2:1.0: cp210x converter detected
[   19.720000] usb 1-1.2: reset full-speed USB device number 4 using ehci-platform
[   19.840000] usb 1-1.2: cp210x converter now attached to ttyUSB0
[   19.850000] usbcore: registered new interface driver ftdi_sio
[   19.850000] usbserial: USB Serial support registered for FTDI USB Serial Device
[   19.860000] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[   19.870000] usb 1-1.3: Detected FT232RL
[   19.870000] usb 1-1.3: Number of endpoints 2
[   19.870000] usb 1-1.3: Endpoint 1 MaxPacketSize 16384
[   19.880000] usb 1-1.3: Endpoint 2 MaxPacketSize 16384
[   19.880000] usb 1-1.3: Setting MaxPacketSize 64
[   19.900000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB1
[   19.960000] usbcore: registered new interface driver pl2303
[   19.980000] usbserial: USB Serial support registered for pl2303
[   19.980000] PPP generic driver version 2.4.2
[   20.000000] NET: Registered protocol family 24
[   20.060000] usbcore: registered new interface driver option
[   20.080000] usbserial: USB Serial support registered for GSM modem (1-port)
[   20.120000] ath: EEPROM regdomain: 0x0
[   20.120000] ath: EEPROM indicates default country code should be used
[   20.120000] ath: doing EEPROM country->regdmn map search
[   20.120000] ath: country maps to regdmn code: 0x3a
[   20.120000] ath: Country alpha2 being used: US
[   20.120000] ath: Regpair used: 0x3a
[   20.140000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   20.140000] cfg80211: Calling CRDA for country: US
[   20.150000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[   20.160000] cfg80211: Regulatory domain changed to country: US
[   20.160000] cfg80211:  DFS Master region: FCC
[   20.160000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   20.170000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[   20.180000] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[   20.190000] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[   20.200000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[   20.210000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[   20.320000] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[   20.320000] scsi2 : usb-storage 1-1.1:1.0
[   20.340000] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
[   20.340000] cp210x 1-1.2:1.0: device disconnected
[   20.360000] cp210x 1-1.2:1.0: cp210x converter detected
[   20.450000] usb 1-1.2: reset full-speed USB device number 4 using ehci-platform
[   20.570000] usb 1-1.2: cp210x converter now attached to ttyUSB0
[   20.570000] ftdi_sio ttyUSB1: FTDI USB Serial Device converter now disconnected from ttyUSB1
[   20.580000] ftdi_sio 1-1.3:1.0: device disconnected
[   20.600000] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[   20.600000] usb 1-1.3: Detected FT232RL
[   20.610000] usb 1-1.3: Number of endpoints 2
[   20.610000] usb 1-1.3: Endpoint 1 MaxPacketSize 16384
[   20.620000] usb 1-1.3: Endpoint 2 MaxPacketSize 16384
[   20.620000] usb 1-1.3: Setting MaxPacketSize 64
[   20.650000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB1
[   21.340000] scsi 2:0:0:0: Direct-Access     Lexar    microSD RDR      0815 PQ: 0 ANSI: 6
[   21.350000] sd 2:0:0:0: Attached scsi generic sg0 type 0
[   21.990000] sd 2:0:0:0: [sda] 62552064 512-byte logical blocks: (32.0 GB/29.8 GiB)
[   21.990000] sd 2:0:0:0: [sda] Write Protect is off
[   22.000000] sd 2:0:0:0: [sda] Mode Sense: 23 00 00 00
[   22.030000] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[   22.040000]  sda: unknown partition table
[   22.060000] sd 2:0:0:0: [sda] Attached SCSI removable disk
[   22.730000] i2c /dev entries driver
[   22.760000] Custom GPIO-based I2C driver version 0.1.1
[   22.760000] i2c-gpio i2c-gpio.0: using pins 20 (SDA) and 21 (SCL)
[   35.720000] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   36.360000] eth0: link up (1000Mbps/Full duplex)
[   36.360000] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   51.250000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[   51.260000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[   51.270000] EXT4-fs (sdb): INFO: recovery required on readonly filesystem
[   51.270000] EXT4-fs (sdb): write access unavailable, cannot proceed
[   52.310000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[   52.320000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[   52.350000] EXT4-fs (sdb): INFO: recovery required on readonly filesystem
[   52.350000] EXT4-fs (sdb): write access unavailable, cannot proceed
[   58.410000] EXT4-fs (sda): couldn't mount as ext3 due to feature incompatibilities
[   58.420000] EXT4-fs (sda): couldn't mount as ext2 due to feature incompatibilities
[   58.490000] EXT4-fs (sda): mounted filesystem with ordered data mode. Opts: (null)
[   87.070000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[   87.070000] scsi3 : usb-storage 1-1.4:1.0
[   88.080000] scsi 3:0:0:0: Direct-Access     TOSHIBA  TransMemory      PMAP PQ: 0 ANSI: 0 CCS
[   88.090000] sd 3:0:0:0: Attached scsi generic sg1 type 0
[   88.090000] sd 3:0:0:0: [sdb] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[   88.100000] sd 3:0:0:0: [sdb] Write Protect is on
[   88.110000] sd 3:0:0:0: [sdb] Mode Sense: 23 00 80 00
[   88.110000] sd 3:0:0:0: [sdb] No Caching mode page found
[   88.120000] sd 3:0:0:0: [sdb] Assuming drive cache: write through
[   88.130000] sd 3:0:0:0: [sdb] No Caching mode page found
[   88.130000] sd 3:0:0:0: [sdb] Assuming drive cache: write through
[   88.140000]  sdb: unknown partition table
[   88.150000] sd 3:0:0:0: [sdb] No Caching mode page found
[   88.160000] sd 3:0:0:0: [sdb] Assuming drive cache: write through
[   88.160000] sd 3:0:0:0: [sdb] Attached SCSI removable disk
[   90.500000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[   90.510000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[   90.520000] EXT4-fs (sdb): INFO: recovery required on readonly filesystem
[   90.530000] EXT4-fs (sdb): write access unavailable, cannot proceed
[  194.360000] IPv6: ADDRCONF(NETDEV_UP): scan0: link is not ready
[  241.420000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[  241.420000] scsi4 : usb-storage 1-1.4:1.0
[  242.440000] scsi 4:0:0:0: Direct-Access     TOSHIBA  TransMemory      PMAP PQ: 0 ANSI: 0 CCS
[  242.450000] sd 4:0:0:0: Attached scsi generic sg1 type 0
[  242.450000] sd 4:0:0:0: [sdb] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[  242.460000] sd 4:0:0:0: [sdb] Write Protect is on
[  242.470000] sd 4:0:0:0: [sdb] Mode Sense: 23 00 80 00
[  242.470000] sd 4:0:0:0: [sdb] No Caching mode page found
[  242.480000] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[  242.490000] sd 4:0:0:0: [sdb] No Caching mode page found
[  242.490000] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[  242.500000]  sdb: unknown partition table
[  242.510000] sd 4:0:0:0: [sdb] No Caching mode page found
[  242.520000] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[  242.520000] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[  245.870000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[  245.880000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[  245.890000] EXT4-fs (sdb): INFO: recovery required on readonly filesystem
[  245.900000] EXT4-fs (sdb): write access unavailable, cannot proceed
[  519.480000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[  519.480000] scsi5 : usb-storage 1-1.4:1.0
[  520.490000] scsi 5:0:0:0: Direct-Access     TOSHIBA  TransMemory      PMAP PQ: 0 ANSI: 0 CCS
[  520.500000] sd 5:0:0:0: Attached scsi generic sg1 type 0
[  520.500000] sd 5:0:0:0: [sdb] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[  520.510000] sd 5:0:0:0: [sdb] Write Protect is on
[  520.520000] sd 5:0:0:0: [sdb] Mode Sense: 23 00 80 00
[  520.520000] sd 5:0:0:0: [sdb] No Caching mode page found
[  520.530000] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[  520.540000] sd 5:0:0:0: [sdb] No Caching mode page found
[  520.540000] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[  520.550000]  sdb: unknown partition table
[  520.560000] sd 5:0:0:0: [sdb] No Caching mode page found
[  520.570000] sd 5:0:0:0: [sdb] Assuming drive cache: write through
[  520.570000] sd 5:0:0:0: [sdb] Attached SCSI removable disk
[  523.900000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[  523.910000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[  523.920000] EXT4-fs (sdb): INFO: recovery required on readonly filesystem
[  523.930000] EXT4-fs (sdb): write access unavailable, cannot proceed
[  861.470000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[  861.470000] scsi6 : usb-storage 1-1.4:1.0
[  862.480000] scsi 6:0:0:0: Direct-Access     TOSHIBA  TransMemory      PMAP PQ: 0 ANSI: 0 CCS
[  862.490000] sd 6:0:0:0: Attached scsi generic sg1 type 0
[  862.490000] sd 6:0:0:0: [sdb] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[  862.500000] sd 6:0:0:0: [sdb] Write Protect is on
[  862.510000] sd 6:0:0:0: [sdb] Mode Sense: 23 00 80 00
[  862.510000] sd 6:0:0:0: [sdb] No Caching mode page found
[  862.520000] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[  862.530000] sd 6:0:0:0: [sdb] No Caching mode page found
[  862.530000] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[  862.540000]  sdb: unknown partition table
[  862.550000] sd 6:0:0:0: [sdb] No Caching mode page found
[  862.560000] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[  862.560000] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[  865.910000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[  865.920000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[  865.930000] EXT4-fs (sdb): INFO: recovery required on readonly filesystem
[  865.940000] EXT4-fs (sdb): write access unavailable, cannot proceed
[ 1185.520000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 1185.520000] scsi7 : usb-storage 1-1.4:1.0
[ 1186.530000] scsi 7:0:0:0: Direct-Access     TOSHIBA  TransMemory      PMAP PQ: 0 ANSI: 0 CCS
[ 1186.540000] sd 7:0:0:0: [sdb] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[ 1186.550000] sd 7:0:0:0: Attached scsi generic sg1 type 0
[ 1186.550000] sd 7:0:0:0: [sdb] Write Protect is on
[ 1186.560000] sd 7:0:0:0: [sdb] Mode Sense: 23 00 80 00
[ 1186.560000] sd 7:0:0:0: [sdb] No Caching mode page found
[ 1186.570000] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[ 1186.580000] sd 7:0:0:0: [sdb] No Caching mode page found
[ 1186.580000] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[ 1186.590000]  sdb: unknown partition table
[ 1186.600000] sd 7:0:0:0: [sdb] No Caching mode page found
[ 1186.600000] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[ 1186.610000] sd 7:0:0:0: [sdb] Attached SCSI removable disk
[ 1188.830000] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
[ 1188.830000] cp210x 1-1.2:1.0: device disconnected
[ 1188.940000] usb 1-1.2: reset full-speed USB device number 4 using ehci-platform
[ 1189.050000] cp210x 1-1.2:1.0: cp210x converter detected
[ 1189.140000] usb 1-1.2: reset full-speed USB device number 4 using ehci-platform
[ 1189.260000] usb 1-1.2: cp210x converter now attached to ttyUSB0
[ 1190.020000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[ 1190.030000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[ 1190.040000] EXT4-fs (sdb): INFO: recovery required on readonly filesystem
[ 1190.050000] EXT4-fs (sdb): write access unavailable, cannot proceed
[ 1467.470000] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 1467.490000] scsi8 : usb-storage 1-1.4:1.0
[ 1468.490000] scsi 8:0:0:0: Direct-Access     TOSHIBA  TransMemory      PMAP PQ: 0 ANSI: 0 CCS
[ 1468.500000] sd 8:0:0:0: Attached scsi generic sg1 type 0
[ 1468.500000] sd 8:0:0:0: [sdb] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[ 1468.510000] sd 8:0:0:0: [sdb] Write Protect is on
[ 1468.520000] sd 8:0:0:0: [sdb] Mode Sense: 23 00 80 00
[ 1468.520000] sd 8:0:0:0: [sdb] No Caching mode page found
[ 1468.530000] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 1468.540000] sd 8:0:0:0: [sdb] No Caching mode page found
[ 1468.540000] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 1468.550000]  sdb: unknown partition table
[ 1468.560000] sd 8:0:0:0: [sdb] No Caching mode page found
[ 1468.570000] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 1468.570000] sd 8:0:0:0: [sdb] Attached SCSI removable disk
[ 1471.930000] EXT4-fs (sdb): couldn't mount as ext3 due to feature incompatibilities
[ 1471.940000] EXT4-fs (sdb): couldn't mount as ext2 due to feature incompatibilities
[ 1471.950000] EXT4-fs (sdb): INFO: recovery required on readonly filesystem
[ 1471.960000] EXT4-fs (sdb): write access unavailable, cannot proceed
