BUG: wind0dir-val* no longer correct **solved**
CyberMike
Post by CyberMike »
Reading the change log, I see on July 3 the software was updated to change the Wind Direction algorithm.
In the Templates, wind0dir-act works properly.
However, wind0dir-val1, wind0dir-val2, wind0dir-val3, etc have stopped working, and just return 90 degrees at all times.
Checking wind0dir-min1, wind0dir-max1, wind0dir-avg1, they all do change properly as the sensor data changes. Only wind0dir-val1 et al is stuck at 90 degrees.
I obviously do use the wind0dir-val* series of template codes: every 15 minutes the Meteobridge sends me a snapshot of the prior 15 minutes, including 15 one-minute snapshots of the instantaneous wind direction at each minute.
Re: BUG: wind0dir-val* no longer correct in Template after J
Thanks for the feedback, I will check this.
QuilpieGuy
Post by QuilpieGuy »
Any news on this??
I've just encountered the same problem, using Meteobridge 3.1 (Nov 26 2016, build 10749), FW 1.4
sjw
Post by sjw »
I am also interested in this. I reported this as 'Template error after update' viewtopic.php?f=56&t=11390 on October 16, but had no response.
Should work again fine with todays update.
sjw
Re: BUG: wind0dir-val* no longer correct **solved**
Post by sjw »
Thank-you very much for the fix!
I was starting to rewrite the scripts I use for my weather display to work around the problem, but not getting very far with it.
All working nicely now. Thanks.
Regards,
Stephen
View my different style 24 hour weather display at: http://lantanasystems.com.au/weather.html.
