Error FTP Upload
What's hot...
tt22tt
Error FTP Upload
Post by tt22tt »
Hi all,
the FTP section is filled in correctly and the test in the webinterface works: A file was created.
But the automated transfer of files via FTP does not work. There is an error in the eventlog:
Jul 9 19:05:22 meteohub-rpi logger: ncftpput: Could not change to directory /var/run/meteohub/uploads/clientraw.txt: server said: Failed to change directory.
The files are correctly in /var/run/meteohub/uploads/clientraw.txt
root@meteohub-rpi:/var/run/meteohub/uploads# ls -l
total 20
-rw-r--r-- 1 root root 410 Jul 9 19:57 clientraw.txt
-rw-r--r-- 1 root root 913 Jul 9 19:30 clientrawdaily.txt
-rw-r--r-- 1 root root 1618 Jul 9 19:45 clientrawextra.txt
-rw-r--r-- 1 root root 1350 Jul 9 19:57 clientrawhour.txt
-rw-r--r-- 1 root root 2753 Jul 9 19:57 mwlive.xml
My page of System Information:
Software
Linux Kernel: 3.18.8 2000 BogoMIPS, 949 MB RAM, Raspberry PI Model 2
MeteoHub: 5.0q (Build 177) ©2015 by smartbedded UG (haftungsbeschränkt)
System-ID: Cs5@ac03 aktiviert
Speicherplatz
Medium: 00000 01/2016 0xf4f85d8c (0.12 rounds)
Swap: 0MB von 127MB belegt (0%)
System: 1337MB von 1641MB belegt (81%)
Daten: 50MB von 28071MB belegt (0%)
Datum und Zeit
Weltzeit: 09.07.2016 17:55:20
Zeitzone: Europe/Berlin
Ortszeit: 09.07.2016 19:55:20
Laufzeit: 2 hours, 28 minutes
Systemlast: 0.11, 0.08, 0.05
Prozesse
Wetterdatenneuberechnung: abgeschlossen
Wetterdatenerfassung: läuft (letzter Datensatz: 1 sec)
SSH Login: läuft
SMB Netzwerkfreigabe: läuft
Zeitsynchronisation: läuft
This is the full log:
Jul 9 19:06:01 meteohub-rpi /USR/SBIN/CRON[11154]: (root) CMD (/bin/pidof histeval0 || /usr/bin/nice /home/meteohub/histeval0)
Jul 9 19:06:01 meteohub-rpi /USR/SBIN/CRON[11155]: (root) CMD (sleep 20; [ -z "`ls /var/run/meteohub/uploads/`" ] || [ -n "`/bin/pidof /usr/bin/ncftpput`" ] || /usr/bin/ncftpput -S .tmp -R -V -DD -u "myusername" -p 'mypassword -P 21 my.server /var/run/meteohub/uploads/* 2>&1 | /usr/bin/logger)
Jul 9 19:06:01 meteohub-rpi /USR/SBIN/CRON[11157]: (root) CMD (sleep 8; /srv/www/meteohtml.cgi /home/meteohub/clientrawhour.conf >/var/run/meteohub/clientrawhour.out; cp /var/run/meteohub/clientrawhour.out /var/run/meteohub/perm/clientrawhour.txt; mv /var/run/meteohub/clientrawhour.out "/var/run/meteohub/uploads/clientrawhour.txt")
Jul 9 19:06:01 meteohub-rpi /USR/SBIN/CRON[11158]: (root) CMD (sleep 0; /srv/www/meteohtml.cgi /home/meteohub/mwlive.conf >/var/run/meteohub/mwlive.out; cp /var/run/meteohub/mwlive.out /data/myweb/uploads/mwlive.xml; mv /var/run/meteohub/mwlive.out "/var/run/meteohub/uploads/mwlive.xml")
Jul 9 19:06:01 meteohub-rpi /USR/SBIN/CRON[11156]: (root) CMD (([ -n "`/bin/pidof thttpd`" ] && [ -n "`/bin/pidof thttpdbackup`" ]) || rcthttpd restart)
Jul 9 19:06:01 meteohub-rpi /USR/SBIN/CRON[11160]: (root) CMD (sleep 0; /srv/www/meteohtml.cgi /home/meteohub/clientraw.conf >/var/run/meteohub/clientraw.out; cp /var/run/meteohub/clientraw.out /var/run/meteohub/perm/clientraw.txt; mv /var/run/meteohub/clientraw.out "/var/run/meteohub/uploads/clientraw.txt")
Jul 9 19:06:01 meteohub-rpi /USR/SBIN/CRON[11166]: (root) CMD (/bin/pidof wswinimport || /usr/bin/nice /home/meteohub/wswinimport 2>>/data/log/messages)
Jul 9 19:06:01 meteohub-rpi /USR/SBIN/CRON[11167]: (root) CMD (/bin/cat /proc/uptime >/home/meteohub/alive)
Jul 9 19:06:22 meteohub-rpi logger: ncftpput: Could not change to directory /var/run/meteohub/uploads/clientraw.txt: server said: Failed to change directory.
Jul 9 19:06:38 meteohub-rpi thttpd[5335]: spawned CGI process 11194 for file 'cgi-bin/meteohub.cgi'
Jul 9 19:06:40 meteohub-rpi thttpd[5335]: spawned CGI process 11227 for file 'cgi-bin/meteohub.cgi'
Jul 9 19:06:43 meteohub-rpi thttpd[5335]: spawned CGI process 11260 for file 'cgi-bin/meteohub.cgi'
Jul 9 19:06:47 meteohub-rpi thttpd[5335]: spawned CGI process 11293 for file 'cgi-bin/meteohub.cgi'
Could someone give me a hint, please?
//edit: I have just install all available linux-update (apt-get upgrade). But this does not help, too.
tt22tt
Re: Error FTP Upload
Post by tt22tt »
The solution was: I have to use a subfolder. There is a bug in ncftpput.
Could you please change the webinterface and the manual: Please give a hint that it is necessarry to use a subfolder?
Thanks for finding out, but to be honest I don't fully understand what you suggest.
Can you please explain a bit more which input in the web interface worked and which did not?
tt22tt
Post by tt22tt »
Auf der Seite E-mail und FTP hinterlege ich die FTP-Daten für den automatischen Upload.
Wenn ich unter dem Punkt Inhaltsverzeichnis keinen Ordner eintragen und sozusagen den Root-Ordner nehmen möchte, dann läuft das in einen Fehler. Unter dem Punkt Inhaltsverzeichnis muss daher immer ein Ordner stehen. Für diesen Vorgang wird innerhalb von Meteohub das Tool ncftpput eingesetzt. Das hat eine Fehlfunktion und kann mit einem leeren Ordnerpfad nicht umgehen.
