What is going on with the MBPRO again.
MeteoLeudal
Post by MeteoLeudal »
After the internal memory card problems it should have to be replaced.
Now the following problem arise :( There is no content with data to see on the display even isn’t to see the MB start screen.
Back to the factory settings gives the same story the display remains black ... very strange this.
What is going on with this € 369.00 costing device!
Now what to do bring te MBPRO back for repair or is there a solotion for this.
Thanks Peter.
Re: What is going on with the MBPRO again.
Peter, I have already replaced the memory in one of mine and replacing the USB memory isn't a big deal and firmware changes have been made to prevent/reduce this occurring with the early units. For a device that's only been available 6-7 months I don't see any issues that aren't being addressed as quickly as they can be addressed after being reported. I am sure Boris will be in touch with you to help your issues.
When display stays black during boot, that indicates a broken display. Does the Meteobridge proceed boot to the point where the red LED second from the top reaches steady on? If so, it is rather obvious that the display is defective, while the unit itself is working fine.
If so, please schedule a repair with the distributor.
I am sorry that you again have a hassle with it, but display breaks are not happening that often.
We test the device including the display before we ship, but cracks can happen.
MeteoLeudal
Mattk wrote:Peter, I have already replaced the memory in one of mine and replacing the USB memory isn't a big deal and firmware changes have been made to prevent/reduce this occurring with the early units. For a device that's only been available 6-7 months I don't see any issues that aren't being addressed as quickly as they can be addressed after being reported. I am sure Boris will be in touch with you to help your issues.
Thanks for your reply Mattk. Have you exchanged the internal memory card by yourself and which memory you have used in the MBPRO now?
MeteoLeudal
admin wrote:When display stays black during boot, that indicates a broken display. Does the Meteobridge proceed boot to the point where the red LED second from the top reaches steady on? If so, it is rather obvious that the display is defective, while the unit itself is working fine.
Also thanks for your reply Boris (admin) :)
As you says the mbpro boot normally and everything works fine with the front memory card and the latest version 3.0 also the second red led is steady on. Can't see on the outside that the display is broken it looks like new. I'm always careful with such devices but everything can break down unfortunately. Just for a 6 month old device is this very quickly. Ok I will bring the mbpro back to the distributor for repair.
Peter.
Yes not that difficult to change the internal USB but suggest you contact Boris first for advice. Have replaced one original Intenso with a Transcend JetFlash 710S (USB 3.1/3.0 32GB) but only time will tell how it stands up. By all accounts with FW 3.0 it should last much longer due to the reduced read/writes? Also have some SLC USB coming which should eliminate read/write issues forever but these are not cheap.
MeteoLeudal
Thanks for this useful information but first I will return the MBPRO to the vendor for the defects which has manifested. Think it's a warranty case.
