http://hetweerinbleiswijk.nl/
as you can see, the graphs are up-to-date up to the point of the recomputation, but nothing after that. the funny part is that the top table is up to date with the current data. somehow history data gets calculated, but the aggregation of the data is not. ssh'ing to the device shows that all the cron-jobs are still there:
root@meteohub:/data/weather$ head -n 50 /var/cron/tabs/root
# DO NOT EDIT THIS FILE - edit the master and reinstall.
# (/var/cron/tabs/root.new installed on Sun Jul 31 08:27:32 2016)
# (Cron version -- $Id: crontab.c,v 2.13 1994/01/17 03:20:37 vixie Exp $)
*/1 */1 * * * /bin/pidof histeval0 || /usr/bin/nice /home/meteohub/histeval0
*/1 * * * * /bin/cat /proc/uptime >/var/run/meteohub/alive
22,52 * * * * echo 'wdnow' >/dev/meteohub
13 */6 * * * /bin/pidof histeval2 || /usr/bin/nice /home/meteohub/histeval2
47 4 * * * /bin/pidof histeval3 || /usr/bin/nice /home/meteohub/histeval3
*/3 * * * * /bin/pidof wswinimport || /usr/bin/nice /home/meteohub/wswinimport 2>>/data/log/messages
17 */6 * * * rm /var/run/*.idx
18 */4 * * * /usr/bin/tail -n 1000 /var/log/messages >/var/log/messages.new; /bin/mv -f /var/log/messages.new /var/log/messages
26 6 * * * nice /srv/www/meteolog.cgi 0 0
# optional nightly reboot
37 2 * * * /usr/bin/test -f /home/meteohub/autoreboot && echo norecompute >/home/meteohub/norecompute && /sbin/shutdown -r -n now
# keep watchdog happy
# generate history data
*/5 */1 * * * /bin/pidof histeval1 || /usr/bin/nice /home/meteohub/histeval1
# synchronize hw clock
44 */2 * * * /sbin/hwclock -w
# generate live wswin data
# compute weather data
8,18,28,38,48,58 * * * * /usr/bin/nice /home/meteohub/wmr928eval -x -c min1 -t -3600 -w /data/weather/ -s /home/meteohub/wmr928eval.conf -e /home/meteohub/wswin.conf -E /home/meteohub/wd.conf
1,11,21,31,41,51 * * * * /usr/bin/nice /home/meteohub/wmr928eval -c min5 -t -3600 -w /data/weather/ -s /home/meteohub/wmr928eval.conf
2,22,42 * * * * /usr/bin/nice /home/meteohub/wmr928eval -c min10 -t -3600 -w /data/weather/ -s /home/meteohub/wmr928eval.conf
3,33 * * * * /usr/bin/nice /home/meteohub/wmr928eval -c min30 -t -7200 -w /data/weather/ -s /home/meteohub/wmr928eval.conf
3 * * * * /usr/bin/nice /home/meteohub/wmr928eval -c hour1 -t -7200 -w /data/weather/ -s /home/meteohub/wmr928eval.conf
4 0,6,12,18 * * * /usr/bin/nice /home/meteohub/wmr928eval -c hour6 -t -50000 -w /data/weather/ -s /home/meteohub/wmr928eval.conf
5 2 * * * /usr/bin/nice /home/meteohub/wmr928eval -c day1 -t -200000 -w /data/weather/ -s /home/meteohub/wmr928eval.conf
6 2 1 * * /usr/bin/nice /home/meteohub/wmr928eval -c month1 -t -7000000 -w /data/weather/ -s /home/meteohub/wmr928eval.conf
# test for complete recomputation of weather data
*/5 * * * * /home/meteohub/wmr928fullevalwrapper >/dev/null 2>>/data/log/messages
# check for alarms to be mailed to the admin and send them once a day
44 5,11,17,23 * * * /home/meteohub/alarm check "" >/dev/null 2>>/data/log/messages
55 23 * * * /home/meteohub/alarm send "" >/dev/null 2>>/data/log/messages
# shorten logfilesCode: Select all
-rw-r--r-- 1 root root 386 Jul 31 11:14 wind0-month1
-rw-r--r-- 1 root root 242 Jul 31 11:14 rain0-month1
-rw-r--r-- 1 root root 797 Jul 31 11:14 thb0-month1
-rw-r--r-- 1 root root 754 Jul 31 11:14 th0-month1
-rw-r--r-- 1 root root 745 Jul 31 11:14 th1-month1
-rw-r--r-- 1 root root 0 Jul 31 11:14 uv0-month1
-rw-r--r-- 1 root root 308 Jul 31 11:14 tdir0-month1
-rw-r--r-- 1 root root 541 Jul 31 11:14 sdir0-month1
drwxr-xr-x 2 root root 4.0K Aug 1 02:06 201608
drwxr-xr-x 12 root root 4.0K Aug 1 02:06 .
-rw-r--r-- 1 root root 8.4K Aug 1 05:08 hist-alltime
-rw-r--r-- 1 root root 1.9K Aug 1 05:25 seq-month1
-rw-r--r-- 1 root root 7.9K Aug 1 05:41 hist-year1
-rw-r--r-- 1 root root 8.0K Aug 1 06:21 hist-month1
-rw-r--r-- 1 root root 7.4K Aug 1 06:23 seq-day1
-rw-r--r-- 1 root root 5.8K Aug 1 06:25 seq-hour6
-rw-r--r-- 1 root root 5.3K Aug 1 2016 seq-hour1
-rw-r--r-- 1 root root 7.5K Aug 1 2016 hist-day1
-rw-r--r-- 1 root root 7.7K Aug 1 2016 hist-hour1
-rw-r--r-- 1 root root 8.3K Aug 1 2016 hist-last24h
-rw-r--r-- 1 root root 8.3K Aug 1 2016 hist-last60m
-rw-r--r-- 1 root root 8.3K Aug 1 2016 hist-last15m
-rw-r--r-- 1 root root 9.5K Aug 1 2016 seq-min1
-rw-r--r-- 1 root root 15K Aug 1 2016 seq-min15
root@meteohub:/data/weather$Code: Select all
root@meteohub:/data/weather$ tail thb0-min5
20160731080500 23.6 23.6 23.6 12.0 12.0 12.0 48.0 48.0 48.0 1015.0 1015.0 1015.0 1012.6 1012.6 1012.6 23.6 23.6 23.6 25.9 25.9 25.9
20160731081000 23.6 23.5 23.6 12.0 11.9 12.0 48.0 48.0 48.0 1015.0 1015.0 1015.0 1012.6 1012.6 1012.6 23.6 23.5 23.6 25.9 25.7 25.9
20160731081500 23.5 23.5 23.6 11.9 11.9 12.0 48.0 48.0 48.0 1015.0 1015.0 1015.0 1012.6 1012.6 1012.6 23.5 23.5 23.6 25.7 25.7 25.9
20160731082000 23.6 23.5 23.6 12.0 11.9 12.0 48.0 48.0 48.0 1015.0 1015.0 1015.0 1012.6 1012.6 1012.6 23.6 23.5 23.6 25.8 25.7 25.9
20160731082500 23.6 23.6 23.6 12.0 12.0 12.0 48.0 48.0 48.0 1015.0 1015.0 1015.0 1012.6 1012.6 1012.6 23.6 23.6 23.6 25.9 25.9 25.9
20160731083000 23.6 23.6 23.6 12.0 12.0 12.0 48.0 48.0 48.0 1015.0 1015.0 1015.0 1012.6 1012.6 1012.6 23.6 23.6 23.6 25.9 25.9 25.9
20160731083500 23.6 23.6 23.6 12.0 12.0 12.0 48.0 48.0 48.0 1015.0 1015.0 1015.0 1012.6 1012.6 1012.6 23.6 23.6 23.6 25.9 25.9 25.9
20160731084000 23.6 23.6 23.6 12.0 12.0 12.0 48.0 48.0 48.0 1015.0 1015.0 1015.0 1012.6 1012.6 1012.6 23.6 23.6 23.6 25.9 25.9 25.9
20160731084500 23.6 23.6 23.6 12.0 12.0 12.0 48.0 48.0 48.0 1015.0 1015.0 1015.0 1012.6 1012.6 1012.6 23.6 23.6 23.6 25.9 25.9 25.9
20160731085000 23.6 23.6 23.6 12.0 12.0 12.0 48.0 48.0 48.0 1015.0 1015.0 1015.0 1012.6 1012.6 1012.6 23.6 23.6 23.6 25.9 25.9 25.9
root@meteohub:/data/weather$Is there some process I can start manually? to see what's going wrong or something? the meteohub.log file displays no abnormalities:
wmr928fulleval(30.07.2016 09:25:04): recomputation of weather data started.
wmr928fulleval(30.07.2016 22:05:49): recomputation of weather data finished: 16337270 records processed in 45497 seconds (359 records per second)
wmr928fulleval(31.07.2016 08:35:05): recomputation of weather data started.
wmr928fulleval(31.07.2016 12:07:03): recomputation of weather data finished: 3417608 records processed in 12672 seconds (269 records per second)
