Pro database problem
1fcmrYpC2Nw8
Post by 1fcmrYpC2Nw8 »
I received my new Meteobridge Pro in May thinking that life would be so much easier.
Everything was fine for the first couple of months until I spotted lots of write error messages and a warning that 99% storage was used
About every three or four days I notice that the internal storage has increased from 1% used to around 95% or 99% used.
I tick the box 'check and repair on next startup' in the database section of system, save and then reboot.
The Pro reboots and then I miraculously have on 1% database usage. Until the next time...
Is there a problem with the internal storage?
Re: Pro database problem
I can't say from the symptoms you describe. If you like to give me
a remote login I could have a closer look: info(at)meteobridge.com
