MBP crashed - no contact
plex
Post by plex »
Hi
This morning I've noticed, that display was "frozen", and a login showed lots of problems. After a reboot device, the database was stalled, and another reboot resulted in a bricked MBP - no contact with http.
What to do :?: :?
backup (20.08.2016 09:18:34): backup completed: daily (142.5M)
backup (21.08.2016 09:18:35): backup completed: daily (142.6M)
logger (21.08.2016 21:21:52): DB cannot retrieve rain0total_day (100 tries, 9116ms): database is locked (5)
logger (21.08.2016 21:22:01): DB cannot retrieve th0temp_day (100 tries, 9127ms): database is locked (5)
logger (21.08.2016 21:22:10): DB cannot retrieve th0temp_day (100 tries, 9066ms): database is locked (5)
logger (21.08.2016 21:22:19): DB cannot retrieve th0dew_day (100 tries, 9095ms): database is locked (5)
logger (21.08.2016 21:22:28): DB cannot retrieve th0dew_day (100 tries, 9095ms): database is locked (5)
logger (21.08.2016 21:22:37): DB cannot retrieve wind0chill_day (100 tries, 9069ms): database is locked (5)
logger (21.08.2016 21:22:46): DB cannot retrieve wind0wind_day (100 tries, 9083ms): database is locked (5)
logger (21.08.2016 21:22:55): DB cannot retrieve thb0seapress_day (100 tries, 9088ms): database is locked (5)
logger (21.08.2016 21:23:05): DB cannot retrieve thb0seapress_day (100 tries, 9067ms): database is locked (5)
logger (21.08.2016 21:23:14): DB cannot retrieve thb0seapress_year (100 tries, 9072ms): database is locked (5)
logger (21.08.2016 21:23:23): DB cannot retrieve thb0seapress_year (100 tries, 9073ms): database is locked (5)
logger (21.08.2016 21:23:32): DB cannot retrieve rain0total_day (100 tries, 9091ms): database is locked (5)
logger (21.08.2016 21:23:41): DB cannot retrieve rain0rate_day (100 tries, 9072ms): database is locked (5)
logger (21.08.2016 21:23:50): DB cannot retrieve th0hum_day (100 tries, 9096ms): database is locked (5)
logger (21.08.2016 21:23:59): DB cannot retrieve th0hum_day (100 tries, 9082ms): database is locked (5)
logger (21.08.2016 21:24:08): DB cannot retrieve th0temp_day (100 tries, 9088ms): database is locked (5)
logger (21.08.2016 21:24:17): DB cannot retrieve th0temp_day (100 tries, 9115ms): database is locked (5)
logger (21.08.2016 21:24:26): DB cannot retrieve th0dew_day (100 tries, 9109ms): database is locked (5)
logger (21.08.2016 21:24:35): DB cannot retrieve th0dew_day (100 tries, 9113ms): database is locked (5)
logger (21.08.2016 21:24:45): DB cannot retrieve wind0chill_day (100 tries, 9288ms): database is locked (5)
logger (21.08.2016 21:24:54): DB cannot retrieve rain0rate_day (100 tries, 9080ms): database is locked (5)
logger (21.08.2016 21:25:03): DB cannot retrieve th0hum_day (100 tries, 9131ms): database is locked (5)
logger (21.08.2016 21:25:12): DB cannot retrieve th0hum_day (100 tries, 9083ms): database is locked (5)
logger (21.08.2016 21:25:21): DB cannot retrieve thb0seapress_day (100 tries, 9087ms): database is locked (5)
logger (21.08.2016 21:25:30): DB cannot retrieve thb0seapress_day (100 tries, 9081ms): database is locked (5)
logger (21.08.2016 21:25:39): DB cannot retrieve wind0wind_day (100 tries, 9071ms): database is locked (5)
logger (21.08.2016 21:25:48): DB cannot retrieve wind0avgwind_day (100 tries, 9077ms): database is locked (5)
logger (21.08.2016 21:25:57): DB cannot retrieve rain0total_day (100 tries, 9083ms): database is locked (5)
logger (21.08.2016 21:26:07): DB cannot retrieve rain0total_day (100 tries, 9119ms): database is locked (5)
logger (21.08.2016 21:26:16): DB cannot retrieve th0temp_day (100 tries, 9089ms): database is locked (5)
logger (21.08.2016 21:26:25): DB cannot retrieve th0temp_day (100 tries, 9090ms): database is locked (5)
logger (21.08.2016 21:26:34): DB cannot retrieve th0temp_day (100 tries, 9054ms): database is locked (5)
logger (21.08.2016 21:26:43): DB cannot retrieve th0temp_month (100 tries, 9096ms): database is locked (5)
logger (21.08.2016 21:26:52): DB cannot retrieve th0temp_month (100 tries, 9100ms): database is locked (5)
logger (21.08.2016 21:27:01): DB cannot retrieve th0temp_month (100 tries, 9076ms): database is locked (5)
logger (21.08.2016 21:27:10): DB cannot retrieve th0temp_year (100 tries, 9092ms): database is locked (5)
logger (21.08.2016 21:27:19): DB cannot retrieve th0temp_year (100 tries, 9103ms): database is locked (5)
logger (21.08.2016 21:27:28): DB cannot retrieve th0temp_year (100 tries, 9105ms): database is locked (5)
logger (21.08.2016 21:27:38): DB cannot retrieve th0hum_day (100 tries, 9105ms): database is locked (5)
logger (21.08.2016 21:27:47): DB cannot retrieve th0hum_day (100 tries, 9105ms): database is locked (5)
logger (21.08.2016 21:27:57): malformed parameter string (8): I 103 41 0 9F FF C3 0 B1 A5 FF F
logger (21.08.2016 21:27:57): unexpected parameter number (13): I 103 E0 0 0 26 5 0 40 AB FF FF -50 256247
logger (21.08.2016 21:27:57): unexpected parameter number (1): I 104
logger (21.08.2016 21:27:57): unexpected parameter number (5): I 100 E1 0 9F 80
logger (21.08.2016 21:27:57): unexpected parameter number (9): I 100 A0 0 0 A6 3D 0 9D DD
logger (22.08.2016 03:31:15): DB cannot retrieve rain0total_day (100 tries, 9101ms): database is locked (5)
logger (22.08.2016 03:31:24): DB cannot retrieve th0temp_day (100 tries, 9132ms): database is locked (5)
logger (22.08.2016 03:31:33): DB cannot retrieve th0temp_day (100 tries, 9138ms): database is locked (5)
logger (22.08.2016 03:31:42): DB cannot retrieve th0temp_day (100 tries, 9117ms): database is locked (5)
logger (22.08.2016 03:31:51): DB cannot retrieve th0temp_month (100 tries, 9137ms): database is locked (5)
logger (22.08.2016 03:32:01): DB cannot retrieve th0temp_month (100 tries, 9107ms): database is locked (5)
logger (22.08.2016 03:32:10): DB cannot retrieve th0temp_month (100 tries, 9090ms): database is locked (5)
logger (22.08.2016 03:32:19): DB cannot retrieve th0temp_year (100 tries, 9121ms): database is locked (5)
logger (22.08.2016 03:32:28): DB cannot retrieve th0temp_year (100 tries, 9136ms): database is locked (5)
logger (22.08.2016 03:32:37): DB cannot retrieve th0temp_year (100 tries, 9094ms): database is locked (5)
logger (22.08.2016 03:32:46): DB cannot retrieve th0hum_day (100 tries, 9117ms): database is locked (5)
logger (22.08.2016 03:32:55): DB cannot retrieve th0hum_day (100 tries, 9099ms): database is locked (5)
logger (22.08.2016 03:33:04): DB cannot retrieve th0hum_day (100 tries, 9091ms): database is locked (5)
logger (22.08.2016 03:33:13): DB cannot retrieve th0hum_month (100 tries, 9086ms): database is locked (5)
logger (22.08.2016 03:33:23): DB cannot retrieve th0hum_month (100 tries, 9104ms): database is locked (5)
logger (22.08.2016 03:33:32): DB cannot retrieve th0hum_month (100 tries, 9092ms): database is locked (5)
logger (22.08.2016 03:33:41): DB cannot retrieve th0hum_year (100 tries, 9138ms): database is locked (5)
logger (22.08.2016 03:33:50): DB cannot retrieve th0hum_year (100 tries, 9127ms): database is locked (5)
logger (22.08.2016 03:33:59): DB cannot retrieve th0hum_year (100 tries, 9105ms): database is locked (5)
logger (22.08.2016 03:34:06): malformed parameter string (8): I 103 40 0 0 FF C5 0 4C D2 FF FF
logger (22.08.2016 03:34:06): unexpected parameter number (13): I 103 81 1 9A FF C3 0 19 81 FF FF -44 2624960
logger (22.08.2016 03:34:06): unexpected parameter number (2): I 104 E
logger (22.08.2016 03:34:06): unexpected parameter number (6): I 100 E0 0 0 26 5
logger (22.08.2016 03:34:06): malformed parameter string (8): I 100 51 1 9A FF 73 0 A3 38 FF
backup (22.08.2016 09:22:12): backup completed: daily (142.6M)
logger (22.08.2016 15:21:50): DB cannot retrieve rain0total_day (100 tries, 9119ms): database is locked (5)
logger (22.08.2016 15:21:59): DB cannot retrieve th0temp_day (100 tries, 9083ms): database is locked (5)
logger (22.08.2016 15:22:08): DB cannot retrieve th0temp_day (100 tries, 9080ms): database is locked (5)
logger (22.08.2016 15:22:17): DB cannot retrieve th0temp_day (100 tries, 9118ms): database is locked (5)
logger (22.08.2016 15:22:26): DB cannot retrieve th0temp_month (100 tries, 9107ms): database is locked (5)
logger (22.08.2016 15:22:35): DB cannot retrieve th0temp_month (100 tries, 9109ms): database is locked (5)
logger (22.08.2016 15:22:44): DB cannot retrieve th0temp_month (100 tries, 9087ms): database is locked (5)
logger (22.08.2016 15:22:54): DB cannot retrieve th0temp_year (100 tries, 9077ms): database is locked (5)
logger (22.08.2016 15:23:03): DB cannot retrieve th0temp_year (100 tries, 9122ms): database is locked (5)
logger (22.08.2016 15:23:12): DB cannot retrieve th0temp_year (100 tries, 9144ms): database is locked (5)
logger (22.08.2016 15:23:21): DB cannot retrieve th0hum_day (100 tries, 9106ms): database is locked (5)
logger (22.08.2016 15:23:30): DB cannot retrieve th0hum_day (100 tries, 9123ms): database is locked (5)
logger (22.08.2016 15:23:39): DB cannot retrieve th0hum_day (100 tries, 9135ms): database is locked (5)
logger (22.08.2016 15:23:48): DB cannot retrieve th0hum_month (100 tries, 9104ms): database is locked (5)
logger (22.08.2016 15:23:57): DB cannot retrieve th0hum_month (100 tries, 9104ms): database is locked (5)
logger (22.08.2016 15:24:06): DB cannot retrieve th0hum_month (100 tries, 9083ms): database is locked (5)
logger (22.08.2016 15:24:16): DB cannot retrieve th0hum_year (100 tries, 9117ms): database is locked (5)
logger (22.08.2016 15:24:25): DB cannot retrieve th0hum_year (100 tries, 9104ms): database is locked (5)
logger (22.08.2016 15:24:34): DB cannot retrieve th0hum_year (100 tries, 9127ms): database is locked (5)
logger (22.08.2016 15:24:49): unexpected parameter number (3): I 101 E0 0
logger (22.08.2016 15:24:49): unexpected parameter number (8): I 100 51 A 7E FF 71 0 6
logger (22.08.2016 15:24:49): malformed parameter string (8): I 102 50 0 0 FF 75 0 48 5B FF FF
logger (22.08.2016 15:24:49): unexpected parameter number (1): I 10
logger (22.08.2016 21:19:07): DB cannot retrieve rain0total_day (100 tries, 9103ms): database is locked (5)
logger (22.08.2016 21:19:16): DB cannot retrieve th0temp_day (100 tries, 9117ms): database is locked (5)
logger (22.08.2016 21:19:25): DB cannot retrieve th0temp_day (100 tries, 9115ms): database is locked (5)
logger (22.08.2016 21:19:34): DB cannot retrieve th0dew_day (100 tries, 9067ms): database is locked (5)
logger (22.08.2016 21:19:43): DB cannot retrieve th0dew_day (100 tries, 9116ms): database is locked (5)
logger (22.08.2016 21:19:52): DB cannot retrieve wind0chill_day (100 tries, 9116ms): database is locked (5)
logger (22.08.2016 21:20:01): DB cannot retrieve wind0wind_day (100 tries, 9106ms): database is locked (5)
logger (22.08.2016 21:20:11): DB cannot retrieve thb0seapress_day (100 tries, 9130ms): database is locked (5)
logger (22.08.2016 21:20:20): DB cannot retrieve thb0seapress_day (100 tries, 9096ms): database is locked (5)
logger (22.08.2016 21:20:29): DB cannot retrieve thb0seapress_year (100 tries, 9066ms): database is locked (5)
logger (22.08.2016 21:20:38): DB cannot retrieve thb0seapress_year (100 tries, 9116ms): database is locked (5)
logger (22.08.2016 21:20:47): DB cannot retrieve rain0total_day (100 tries, 9111ms): database is locked (5)
logger (22.08.2016 21:20:56): DB cannot retrieve rain0rate_day (100 tries, 9110ms): database is locked (5)
logger (22.08.2016 21:21:05): DB cannot retrieve th0hum_day (100 tries, 9086ms): database is locked (5)
logger (22.08.2016 21:21:14): DB cannot retrieve th0hum_day (100 tries, 9104ms): database is locked (5)
logger (22.08.2016 21:21:23): DB cannot retrieve th0temp_day (100 tries, 9106ms): database is locked (5)
logger (22.08.2016 21:21:32): DB cannot retrieve th0temp_day (100 tries, 9105ms): database is locked (5)
logger (22.08.2016 21:21:44): unexpected parameter number (3): I 100 E0 0
logger (22.08.2016 21:21:45): Bad thb0(0) sensor data, "pressure x10" (102) out of range [4000:12000]
logger (22.08.2016 21:21:45): unexpected parameter number (1): I 1
logger (22.08.2016 21:21:45): unexpected parameter number (4): I 101 81 2 CB
Re: MBP crashed - no contact
This looks like a somehow stalled process holds a lock to the database. Do I have a chance to inspect situation on your rig? That this keeps the MB PRO from booting is rather unusual
What I would like to check is calling "system.cgi?dmesg" as this might tell if there are any low level errors.
plex
Post by plex »
admin wrote:This looks like a somehow stalled process holds a lock to the database. Do I have a chance to inspect situation on your rig or did you reboot to have it back working?
I did reboot, but now it can't open databasse, and I can't reboot
oled (23.08.2016 17:08:42): process started.
test5m (23.08.2016 19:11:38): weathernet daemon stalled, will be restarted now.
wnetd (23.08.2016 19:11:38): process started.
test5m (23.08.2016 19:11:38): logger stalled, will be restarted now.
test5m (23.08.2016 19:11:39): database daemon stalled, will be restarted now.
database (23.08.2016 19:11:39): process started.
logger (23.08.2016 19:49:55): can't open database: unable to open database file
logger (23.08.2016 19:49:55): Historical data loaded (0 records).
logger (23.08.2016 19:49:55): data logger (version 5.0r, build 10256) started.
logger (23.08.2016 19:49:56): connect station 0 (Meteostick Vantage via USB serial).
logger (23.08.2016 19:49:56): connect station 9 (System Data via Plug-in).
logger (23.08.2016 19:49:56): no synchronization for 900 seconds, data logger will be restarted.
logger (23.08.2016 19:49:56): disconnect station 0 (Meteostick Vantage): exit
logger (23.08.2016 19:49:56): disconnect station 9 (System Data): exit
logger (23.08.2016 19:49:57): data logger stopped.
logger (23.08.2016 19:49:57): databases disconnected.
logger (23.08.2016 19:49:57): can't open database: unable to open database file
logger (23.08.2016 19:49:57): Historical data loaded (0 records).
logger (23.08.2016 19:49:57): data logger (version 5.0r, build 10256) started.
logger (23.08.2016 19:49:58): connect station 0 (Meteostick Vantage via USB serial).
logger (23.08.2016 19:49:58): connect station 9 (System Data via Plug-in).
logger (23.08.2016 19:50:00): transmitter 1 registered as ISS
logger (23.08.2016 19:50:00): transmitter 2 registered as Wind
logger (23.08.2016 19:50:00): Meteostick Version 2.4
logger (23.08.2016 19:50:00): debug off
logger (23.08.2016 19:50:00): verbose off
logger (23.08.2016 19:50:00): output raw (8 bytes)
logger (23.08.2016 19:50:00): output raw (10 bytes)
logger (23.08.2016 19:50:00): filter on
logger (23.08.2016 19:50:00): rx threshold set to -70db
logger (23.08.2016 19:50:00): listening to transmitter 1 2
logger (23.08.2016 19:50:00): bandwidth narrow
logger (23.08.2016 19:50:00): chip authentication ok: 14
logger (23.08.2016 19:50:00): frequency band 868MHz (EU)
