Where did the versions go? Only up to 2.8 **solved**
droiddk
Post by droiddk »
Hello
Where did the versions go? Only up to 2.8 in interface:
Re: Where did the versions go? Only up to 2.8 in interface.
As you are currently on version 2.8 you only can go back to versions before 2.8 from there, or to "newest". Reason is that version 2.8 did not know of newer versions and the version control is hard coded into each of the releases.
When you select "newest" and reboot, then you have a full list of currently available releases. May be a bit complicated, but this is how it works.
droiddk
Re: Where did the versions go? Only up to 2.8 **solved**
Post by droiddk »
"newest" was already selected and image shows what I saw right after a reboot -> uptime 2 minutes and using 2.8 so "stick to version.." was not selected.
I will try another reboot when I'm back at work.
droiddk
Post by droiddk »
I tried rebooting (two times) (have vpn-access) the Meteobridge and made sure that "Get newest on boot" was selected and still see the same, only up to version 2.7 and version 2.8 is loaded.
Just powered up a spare MR-3020 that was previously set for get newest on boot and it came up with 3.1 (Aug24 2016 build 10289)
droiddk
Post by droiddk »
Mattk wrote:Just powered up a spare MR-3020 that was previously set for get newest on boot and it came up with 3.1 (Aug24 2016 build 10289)
Strange, try playing with the "stick to.." and see what happens, I used that option some time ago and now I have this issue :/
droiddk
Post by droiddk »
Okay this is what fixed it: I choose "Stick to version 2.7" and rebooted the MeteoBridge. MeteoBridge loaded with version 2.7. This version could not find my station. Choose "Get newest.." and rebooted. MeteoBridge rebooted and loaded newest version. Running fine. "Something" must have been locked up.
