Stuck in a loop
AlVista
Stuck in a loop
Post by AlVista »
Now the MB Pro has stopped collecting data. I have rebooted and it is going again, but the uptime was only 2+ hours before this happened.
This is a strange thing: - "connect station 0 (Meteostick Vantage via USB serial)" - don't have one of those - and it seems to be connected with the event that kicked off the failure at 11:39:32
SW Version: Meteobridge 3.1 (Aug 24 2016, build 10289), FW 1.4
The message list said:
oled (30.08.2016 08:04:43): process started.
database (30.08.2016 09:06:39): process started.
wnetd (30.08.2016 09:06:41): process started.
system (30.08.2016 09:06:41): start of logging process initiated.
logger (30.08.2016 09:06:41): databases connected. Update interval 3600 seconds.
logger (30.08.2016 09:06:41): Historical data loaded (0 records).
logger (30.08.2016 09:06:41): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 09:06:43): connect station 0 (Meteostick Vantage via USB serial).
logger (30.08.2016 09:06:43): connect station 9 (System Data via Plug-in).
logger (30.08.2016 09:06:45): transmitter 2 registered as ISS
logger (30.08.2016 09:06:45): Meteostick Version 2.4
logger (30.08.2016 09:06:45): debug off
logger (30.08.2016 09:06:45): verbose off
logger (30.08.2016 09:06:45): output raw (8 bytes)
logger (30.08.2016 09:06:45): output raw (10 bytes)
logger (30.08.2016 09:06:45): filter on
logger (30.08.2016 09:06:45): rx threshold set to -90db
logger (30.08.2016 09:06:45): listening to transmitter 2
logger (30.08.2016 09:06:45): bandwidth narrow
logger (30.08.2016 09:06:46): chip authentication ok: 14
logger (30.08.2016 09:06:46): frequency band 868MHz (EU)
database (30.08.2016 09:07:24): database sync done (40 tables, 184/6360 writes)
logger (30.08.2016 09:09:05): wind0 data incomplete (missing outdoor temp for windchill)
logger (30.08.2016 11:39:32): unexpected 0 bytes.
logger (30.08.2016 11:39:32): station 0 (Meteostick Vantage), can't set attributes of device /dev/ttyMH to former values: Input/output error
logger (30.08.2016 11:39:32): disconnect station 0 (Meteostick Vantage): response without data
system (30.08.2016 11:40:47): stop of logging process initiated.
logger (30.08.2016 11:40:48): parent process received termination signal (15).
logger (30.08.2016 11:40:48): child process received termination signal (15).
database (30.08.2016 11:40:48): process terminated normally.
test5m (30.08.2016 11:40:49): USB storage remounted: /dev/
database (30.08.2016 11:40:49): process started.
system (30.08.2016 11:40:49): start of logging process initiated.
logger (30.08.2016 11:40:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:40:49): Historical data loaded (0 records).
logger (30.08.2016 11:40:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:40:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:40:49): killed process "2432/sh" listening to port 5551.
logger (30.08.2016 11:41:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:41:19): Historical data loaded (0 records).
logger (30.08.2016 11:41:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:41:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:41:19): killed process "2435/meteosys" listening to port 5551.
database (30.08.2016 11:41:32): database sync done (40 tables, 1250/6648 writes)
logger (30.08.2016 11:41:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:41:49): Historical data loaded (0 records).
logger (30.08.2016 11:41:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:41:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:41:49): killed process "11474/sh" listening to port 5551.
logger (30.08.2016 11:42:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:42:19): Historical data loaded (0 records).
logger (30.08.2016 11:42:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:42:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:42:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:42:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:42:49): Historical data loaded (0 records).
logger (30.08.2016 11:42:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:42:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:42:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:43:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:43:19): Historical data loaded (0 records).
logger (30.08.2016 11:43:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:43:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:43:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:43:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:43:49): Historical data loaded (0 records).
logger (30.08.2016 11:43:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:43:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:43:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:44:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:44:19): Historical data loaded (0 records).
logger (30.08.2016 11:44:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:44:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:44:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:44:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:44:49): Historical data loaded (0 records).
logger (30.08.2016 11:44:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:44:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:44:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:45:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:45:19): Historical data loaded (0 records).
logger (30.08.2016 11:45:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:45:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:45:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:45:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:45:49): Historical data loaded (0 records).
logger (30.08.2016 11:45:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:45:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:45:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:46:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:46:19): Historical data loaded (0 records).
logger (30.08.2016 11:46:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:46:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:46:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:46:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:46:49): Historical data loaded (0 records).
logger (30.08.2016 11:46:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:46:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:46:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:47:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:47:19): Historical data loaded (0 records).
logger (30.08.2016 11:47:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:47:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:47:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:47:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:47:49): Historical data loaded (0 records).
logger (30.08.2016 11:47:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:47:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:47:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:48:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:48:19): Historical data loaded (0 records).
logger (30.08.2016 11:48:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:48:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:48:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:48:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:48:49): Historical data loaded (0 records).
logger (30.08.2016 11:48:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:48:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:48:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:49:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:49:19): Historical data loaded (0 records).
logger (30.08.2016 11:49:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:49:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:49:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:49:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:49:49): Historical data loaded (0 records).
logger (30.08.2016 11:49:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:49:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:49:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:50:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:50:19): Historical data loaded (0 records).
logger (30.08.2016 11:50:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:50:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:50:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:50:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:50:49): Historical data loaded (0 records).
logger (30.08.2016 11:50:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:50:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:50:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:51:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:51:19): Historical data loaded (0 records).
logger (30.08.2016 11:51:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:51:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:51:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:51:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:51:49): Historical data loaded (0 records).
logger (30.08.2016 11:51:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:51:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:51:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:52:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:52:19): Historical data loaded (0 records).
logger (30.08.2016 11:52:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:52:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:52:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:52:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:52:49): Historical data loaded (0 records).
logger (30.08.2016 11:52:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:52:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:52:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:53:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:53:19): Historical data loaded (0 records).
logger (30.08.2016 11:53:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:53:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:53:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:53:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:53:49): Historical data loaded (0 records).
logger (30.08.2016 11:53:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:53:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:53:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:54:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:54:19): Historical data loaded (0 records).
logger (30.08.2016 11:54:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:54:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:54:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:54:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:54:49): Historical data loaded (0 records).
logger (30.08.2016 11:54:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:54:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:54:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:55:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:55:19): Historical data loaded (0 records).
logger (30.08.2016 11:55:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:55:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:55:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:55:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:55:49): Historical data loaded (0 records).
logger (30.08.2016 11:55:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:55:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:55:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:56:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:56:19): Historical data loaded (0 records).
logger (30.08.2016 11:56:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:56:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:56:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:56:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:56:49): Historical data loaded (0 records).
logger (30.08.2016 11:56:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:56:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:56:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:57:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:57:19): Historical data loaded (0 records).
logger (30.08.2016 11:57:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:57:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:57:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:57:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:57:49): Historical data loaded (0 records).
logger (30.08.2016 11:57:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:57:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:57:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:58:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:58:19): Historical data loaded (0 records).
logger (30.08.2016 11:58:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:58:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:58:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:58:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:58:49): Historical data loaded (0 records).
logger (30.08.2016 11:58:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:58:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:58:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:59:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:59:19): Historical data loaded (0 records).
logger (30.08.2016 11:59:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:59:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:59:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 11:59:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 11:59:49): Historical data loaded (0 records).
logger (30.08.2016 11:59:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 11:59:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 11:59:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:00:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:00:19): Historical data loaded (0 records).
logger (30.08.2016 12:00:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:00:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:00:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:00:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:00:49): Historical data loaded (0 records).
logger (30.08.2016 12:00:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:00:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:00:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:01:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:01:19): Historical data loaded (0 records).
logger (30.08.2016 12:01:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:01:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:01:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:01:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:01:49): Historical data loaded (0 records).
logger (30.08.2016 12:01:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:01:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:01:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:02:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:02:19): Historical data loaded (0 records).
logger (30.08.2016 12:02:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:02:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:02:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:02:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:02:49): Historical data loaded (0 records).
logger (30.08.2016 12:02:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:02:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:02:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:03:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:03:19): Historical data loaded (0 records).
logger (30.08.2016 12:03:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:03:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:03:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:03:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:03:49): Historical data loaded (0 records).
logger (30.08.2016 12:03:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:03:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:03:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:04:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:04:19): Historical data loaded (0 records).
logger (30.08.2016 12:04:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:04:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:04:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:04:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:04:49): Historical data loaded (0 records).
logger (30.08.2016 12:04:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:04:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:04:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:05:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:05:19): Historical data loaded (0 records).
logger (30.08.2016 12:05:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:05:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:05:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:05:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:05:49): Historical data loaded (0 records).
logger (30.08.2016 12:05:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:05:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:05:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:06:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:06:19): Historical data loaded (0 records).
logger (30.08.2016 12:06:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:06:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:06:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:06:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:06:49): Historical data loaded (0 records).
logger (30.08.2016 12:06:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:06:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:06:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:07:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:07:19): Historical data loaded (0 records).
logger (30.08.2016 12:07:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:07:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:07:19): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:07:49): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:07:49): Historical data loaded (0 records).
logger (30.08.2016 12:07:49): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:07:49): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:07:49): killed process "11484/usbreset" listening to port 5551.
logger (30.08.2016 12:08:19): databases connected. Update interval 3600 seconds.
logger (30.08.2016 12:08:19): Historical data loaded (0 records).
logger (30.08.2016 12:08:19): data logger (version 5.0r, build 10289) started.
logger (30.08.2016 12:08:19): error while doing bind (port 5551): Address already in use
logger (30.08.2016 12:08:19): killed process "11484/usbreset" listening to port 5551.
Re: Stuck in a loop
Can you please send me remote login credentials? "info(at)meteobridge.com"
