Problems after upgrade to 3.1 **solved**
screamingdead
Post by screamingdead »
My Meteobridge Pro is having issues after upgrading to 3.1.
The display keeps on going blank, hourly tweets are failing to upload & no data is being uploaded to Wunderground even though this reports back as successful.
I've just rebooted and watching the boot screen, the device is trying to format the storage & the format is failing.
Logs so far:-
oled (31.08.2016 22:04:14): process started.
database (02.09.2016 10:11:34): process started.
database (02.09.2016 10:11:34): database sync done (0 tables, 0/0 writes)
wnetd (02.09.2016 10:11:36): process started.
system (02.09.2016 10:11:36): start of logging process initiated.
logger (02.09.2016 10:11:36): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:11:36): Historical data loaded (0 records).
logger (02.09.2016 10:11:36): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:11:42): connect station 0 (Meteostick Vantage via USB serial).
logger (02.09.2016 10:11:42): connect station 9 (System Data via Plug-in).
logger (02.09.2016 10:11:44): transmitter 1 registered as ISS
logger (02.09.2016 10:11:44): Meteostick Version 2.4
logger (02.09.2016 10:11:44): debug off
logger (02.09.2016 10:11:44): verbose off
logger (02.09.2016 10:11:44): output raw (8 bytes)
logger (02.09.2016 10:11:44): output raw (10 bytes)
logger (02.09.2016 10:11:44): filter on
logger (02.09.2016 10:11:44): rx threshold set to -90db
logger (02.09.2016 10:11:44): listening to transmitter 1
logger (02.09.2016 10:11:44): bandwidth narrow
logger (02.09.2016 10:11:44): chip authentication ok: 14
logger (02.09.2016 10:11:44): frequency band 868MHz (EU)
database (02.09.2016 10:13:12): cannot create table (after 100 tries in 11169ms): database is locked
database (02.09.2016 10:13:12): cannot prepare insert into th0temp_min RAM (after 0 tries in 15ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:12): rollback on insert forced: th0temp
database (02.09.2016 10:13:12): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:13): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:13): rollback on insert forced: th0temp
database (02.09.2016 10:13:14): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:14): rollback on insert forced: th0temp
database (02.09.2016 10:13:15): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:15): rollback on insert forced: th0temp
database (02.09.2016 10:13:16): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:16): rollback on insert forced: th0temp
database (02.09.2016 10:13:17): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:17): rollback on insert forced: th0temp
database (02.09.2016 10:13:18): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:18): rollback on insert forced: th0temp
database (02.09.2016 10:13:19): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:19): rollback on insert forced: th0temp
database (02.09.2016 10:13:20): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:20): rollback on insert forced: th0temp
database (02.09.2016 10:13:21): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:21): rollback on insert forced: th0temp
database (02.09.2016 10:13:22): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:22): rollback on insert forced: th0temp
database (02.09.2016 10:13:23): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:23): rollback on insert forced: th0temp
database (02.09.2016 10:13:24): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:24): rollback on insert forced: th0temp
database (02.09.2016 10:13:25): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:25): rollback on insert forced: th0temp
database (02.09.2016 10:13:26): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:26): rollback on insert forced: th0temp
database (02.09.2016 10:13:27): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:27): rollback on insert forced: th0temp
database (02.09.2016 10:13:28): cannot prepare insert into th0temp_min RAM (after 0 tries in 1ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:28): rollback on insert forced: th0temp
database (02.09.2016 10:13:28): cannot prepare insert into th0temp_min RAM (after 0 tries in 21ms): no such table: th0temp_min (1)
database (02.09.2016 10:13:28): process stopped.
system (02.09.2016 10:15:45): stop of logging process initiated.
logger (02.09.2016 10:15:45): parent process received termination signal (15).
logger (02.09.2016 10:15:45): child process received termination signal (15).
test5m (02.09.2016 10:15:46): USB storage remounted: /dev/sda
database (02.09.2016 10:15:46): process started.
system (02.09.2016 10:15:46): start of logging process initiated.
logger (02.09.2016 10:15:47): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:15:47): Historical data loaded (0 records).
logger (02.09.2016 10:15:47): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:15:47): error while doing bind (port 5551): Address already in use
database (02.09.2016 10:15:47): database sync done (4 tables, 20/20 writes)
logger (02.09.2016 10:15:48): killed process "2796/sh" listening to port 5551.
screamingdead
Re: Problems after upgrade to 3.1
Next batch of logs:-
logger (02.09.2016 10:16:17): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:16:17): Historical data loaded (0 records).
logger (02.09.2016 10:16:17): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:16:17): error while doing bind (port 5551): Address already in use
logger (02.09.2016 10:16:17): killed process "2797/meteosys" listening to port 5551.
logger (02.09.2016 10:16:47): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:16:47): Historical data loaded (0 records).
logger (02.09.2016 10:16:47): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:16:48): connect station 0 (Meteostick Vantage via USB serial).
logger (02.09.2016 10:16:48): connect station 9 (System Data via Plug-in).
logger (02.09.2016 10:16:48): transmitter 1 registered as ISS
logger (02.09.2016 10:16:48): Meteostick Version 2.4
logger (02.09.2016 10:16:48): debug off
logger (02.09.2016 10:16:48): verbose off
logger (02.09.2016 10:16:48): output raw (8 bytes)
logger (02.09.2016 10:16:48): output raw (10 bytes)
logger (02.09.2016 10:16:48): filter on
logger (02.09.2016 10:16:48): rx threshold set to -90db
logger (02.09.2016 10:16:48): listening to transmitter 1
logger (02.09.2016 10:16:48): bandwidth narrow
logger (02.09.2016 10:16:48): chip authentication ok: 14
logger (02.09.2016 10:16:48): frequency band 868MHz (EU)
system (02.09.2016 10:21:04): stop of logging process initiated.
logger (02.09.2016 10:21:04): parent process received termination signal (15).
logger (02.09.2016 10:21:04): child process received termination signal (15).
database (02.09.2016 10:21:04): process terminated normally.
test5m (02.09.2016 10:21:06): USB storage remounted: /dev/sda
database (02.09.2016 10:21:06): process started.
system (02.09.2016 10:21:06): start of logging process initiated.
logger (02.09.2016 10:21:06): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:21:06): Historical data loaded (0 records).
logger (02.09.2016 10:21:06): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:21:06): error while doing bind (port 5551): Address already in use
logger (02.09.2016 10:21:06): killed process "4215/sh" listening to port 5551.
database (02.09.2016 10:21:08): database sync done (39 tables, 185/195 writes)
logger (02.09.2016 10:21:36): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:21:36): Historical data loaded (0 records).
logger (02.09.2016 10:21:36): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:21:36): error while doing bind (port 5551): Address already in use
logger (02.09.2016 10:21:36): killed process "4216/meteosys" listening to port 5551.
logger (02.09.2016 10:22:06): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:22:06): Historical data loaded (0 records).
logger (02.09.2016 10:22:06): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:22:07): connect station 0 (Meteostick Vantage via USB serial).
logger (02.09.2016 10:22:07): connect station 9 (System Data via Plug-in).
logger (02.09.2016 10:22:07): transmitter 1 registered as ISS
logger (02.09.2016 10:22:07): Meteostick Version 2.4
logger (02.09.2016 10:22:07): debug off
logger (02.09.2016 10:22:07): verbose off
logger (02.09.2016 10:22:07): output raw (8 bytes)
logger (02.09.2016 10:22:07): output raw (10 bytes)
logger (02.09.2016 10:22:07): filter on
logger (02.09.2016 10:22:07): rx threshold set to -90db
logger (02.09.2016 10:22:07): listening to transmitter 1
logger (02.09.2016 10:22:07): bandwidth narrow
logger (02.09.2016 10:22:08): chip authentication ok: 14
logger (02.09.2016 10:22:08): frequency band 868MHz (EU)
system (02.09.2016 10:26:31): stop of logging process initiated.
logger (02.09.2016 10:26:31): parent process received termination signal (15).
logger (02.09.2016 10:26:31): child process received termination signal (15).
database (02.09.2016 10:26:31): process terminated normally.
test5m (02.09.2016 10:26:32): USB storage remounted: /dev/sda
database (02.09.2016 10:26:33): process started.
system (02.09.2016 10:26:33): start of logging process initiated.
logger (02.09.2016 10:26:33): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:26:33): Historical data loaded (0 records).
logger (02.09.2016 10:26:33): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:26:33): error while doing bind (port 5551): Address already in use
logger (02.09.2016 10:26:33): killed process "5075/sh" listening to port 5551.
database (02.09.2016 10:26:35): database sync done (39 tables, 155/195 writes)
logger (02.09.2016 10:27:03): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:27:03): Historical data loaded (0 records).
logger (02.09.2016 10:27:03): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:27:03): error while doing bind (port 5551): Address already in use
logger (02.09.2016 10:27:03): killed process "5076/meteosys" listening to port 5551.
logger (02.09.2016 10:27:33): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:27:33): Historical data loaded (0 records).
logger (02.09.2016 10:27:33): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:27:34): connect station 0 (Meteostick Vantage via USB serial).
logger (02.09.2016 10:27:34): connect station 9 (System Data via Plug-in).
logger (02.09.2016 10:27:34): transmitter 1 registered as ISS
logger (02.09.2016 10:27:34): Meteostick Version 2.4
logger (02.09.2016 10:27:34): debug off
logger (02.09.2016 10:27:34): verbose off
logger (02.09.2016 10:27:34): output raw (8 bytes)
logger (02.09.2016 10:27:34): output raw (10 bytes)
logger (02.09.2016 10:27:34): filter on
logger (02.09.2016 10:27:34): rx threshold set to -90db
logger (02.09.2016 10:27:34): listening to transmitter 1
logger (02.09.2016 10:27:34): bandwidth narrow
logger (02.09.2016 10:27:34): chip authentication ok: 14
logger (02.09.2016 10:27:34): frequency band 868MHz (EU)
system (02.09.2016 10:30:34): stop of logging process initiated.
logger (02.09.2016 10:30:34): parent process received termination signal (15).
logger (02.09.2016 10:30:34): child process received termination signal (15).
database (02.09.2016 10:30:34): process terminated normally.
test5m (02.09.2016 10:30:35): USB storage remounted: /dev/sda
database (02.09.2016 10:30:36): process started.
system (02.09.2016 10:30:36): start of logging process initiated.
logger (02.09.2016 10:30:36): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:30:36): Historical data loaded (0 records).
logger (02.09.2016 10:30:36): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:30:36): error while doing bind (port 5551): Address already in use
logger (02.09.2016 10:30:36): killed process "6004/sh" listening to port 5551.
database (02.09.2016 10:30:38): database sync done (39 tables, 155/195 writes)
logger (02.09.2016 10:31:06): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:31:06): Historical data loaded (0 records).
logger (02.09.2016 10:31:06): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:31:06): error while doing bind (port 5551): Address already in use
logger (02.09.2016 10:31:06): killed process "6005/meteosys" listening to port 5551.
logger (02.09.2016 10:31:36): databases connected. Update interval 3600 seconds.
logger (02.09.2016 10:31:36): Historical data loaded (0 records).
logger (02.09.2016 10:31:36): data logger (version 5.0r, build 10289) started.
logger (02.09.2016 10:31:37): connect station 0 (Meteostick Vantage via USB serial).
logger (02.09.2016 10:31:37): connect station 9 (System Data via Plug-in).
logger (02.09.2016 10:31:37): transmitter 1 registered as ISS
logger (02.09.2016 10:31:37): Meteostick Version 2.4
logger (02.09.2016 10:31:37): debug off
logger (02.09.2016 10:31:37): verbose off
logger (02.09.2016 10:31:37): output raw (8 bytes)
logger (02.09.2016 10:31:37): output raw (10 bytes)
logger (02.09.2016 10:31:37): filter on
logger (02.09.2016 10:31:37): rx threshold set to -90db
logger (02.09.2016 10:31:37): listening to transmitter 1
logger (02.09.2016 10:31:37): bandwidth narrow
logger (02.09.2016 10:31:37): chip authentication ok: 14
logger (02.09.2016 10:31:37): frequency band 868MHz (EU)
The Twitter Upload is failing with this error (uploads were working prior to update and the code hasn't changed): 2016-09-02 10:23:07 Error: sed: unmatched '/' can not decode tweet (bad character) (no more tries)
bseeger
Post by bseeger »
auch bei mir wollte das System nach einem Neuboot den Datenträger formatieren! Meldung auf dem Display sagt zwar "Format FAILED" aber trotzdem ist die ganze Datenablage auf dem intern Speicher leer, nix mehr da, kein Verzeichnis....kein Template, alles weg...
:cry:
traurige Grüsse
B. Seeger
screamingdead
I've looked at the contents of dmesg
command: dmesg
[ 806.570000] sd 2:0:0:0: [sda] Device not ready
[ 806.580000] sd 2:0:0:0: [sda]
[ 806.580000] Result: hostbyte=0x00 driverbyte=0x08
[ 806.590000] Sense Key : 0x2 [current]
[ 806.590000] sd 2:0:0:0: [sda]
[ 806.590000] ASC=0x3a ASCQ=0x0
[ 806.600000] sd 2:0:0:0: [sda] CDB:
[ 806.600000] cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[ 806.610000] sd 2:0:0:0: [sda] Device not ready
[ 806.610000] Result: hostbyte=0x00 driverbyte=0x08
[ 806.620000] sd 2:0:0:0: [sda]
[ 806.620000] Sense Key : 0x2 [current]
[ 806.630000] ASC=0x3a ASCQ=0x0
[ 806.630000] sd 2:0:0:0: [sda] CDB:
[ 806.630000] cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00
[ 806.640000] sd 2:0:0:0: [sda] Device not ready
[ 806.650000] Result: hostbyte=0x00 driverbyte=0x08
[ 806.650000] sd 2:0:0:0: [sda]
[ 806.650000] Sense Key : 0x2 [current]
[ 806.660000] sd 2:0:0:0: [sda]
[ 806.660000] ASC=0x3a ASCQ=0x0
[ 806.660000] sd 2:0:0:0: [sda] CDB:
[ 806.670000] cdb[0]=0x28: 28 00 00 00 00 80 00 00 08 00
[ 808.000000] sd 2:0:0:0: [sda] Device not ready
[ 808.010000] Result: hostbyte=0x00 driverbyte=0x08
[ 808.010000] sd 2:0:0:0: [sda]
[ 808.020000] Sense Key : 0x2 [current]
[ 808.020000] sd 2:0:0:0: [sda]
[ 808.020000] ASC=0x3a ASCQ=0x0
[ 808.030000] sd 2:0:0:0: [sda] CDB:
[ 808.030000] cdb[0]=0x28: 28 00 00 00 00 00 00 00 02 00
[ 808.030000] SQUASHFS error: squashfs_read_data failed to read block 0x0
[ 808.040000] SQUASHFS error: unable to read squashfs_super_block
[ 808.050000] sd 2:0:0:0: [sda] Device not ready
[ 808.060000] Result: hostbyte=0x00 driverbyte=0x08
[ 808.060000] sd 2:0:0:0: [sda]
[ 808.060000] Sense Key : 0x2 [current]
[ 808.070000] sd 2:0:0:0: [sda]
[ 808.070000] ASC=0x3a ASCQ=0x0
[ 808.070000] sd 2:0:0:0: [sda] CDB:
[ 808.080000] cdb[0]=0x28: 28 00 00 00 00 02 00 00 02 00
[ 808.080000] EXT4-fs (sda): unable to read superblock
[ 808.090000] sd 2:0:0:0: [sda] Device not ready
[ 808.100000] Result: hostbyte=0x00
I'm assuming that the internal storage has failed. Do I need to arrange a return to Prodata Weather Systems in the uk?
screamingdead
OK, so I've changed the database media to a usb stick - this has formatted successfully on boot, but was still giving issues - it looked like the usb stick was write protected (which it wasn't). I've now downgraded to version Meteobridge 3.0 (Aug 9 2016, build 10243), FW 1.4 - this version now is uploading to Wunderground & I'm getting rain data in the upload at last.
I know admin was on vacation until 31st August, but no posts in September at all - is the Meteobridge PRO unit still supported through this website, or do I need to return the unit to the UK suppliers for refund as the hardware seems very unstable?
Sorry for my delay in responding. The USB media errors in your posting clearly indicate that the storage needs a replacement. Please contact your dealer.
screamingdead
Hi Boris
Does the unit have to be returned to the supplier for the internal storage replacement, or is it a user serviceable replacement, also is it possible to move the database from the external usb back to the internal storage?
SD
Unit needs to be returned. Replacement is already handled with the reseller.
