since I upgraded my Sheevaplug to 5.0q, I get a lot of error messages in the log :
Every 5 minutes the message appears 2 time. I noticed that you solved this for Meteohub PRO. Can this be fixed for Sheevaplug as well ?
I am connecting to Davis Vantage Pro through WeatherlinkIP which is only used in the local network, so does not send to WeatherlinkIP.
logger (06.09.2016 10:40:08): data logger (version 5.0q, build 1628) started.
logger (06.09.2016 10:40:08): connect station 0 (Vantage via TCP/IP).
logger (06.09.2016 10:40:09): station 0 (Vantage), wakeup sent.
logger (06.09.2016 10:40:09): station 0 (Vantage), internal logger activated.
logger (06.09.2016 10:40:09): station 0 (Vantage), syncing.
logger (06.09.2016 10:40:19): station 0 (Vantage), gettime request sent.
logger (06.09.2016 10:40:19): station 0 (Vantage), time offset of Vantage: -1 minutes
logger (06.09.2016 10:40:19): station 0 (Vantage), eeprom request sent.
logger (06.09.2016 10:40:20): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (06.09.2016 10:40:20): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (06.09.2016 10:40:20): station 0 (Vantage), transmitter 2 active as station type (#7) "Soil".
logger (06.09.2016 10:40:20): station 0 (Vantage), transmitter 3 active as station type (#4) "Wind".
logger (06.09.2016 10:40:20): station 0 (Vantage), firmware version request sent.
logger (06.09.2016 10:40:20): station 0 (Vantage), firmware version 1.90
logger (06.09.2016 10:40:20): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 283 secs
logger (06.09.2016 10:45:29): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (06.09.2016 10:45:33): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (06.09.2016 10:50:39): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (06.09.2016 10:50:43): station 0 (Vantage), can't write string "LPS": Bad file descriptor
Error msg can't write string "LPS": Bad file descriptor
