MBP with Cumulus or WsWin (PC-Wetterstation)
Posted: Fri Sep 09, 2016 11:14 pm
by Denislaw
1. I use a meteobridge with Cumulus, but my MBP doesn't work with it.
Am I doing something wrong or is it impossible?
2. Are there any progress regarding WsWin (PC-Wetterstation) to use with MBP (Dateiüberwachung)?
Re: MBP with Cumulus or WsWin (PC-Wetterstation)
Posted: Sat Sep 17, 2016 3:15 pm
When using MBP with internal RF module then data is processed in a different format compared to operation with a Davis USB data logger.
Pass-through of data from Davis data logger to a follow-on program like Cumulus can only be done when a Davis data logger is used with Meteobridge.
WSWIN Dateiüberwachung has been removed from the short list.
Posted: Thu Jan 25, 2018 6:37 pm
by Cumulonimbus
Is there any reason why WSWIN Dateiüberwachung was removed? Is it not planned to realize this feature at any time?
Posted: Thu Jan 25, 2018 8:20 pm
Die-hard WSWIN fans mostly already have a Davis logger and by that can operate MBPro by sharing the Davis logger via TCP/IP port 22222. Having this alternative, we spare doing the development effort (Dateiüberwachung is not easy to realize), which just a very few will benefit from.
