Minimum separation Dist. - MBPro(RF) to Davis ISS **solved**
Anybody seen any recommendations for what a minimum separation distance might be between a Davis ISS and MBPro(RF). Would there be any signal conflict or other issues with both the ISS and MBPro(RF) installed in the same enclosure. Basically talking about ISS & Pro being side by side.
peterb
Re: Minimum separation Distance - MBPro(RF) to Davis ISS
Post by peterb »
Mattk wrote:Anybody seen any recommendations for what a minimum separation distance might be between a Davis ISS and MBPro(RF). Would there be any signal conflict or other issues with both the ISS and MBPro(RF) installed in the same enclosure. Basically talking about ISS & Pro being side by side.
mine are 10cm but have been touching and it work ok hope this is of help.
Similar here with ISS & Envoy combinations, basically on top of each other for many years and have not noticed any problems. Plan is to add MBpro(RF) to this mix so was just checking if anybody had identified any issues, thankyou peterb
should work at any minimal distance.
