Minimum separation Dist. - MBPro(RF) to Davis ISS **solved**
Posted: Thu Sep 15, 2016 3:23 am
by Mattk
Anybody seen any recommendations for what a minimum separation distance might be between a Davis ISS and MBPro(RF). Would there be any signal conflict or other issues with both the ISS and MBPro(RF) installed in the same enclosure. Basically talking about ISS & Pro being side by side.
Re: Minimum separation Distance - MBPro(RF) to Davis ISS
Posted: Thu Sep 15, 2016 6:26 pm
by peterb
Mattk wrote:Anybody seen any recommendations for what a minimum separation distance might be between a Davis ISS and MBPro(RF). Would there be any signal conflict or other issues with both the ISS and MBPro(RF) installed in the same enclosure. Basically talking about ISS & Pro being side by side.
mine are 10cm but have been touching and it work ok hope this is of help.
Posted: Fri Sep 16, 2016 12:12 pm
by Mattk
Similar here with ISS & Envoy combinations, basically on top of each other for many years and have not noticed any problems. Plan is to add MBpro(RF) to this mix so was just checking if anybody had identified any issues, thankyou peterb
Posted: Sat Sep 17, 2016 3:10 pm
should work at any minimal distance.
