MB Pro - random restarts
1fcmrYpC2Nw8
Post by 1fcmrYpC2Nw8 »
oled (26.09.2016 14:28:22): process started.
oled (26.09.2016 17:30:03): process started.
test5m (26.09.2016 17:30:09): weathernet daemon stalled, will be restarted now.
wnetd (26.09.2016 17:30:09): process started.
test5m (26.09.2016 17:30:09): logger stalled, will be restarted now.
system (26.09.2016 17:30:09): stop of logging process initiated.
database (26.09.2016 17:30:43): process started.
system (26.09.2016 17:30:45): start of logging process initiated.
logger (26.09.2016 17:30:45): databases connected. Update interval 3600 seconds.
logger (26.09.2016 17:30:45): Historical data loaded (0 records).
logger (26.09.2016 17:30:45): data logger (version 5.0r, build 10341) started.
logger (26.09.2016 17:30:47): connect station 0 (Meteostick Vantage via USB serial).
logger (26.09.2016 17:30:47): connect station 9 (System Data via Plug-in).
logger (26.09.2016 17:30:49): transmitter 1 registered as ISS
logger (26.09.2016 17:30:49): transmitter 2 registered as Wind
logger (26.09.2016 17:30:49): Meteostick Version 2.3b3
logger (26.09.2016 17:30:49): debug off
logger (26.09.2016 17:30:49): verbose off
logger (26.09.2016 17:30:49): output raw (8 bytes)
logger (26.09.2016 17:30:49): output raw (10 bytes)
logger (26.09.2016 17:30:49): filter on
logger (26.09.2016 17:30:49): rx threshold set to -90db
logger (26.09.2016 17:30:49): listening to transmitter 1 2
logger (26.09.2016 17:30:49): bandwidth narrow
logger (26.09.2016 17:30:50): chip authentication ok: 14
logger (26.09.2016 17:30:50): frequency band 868MHz (EU)
logger (27.09.2016 11:54:31): no signal for 900 seconds, station to be restarted.
logger (27.09.2016 11:54:31): disconnect station 0 (Meteostick Vantage): timeout
logger (27.09.2016 11:54:31): disconnect station 9 (System Data): timeout
logger (27.09.2016 11:55:01): connect station 0 (Meteostick Vantage via USB serial).
logger (27.09.2016 11:55:01): connect station 9 (System Data via Plug-in).
logger (27.09.2016 11:55:01): no synchronization for 900 seconds, data logger will be restarted.
logger (27.09.2016 11:55:01): disconnect station 0 (Meteostick Vantage): exit
logger (27.09.2016 11:55:01): disconnect station 9 (System Data): exit
logger (27.09.2016 11:55:03): data logger stopped.
logger (27.09.2016 11:55:03): databases disconnected.
logger (27.09.2016 11:55:03): databases connected. Update interval 3600 seconds.
logger (27.09.2016 11:55:03): Historical data loaded (0 records).
logger (27.09.2016 11:55:03): data logger (version 5.0r, build 10341) started.
logger (27.09.2016 11:55:05): connect station 0 (Meteostick Vantage via USB serial).
logger (27.09.2016 11:55:05): connect station 9 (System Data via Plug-in).
database (27.09.2016 11:55:08): database sync done (52 tables, 179/9365 writes)
logger (27.09.2016 11:55:08): transmitter 1 registered as ISS
logger (27.09.2016 11:55:08): transmitter 2 registered as Wind
logger (27.09.2016 11:55:08): Meteostick Version 2.3b3
logger (27.09.2016 11:55:08): debug off
logger (27.09.2016 11:55:08): verbose off
logger (27.09.2016 11:55:08): output raw (8 bytes)
logger (27.09.2016 11:55:08): output raw (10 bytes)
logger (27.09.2016 11:55:08): filter on
logger (27.09.2016 11:55:08): rx threshold set to -90db
logger (27.09.2016 11:55:08): listening to transmitter 1 2
logger (27.09.2016 11:55:08): bandwidth narrow
logger (27.09.2016 11:55:08): chip authentication ok: 14
logger (27.09.2016 11:55:08): frequency band 868MHz (EU)
Here is everything in the logs following a restart this morning. There were different messages in the logs before the restart, but they seem to have disappeared..
26 September -
I was aware of intermittent WAN problems around 22:45
MB Pro appears to report at five minute intervals without problem until 23:19 with only one further data received by WU at 23:49.
27 September
From 00:04 until 04:16 there is a mixture of data received at five and one minute intervals. (Data normally sent at 5 minute intervals)
From 04:16 no data is received by WU and there is no data in the history after 02:00
At 10:20, I receive a message from WU to tell me there has been no data received since 08:18 although there has been none since 04:16
I manage a local logon to the MB Pro around 11:00, 'up time says 11h 35 mins, see there is no history from 02:00. I look at logs and at WU to try to put together the course of events then try to logon from my laptop to find the MB Pro is not responding to ping with 'No Network Found' on the display. I power cycle the MB Pro around 11:53.
Nothing in the log after 17:30 26 September but entries seen before power cycle now missing...
MB Pro now appears to be working normally
Re: MB Pro - random restarts
I see nothing special in the logs, so it is hard to diagnose from remote.
Do you also find those gaps in the MB PRO database? You can inspect on History tab.
As your embedded Meteostick is still on 2.3 firmware you might consider to update
this. There is a button for this on System tab. This might help if the reason is
sometimes no data coming in from sensors via RF.
We fixed a memory leak problem in the September 25 release, so this might also
have added to problems before.
1fcmrYpC2Nw8
I have updated the Meteostick to 2.4 and we will see how that goes.
The data was missing in the internal MB Pro history.
Interestingly the MB Pro was still sending emails just not recording any data internally or sending to WU.
